Results 1 to 6 of 6
    Reputation: ryan123's Avatar
    Titanium skewer on rear axle of dually xc bike?
    Salsa dont recommend putting Ti skewers on the rear of dual suspension bikes. I ride XC only with one - two foot drops absolute max and own a Salsa caballero.
    Has anyone run Ti on rear with problems, will I be OK or am i risking death?!?
    beer thief
    Reputation: radair's Avatar
    Dec 2002
    Quote Originally Posted by ryan123
    No problem, in my experience.
    As far as I know the industry in general does not seem to recommend it. However, I'm sure tons of people over on the weight weenie board do it. You might try asking over there.
    Also, you may want to consider what type of hubs you are using. I believe Chris King for one does not recommend using ti skewers with their hubs. Although once again, I'm sure plenty of people do it .
    Start slow and taper off
    And
    no ti with discs either. NO no no!
    My Artwork
    Hard words break no bones, fine words butter no parsnips.
    Trail rider and racer
    Reputation: Trevor!'s Avatar
    The recommendation is NO and most don't use them but some choose too. A good place to look at for this discussion is the Save Some Weight. You should be able to read up on the pros and (Obvious) cons of using them in the rear.
    I use good bolt on steel. Light and strong = Perfect!
    Trev!
    www.derbyrims.com
    Reputation: derby's Avatar
    Steel stretches much better
    Strength is not really the issue. Steel can break too, but it stretches and rebounds much more before it breaks. Ti will snap from metal fatigue that starts with a scratch.
    Skewers by design are stretched, which is not a good application for ti.
    - ray
  1. Mountain bike jargon/ lingo
    By bstguitarist in forum Beginner's Corner
    Last Post: 05-26-2005, 12:02 PM
  2. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  3. Salsa Dos Niner review
    By mikesee in forum Salsa
    Last Post: 12-06-2004, 11:57 PM
  4. bike for 6'5"
    By overcast666 in forum Bike and Frame discussion
    Last Post: 04-24-2004, 08:49 AM
  5. Is there a truly XC full squishy bike with Manitou SPV front and rear?
    By Greyeye in forum Bike and Frame discussion
    Last Post: 03-27-2004, 09:54 AM
