Results 1 to 7 of 7
    I throw poop
    Reputation: zilla's Avatar
    A puter question?
    I know somone here knows the answer cause I've seen it posted here.. How do you capture a pic of the browser tool bar at the top of the page?? I need to show a friend, via e-mail what to look for in the drop down menu's..
    cojones inside
    Reputation: Kley's Avatar
    Hope it helps.
    Quote Originally Posted by zilla
    Do you mean how to save a screenshot of the desktop to a file? The only way I know how to do this is to press (on a PC) Shift-PrtScn, and then use the right mouse to choose Paste (or use Edit |Paste from menu), to insert the picture in a program like Paint (comes with Windows), then save the file as .jpeg or whatever format you want.
    Kley
    I throw poop
    That didn't seem to work.. Pressed shift print screen and nada..
    cojones inside
    The image of the desktop will be stored in a buffer somewhere. You will not see anything visible at this point.
    You will see the image after you paste it in program like "Paint" or "Word".
    If this does not work for you I don't know what else to tell you.
    Good luck.
    Kley
    34N 118W
    Reputation: Hollywood's Avatar
    it's Alt + Print Screen (together)
    then Paste into Word
    Reputation: pacman's Avatar
    Press PrintScrn all by itself
    Then paste into your draw program and edit and crop to suit your taste.
    I throw poop
    Got it.. thanx!
  1. Brake response question? and Slider pressure question?
    By Gnar in forum Downhill - Freeride
    Last Post: 09-05-2004, 03:20 PM
  2. Newbie lbs question
    By joshua_msu in forum General Discussion
    Last Post: 03-15-2004, 04:49 PM
  3. Newbie Lbs question
    By joshua_msu in forum Passion
    Last Post: 03-15-2004, 10:13 AM
  4. A couple of question...
    By bike_riot in forum Beginner's Corner
    Last Post: 03-14-2004, 06:48 PM
  5. Tracer question and an answer
    By Fat Elvis in forum Intense
    Last Post: 02-17-2004, 08:10 AM
