Results 1 to 54 of 54
    What is the right way to clear this?
    Ok I had to use the smilies since I do not know how to post a drawn picture. So there is a log triangle on the trails that I ride and it looks like this. I think if i just ride it over my big ring on my crank will get caught up on the top log. Its about 3 feet high. And its in the middle of some single track. It is really stap so i dont think jumping it is an option. What is the correct way to ride over something like this?
    made in Oregon
    Reputation: Goldtooth's Avatar
    that is why they make bash guards
    nathan
    WTB: Mountain Cycle 9.5 frame, size Med
    Goldtooth
    Custom Bashguards
    www.goldtoothmafia.com
    paintbucket
    Reputation: wooglin's Avatar
    When the going gets weird its bedtime.
    Aug 2005
    Use momentum to get as far as you can, then rachet the cranks back and forth 1/4 rev or so to get over.
    Keep The Rubber Side Down
    Reputation: Mellow Yellow's Avatar
    Sep 2003
    Very cool website...
    Quote Originally Posted by wooglin
    I know some beginners who could use this info
    Some of my happiest memories in life took place on my bicycles. - Me
    paintbucket
    Quote Originally Posted by Mellow Yellow
    Thank Drevil.
    Glad to Be Alive
    learn to bunny hop...
    Reputation: Drewdane's Avatar
    Quote Originally Posted by mtnbkr33
    Unweight your front fork and/or do a wheelie right as you're about to hit the logs, so your front wheel ends up on top of the pile. "Buck" the rear end and shift your weight forward while letting your momentum carry you over to the other side. Let momentum and gravity do as much of the work as possible.
    Reputation: dir-T's Avatar
    The coolest way to do it would be to endo when your front tire is at the very top, pivot off that tire into a 180, land on your back wheel (on the other side of the obsticle) then pop another 180 to get yourself pointed in the right direction, and pedal away. Smoooooth.
    Quote Originally Posted by dir-T
    I can do that! I just choose not to...
    Misfit Psycles
    Reputation: nogearshere's Avatar
    Mar 2005
    I have yet to master the rubber down landing. But I rule at the crash and burn. My goal is to crush the obstacle into submission. i am still learning the great rock crush...
    Expert of the Internet.
    BECAUSE I SAID SO
    Here's a good video on doing a log hop.
    http://www.adksportsfitness.com/apri...lumns/mtb.html
    You know, if you were really brave, you could try jumping the thing
    i worship Mr T
    Reputation: *rt*'s Avatar
    carefully
    "where are you not going so fast?" (question asked to cyclist on a trainer)
    *rt*'s fabulous blog
    mm blogging
    I always bleed like this.
    Reputation: PoorBehavior's Avatar
    Carefully? No No No, that is how to porcupines get their freak on.
    You build up some speed, then a little more, lift the front tire so it kinda almost goes all the way over the log and then you SLAM the big ring into the log. Now you really need to get in in there, like stuck in there, then you drive through. Your big chainring will act like a chainsaw blade and you cut your way right through. That's why you see all these logs chewed down to bits all over the trail. Everybody does it this way. Those bunny hopping geeks are too cool for school. Us regular guys don't have time to show off.
    paintbucket
    Quote Originally Posted by PoorBehavior
    That reminds me of how I tell people to learn to bunny hop: Go straight at the curb just as fast as you can and, at the last second, hop. Repeat as necessary.
    Occupation: Human
    Reputation: mtbnewguy's Avatar
    unlimited possibilities
    can it be done as illustrated by http://tuktok.com/loghop/ except do a 360 while in the air, ???
    you would probably have to start rotating before lift-off...
    when i was a kid freestyle was the coolest thing to do on a bike... thankfully, things have changed for the better. hahaha...
    semper ad excelsum
    Hairy man
    Reputation: Dwight Moody's Avatar
    My technique works pretty much the same, but at that point when you need to commit to rolling down the backside, instead I prefer to have a moment of grave doubt, unclip my right foot and kind of jump down and to the right, so I end up standing with one foot on the ground and the rest of my bike way up in the air with my left foot still in and my left hand still on the bar. It's actually trickier than riding it out, which exactly why I do it. Because I'm so damn tricky.
    We all get it in the end.
    Am I getting too bulky?
    Reputation: Bikehigh's Avatar
    Three feet of log pile is a pretty good pile. Depending on how steep it is, and how wide the trail is, you might want to try going at the pile at an angle rather than straight up and over. Attacking the pile at an angle will decrease the effective steepness and make it easier to deal with riding the ring over the top. A right to left attack angle is preferable for better crank ratcheting clearance. Oh, and believe it or not, doing piles like that on a riged bike is way easier than on a bike with suspension.
    I gotta roll, can't stand still, got a flame in my heart, can't get my fill.
    drev-il, not Dr. Evil!
    Reputation: Drevil's Avatar
    Quote Originally Posted by Bikehigh
    ...Attacking the pile at an angle will decrease the effective steepness and make it easier to deal with riding the ring over the top...
    This has not been my experience. I have the best results whenever I go as perpendicular to the log as possible. Whenever I go at an angle, my tires seem to slide sideways, I lose traction, then I end up stalling.
    "Keep your burgers lean and your tires fat." -h.d. | ssoft | flickr
    life is a barrel o'fun
    Reputation: Christine's Avatar
    The humane thing to do would be to affix a tiny helmet to the smiley face on top. Otherwise he'll be screaming in terror and bleeding all over your chainrings.
    We don't get many smiley piles around here, but I'm pretty sure that would be the technique.
    "We sat outside the dentist, tooting a horn on the guy's bike."-overheard in the Underground
    govt kontrakt projkt mgr
    Reputation: ArmySlowRdr's Avatar
    u asked the right way to clear it-----2 ways--1) ask a trail sanitizer 2) dismount and walk.
    I prefer option 2
    u also asked the right way to ride over it---these ways have already been mentioned. I'll just stick with clearing it by using method 2 above.
    Quote Originally Posted by Christine
    We actually have quite a few smiley piles around here and I've found that you can just ride straight through them. They'll regroup and still be happy.
    But for a log pile, just walk it. It can't be fun enough to need to replace your chainring.
    pain don't hurt
    Reputation: TurboasT4's Avatar
    the art of deception
    I've found that it helps to get off the bike, and "walk" it back and forth across the pile to get a feel for how the bike will move over it, and at which point the bike will start falling down the other side. Also you can determine at which point you will inevitably go over the bars, and be prepared for that moment by shrieking like a prepubescent girl.
    This also helps you look intellectual (the test part, not the shrieking part), like you're really studying the "proper" technique and understanding the true physics of clearing log/smiley piles. After you're done walking the bike across, you can just get on the bike and ride off without actually riding over it. It's a great way to fool onlookers into thinking that you're not really walking over it at all.
    Flowtronic engineer
    Reputation: shabadu's Avatar
    Quote Originally Posted by Drewdane
    This is pretty close, but instead of shifting your weight forward (which could cause endo) you want to push your bike out in front of you while you get back behind your seat as far as possible. If you don't feel comfortable with a wheelie move, you can get back on the bike, push your fork into the pile, it will compress and pop you a bit as your momentum carries you up and over, then push your front wheel out, get way back and ride it out. Hit it straight on, if you go at an angle the chances of you slipping increase massively, especially if its ever wet.
    I really identify with you...SO MUCH.
    "Feelin stupid? I know I am."
    "You just have to forget everything you know about gravity."
    H. Simpson
    Like so...
    Nat
    Nat is online now
    Reputation: Nat's Avatar
    Certain doom if I tried it like that.
    Lawyer Time! No Comment.
    Reputation: flyingsuperpetis's Avatar
    Nothin to it. Close your eyes, get as much speed up as you possibly can and get real loose on the bike. You'll be on the other side of it before you know it.
    Or you could do this: Clearing Big(ish) Logs
    Nothing left to lose, & half mad.
    i worship Mr T
    Quote Originally Posted by Drevil
    Like so...
    LOL!
    that's awesome.
    rt
    mm blogging
    Quote Originally Posted by shabadu
    This is pretty close, but instead of shifting your weight forward (which could cause endo) you want to push your bike out in front of you...
    True - that's sort of what I meant; I used extremely poor wording.
    Quote Originally Posted by Nat
    Nah, give it a try. It's a lot of fun! I'm not talking about hitting at at a huge angle, btw, maybe 20 degrees at most, but it makes a difference. If you time it right, you can stall out and do a bit of a track stand as your bike is straddling the top of the pile.
    Quote Originally Posted by TurboasT4
    Nah, it's always better if you go at a new pile completely blind and unaware of what's on the other side. Makes like interesting!Nothing better than getting to the top and finding that you're dealing with a drop instead of a ramp.
    Shamisen Appreciator
    I've found that by kicking out one of the bottom, weight bearing, smilies the pile usually crumbles and it's much easier to ride over them.
    Or you could start practicing your bunny hopping. Smilie piles are great for practice due to their nerf-ish consistency.
    Sean Chaney :: Owner/Builder :: Vertigo Cycles LLC
    flickr :: www.vertigocycles.com
    SS in CO
    Reputation: Jayson44's Avatar
    Aug 2005
    so...what if that log pile is 3 1/2 feet tall? kinda hard to bump the front tire off of and "bunny hop" it...we have one like that, which is why I was asking...
    are you a bike shop owner? or a custom builder? I want to talk to you about your website
    meh, that guy is riding a 29er, better clearance. But the technique is still the same for 26 wheels. Wheelie your front wheel to the top of pile and lean forward and lift your rear wheel over as your front wheel starts going down. This should be able to let your crank clear too. If the other side is realy steep, and may cause u too endo if the front wheel rolls down, i suggest the same method, but bunny hop it once your front wheel is at the top of the pile. Bunny hopping it takes a little more skill, so if your not comfortable, try it on something small.
    Quote Originally Posted by Jayson44
    That depends on how steep the walls are and how fast you're going. If you're doing it super slow speed, you "hook" it. Get your front tire on the back side of the top log and use it to pull back and down, as you jump the back of the bike with your legs...keep your hips moving forward and you're miraculously end up safely on the other side having cleared the top with your chainrings and even back wheel if you apply enough finesse and force.
    That probably makes no sense.
    (why are these things so hard to explain?)
    Time is not a road.
    Reputation: chad1433's Avatar
    Instead of rolling the backside, do you think you could wheelie drop at the top? Might keep you from endoing in the long run. I'd say doing it as some modified jump would get you over safter than trying to shift your weight. You'd just need to perfect your timing.
    Time is not a road.
    Like so...
    You win the award for having the most time on your hands
    Reviewer/Tester
    Reputation: Rainman's Avatar
    No good No ... no ... no...
    All wrong..
    Just use the big logs to perfect your Zen technique and refine it so that it becomes a finer art form.
    My personal method, as taught to me by my Zen Master, Hinata san..
    Do not think. Flow towards the log like rushing water in a stream.
    Let the log become part of you, and you part of the log.
    It is only yourself that you are now going to transcend.
    There is no log, there is only you.
    Then there is no you.
    Only Peace.
    Stillness.
    Where did it go?
    R.
    It is inevitable ...
    Hairy man
    [QUOTE=Rainman]All wrong..
    My personal method, as taught to me by my Zen Master, Hinata san.. [\QUOTE]
    Important to remember is that Zen teachers often strike their students with sticks. Evidently Hinata San developed a technique for getting Rainman to his himself in the head with log piles.
    Nat
    Nat is online now
    I've tried it before and ended up sliding sideways across the pyramid, all wiggly-jiggly. If you approach at a 90 degree angle, the bike goes over the top nice and stable instead of trying to "center" itself by moving the front and rear tires in opposite directions. Maybe I've only tried it on slippery, wet pyramids.
    I wonder how much less of an effective incline a 20 degree approach makes? I guess I could calculate it with trigonometry but I'm not in the mood and am hoping some data-type will gongulate it for me.
    Well, depending on the steepness, it's enough of a difference to allow both wheels to be on logs at the same time so you can take a moment to scrutinize what's waiting for you on the other side if you're not in a hurry. You can even change directions up there if you need to that way. There's no doubt that in most instances the straight on approach works great and might even be the only way, but it's fun to play. I was really just trying to give the OP an alternative way to clear the pile in case he, like me, has trouble jumping three feet in the air.
    Quote Originally Posted by Rainman
    Where did it go?
    R.
    That was the most beautiful log crossing ever. I have to try it...
    Nat
    Nat is online now
    There's one near here that's about that high. The way I get over it is to slow down just a hair before getting to the base, load my body up like a spring, then lunge upwards pulling the bike up the front side of the pyramid in front of my body, with a burst at the pedals to power up it if necessary. It's as if I'm trying to throw the bike over the top first, with my body following.
    Edit: I forgot to add that sometimes it helps to tap the front brake just as the front tire hits the top of the obstacle. Tapping the front brake helps get the rear of the bike up off the ground when you're trying to lunge over stuff.
    VRC Illuminati
    Reputation: Rumpfy's Avatar
    Ooh that is good!
    -eric-
    http://www.rumpfy.com
    Glutton for punishment
    Reputation: ScottN's Avatar
    Here's my .02:
    NOTE: this method works for me from years of riding East Coast Singletrack.
    Basically think of it as a short, steep up and over on dirt.
    1. Ride up to the pile with enough momentum to carry you to the top.
    2. Flow with the bike up to the top and let the front wheel roll over.
    3. Keep your pedals level at the top, if your chainring hangs on it PUSH DOWN with your front foot and you will grind over the top log on the ring.
    4. As the bike moves over the top push it in front of you to get your weight back.
    5. Ride it out.
    With practice you should be able to roll through this with minimal pedaling and no brakes. It's quite and accomplishment when you nail it right the first time!
    Here's a pic of AZMikey hanging up on a log, he made through with a pedal stroke - take a look at the front foot:
    Reputation: skiahh's Avatar
    Interesting. I've seen all kinds of trails berating people who "sanitize" the trails. I wonder what the reaction would be in this case to saying take the obstacle down. It's obviously not natural. Isn't putting artificial crap in a public trail just as bad as sanitizing them of natural obstacles?
    Just wondering.
    (please disregard if this is in an obstacle park)
    Nat
    Nat is online now
    Quote Originally Posted by skiahh
    Just wondering.
    Can you clarify what you mean when you say the pictured obstacle is artificial? It looks natural to me, because it's a tree and branches, but it obviously didn't pile up in a pyramid by itself.
    In the case of my example pic, the tree lies almost perpendicular to the trail and had fallen there in the winter, so they just built a pile of smaller logs to make a go-over rather than haul a chainsaw up the mountain to cut a hole in such a big log. The tree is 40-50 feet long so rerouting the trail would actually be worse. There are several obstacles in the Flagstaff area where enterprising rides have built big fallen trees into the trail rather than build go arounds or cut them out.
    The OP's depiction of a perfectly man made log pile.
    As oposed to the logs that fall across the trail and then people pile smaller logs in front and behind to make the approach to the bigger log more rideable vs cutting a notch or the entire storm fall out of the trail.
    Reputation: cavitykilla's Avatar
    Sep 2004
    Quote Originally Posted by ScottN
    5. Ride it out.
    Just wondering where this log pile is? It kinda looks like one of the log piles in AL. -CK
    Truffle Shuffle
    Nat
    Nat is online now
    So sorry, I still can't tell if you're referring to the smiley pyramid or to AZMikey. Your reply posted under ScottN's pic of AZMikey, so if you meant that pic, then it would be a tree that fell across the trail around which people have piled smaller logs. I rather like that type of obstacle.
    The solution that some people do around here that I don't particularly like is to chainsaw out the portion that blocks the singletrack, but only to the width of the singletrack (about 12" to 20") and no wider. It leaves the big log on either side of the trail very close to your pedals, so that you almost clip it when riding past. If it's on a curved portion of the trail where you'd lean into the turn, then your bike gets extra close to the log end. I keep imagining breaking my ankles. It ends up acting as a speed-check device.
    WOW!
    I did not think I would get this much reaction to my post. Thanks to all who have replyed.
    This is a man made triangle that has bolts or nails that hold the pile togeather. I guess it does bother me that someone has done this. But to answer your questions it was a man made log pile that is about 3 feet tall.
    This may stir up another 50 replies but do I have any right to take this log pile down?
    paintbucket
    Not really. If you can't ride it, walk it or practice til you can.
    Have you actually tried just rolling your bike over to see if your chainring will hit the top log as you go over? If it doesn't then just roll over the thing.
    WOW!
    Man made on a public hiking/biking trail system? I would take it apart.
    If it's in an area that is a stunt park then leave it and learn how to ride it.
