Results 1 to 81 of 81
    Spherical Earther
    Reputation: Forster's Avatar
    Sep 2013
    What's your threshold for cold?
    I may be the wimp in the crowd, but it's been below 10 F when I leave for work since Wednesday and my current threshold for cold seems to be about 15 F. Just can't keep the face warm without fogging the glasses. Everything else seems relatively easy to cover/protect with normal winter gear. I've tried several balaclavas but there doesn't seem to be a good balance of warmth/wind blocking/breathability that's compatible with prescription classes. So my questions are: What's your threshold? and What do you do to protect your face if you wear glasses in temps below 15 F?
    since 4/10/2009
    Reputation: Harold's Avatar
    today has been my coldest ride to date, at about 11F. So far no lower limit. I wore a thin summer Buff on my head. Only thing on my face was my beard, and I never felt uncomfortably cold on my face. My feet, OTOH...I need some winter boots if I want to go colder. The forecast this winter seems to suggest the possibility of more snow rides, and possibly colder ones. My feet were REALLY uncomfortable today. Otherwise, I was quite warm.
    First Snow Ride of Winter 2013/2014 7 Dec 2013
    My glasses kept trying to fog up on me, and I had a persistent spot of fog in the center of my visual field that was annoying. But keeping my glasses just away from my face to improve ventilation kept the fog from overcoming the entire lens. I wear Oakley Jawbones, BTW.
    Reputation: Streetdoctor's Avatar
    Oct 2011
    So far 3F.
    I wore basic light mountaineering/sking clothing and I was very warm.
    -Sorel boots with two pairs of wool socks
    -underarmor cold gear base bottoms with Mountain Hardware softshell pants
    -synthetic t-shirt, Patagonia R1 hoody and pull over mid-weight down puffy.
    Nothing on my face and I used the helmet hoody from the R1 under my helmet. Ski gloves on my hands and I felt warm for a 2 hour ride. It's -3 out now, going to try and get a ride in today to see if Pogies will every be necessary. I didn't feel it necessary to wear glasses- wasn't riding fast and didn't want to worry about fogging.
    Instagram
    Mojo Wheels | DirtLabs Suspension | Honey Stinger
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Six below zero f. The dogs threshold is lower yet.
    Reputation: J.B. Weld's Avatar
    When I lived elsewhere I did commutes as low as about 20 below (F). I wear glasses and used a baklava with one cutout that I could cover and uncover my nose with, also leather wool lined mittens. If I'd thought of it or if they were available then I would have for sure used Moose mitts or something like that.
    Once it got below a certain temperature it didn't seem to matter much if it was 0 or -15, if I dressed right I was fine.
    dru
    dru is offline
    I can comfortably ride off road in 15F weather. I've been out in colder temps but the feet start to feel it.
    Drew
    occasional cyclist
    Reputation: honns's Avatar
    About 40F, anything below that I get bad asthma and my lungs just burn. Also I have no body fat so it takes a lot of layers to keep me warm. I have yet to find a pair of gloves that can keep my fingers warm.
    since 4/10/2009
    Quote Originally Posted by honns View Post
    Doesn't have much to do with body fat. I have low body fat, and I am a furnace. Love it this time of year, but it can suck for summer riding.
    Maybe my heart is just two sizes too small...
    since 4/10/2009
    How muscular are you? Muscle mass raises your metabolism, which generates heat. I don't have a ton of muscle, but am reasonably muscular being 5'8, 170lbs, and ~10% body fat. Also, the TYPE of layers you wear makes a big difference how warm you stay. Your fabric choices, insulation choices, wind blocking choices all play a role. Keeping your core/torso warm is paramount. In this weather, my torso and my hips get more layers than my arms and legs. I wore Gore-tex ski gloves with smartwool liners today. My hands were plenty warm. Pogies/bar mitts may be a better choice for you if you have glove issues. Glove sizing is important. If your fingers press to the end of the glove fingers, your fingers WILL get cold no matter how thick the gloves. Restricting blood flow in your extremities WILL make you cold. Don't cram too-thick socks into your shoes. You're better off using plastic grocery bags as a vapor barrier layer than you are cramming thick socks into tight shoes.
    None of those things will address your lungs, but maybe a face mask that somewhat warms the air you inhale will help for that.
    Reputation: Rev Bubba's Avatar
    50 degrees.............
    No bragging about how I go out in sub-zero temperatures. Wimp? Probably. Skier? Hell yes! When it gets cold enough I have other things to do. I.E. teach skiing on weekends, ski just about every day between weekends. God I love snow! Just got back from a morning on snow and thought I would see what was going on at MTBR.
    Mar 2012
    My threshold is about 40-45 degrees. I live in SLO and if is too cold to wear flip flops, then the masses start to revolt.. Its been pretty cold here relatively speaking and its been tough to find the motivation.. I need to find more cold weather gear.
    Quote Originally Posted by NateHawk View Post
    6' 130 lbs, 3.5%-ish body fat. I have tried all kinds of gloves/layers of gloves. Lobster, mittens, 5 finger gloves, windproof and waterproof. Couldn't find any that worked. I learned the lesson about constriction through this as well. I had like 3 gloves on (way too tight, obviously), and nearly lost control before I took one pair out which allowed circulation.
    Its a shame, but I've just not found biking in the cold very enjoyable.
    Oct 2011
    How did you calculate 3.5% body fat?! If that's true you need a hamburger... or 15!
    Instagram
    Quote Originally Posted by Streetdoctor View Post
    One of those electric meter things. I realize its not super accurate, but I've never been over 5% by any measure, including my dr.
    since 4/10/2009
    I have had caliper measurements done, and found them close to my Tanita monitor. 3.5% is SERIOUSLY thin, though. Still, at your height AND weight, you're working against physics. You have a high surface area to volume ratio, and it will be exceedingly difficult for you to maintain your body temp in very low ambient temps, physiology aside (and assuming you could stoke your internal fire enough to warm up, you'd have to consume more calories than I would to maintain that temp). If you can bulk yourself up (fat or muscle, or preferably both), you'd find yourself more comfortable in the cold.
    Changing your body composition aside, you're a perfect candidate for pogies/bar mitts. You can still wear gloves inside them. I think I'd like a couple sets (one for the mtb and another for my drop bar commuter) so I don't have to wear the ski gloves and get better dexterity on the shifters.
    Nor­wegr
    Reputation: Vegard's Avatar
    Coldest I've been riding in was -20c (-4f), that went alright due to proper clothing.
    Ideally I don't like it being below -10c though.
    Reputation: wetpaint's Avatar
    Quote Originally Posted by Forster View Post
    The type of lenses you are wearing makes a big difference. I've found smaller lenses that don't hug your face work best. I have a pair of Oakley Radarlocks with a vented path lense (smaller lense) and a unvented Pitch lense (bigger lense). The smaller lenses hardly fog up and the bigger ones will fog if I don't have a side wind.
    Dec 2013
    How low will you go?
    A curious biker wants to know.
    Morals are not the question here,
    but how low a temp do you fear?
    20, 15, 10 degrees or so,
    what degree is just too low?
    I was out today at 23,
    rode in fleece and not a tee.
    Covered fingers, nose and toes,
    suffered no frostbitten woes.
    Could maybe go to 10 degrees,
    and still ride among the trees.
    Can't abide getting a wind chill,
    too cold for that kind of thrill.
    So the answer to one who wants to know,
    teens are okay without any snow.
    One final thought to proffer,
    hot tub warming I'd like to offer.
    9 lives
    Quote Originally Posted by jimed2045 View Post
    etc
    Your poem was spot on jimed2045 ! Good work
    Singlesprocket and I were riding our local trails today.
    -6c (21f) and wind chill -12c (10.4f)
    Yup it was cold but it isn't the coldest ride we've ever done. For those rides I need to wear my ski pants and ski jacket and thats probably a few weeks away. I don't think we've ever reached a point where we haven't ridden because of the cold. What usually stops us is when the snow is too deep. And actual extreme cold makes for the best conditions for ice biking and we can ride on the river.
    Gosh it's still 2 weeks before the first day of winter
    F*ck Cancer
    Eat your veggies
    Spherical Earther
    Sep 2013
    Quote Originally Posted by wetpaint View Post
    I had smaller Bolles but switched to a slightly larger Columbia frame due to my eyes watering. I've been thinking about getting Wiley-Xs . Anyone have experience with those?
    As far as deep-diving into motivation to bike verses another sport, eastern Nebraska gets very few XC ski worthy snows and I've only had the snow shoes out 5 times in the last 5 years. Since I run as little as possible (back issues) and would rather not live in the Gym, riding to work creates two+ hours of exercise for just more than one hour of commitment (after subtracting the 30 minute drive each way).
    Shoes-wise, I'm using some cheap neoprene shoe covers made by Performance Bike that are probably 10 years old and holding. Several buddies are using Seal Socks and duct-tape toe covers with good success.
    the half breed devil
    Reputation: shekky's Avatar
    Oct 2011
    i live in northern california. in thirty years, the coldest i've seen it at night is about twenty five degrees. i have been on mt tam when there were remnants of snowfall on the ground; i do not know what the temperature was.
    in 1998 or 99 i was riding with friends in san francisco's golden gate park while a (rare) light snow was falling. so how cold does it have to be to snow?
    that's my threshold...
    Resident Curmudgeon
    Reputation: Buzz Cut's Avatar
    Warning: Consumption of alcohol may make you think the person on the barstool next to you is attractive
    Mar 2005
    40 degrees for me. I've spent time biking in both Pennsylvania and Arizona attempting to bike in the winter. I do better in Phoenix winter riding where it is usually very comfortable riding conditions.
    I have a name for my pain and call it "dog".
    Reputation: letitsnow's Avatar
    Anything below 20 degrees F is tough. That is when I ride on the trainer and watch football (while riding).
    Reputation: dickeydoo's Avatar
    At between 35 and 40 degrees around the 45 min mark my toes are done. I've been thinking of trying flat pedals and Sorrels to possibly go longer.
    You will be scarred for life if you click my avatar
    I'm a wuss with bad circulation in my hands and feet. So it's gotta be around 35F. Might push it a bit lower if there's full sun and no wind.
    '15 Giant Anthem SX - '01 Schwinn Homegrown Comp - '12 Giant Defy 1 - '14 Kona Jake the Snake
    Reputation: jhmeathead's Avatar
    Apr 2013
    from my commute to work earlier this week. The next day it was 4.
    Id have to say them alaskan boys are nuts at -20
    Reputation: bikefat's Avatar
    Nov 2013
    Yeah, Alaska does make a Colorado winter seem balmy. I can just choose to stay inside on those few days where it's below -30*F, pretty much have to -- gotta babysit those pipes, or help neighbors thaw theirs out. Below that, gear starts to break anyway. Or, you can get your truck started 'cuz it's plugged in, but the power steering's frozen solid... I remember learning to alpine-ski the winter the Broncos made their first Super Bowl, at 43 below, in a pair of hand-me-down leather ski boots. Lesson learned -- I've never let my feet get cold enough for frostbite, since. Mostly by staying inside when it's that cold, like a sane person...
    Denver Broncos: 101-3 since 1975 when scoring 30+ at home.
    C.J. Anderson career YPC = 5.67
    Here in So-Cal, I sometimes ride up in the local Mtns in the Winter, and I have ridden in the 20's. As a general rule, I ride anything in the 50's and up. If I am on an Epic like Cannell, I am ok with it really cold at the start, since it tends to warm up as I descend. Last Spring we rode Cannell Trail it was 21 degrees at the top, and my hands were in pain, but it got better...
    The White Jeff W
    Reputation: jeffw-13's Avatar
    Rode in 25* temps today. Ive done colder but thats about as cold as I wanna go unless Im really desperate to ride.
    No moss...
    Oct 2013
    I just started riding in the cold, and have been working my way down in temp and learning to find the right combination of riding clothes/gear. A biggie for me has been getting my feet to stay warm. I finally bought a pair of Shimano SW81 winter riding shoes and a pair of DeFeet Woolie Boolies. Those are awesome. I rode with them yesterday (21║) and today (27║) and my feet stayed warm enough to enjoy the ride. I don't know if I will ride below 20║. I start having problems with my glasses fogging from breathing under a balaclava.
    2014 Trek Superfly FS 9; 2013 Trek Domane 4.5
    Reputation: KRob's Avatar
    Quote Originally Posted by RaceTripper View Post
    Yep, that's the problem right there. I have to pull my balaclava down below my lower lip or it just fogs up my glasses and caused ice to form on the balaclava. I've ridden in temps down to -20 F and haven't had any problems with my nose or cheeks getting cold but I only stay out about an hour when it's that cold. My "normal" low riding temps are closer to zero F.
    Hands: Moose mitts are the answer.
    Feet: Lake or Shimano winter riding boots if you really want to stay clipped in. Get a size or two larger than you wear so you'll have room for thick socks and 1/4" felt insole without restricting circulation as others have mentioned. Regular thick, insulated boots work well with flats.
    I use regular oversized cycling shoes with two pairs of socks (one medium weight smart wool sock with a lighter merino wool sock underneath it with a chemical toe warmer between them and a piece of neoprene under the sole liner where the cleat is (this is a serious heat sink), all covered with the fleece lined neoprene booties from Performance or Nashbar over the whole mess. This works pretty well down to about zero but my toes still get cold if I'm out longer than an hour with sub zero temps.
    I think I'm going to ask Santa for some of these this Christmas.
    Isaiah 58:14
    www.stuckinthespokes.com
    psycho cyclo addict
    Reputation: edubfromktown's Avatar
    Depends on a number if factors for me (wind being one of the top considerations). According to my Tanita scale- 13% body fat on my 195 lb. carcass.
    Around 25 F, I typically wear a balaclava. My hands go numb for the first ~15 mins of a ride at lower temps and then are fine as long as I keep moving. My feet start off warm and eventually get cold after 3+ hours (for longer rides, I use foot warmers). This was yesterday (and it was ~26 F)
    Mar 2013
    -40F or -40C
    Funny how they are the same at that point.
    That's as cold I've ever experienced but I think I could manage colder even. If there's no wind. -40 and wind would be pretty bad for anyone.
    Laramie, Wyoming
    Reputation: alphazz's Avatar
    Oct 2012
    As far as riding with a balaclava, it just takes riding with one made for use with goggles. Klim makes what they call their Arctic and it has a large opening for air exchange that still protects your face. Used with a pair of Spice goggles, it works very well.
    Temperature doesn't matter.
    Spherical Earther
    Sep 2013
    Klim Arctic Balaclava Review at RevZilla.com - YouTube
    That's a great idea, makes me wonder if I couldn't mod one of my existing balaclavas (to avoid the additional insulation below the jacket).
    Feb 2006
    Not sure where my bottom limit is, but I know I'm good down to -10C or so. It was -8C (13F) when I hit the trail this morning. Chilly but not bad once I got going. I wore a wool base layer with a long sleeve jersey with a cycling shell on top; compression shorts + G-form knee pads and knee length ski socks under lightly lined nylon splash pants and my 5-10 Impacts; thin wool toque under my helmet and a pair of light ski gloves. The trails I ride this time of year are pretty sheltered and they're also pretty technical which means low speed/high effort, so after about 10 minutes I was plenty warm and by 20 minutes in I was sweating and had to ditch the toque.
    I've lived in a cool-cold climate all my life so I'm pretty accustomed to it. Flip side is that I blow up pretty fast when it gets warm. If it's over 20C (67F) it's getting too warm for me and I get exertion headaches and such.
    I love riding this time of year. Frozen dirt but no snow makes for hero trail condtions after a soul sucking, rainy autumn.
    For the glasses people, have you tried one of the fog clothes made for skiing? I use that, along with my ski helmet and ski goggles, which are designed to go over the glasses, and have a fan built into them. The combo seems to work.
    Ride More, Work Less
    Reputation: heyyall's Avatar
    I've had issues with balacavas and fogging with regular sunglasses. This is what I'm experimenting with now.
    In terms of too low, I really haven't met it. I rode at -5F this weekend for about an hour. It wasn't that bad. I'll certainly do it again.
    Reputation: juan_speeder's Avatar
    I'll ride in the digits.
    I got some Shimano winter shoes, but I really should have gotten the Lakes. Below 15F I have to tape chemical hand-warmers to the top of my shoes.
    Doing that, I can do the 15 mile low-mid angle climb, and that damn 15 mile descent, that comprises my morning ride.
    Scarlett Johansson loves my hummus.
    Type A
    Reputation: Overhillthruthewoods's Avatar
    Sep 2012
    When I lived in Ohio, I rode as long as it was warmer than -10F. It's all about keeping your hands and feet warm. The other parts of the body are easy. What I learned:
    Cotton kills
    Thin layers are better than thick ones
    Moisture, be it from the weather or your body, is bad
    Gore tex socks rock
    You are properly dressed if your body is shivering when you are first starting your ride
    Now, I live in California and riding below freezing temps is rare. All you have to do is change the elevation you are riding to find the right climatic zone.
    Reputation: SlowPokePete's Avatar
    Mar 2006
    Ridden down to 12 deg.
    Will ride colder if necessary.
    SPP
    Rigid.
    Reputation: bgfthntr's Avatar
    25 F is my lowest.... cant keep my feet warm below that..... plus I love drinking MORE beer in the winter....
    Now broadcasting from CO
    Reputation: PAmtbiker's Avatar
    Feb 2005
    I don't have a limit for cold so far. I think the coldest I've ridden in was single digit temps. I do have a limit for wind, especially when riding on the road/open trails. Sustained winds over 20 - 25 mph, I'll stay inside, thank you. You can always put more/better clothes on to keep warm, but even with windproof layers, the wind finds some way to make you uncomfortable. Plus, being blown around is no fun.
    Brought to you by rocks.
    Reputation: roknfnrol's Avatar
    Sep 2013
    Around 18-20F so far. As everyone else has said so far, it's all about the hands and feet. I just bought these shoes, so we will see how that goes.
    Attached Thumbnails Attached Thumbnails What's your threshold for cold?-shimano-wm81-winter-cycling-mountain-bike-shoe2.jpg
    Spherical Earther
    Sep 2013
    With Freezing rain forecast for Saturday I think I'll worry less about the temp and more about the survivability issue. As much as I'd like to think I could control my bike on slick surfaces, I trust cars on ice as far as I can throw one (not very far).
    As a California native, 40F or 50F start feeling cold. 60F or above isn't too bad. You other state people are tough!
    Spherical Earther
    Sep 2013
    SS Hack, I think "tough" in this case is a matter of acclimatization more than fortitude. My Senior year of High School I worked in a gas station in eastern Nebraska that was about 30 miles away (20 on the interstate) an I rode that daily for a year on a Yamaha 250 with no real technical clothing (just layers of sweatpants and thermal long johns). I was miserable for the entire winter but my tolerance for cold was better the next winter doing normal stuff. I think most folks get used to a certain level of suck if given the necessity.
    Reputation: HillbillyTom's Avatar
    Sep 2012
    I'm pretty much at my limit now. 18 degrees, but the real problem is the thawed yesterday and now refrozen slush on the ground everywhere. Was snow, now it's all rutted up ice..
    Salsa El Mariachi 29er
    Giant CFR Team Road Bike
    Kona Jake the Snake
    '03 Yz250
    '05 Ducati 749
    Oct 2011
    Quote Originally Posted by SS Hack View Post
    don't forget about our neighbors in auburn/tahoe/truckee and other parts of california where it gets cold...
    Apr 2005
    I have now made it down to -6F and was actually quite toasty. I hope that is my record low. It seemed a little wrong going on a ride later in the week when it was 18 and thinking that was warm.
    I wear glasses and use a smartwool neck gaiter most of the time. It is much easier for me to direct the air flow than a balaclava. I do sometimes have to play with it a bit if I am breathing really hard. Sometimes doing a small fold/roll at the top either in or out can help.
    I also have an OR windstopper balaclava that I only use when the wind is really bad. It is difficult to breathe in and very finicky if I want to keep my glasses clear. I have to use it with a headband as the only way I can breathe and keep from fogging up exposes part of my ears.
    When it gets colder I add some OTG googles. I usually pull the gaiter up high enough that the googles go over the very top and it helps. But I do still end up with some fogging if I am breathing really hard. Then I have to adjust it, sometimes multiple times.
    So I would say if you really want to be out there you might have to experiment a bit. If you dont want to be out in the cold though that is completely understandable. I dont think that makes you a "wimp". Everyone has different tolerances. I bought a lot of gear trying to figure out what would work and am still trying to get it perfected.
    Some of the OTG googles I have seen have a battery powered fan that is supposed to help with fogging. I have been tempted to try a pair but am not sure how well they would work.
    Spherical Earther
    Sep 2013
    Rutted Ice seems to be the perfect venue for the fatbike. Worse than riding on the rutted ice is falling on the rutted ice. Sharp ice is a tough surface to fall on.
    Jun 2010
    When stationed in anchorage I rode in negative 17. With snow board jacket and pants boots. Poggies hat gloves and face mask. Was an amazing experience. So cold no animals were out it was literally me and the woods. The trail was no wider than two feet and if u stepped off u were hip deep in snow Imagine complete and total quite except the noise of your bike and the sounds of your body . Snow as far as the eyes can see and beautiful blue skies. Was so serene I miss it so much stationed down here in miserable idaho
    Jun 2010
    I rode a fatback from speedway cycles
    Reputation: June Bug's Avatar
    This sounds right, although I've bike commuted at temps around freezing and stayed pretty comfy. Temps flips back and fourth here in Central Texas during the winter. Low pressure from an oncoming polar express pulls warm moist air from the Gulf, so lovely balmy shorts-T shirt weather for two or three days. Then the Blue Norther arrives and it can be 40 degrees colder the next day. Point being, we never really have to learn to accommodate to cold weather; if you wait long enough, it WILL get warmish again.
    Fun seeing pictures of fat bikes in the snow, tho.
    Spherical Earther
    Sep 2013
    Quote Originally Posted by ridehard84 View Post
    First, you Alaska guys are nuts to begin with. I was in Fairbanks a few winters back and couldn't believe how much the cold folks were dealing with. One of my friends from there moved to Duluth and when I was visiting, we'd wait for the temps to warm up to -16F then he'd decide it was time to XC Ski (because clearly any colder was too cold and any warmer was too warm). I do like those rides when nothing living seems to be around although that's usually when I see skunks.
    I went out at 16 F on Saturday. Was definitely cold, but could probably have dealt with that. The intense burn in my lungs was another story. That's about as cold as I'll go.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Well, fairbanks IS nuts, -30 today. It was -5 today in anchorage, a bit of a cold-spell, it usually doesn't stay this cold. Anyways, with the gear I had on I was toasty warm during my commute, both ways. Actually, with the gear I wear, I have to usually slow down because I'm getting too warm. Amazing to be out riding in this stuff. I wish time and time again that I had some of this gear back in AZ, mostly the pogies and shoes/boots. Those items would have made riding so much funner even on moderately cold days. I'm finding that around 30 degrees is downright balmy, pretty hard not to overheat with most setups. Less than 20 and it's starting to get chilly, but given the gear I've got it gets pretty optimal down into the single digits. Down into the negatives it's not bad but a little sweat doesn't take long to bite back and make you cold, so you got to be a little more careful as it gets into those temps.
    Reputation: mpmffitz's Avatar
    Freezing your nuts off builds character.
    Another California rider, and here in So-Cal, I ride if it's 50 or higher. Sometimes we ride high mountain stuff, and I have ridden in 21 degree stuff over 9,400 feet, but usually it warms up as you drop elevation. I don't mind it a little colder into the 40's at times, as long as it's dry and not wet stuff.
    Been out in 10-12F weather with snow and ice. It was fun.
    With my gear, I can last about 2-3 hours before I have had enough.
    18 Focus Raven Lite
    17 Focus o1e
    17 Yeti ASR-cT
    16 Bianchi Specialissima
    15 Echo Big Deal
    Try a neoprene facemask. Lets the breath out with some moisture trapped. Worked with my goggles on last weeks 14 F, 18 miles bike commute.
    As long as my feet are warm, I've been fine right down to around 0F.
    Frosted my toes a bit a number of years back doing some winter backpacking in NH, so they're pretty sensitive to the cold now, and the thing I've found that really saves the day are those disposable toe warmer packets. Dirt cheap and they make all the difference in the world. I highly recommend giving them a try if you have trouble keeping your feet warm.
    Sinister Bikes
    Wraith Bicycles
    Sunday River Mtn Bike Park
    NEMBA
    Wachusett Brewing Co.
    Oct 2012
    For me it depends on whether we're talking trail riding or Road. I live in Virginia so 20 is about as cold as it gets and that is at night (sometimes in the teens). I can do trail riding at 20 but I would never do road at that temp. Just no fun for me.
    I also hear that exercising in low temps can mess your lungs up. Of course I wouldn't know by experience living in VA.
    turtles make me hot
    Reputation: NYrr496's Avatar
    I used to ride in any temp a Long Island winter could muster. Zero, 5 degrees, whatever...
    Once you get into the trees, the wind pretty much disappears.
    I have no idea why, but this year, I've been in no hurry to get out in the cold.
    I've been very busy and my rides would have to be squeezed in between other things that need to be done. Just haven't felt like riding in the cold if it's also going to be a hassle.
    I like turtles
  67. #67
    govt kontrakt projkt mgr
    Reputation: ArmySlowRdr's Avatar
    Really Hawaii and Texas has spoiled me. I do not like to venture out below 50F.
  68. #68
    29ers Forever
    Reputation: CannondaleF9's Avatar
    Nov 2012
    Under 20 degrees Fahrenheit.
  69. #69
    Light freak
    Reputation: scar's Avatar
    Jun 2005
    Been wishing for some winter weather to show up here in the Denver Front Range area. Been unseasonably warm for December, was mid 50's today. Got to ride in some cold weather last Friday as it was about 18 degrees at 5 am and had a few spits of snow. Some low hanging clouds were much enjoyed -
    The lights you see to the left of the trail are from the Coors brewery.
  70. #70
    Reputation: Jams_805's Avatar
    Aug 2013
    I don't ride in anything less than 50 degrees farenheit.. Southern Californians are spoiled as hell.. heck its been 70 degrees through Christmas! Working out under 50 degrees makes my lungs hurt from the chilled air, I guess im not used to it
    Rockhopper 29er
    -FSA Carbon handlebars, stem, & seatpost
    -2011 Rockshox Reba
    -Stan's Flow Wheelset
    -Ergon Grips
  71. #71
    ENDO!!!
    Reputation: The Yetti's Avatar
    Dec 2005
    It's funny, beginning of the year, when I was in Colorado, I had many rides when it was single digits and was cold but not below my threshold. I've been in Qatar (near Saudi Arabia) since March, and I rode this morning it was 51 degrees, and I froze my ass off!! alot of it is not bringing anything for cold, even though 51 ain't cold, but when you get used to riding at 5 am and its 90 with 90% humidity, 51 is freezing!
    Just circles turning circles....
  72. #72
    Oct 2012
    Living in ND, -20F pretty frequently on the fatbike. But since spending the last 6 months in Virginia, I've turned into a p*ssy! 20F and I get chilled...
  73. #73
    I hate asthma. I did a short 6 mile trail ride today in 60 degree weather and my lungs are absolutely congested now.
  74. #74
    Jul 2013
    Crap man, I'm with these other guys that don't like it too much below 50. I'll take 108 degree summers all day over being cold.
  75. #75
    RAKC
    Reputation: tigris99's Avatar
    So far has been 11f and been comfortable. Found pogees to be a life saver on the fingers. Found wool socks with pair of athletic socks underneath perfect with my shoes on platforms. When it gets below 15 just throw my neoprene shoe covers on and gtg. Fighting with fogging on glasses if wind is at my back though. Next thing is to chase down goggles that will fit my fat head comfortably. I did modify my bala though so it's mostly tight around bridge of my nose, went from can't wear glasses at all due to fog, now only having issues with my glasses when wind is on my back and its below 20F.
  76. #76
    Spherical Earther
    Sep 2013
    Quote Originally Posted by ArmySlowRdr View Post
    Asthma is a pain for sure. I've got a good friend who lived in Duluth Mn with Asthma and pretty much all winter she was homebound. I've been off during three really nice days because of post-flu congestion. Probably not riding today either (8F and still congested). Have you looked into some of the treatments for Asthma? Probably a redundant comment, but worth asking.
  77. #77
    Nov 2013
    Well said. Those new to seriously subzero conditions are best advised not to stray too far from some sort of warming hut / vehicle etc. until they've gotten the hang of working out without breaking a sweat, which is kinda counter-intuitive.
    Quote Originally Posted by ironsinker View Post
    At some point in my mid-20's I realized I breathe in through my nose, and out through my mouth, whenever I exercise (unless it's hot). I started focusing on my breathing in my mid-teens, practicing this even in warm weather, after a few years muscle-memory takes over -- just like riding a bike.
    Makes sense if you think about it -- most heat is lost from the head, but the head has built-in heat exchangers called sinus cavities. Breathing in through the nose channels this heat loss to the lungs, mouth-inhaling gives an unwarmed blast of air straight to the lungs -- without "re-capturing" any of the heat lost through the head.
    If you need more air volume than you can suck through your nose, you're probably breaking a sweat, which as Jayem pointed out, can come back to bite you. Feeling like I need to breathe in through my mouth, is my signal to dial it back a notch.
    Quote Originally Posted by scar View Post
    Yeah, it's been ridiculously warm of late even up here in the mountains. I've been fortunate to log many days skiing Steamboat in many epic-snowfall winters, but my favorite is still January of '96 or thereabouts, whatever year where we still refer to Feb. 1 as "Fat Tuesday" because the sun finally came out, cold but cloudless blue skies and bottomless champagne pow every run, best day ever. That January snowed, a lot, every single day -- over 100" down in the valley, over 300" up top without a minute of sun, and hardly any wind.
    But, I do remember having green grass in my snowless yard on Christmas that year. So I don't get too down on the potential of any winter until February...
  78. #78
    Dec 2013
    Alright call me a wimp but below 60* it cold to me being used to the beautiful Santa Clarita weather has really spoiled me.
  79. #79
    29ers Forever
    Nov 2012
    Quote Originally Posted by PROFILECLIMB View Post
    60 degrees Fahrenheit for me would be WARM spring riding, and VERY WARM fall riding.
  80. #80
    I waited all day for it to warm up. My warm up, I mean reach -1F.
  81. #81
    Dec 2013
    Been mainly low 30's upper 20's lately here in NY. Suppose to get 8" of snow friday and a realfeel temp of -9░. Riding 2morrow morning and maybe fri for a quick ride. Dont mind the cold but cant stand the wind.
  1. XC Threshold... Basically AM
    By mmpgh in forum All Mountain
    Last Post: 06-26-2013, 10:19 AM
  2. Norco Threshold
    By single-trac-mind in forum Cyclocross
    Last Post: 05-05-2012, 10:05 AM
  3. Cold weather apparel. What are you wearing for the cold rides?
    By masterlucasdude in forum Apparel and Protection
    Last Post: 08-10-2011, 06:42 PM
  4. Lactate Threshold Test
    By Betamaxstan in forum XC Racing and Training
    Last Post: 02-07-2011, 07:39 AM
  5. Threshold workouts.
    By fux in forum XC Racing and Training
    Last Post: 01-10-2011, 02:31 PM
