Results 1 to 40 of 40
    Formerly DMR For Life
    Reputation: Full Mountain's Avatar
    Mar 2005
    Winter riding passion+ Asthma = no riding for this pssionite
    hey all
    heres my problem I really want to ride year round, snow, wind all that is good.
    But here's the problem i have asthma and whenever i exert my self in cold weather i end up coughing and quite often feeling sick for at least the rest of the day and sometimes longer
    So heres my question to those of u with a similar problem how do u deal with it other than riding inside (which i extremely dislike btw)?
    thanks
    DMR
    Aug 2005
    I have the same problem. One method (I have yet to try) is to ride with one of those disposable dust masks. I don't know how much it would impede air intake. I was told that it helps the inhalation of warm air which supresses asthma attacks.
    Good luck
    Reputation: mb3designs's Avatar
    Try the disposable mask's migeorgeco mentioned, or try using a light-weight wicking balaclava. Either one is relatively inexpensive. Good luck, hopefully one will work for you.
    Reputation: Cole82's Avatar
    I'm a regular user of the dust mask. It works so well. You do get a lot of people asking why you wear it.
    Just don't forget to remove it before spitting.
    Mar 2005
    anyone had expeience using a balaclava with glasses?
    thanks
    DMR
    Reputation: Irish's Avatar
    Mar 2005
    I have the same problem and was about to post the same question.
    Thanks for the tips!
    I don't like them because your lips are allways in contact with it. They also seam to ice over easier.
    I've used both. Both have their drawbacks. The balaclava and glasses tend to fog over the glasses for me, but I prefer it to the dust mask, just have to play a bit to find the spot where your breath doesn't come up into your glasses. The other key is to ride easy, it's all about base miles this time of year, easy riding keeping the exertion/hard efforts/deep breathing to a minimum will help alleviate that and if you're like me you'll find the more you do, the better it gets, your body will adjust.
    Reputation: AkDave's Avatar
    Another option is a neck gaiter....
    Quote Originally Posted by DMR For Life
    thanks
    DMR
    A fleece neck gaiter works well for warming air when breathing. The thin balacava does it well also with less fogging of riding glasses. If you live near an REI store they have a balacava made of their mts wicking fabric which is great. Its thin also so it will fit under a helmet well. I think they carry it on line also for about $10-12.
    Try one out and KEEP riding this winter.
    Dave
    Idaho Transplant (closet roadie)
    i've got the same issues with cold weather asthma and sports induced asthma.
    i don't have issues very often, but it worries me enough that i will carry an albuterol inhaler with me for instant relief.
    i've never thought of trying a dust mask or gaitor, but with give a try this winter.
    It depends how bad your Asthma is. Take albuterol before your start exercising. If you can put up with it, use a face-cover to warm the air you breath. If your Asmtha is so bad that it effects the rest of your day (even after albuterol) you should talk with your pulmonary physician.
    Sofa King We Todd Did
    Reputation: SpinWheelz's Avatar
    I suffer from asthma, but I also have the benefit of working on asthma pharmaceuticals, so I've had the privilege of learning quite a few things about my condition to help me cope with riding in the winter time. The trick to keeping one's asthma under control has almost nothing to do with the whether it's cold or it's warm or whatever. If your asthma's under control, it's under control, ya dig.
    For that, I use an inhaled corticosteroid. Corticosteroids are by far the best thing to use to keep that asthma under control and prevent asthma attacks. They're basically a man-made version of a chemical compound that's already being produced in your body, just tweaked to the higher levels you need and specific to working in your lungs. Just don't expect this to start working overnight. You gotta start taking it now and you'll see results in about a week or two, i.e. the absence of asthma attacks.
    Don't get me wrong, the cold will aggravate your lungs and may trigger some tightness or some wheezing, but if you're controlling your asthma with a preventive medicine, then the small bits of tightness and wheezing become far more managable. For that, I take a puff of my broncholdilator and off I go.
    You can do it. You can get that asthma under control and keep riding. Just go talk to your doctor about it. And the truth is, if your doctor tells you that there's no hope for you and that there's no way to control your asthma, then it's time to choose another doctor. 'Cause if it's one thing that I've learned while working on this business, it's that no one - and I mean NO ONE needs to suffer from asthma attacks, given the medicines we have available to us.
    Mar 2005
    Quote Originally Posted by SpinWheelz
    yeah spinwheelz i agree...see my problem is that i have my asthma under control yet when i exert my self (ie running for the bus, biking, etc.) i end up coughing and i dislike that a lot (it hurts a lot too)
    i'll try this week and see how it goes
    DMR
    May 2005
    I do a voice breathing exercise before riding that helps alot, send me a pm if you want to find out how to do it.
    resident crackpot
    Reputation: loonyOne's Avatar
    derekbob, I'd like to hear your voice breathing thingy. I'd like very much if'n you'd send me an email about it.
    I experience something different from most folks with asthma, in that I don't have a lot of problems most of the time, especially in the winter (dry) months...that is, until I over-exert. I usually have most of my breathing problems within the first hour of riding, especially if the terrain is hilly or the pace is fast. After about the first hour, and I have already had a few "bend-overs", I usually tend to have a fine ride afterwards, and mostly have a great day,even after while being proactive and inhaling beforehand. I don't exactly know what it is about that time frame, but warming up beforehand, even for as much as 30 minutes doesn't help.
    I have been in immunotherapy for almost three years for adult-diagnosed asthma. I have seen a dramatic decrease in daily episodes, but anytime exercise is involved, things go downhill. I have yet to try one of those 'breathing trainers', but am open if they work. I am at some diagnosis odds with my Doc, because I believe I have asthma due to pulmonary fibrosis. I worked for a railroad for a while when I was young and dumped LOTS of dry gravel on the rail beds that were due for rebuilding. Anyone remotely familiar with gravel knows that there can be huge dust storms involved. I think that I suffered some lung damage from this...it will never be cured. I am currently on a couple of meds, religiously, that help a lot...along with the allergy shots for dust and whatnot.
    Also, I chew mint flavored gum ALL of the time! It really helps to clear out the sinuses and keeps air flow to a maximum. I have used Breath-Rite strips with great success, but don't always have them on hand.
    Enough for now...derekbob, I want your voice power...
    Latah~
    sru
    sru is offline
    Reputation: sru's Avatar
    I hang the bike up for the winter around this time of year and play hockey to keep in shape. I also suffer from asthma when I play in very cold arenas or ride on cold days.
    I read a great article on the subject written by Gary Roberts, a veteran player in the NHL, who has had asthma since he was a kid. He has tried every drug, exercise and therapy there is and finds the best way to keep it under control is to have a spirited but fairly short (5 minutes) warm-up about 20 minutes before game time to get his breathing fairly heavy, then rest to let the lungs aclimatize to the tempurature and increased air intake.
    I started using this method a few years ago, and its been working for me. I no longer need the puffer on the bench.
    My usual bike loop has a short climb to get to the trailhead which gives me the short spirited warm-up I use when I play hockey. I have a short rest at the trailhead to let the lungs relax a bit, then go riding.
    Works for me.
    Dr. Porkenheimer
    Reputation: bykhed's Avatar
    Exercise-induced sufferer
    I suffer from mild exercise-induced asthma and have gone the drug-free route. The use of a neck gaiter helps me quite a bit, as does a gradual warm-up beforehand. I try to think about my breathing, keeping it controlled, deep and even. If I'm feeling tight and/or wheezy, I take a rest and focus again on my breathing and being relaxed. My case is mild so you might need corticosteroids as well, but I am convinced that actively focusing on your breathing, along with use of a neck gaiter and some warm-up, makes a big difference.
    Reputation: PinsNeedles's Avatar
    Idea! Have you tried Acupuncture ?
    I am biased toward this approach not only as a practitioner but also as a patient.
    My experience with treating Asthma began as a Paramedic working in Harlem, NYC which has some of the highest rates of Asthma in the country.
    Following ten years working for FDNY I myself developed severe Asthma at 30 years old, for which I took Steroids and used Albuterol inhalers frequently with no resolve.
    My condition was brought under control utilizing Acupuncture, Herbs and Chi Kung. I was so impressed that I resigned from my job and went back to school for a Masters in Traditional Orental medicine...
    Now I ride a SS daily at altitudes between 4-6k with little trouble and race XC again. Yesterdays SS ride was at 45 degrees with no trouble and tonight I will do a two hour night ride at temps in the 30's.
    Yes I still carry an Albuterol inhaler ( effective and benign) but I rareley use it...So I would recommend you contact an Acupuncturist, eat quality food and look into Tai Chi or Yoga and learn to control your breathing.
    Good Luck
    ' Bend's dirtiest Acupuncturist '
    bendoregonsinglespeeders
    teamwebcyclery
    Mar 2005
    yeah skating right this canadian don't skate i know scary....so hockey out of the question
    DMR
    Mar 2005
    Thanks dave for the suggestion tried this out the last few mornings 2 and -2 C respectively and it worked great...especially with it a bit loose around the face and if i keep moving
    DMR
    pewpewpew Moderator
    Reputation: Impy's Avatar
    I agree. If my asthma messes up my ride it is because I didn't take my medicines or didn't warm up properly. In the height of my asthma season I take a daily antihistamine (claritin), a long acting steroid/bronchodialator (advair) twice a day, flonase daily to keep away the sinusitis, and two puffs of albuterol before I hit the trails. If I slack and miss doses, then I pay for it.
    Mar 2005
    yeah i have some serious meds as well (my asthma is considered a serious case)pulmicort everyday and bricanol (sp?) if i need it which isn't very often...but doesn't seem to effect me to much unless i miss my pulmicort for quite a length of time...that said rode at 26 degrees this morning with my neck gaiter my mom wipped up in 20 min the other morning looks like i'll be riding for a while yet
    DMR
    Reputation: okkra's Avatar
    You could Puma x Vexed Cycling Jacket
    Unfortunately, only 20 will be sold in US.
    Shut Up, Legs!
    Good job!
    I was in respiratory therapy for 8 years, and yes, warming the incoming air is the answer. Kudos to facing this issue and getting off of the trainer! I ride year round, in Chicago, a.k.a. The Windy City, and I have found the answers to all of the winter issues. Let me know if you need any more on this.
    A tough day on the trails still beats a good day at work...
    bpuodt
    Reputation: Robot Chicken's Avatar
    Jun 2005
    This may sound weird, but most of the time Asthma is 80% mental.
    I USED to have asthma, untill I trained my body to stop freaking out when it sensed danger. I had a really bad asthma attack when I was 12 years old. It freaked me out because I couldn't breath. Any time after that, I would freak out if I thought I was going to have an attack.
    Just freaking out and becoming nervous about your lungs will actually make the attack worse and worse.
    When I was 12, I couldn't do a single activity without my inhaler. I haven't touched one in over 10 years now.
    How did I solve my asthma?
    First, I had a near death experience when I passed out into a fire pit at age 15. I would've died, but someone pulled me out and I only suffered 3rd degree burns all over the back of my body. I now feel like my life has been running on over time since I could've died. I'm not affraid of death AT ALL. It helps a lot to not fear death, disease, asthma, whatever.
    Fear and panic ar the fuel of asthma attacks. Allergens are just the spark that triggers the fire.
    After High School, I went to college. I lived in a house with 5 dogs and 3 cats. Out of a scale of 1-10 my allergies WERE at 9. Severe. I moved into this house and suffered like you wouldn't believe for over 8 months. I eventually gained resistance to the allergens. This helped my asthma 10x. I no longer suffer as bad from allergens.
    THE MOST IMPORTANT thing I think I did was learn how to control my own mind and body. It takes a lot of work, but you can eventually take control of the subconscious mechanics in the brain that cause asthma attacks.
    Here's an exercise in mental control I use every day. It's easy, take the biggest breath you can take and hold it in as long as you can. As soon as you feel that tingle in your lungs that feels like asthma don't let all the air out at once. Instead let the air out as slowly as you can untill your lungs are empty. Do this as often and as many times a day as you can. You don't need to meditate to do this. Try it while walking or riding your bike, or at work. Just don't drive while doing it, you may pass out. This will train your body to leave you iin controll in any setting you might experiece in day to day life. Sitting down in a nice quite hot tub to practivce this doesn't prepare your body for controlling itself outside of comforts.
    Quote Originally Posted by anand
    That is the most practical advice posted yet. Stay hydrated (it will help warm and moisten inhaled air) and hit your inhaler before you ride. Albuterol in particular will all but paralyze your lungs ability to narrow its airways. Try acupuncture if you want to, but don't depend on it to save your life because its incapable in that capacity and asthma can easily be fatal. Also herbal supplements aren't regulated, so you never know if you are getting what you need.
    Albuterol is a life saver, I was using steroids from 1980 until my late teens when I switched to prophylactic hits of Albuterol. I use it before my rides and have no problems with wheezing regardless of how far into the red zone I go. There are other medications you can take Advair, Corticosteroids, Salmeterol,oral beta-2 agonists, etc, but each one works well with different sets of patients (steroids don't work for me). If you are still riding strong a regular old visit to a family practice doc and a $20 inhaler will probably set you straight (maybe some allergy meds to even everything out).
    Incidentally if you take some oral asthma meds the UCI will bust you for doping.
    me like bikes
    same problem here
    I actually had an asthma attack a few nights ago while i was doing some urban assult at 12 o'clock at night. It was pretty bad cause i didn't have my inhaler with me and all the sudden i was on the ground. i passed out for a few seconds my friends said. i puked and then felt like crap the whole next day. it sucked, but i still went out the following night and rode. i keep the inhaler handy at all times...the only time i forget i get raped in the lungs.
    pewpewpew Moderator
    Quote Originally Posted by Robot Chicken
    Can you do me a favor and go to my hospital and tell my patients on ventilators that it's all mental? Would save me a lot of work, thanks.
    Team Cspine
    Reputation: bulletbob's Avatar
    Wow!
    Quote Originally Posted by sru
    Works for me.
    And I thought Gary Roberts was just a no talent cementhead!! Guess I'll have to rethink that now...
    Sorry what?
    Team Cspine
    That's a good one...
    I definitely understand that as a kid, when the asthma hits it sometimes gets worse because of the anxiety of not being able to breathe BUT having said that...
    80% mental?? Um survey sez no........... Especially after I just got through inhaling Albuterol with my nebulizer a few minutes ago. Mine is better than some of the folks that posted above it sounds like but it's definitely not mental at age 40, when it hits, it hits.
    What helps me on a ride and I have to force myself sometimes to do it is just ride a decent warmup and not do what I did a couple of weekends ago which was get a bug up @ss, get up on the pedals bustin a hill real early in the ride and clog my lungs for the rest of the ride (dammit).
    Just my $.02 from a lifetime of asthma. Wheee.
    Sorry what?
    34N 118W
    Reputation: Hollywood's Avatar
    hey junkie -
    Quote Originally Posted by Impy
    Good lord! Wash it all down with some Oxy-C? who the hell writes you all those Rx???
    My cold weather riding regime over the past few years:
    1) premedicate with one toke of Albuterol
    2) "in through the nose, out through the mouth". Helps humidify the air first.
    3) in an emergency, a cup of hot coffee will help remedy an attack.
    below freezing and I add on a neoprene ski mask.
    PS - Impy-score me some more Alby?
    bpuodt
    Jun 2005
    Ummm, actually YES, asthma is a mental thing to a degree.
    Notice I never said asthma WAS CAUSED BY mental conditions. Mental conditions will take a small reaction and multiply its effect many fold.
    OK let me get this straight, someone who is 40 years old with asthma and has not gotten any better or seeked any type of alternative treatment, STILL has asthma attacks. I would think that after THAT long of having asthma, your body would be set to react right on que.
    Another thing. It's obvious that the mental aspects of asthma are a sub-conscious event. Otherwise we could all just cognitively tell our brains STOP REACTING!! It doesn't work that way. Our brain is hard wired with SOOOOOOO many subconscious triggers and backup safety features that we really have less cognitive control of our systems than we would like to think.
    The trick is to find out what exercises in mental control work in retraining our subconscious wiring. I'm a living case study of this exact type of transformation. It took me a long time, but I was able to "cure" my asthma by kicking the drugs (which I may add are also another crutch for the brain) and looking at it from this perspective:
    IT'S MY BODY THAT IS THE CAUSE OF THE ATTACK. NOT THE ALLERGEN!
    I've been to the hospital 8 times due to severe asthma attacks.
    I have yet to have a single attack in over 10 years, not a single inhaler used this whole time!
    Inhalers are also another major problem with what I like to call the "Inhaler mental addiction". Us asthmatics become addicted to the safety zone that an inhaler provides. This in turn creates a mental addiction (along with the physical addictions) to the safety of the inhaler. Getting rid of the inhaler is by far the most difficult thing ANY asthmatic can possibly try to do, it does absolutely NOTHING to help treat or cure a person over the long term and only helps to reinforce the mental crutch that is hard to get rid of.
    Here's an example of how asthma is controlled by the mental triggers:
    My brother, who had even worse asthma than me, came to visit me in college. He didn't know we had cats and dogs in the house. He was there for over 5 HOURS without a single problem. He then mentioned something about feeling funny and was fine for another hour. Then one of the dogs comes inside from the backyard. The very second my brother saw the dog he realized it lived there. At that very second he also sprung right into a asthma attack. He had been SOOOOO afraid since childhood of dogs and cats (they caused him several trips to the hospital) that the very sight of the dog and realization of the allergens in the house made him freak out and go straight into an attack. From a medical POV it would seem logical that he would've experienced an attack much sooner due to the high levels of allergens.
    The breathing exercises I explained are really an effective way to lessen or eliminate asthma over a long term period. Not only does it help to build lung strength and volume, it also helps in many ways to get you back in control of your own body again. That's the worst thing about an asthma attack, not being in control.
    But, hey, what the heck do I know? I managed to cure myself of asthma (along with others like myself) so anything I say is invalid?
    What I see is a system of health treament that focuses ENTIRELY on the drugs being sold to patients. It's a system that makes money off sick people by selling them drugs. Simple as that. When's the last time a cancer doctor told his patient, "don't buy these $30 a pill drugs for your white cell production, when you can eat liver which is even more effective than the DRUGS!" In some cases doctors are prohibited by law or contract to even mention these alternatives, even when they are more effective than what is being sold to you.
    Doctors are good people, but the system they work for really has them held tight. It forces them to be drug salesmen rather than geniune people looking to help others in any way possible.
    how heavy are you ??
    Reputation: Scottay5150's Avatar
    This guy is to Medicine what Tom Cruise is to Psychiatry...
    nuff said
    bpuodt
    Jun 2005
    It really makes me sad when I try to help people and all I get is pointless criticism.
    Why are you guys sooooooo against the mental aspects of asthma? Are you trying to say our mental health has no effect on our physical well being????!!!!????? You would be retarded to even think that was remotely true...
    If doing a breathing exercise (which I may add is FREE!) is too much work, then give up now. You will always have asthma and be stuck paying drug and doctor bills, along with not being able to bike when you want!! It's that simple, if you don't take control of your life, then who's going to do it for you? God? Your doctor?
    Even if the breathing exercise only gave you a 5% chance of curing yourself, sin't that worth it?
    I mean come on. It's not like I said to remove your testicals or shave your head, or drink lemon juice, or something quacky and potentially with adverse effects. Breathing is some ALL of us do ALL day. Not hard folks.
    Like I said, if that's too much then just give up now.
    Mar 2005
    ok...i agree with you that there is a mental aspect to asthma but that said not everyone can cure their asthma by breathing excerises and mental stuff
    sorry it just don't work for everyone
    we're all glad that it worked for you but it may not work for the next person so please don't try to tell them that it is 80 percent mental i'm guessing that as you said in you post farther down it might work in five percent of the cases
    so now what are these breathing excerises that u talk about i would like to know
    DMR
    me like bikes
    i don't know about the mental thing...
    I'm not trying to bash you idea in no way, shape, or form. I feel that well...mabye you had those problems cause you were so scared of having an asthma attack that you would freak out and have small panic attacks. Which can leaving you gasping for air. Idk...just a thought though.
    me like bikes
    i guess i should also mention i have horrible allergies
    I'm allergic to almost every...oddly except for cats and dogs. I'm allergic to yeast for crying out loud. It sucks cause i can sometimes eat a sandwich and then suddenly feel like i've been stabbed in the chest cause my asthma will act up. it also makes me sick sometimes. Allergies suck especially when you allergic to such common things like i am.
    bpuodt
    Jun 2005
    Cure everyone? Most likely not.
    Help make a person stronger and more attack resistant? You bet!
    We all have different reasons and levels of asthma. Treating it from a wholistic approach is going to yield better results than relying on drugs alone!
    I would never advise anyone to go cold turkey with their inhaler. It took me three years before I was free of mine.
    All I've got to say, is why give up on yourself? Are you going to let asthma control you or are you going to try and control the asthma?
    The breathing exercise I mentioned earlier works well in managing panic. I can't imagine there's a single person in this whole world with asthma who doesn't panic to a degree when things go downhill.
    By holding your breath and letting it out slowly (making sure to regulate the pressure with your mouth and blow firmly with your lungs) you are placing yourself into a controlled state of subconscious panic. Your lungs will start to freak out with not having air, but after a long time of doing this your lungs will be retrained into feelng comfortable with low amounts of air.
    Don't get me wrong, I still have allergies and a bit of a wheez from time to time, but it never gets any worse than that. I can now do 30+ mile rides in any weather. I could only do 1 lap around the track in Highschool before being close to passing out. It's taken me MANY years to get my lung volume up and it has been worth every freakin second of hard work to attain it!
    For what it's worth. Of 6 people I know with asthma who have tried similar methods, ALL 6 have significantly reduced reactions. My brother hasn't had an attack in close to three years, which is how long he's been without an inhaler.
    Mar 2005
    thanks
    heres my thoughts...I have lung capacity much better than some people that i know that don't have asthma...i don't know how much effect that lung capacity has on asthma i think that the idea of training your lungs to live with less air is a good idea
    thanks
    DMR
    thanks
    thanks
    DMR
    i don't think lung capacity is going to help too much unless you can get absolutely massive lungs to help you or already have really incredibly tiny ones handicapping you.
    my reasoning is this - one of the big problems with many lung diseases (asthma included) is that the airways are narrowed during an attack and can close completely while you are trying to exhale (dynamic compression). this happens because the air must move faster through the smaller airways, bernoulli's equation (and many others) tells us that the pressure in the airways is no longer sufficient to keep them from collapsing.
    one of the typical findings in someone with this is that it takes them forever to empty their lungs - this limits the ventilation rate. because of this the person must inhale really fast, but they can't because their airways are narrowed.
    my grandfather was also a huge asthmatic and the best thing he ever did for his health was to move somewhere warm and dry. if it is that bad consider moving. best of luck.
