Results 1 to 97 of 97
Thread: Night riding
    Oct 2015
    Night riding
    Anyone go alone, is it safe?
    Sneaker man
    Reputation: mik_git's Avatar
    Depends if you crash or not... Never had a problem, need some decent lights and then you have all new treails, you think you know them liek the back of your hand, till you ride them at night...
    All the gear and no idea.
    Aug 2015
    I pretty much only ride solo, and just recently started night rides. I've also started using the app road ID in the event something happens. Start the app when you start your ride and if you remain stationary for 5 minutes, it will text or email a contact of your choosing.
    EMBA Member
    Reputation: Ladmo's Avatar
    Jan 2013
    Difference is there are fewer people out at night to help you if a problem. I always figure it is as safe as the choices I make. Meaning, I leave a larger margin for error at night than I do during the day. Night riding is a lot of fun. Try it.
    Reputation: coke's Avatar
    Let someone know where you're going and an expected time you'll be finished.
    Use good lights and carry a spare.
    Slow down and don't ride at the same pace as you do during the day. If you want to get a good workout, work on the climbs and take it easy on the descents.
    You can also make it safer by riding a more forgiving bike. Full suspension or fatbikes are a lot more forgiving when hitting unseen holes or rocks than a rigid bike for example.
    Using more aggressive tires than normal can help. The weight and rolling resistance will slow you down, but can also save you when you hit an obstacle you couldn't see and weren't expecting.
    Reputation: Maday's Avatar
    Use two lights. Put one on your handlebars and one on your helmet. It will cast two different shadows, which helps with depth perception.
    - Be Someone
    Aug 2015
    I solo night ride all the time, I enjoy the solitude and the abundance of wildlife that you can see and hear at night. Familiar trails take on a different feel as well.
    Expect the first few times to feel a little...creepy. Persevere, this fades as you get used to the new sensory inputs.
    All advice given above is good:
    - use a light on your bars and on your helmet. You definitely need both to get the most out of night riding
    - keep at minimum at least one headlight spare in your pack in case you need to hike out or your other lights die on you. As a bonus, this helps when getting setup and at the end of the ride
    - don't stay out past the life of your batteries for your lights! Especially true if you are riding in the cold. For this reason I usually bring at least one spare bar light in addition to those mentioned above
    - redundancy and self-sufficiency should be your guiding principles
    - dial back the risk level a bit
    - let someone know where you are going and when to expect you back
    - mechanical breakdowns are the worst in the dark, make sure that you bring all spare parts and tools you might need, or don't venture far from thew trail head in case you need to hike out
    Professional Crastinator
    Reputation: Fleas's Avatar
    After a couple minor mishaps on night rides, I found it is helpful to know the easiest way out of the woods from any point on the course/trail. It would have saved me a lot of bungling around in the dark. (see redundancy note above )
    Have extra clothing for rain, cold, etc.
    ...and bug repellent for when you have to stop and fix a flat in the dark near the mosquito infested swamp.
    Also, probably of greater risk where I ride are the weirdos that stop by the parking lot at night. They won't venture too far afield, but they've been known to mess with peoples' vehicles.
    Other than that, night rides have been some of my more memorable and enjoyable rides, both group and solo.
    -F
    It's never easier - you just go faster.
    Momentum Junkie
    Oct 2013
    i've done it, but i don't really like it from a safety standpoint. I'm worried i could crash, get seriously hurt, and be in real trouble. plus right now it's cold.
    last summer i had a bad wreck doing nothing spectacular, in the daylight. if i had been alone at night the outcome could have been much worse. it has made me rethink some of the riding i do.
    the terrain i usually ride is fairly unforgiving and the potential for injury is constant. (I know that's not uncommon)
    some areas are very remote and a 5 mile hike out of the woods when injured would be impossible.
    it probably depends a lot on where your riding. cell service is a big plus. just be prepared for breakdowns and light failure etc. and as stated above, dial it back a notch.
    Rigid SS 29er
    Fat Lefty
    SS MonsterCross
    SS cyclocross
    all steel
    Big Mac
    Reputation: mbmb65's Avatar
    I do it all the time. But I wouldn't call it safe.
    Magically Delicious
    Reputation: Cleared2land's Avatar
    Quote Originally Posted by andersonsmog View Post
    Your question leaves too many unaddressed details about where you're riding.
    Wouldn't this question be contingent on where you are riding and the frequency of who else rides there at night? Perhaps even taking into account your riding skills and familiarity of the location that you are riding.
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
    Reputation: dagenhay's Avatar
    All good advice above. It pretty much covers everything. But I'll add a few and elaborate a couple.
    The helmet light allows you to see around corners that you are riding into, the handlebar doesn't do that.
    The tunnel vision is a good thing. It bothers some people but not having peripheral vision allows me to focus only on the trail, where I am riding. You don't need to see the tree 20 feet off the trail.
    The lights casting shadows on roots and rocks can make the roots and rocks look a lot bigger than they actually are. It can take a while to figure this out and realize the 4" inch high rock is not actually the 10" high rock it looks like. Knowing the trail you are night riding helps you figure this out.
    Another way to keep others aware of your night ride is to post it on Facebook and tag friends who you know are active on FB. Put the time when you are starting, when you expect to be done, where you are riding and that you will post again when you finish your ride. I have a friend that does this a lot, he calls it a safety post.
    If you have a dog that can keep up with you and will stay with you, take them. I ride with 2 dogs. They hear anything that's out there well before you will, then you can keep track of what is moving around you. Most of the time it is just deer, but they have keyed in on the coyote a couple of times.
    Take Gravity For A Ride
    Aug 2015
    I go all the time. You won't be going as fast as you do in the daylight and it's easier if you ride familiar trails. So I say it's SAFE and I'm over 50 yrs old. I get the what if something happens to you question all the time, because I hardly ever have my phone,and my reply is always ," I'll do the same thing that I would have done 20 plus years ago before the phone."
    Give'er!
    Reputation: MCHB's Avatar
    Jun 2014
    I go out alone at night (dusk) all the time. I do carry a phone on me, but I've never had to use it. Like has been said, make sure you have at least two lights. I typically have a light on my helmet, one on my bars and carry a spare run-o-the mill headlamp in my pack just in case. You don't have to run them both at the same time, mind you, it's just nice to have a backup in case one craps out.
    It's a lot of fun; you definitely need to be self reliant. In a lot of ways, I prefer it over riding during daylight hours. Less people, it's typically cooler out and the trails just feel more alive! So awesome to go out somewhere to check out a sunset, and then bike back down in the dark.
    Hermit
    Reputation: swampboy62's Avatar
    Depends on where you are riding.
    Around here it's safe. No wild animals are going to eat you. No murderous hobos hanging out on the trails. No trails so steep you're going to fall off in the dark and disappear.
    So for NE Ohio - yeah, it's safe.
    Where you are, it's hard to tell.
    Steve Z
    Pedaling when it's dry
    And paddling when it's wet
    My insignificant blog:
    http://swampboy62.blogspot.com/
    Magically Delicious
    The joys of riding in your 'sphere of light'.
    Aug 2015
    Speaking of a "sphere of light," few inspirational photos:
    since 4/10/2009
    Reputation: Harold's Avatar
    Wrong question.
    It is no more or less safe than doing the same activity in the same place, by yourself, during the daytime.
    Some details change, like traffic levels, visibility, temperatures, etc.
    Sometimes, night riding is the BETTER choice. You try riding in midsummer in E. Texas when it's 105F outside with 50% humidity during midday. And then after sundown when it's only 95, there's no direct sunshine, and the humidity is very similar.
    Urban trail in a rough neighborhood, and you're a woman. That'll be different than if you're a guy in the same place, or if you're in a remote place with no traffic.
    Depending on where you are, wildlife may be a concern for solo nighttime travel in the woods by any conveyance. I've been stalked by large predators in dark canyons in Utah miles from the nearest people while working. Gotta know how to handle that situation, and be able to GTFO if something goes outside your comfort zone.
    If you're talking about the riding itself, then it's fine. The key is not to be an idiot.
    Magically Delicious
    Quote Originally Posted by Harold View Post
    There you go making a statement like that.
    Might as well bring Artificial Intelligence into the equation.
    Reputation: jonz's Avatar
    All the time. There's nothing quite like solo night riding on a calm night with 2-3" of fresh powder on a single speed....absolutely dead quiet.
    Jan 2005
    Been night riding, mostly solo, for over 10 years. For me the rules are simple and most have been touched on already.
    1. Take a spare light and battery. I use a single unit that has the battery and light in the same housing for my spare. Quick and easy to slap on. I also take a headlamp for trail side repairs.
    2. In cold climate take extra clothing. I also take matches and a small amount of cotton balls to act as starter material. Soak them in a little lighter fluid, place in a baggie and they take up almost no space. Take a space blanket. If you fall and break something the ability to build a fire is a must. Never had to do it but you never know.
    3. I take the necessary tools and spares for most emergencies.
    4. cell phone - fully charged.
    5. extra food
    6. Always let someone know where you're going and that you will be calling them when getting off the trail.
    7. I only ride trails that I know well. Never explore a new trail at night. I don't necessarily go slower. I actually tend to go faster because I know the trails will be clear of others. (Won't count the one time I nearly t-boned a deer)
    8. My light setup has evolved over the years. I've owned all the major brands. tried bar/helmet setups but now I use lights on the bars only and they are my own design. I've found that if the light on the bar has sufficient spread and depth there is no need for the helmet light. I have no problem seeing around corners and I don't have to deal with the dual beams bouncing around in my field of view. Building your own lights also allows one to pick your tint. I found that the white/bluish tints that most manufacturer's use are too harsh and don't show terrain detail in correct color. They also tend to make the eyes tired.
    With the right preparation solo night riding can be exhilarating. I've seen every kind of animal at night. Nothing more exciting than bombing a trail at night with a bobcat in the lead.
    Reputation: milliesand's Avatar
    Jun 2015
    As already covered, there's less traffic, it's likely to be cooler, and any falls or mechanical issues leave you on your own to resolve. The points about having a backup (or two) for lighting can't be understated.
    If your area has large predators that see you as a potential meal you also stand that risk (although at a lower level) during the day. However, most animals will avoid you if given the chance. One of my rides takes me through an area with range cattle and evidently a bike comes upon them suddenly and can/will spook them.
    But riding under a canopy of stars? Ahhh, now THAT's interesting! I'll usually stop and let my eye adjust fully (about 15 minutes) with the lights off. Heaven, literally.
    Just Ride !
    Reputation: C.M.S's Avatar
    Riding Solo is how i roll .
    #Nightridingrules.
    Hit the trails with your bike and get freaky.
    Magically Delicious
    I have used Live Track through Garmin Connect to provide near real time tracking to whoever you are interesting being able to follow your travel. While I have experienced some phone-tower-GPS connection issues on occasion, it's performed pretty well.
    RAKC
    Reputation: tigris99's Avatar
    I go alone almost every time I ride. Ride is under an hour (on the trail) as where I ride the trails are just a few mile loop. Always have some level of cell service but mainly I make sure my wife knows what trails im going to, text when it get to trail head and text when I get back to trail head from the ride. She has gained a good idea as to time between check ins so if im late, she texts. No answer, calls. Never been hurt but I occasionally end up running into a friend or decide to take and play with cameras. So ill be out longer.
    Make sure your supplied for how long you'll be out/distance from vehicle or help. Not something I worry about as never more than a mile or so from trail head. Carry same as I do for normal rides.
    Makes sure someone knows that your going out and how long before you should be checking in.
    NEVER EVER GO OUT WITH ONLY ONE LIGHT. I dont care what anyone says ot what light you have, always have 2 fitted or at least a small flashlight in your pack in case a light fails. Its completely stupid not to (unless riding with a group)
    Oct 2015
    Well I still haven't tried alone. IDK why it just scares me lol
    Feb 2016
    Always bring a way to start a fire, and whiskey. If things go south I'm gonna start a campfire and get drunk till daylight.
    Trek Madone 4.5
    Surly Ice Cream Truck Ops
    Salsa Pony Rustler GX1
    And a couple other beater bikes.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Just got back from a nice night-ride here in Anchorage, alone. During the winter, many of our rides are "night", but that is starting to change rapidly as we are entering the season where the day-to-day change is significant. Now it's light until almost 6, at the end of the month maybe 7:30 or so...
    Of course, I go out and ride with other people and without all the time. We got bears and moose, but truthfully the bears are mostly asleep in the winter. The moose are more dangerous, but usually less active at night. Still, I have a big can of bear-spray in my pack's avalanche probe compartment that can be opened from the outside, also convenient for storing my tire pump. I have some other bail-out gear like extra gloves, handwarmers, sweater, mask, in my pack.
    Riding at night works really well when you have a situation like here: we have several places to ride that are within or on the edge of the city. That works well for night rides without making you get back way late. Rides way into the wilderness at night are less entertaining to me, as there are more opportunities to get lost or for things to go bad. I also don't care to wake up at 4am to go night riding, although I know people do in the summer in the desert. I'll shoot myself before I ruin sleeping in on the weekend.
    livin' the dream......
    Reputation: tjkm's Avatar
    I have some singlegrack I can hit from the house that I ride solo at night. If I have an issue, I am not too far from a road or neighborhood. I let the wife know where I am heading and just go for a mellow ride. No issues so far!
    Group night rides are fun, and usually involve a more spirited pace and some food/drink afterward. Look forward to those!
    I was too drunk and too much in pain to ride. Good times. - TacoBeer
    Reputation: Smilely's Avatar
    Oct 2011
    Most of my rides are solo, but for night rides I really prefer to go with someone. I feel like a bit of a wimp but I get a little freaked out alone in the dark woods with just my little pool of bright light surrounded by blackness. With a buddy or two it's a non issue and I have a blast. Some trails that are close to roads and street light it is less of an issue.
    As for safety, depends on the trail, what are the risks and how far are you from help. Be sure to have back up lights, a little pocket flashlight, an emergency space blanket, some food, extra water, extra layers. If things go bad, what would you need to get out of the woods, what would you need if you had to wait till morning. Weather and location will change what you need.
    I really don't see how solo night riding is any more dangerous or would require doing or packing anything differently than riding in daylight (beyond charging your batteries and mounting your lights of course). You really should be just as prepared during daylight rides as night rides. Darkness in and of itself doesn't change anything (excluding human and non-human predatory patterns, if that's an issue where you ride).
    I guess if you're someone whose general plan for an emergency consists of 'wait for someone to randomly show up and rescue me', you should probably avoid not only night riding, but also riding anywhere besides small crowded parks on busy days.
    Sinister Bikes
    Wraith Bicycles
    Sunday River Mtn Bike Park
    NEMBA
    Wachusett Brewing Co.
    Magically Delicious
    I have a general sense that if I go in alone, I should be equipped to come out alone. I expect no one to look after me or come to my aid unless I'm seriously injured. I have the skills, tools and the most common spare parts to accomplish just about whatever it takes to return to my vehicle unaided. I realize that things can go wrong, but I try and plan for those issues and deal with them accordingly.
    Reputation: ryguy79's Avatar
    I like it, but haven't done it in a while. Always feels like there are bears and mountain lions lurking in the shadows.
    The last time I did any night riding was finishing the last 4 miles of Slickrock under a full moon with no lights. That was awesome.
    May 2005
    Try starting out with an hour of light or so and finishing in the dark. It's easier to set out with some daylight. It takes a little nerve to set out in the dark, maybe it's something about looking down the darkened trail with pitch black on either side. Once you get moving you don't even think about it, except for all the noise (and glowing eyes).
    RAKC
    Quote Originally Posted by derekbob View Post
    At least im not the only one that gets nervous sometimes when going out solo after dark. I still love it but the pack of coyotes that is near my local trail gets unnerving when they start closing in to investigate. This season im just going to ride with headphones in so I dont have to hear them. Though my "battle bellow" turns them around lol. Would freak anyone out hearing it in the dark woods. My only other "threat" is deer and skunks.
    Jun 2013
    I ride at night solo and I love it. I don't have any large predators in my area, worst thing is vipers that are active at night, but mostly are in the grass and not in the trail. I ride with three lights, helmet, bar, and one of those inexpensive chinese led lights on the bar as well. I also keep a Fenix EO1 in my bag if I have to change a flat, fix something, etc., without screwing around with the other lights. My wife knows how to access my Endomondo program which is always running when I ride, and she knows where I am, and the local trail has strong cell and gps reception.
    That said, I do take it easy on a couple of the tougher sections, and ride more slowly on those sections than during the day. The biggest problem is other humans. Sometimes people are out on horseback, and you can meet them at an inconvenient place. They usually see me coming though because I am running around 1400-1500 lumens. The other problem is that there are areas where people come in with cars and do all night raves, and they are blasting techno music, and partying way too loud which takes away from the enjoyment. For the most part, it's a lot of fun, and I feel safe. Worst was coming around a corner a week after the rains, and I did not see the 20 foot long, 2 foot deep mud pit until I was already in it.
    In the summer here, you ride early or you ride late. I ride late during the week and early on the weekends. It's normally 15-25 miles, and I have a few different loops that I do. Some of the other guys think I'm nuts, but I am also not the only solo rider out there.
    All good until a moth flies close to your headlight. The 2 foot shadow looks like giant bat up close. Not good.
    Magically Delicious
    Quote Originally Posted by tigris99 View Post
    How ironic. The opportunity to hear all of the night sounds is the lure for me. I love to hear the coyotes, screech owls and other critters of the woods. My predominate complaint is the sound of my tires when I'm trying to hear the critters. I frequently will pull off of the trail, turn off all lights and sit silently to capture all of the sounds of my surroundings.
    In the silence, you can often hear a mouse scurrying through the leaves or a distant coyote communicating. If you're lucky, you get the thrill of hearing something larger moving through the woods. This is where the adrenaline can begin to elevate.
    Reputation: BeanMan's Avatar
    Yes, and yes. I crashed and separated my AC joint and broke my helmet one night about 6 miles from home in a no cell phone zone. So, I had to ride home. I still ride at night and by myself, just a little slower. If Zinger-UK didn't live across the ocean I might ride with other people at night more often.
    Nothing worth doing is truly safe.
    Quote Originally Posted by Cleared2land View Post
    How ironic. The opportunity to hear all of the night sounds is the lure for me. I love to hear the coyotes, screech owls and other critters of the woods. ... I frequently will pull off of the trail, turn off all lights and sit silently to capture all of the sounds of my surroundings.
    ^^^I have done this - in the daytime as well!
    My bro and I have often said you could hear the worms waking up as the sun warms the earth near our hunting stands.
    btw - a pic from my last night ride... and I lived to tell about it.
    -F
    Oct 2013
    I go alone quite a bit, mostly because it's the only time I can get out. Best part about it is the crowds are gone, the place is empty, and it's absolutely serene. I like descending in the dark much more than I do climbing. We have lots of deer in the area and I get a few carcasses that they have left. I'd say the carcasses are good because the kitty cats are full. My buddy went up and on his way back down came face to face with a large cougar. I like to wear headphones. I don't want to hear the cat before it eats me.
    Jun 2015
    This weekend the almost full Moon rises just before Sunset, maybe a good time to ease into this.
    Jul 2014
    Quote Originally Posted by Galeforce5 View Post
    I'd join the party.
    Are there any good bike shoes that are also good for dancing?
    Dec 2010
    I do a lot of night riding. Mostly on dirt and gravel in the Kisatchie National Forest as I train for the Tour Divide.
    I have two NR Lumina 750s that give about five hours of burn time each on the low setting and provide plenty of light for this kind of riding. I can charge them from my front hub.
    One is a backup.
    I have two red blinkers on the seat stays and a helmet light for reading maps and setting up camp. I also have small LED flashlight but I'm trying to cut the weight of my gear so I probably will not take it on the race.
    It can get a little creepy in the middle of nowhere in a pool of light with blackness all around. I sometimes carry a gun if I'm going way, way out...like fifty or sixty miles but generally even in the woods it's more sparsely rural than outright wilderness.
    Feb 2016
    No, not a good idea. Even if you're a good rider, anyone can come up and hit you.
    Magically Delicious
    Quote Originally Posted by griwulf View Post
    no, not a good idea. Even if you're a good rider, anyone can come up and hit you.
    wtf?
    Oct 2013
    Thanks for the valuable contribution. You can probably back this opinion up with a metric buttload of anecdotal evidence.
    Long Live the Gorn!
    Reputation: bvader's Avatar
    As I have gotten a bit more mature.. we have a few simple guidelines
    1) Be Prepared (Extra Food Clothing etc, More light than you need, Know trail well, Understand your risk profile )
    2) Don't Ride Solo unless you are really good at #1.
    3) If riding solo use the remote buddy system :
    i.e. Txt friend leaving / trail. Txt Done. Friend should understand trails.
    I like riding solo sometimes so I understand the draw, but it is a calculation. My calculation is that it is *relatively* more risky to ride night solo.You have to know your self, if you are one that struggles to control your risk.. then probably not the best idea, if you know how to manage your risk and are comfortable then ok.
    At at this stage, I pretty much prefer to ride with small groups at night, reduces some of the risks... but I still get the night experience / Zing!
    9 lives
    We did a night ride on Saturday...but tonight is a full moon which would have been a blast.
    (Thanks for the pic Slowrunner )
    The last full moon ride, we didn't need much light
    F*ck Cancer
    Eat your veggies
    Aug 2015
    I rode last night. The days are getting longer, so I actually set up and headed out in twilight, but it quickly got dark. I find the twilight period tough to ride in, your lights do not reveal the trail details as well as they do under the high contrast conditions when it is fully dark. I hit a lot of babyheads that I did not even see coming. I was on my hardtail too, so I sure felt them.
    Setting up in daylight is a huge plus though. Much easier than when it is fully dark.
    The moon was full, but too low in the sky for my ride to provide any benefit.
    Magically Delicious
    Great photos Judy!
    Magically Delicious
    Quote Originally Posted by nancy2809 View Post
    hello andersonsmog
    in my opinion its not at all good & safe.
    thanks & regards
    Why do you say this? I'm interested in hearing why you think this?
    Finally!
    Reputation: Terranaut's Avatar
    Jun 2014
    hello andersonsmog
    thanks & regards
    That's kinda lame :/
    You could at least add your reasoning.
    I love to night ride. As long as you prepare and have proper gear there is no issues.
    https://youtu.be/nAIsmEhB5Iw
    Magically Delicious
    She's from India...perhaps wild tigers roaming the streets.
    Finally!
    Jun 2014
    Then I can see how that might change things.
    She's not going to understand why I am so slow in my snow vid ..lol
    Nov 2014
    Does anyone else like to ride up without turning their lights on moonlit nights? Usually only do this on trails you know but it is fun to see who in the group chickens out and throws on their light first. Of course this only works for the climbs, descents always need the lights.
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    Quote Originally Posted by Terranaut View Post
    Haven't you ever seen the the TV show, "When Spambots Attack". Now you know why. No other reasoning is required.
    I resolve to constantly assert my honest opinion on anything and everything - whether it is requested or not.
    Bucky the Cat
    Quote Originally Posted by Big Fil View Post
    Not always.
    Sinister Bikes
    Wraith Bicycles
    NEMBA
    Reputation: Nutball's Avatar
    [QUOTE=Terranaut;12490169]That's kinda lame :/
    Terranaut,
    What camera did you use for that video? It seemed to handle the low light really well and I have been looking for such a camera for my night rides.
    Sent from my SM-G900V using Tapatalk
    Aug 2013
    Back on page 1 a user stated to wear a light on the helmet and one on the bike, but left something out...
    ... Make sure the helmet light is 1/3 to half the lumins of the bar lights. The bar lights cast a shadow behind objects on trail so that protrusions from the trail can be seen, and aid to helping maneuver around obstacles. If the light on the helmet is bright enough to cancel out the shadows the bar lights create, you will not see those things sticking out of the trail that want to cancel your wheels.
    Goodbye '95 ZJ. Just so you know, transfering box of left behind womens panties to next truck. Thank you ZJ!
    RAKC
    Pdx, I disagree strongly. But it's IMO from riding both ways. Less power on lid vs bars and vise versa.
    A helmet light would normally be for throwing light well out in front. Only way helmet light washes shadows is if you are looking down. And when riding you want to be looking well in front most of the time. As well as at least for me, my helmet light is set to point where my eyes would be looking on flat ground, not the angle of my head which is usually just slightly more downwardm So in close there is little light (just the spill). Bar light covers in close which is where your going to see shadows created correctly and where you need to see them anyway. Bright helmet light will cast the shadows just fine further out where I need it anyway.
    I came to this conclusion because the only thing a high powered bar light did for me was cause me not to be looking far enough ahead and screw with my vision because the first bit was light that moves around with the handlebars and my eyes would want to focus down on it instead of out ahead. I switch that up to more power (and proper beams, WIDE on the bars, medium-narrow spot on the helmet) on the helmet with throw and a bit of spread and the lower powered wide beam bar light and my eyes don't try to focus on the over powering bar light instead I can ride just like the day time as watch as far in front as the terrain allows.
    Also, using neutral white emitters instead of cool white makes this a lot easier because I don't have the glare problems those running cool white deal with. Aka lack of shadows cause everyone is bleached out white looking.
    Sent from my XT1565 using Tapatalk
    Finally!
    Jun 2014
    GoPro Hero 4 Silver
    [QUOTE=Nutball;12491770]
    Terranaut,
    Spherical Earther
    Reputation: Forster's Avatar
    Sep 2013
    Mentor, I find any thing but full moon pretty useless for providing contrast when riding. I have the same issue with twilight and generally set my headlight brighter then than when it's darker. When I group ride on road I get a lot of complaints about my tail flashers being too bright, off road I don't use them but it requires other riders to pay closer attention. I do use a reflective band around my camelback, but your lights have to hit it for it to work very well. I guess I could always add battery powered Christmas lights.
    The most expensive bike in the world is still cheaper than the cheapest open heart surgery.
    Aug 2015
    I agree. I prefer a helmet light that is brighter than the bar light, with a tight spot optic for throwing way down the trail where I am looking. The bar light flood illuminates the ground near my front tire so that my peripheral vision has something to work with. The light pattern on my current bar light is not ideal (I'm using Cygloite Expilion 700s on the bars), but I have 2 of them so I use both aligned to provide a wide flood, and keep them on low.
    Forster, I'm with you on adapting to twilight conditions. I usually crank the power on my lights at those times, and turn down when it gets dark.
    Nov 2014
    Quote Originally Posted by slapheadmofo View Post
    Not always.
    I guess I should have stated "on our trails, and speeds, you need the lights"
    Definitely not for every trail or rider, but riding in the dark can be a very...err..."immersive"? experience. I really dig it on occasion. Yes, speed must be kept well under control.
    Sinister Bikes
    Wraith Bicycles
    NEMBA
  67. #67
    Magically Delicious
    Interesting as it might seem, some of my faster rides have been at night. Counterintuitive might better describe the thought.
    There are some prerequisites that must be satisfied first to do this...lot's of light. You need to have enough light that you can't out ride it. If you've ever felt that your speed was limited by your light output, then you most likely understand my statement.
    While I still do not know how to explain this 'faster at night' phenomenon, I can only hypothesize that it comes from a focus that can only be achieved by minimizing your mental and emotional distractions. By this, I mean that the faster we ride, whether day or night, our focus or concentration becomes more centered on what lies before us and less on what surrounds us. We must start to subconsciously begin Ďtuning outí more peripheral distractions the faster we travel.
    At night, our world extends only to edges of our projected light. I think of it as my sphere of light. That sphere is my only reality. Whatever lies beyond it and canít be seen, doesnít exist. So, I find (or choose to believe) that my concentration becomes less distracted by what I canít see and the result is a laser sharp focus only within my reality. Less distractions, more focus, more speed. It's almost a Zen like thing. I'm not the only one that has experienced this. There are others. They exist.
    I know, some will say itís crazy to do this, but my only saving grace is that I only do this with trails Iím familiar with and have night ridden on many occasions. But on those occasions, when the mood is right I can blaze like the lightÖwithin my own reality.
  68. #68
    May 2005
    This guy must be thinking about road biking... If not, that's kinda hilarious.
  69. #69
    Spherical Earther
    Sep 2013
    I think there are several circumstances under which night riding would be faster, certainly the total attention on the visible trail is part of the equation. On my commutes, I'm not only more focused at night, but I'm also trying to make myself harder for dogs to catch. Definitely think riding gravel at night is safer because cars can see me for miles. During the day, I'm just another gray spot on a gray road.
  70. #70
    Aug 2015
    My solo night rides are always faster than daylight rides, because of the machete-wielding zombies in the woods that are always chasing me in the dark.
  71. #71
    Give'er!
    Jun 2014
    Around here, we really only have samsquanches to worry about!
    I err...probably could have explained my setup better on the first page and how I use it, but as others have suggested, I typically have the bar light aimed more downward and in front of the bike, where the helmet light is aimed farther up the trail. I usually run them both at the same output, although I've been known to run the helmet brighter.
  72. #72
    Spherical Earther
    Sep 2013
    Quote Originally Posted by Mentor View Post
    You need to watch more TV. The living wield machetes, the dead just claw and chew. I can't wait for the future when we can just use light sabers.
  73. #73
    Mar 2016
    No .........But it is safe not a dangers........
  74. #74
    Mar 2016
    No, not a good idea. Even if you're a good rider, But it is not safe.....So do not try this idea.....
  75. #75
    Magically Delicious
    Quote Originally Posted by nicolealipford123 View Post
    Geezzz....I think this is a sock account that was griwolf from India.
    You know...wild tigers roaming the trails at night that eat MTB's.
  76. #76
    Reputation: gregg's Avatar
    Sep 2000
    Hey Cleared2land, thanks for the detective work.
    "nicolealipford123" is definitely a spam account, now banned.
    Not 100% sure about griwulf yet.
    -g
    Like us on Facebook - http://www.facebook.com/Mtbrcom
    Follow us on Twitter - twitter.com/Mtbr
    Mtbr YouTube Channel
  77. #77
    Jul 2014
    Not sure why spam accounts would be discouraging night riding, I'd expect them to try to sell us lighting systems or something. If she is in India, it is probably tigers of the 2-legged kind that she has reason to fear.
    Here, the main thing I would be afraid of would be meeting a ranger and getting a $400 ticket.
    Sent from my SM-P900 using Tapatalk
  78. #78
    Surfin' da mountain
    Reputation: Cucucachu's Avatar
    Aug 2003
    My night rides seem faster. Things approach so fast into your limited field of vision and wiz by on each side. But at the end of the ride my computer always reports a slower time.
    P.S. A 7X is a pretty nice work truck - do you ever get the chance to take your bike with you?
  79. #79
    RAKC
    My times seem to be pretty constant. Just like during the day, varies based in how I'm feeling that day. At first they were well slower till I quit with the high powered bar light and did a role reversal. Way less on bars vs lid. Then things evened out.
  80. #80
    Magically Delicious
    Quote Originally Posted by Cucucachu View Post
    Nope, I haven't taken the bike along.
  81. #81
    Reputation: richj8990's Avatar
    Apr 2017
    Quote Originally Posted by Clyde250 View Post
    Sorry to bump a 4-year old thread. Whether it's dangerous or not to bike at night depends a lot on the local area itself. I feel more comfortable with the coyotes than I do with some human stranger out there that is not riding a bike. The rural areas are probably going to be 10 times safer than certain urban areas where the night prowlers and druggies are out between the trails and your car. I looked up statistics on coyote attacks (on humans) and they are very rare, maybe 1-2/year. Even if they are in a pack they know better than to try and take down an adult. They only attack other animals and maybe small children if they are starving, sick, or have been fed previously by humans.
    Now compare that with meeting a stranger walking on the trail while you are biking. WTF are they doing on the trail? If they are 50 years old and walking their dog with a flashlight then no big deal. If on the other hand they just smoked some PCP on their way to steal TV's, you and your bike could be in trouble quickly. Humans are way more unpredictable than coyotes. Besides that unlikely but real potential issue, the only other two issues at night are not seeing rocks come up on the trail quickly enough (crashing), and spiders/rattlesnakes. Not fun to go through a huge spider web in the dark and then try to brush it off and check if the spider's on you. And I've ridden by three rattlesnakes after dark, very close, almost ran over one. Since they are cold-blooded they probably don't have a lot of fight in them, but still... Bottom line is that night biking can be fun but I would ride slower and for sure stick to trails you are familiar with, ones that are fairly clear with not a lot of bushes.
  82. #82
    Apr 2017
    Depends on where you live. I live in Vancouver (Local Vancouver search guy) so biking at night isn't that bad. You just have to watch out for the genius drivers
  83. #83
    Magically Delicious
    I predominately fear the bipedals.
  84. #84
    Self Appointed Judge&Jury
    Oct 2000
    wtf?
    Best exchange of the thread.
    Great shots Judy. And C2L you really paint a great picture of what it's like to ride at night. I haven't been night riding in years, but I do recall some aspects you describe of it.
  85. #85
    Magically Delicious
    Be on the look out for tigers on the trails.
  86. #86
    Oct 2000
    Tiggers
  87. #87
    Reputation: Scott O's Avatar
    Thank you for the thoughtful post on the riding at night. I must recommend to all I know. Shop for weight loss products online in India at Elecwire. Online shopping of weight loss products, slim & Curve body slimmer, slim evolution oil, slim sauna bath, slim sauna belt, nutritional weight loss products with cash on delivery and free shipping in India..
    http://www. elecwire. com/ slim-and-beauty/weight-loss
  88. #88
    no it is not, the boogeyman comes out at night!
  89. #89
    Reputation: Zomby Woof (MCM700)'s Avatar
    Yes, I've gone alone a couple of times.
  90. #90
    Barely in control
    Reputation: Schulze's Avatar
    Feb 2007
    The parks around here close at night. I think I would need night vision goggles to be stealth.
  91. #91
    Jul 2014
    Quote Originally Posted by Scott O View Post
    SPAM SPAM SPAM SPAM
    Get thee hence, vile spammer !
  92. #92
    RAKC Industries
    Jan 2017
    Since it was mentioned, I night ride solo more than not. Around here the only thing to worry about is skunks. Home trail nothing to worry about, seen kids out just after dark thinking they can hide and piss themselves when I come flying around the corner. After dark park is closed. We have outside access and permission to mountain bike after dark. So I have the trails to myself anytime.
    Another in the area that's open to night riding but chances of a bipedal that's a problem are between slim and none. The second one down that way is smaller, in a decent area of the cities but get some morons out there occasionally. Havent ridden it after dark, asshats had to tag the brand new signage with spray paint which was annoying so figure after dark will be restricted to with friends only.
    Final one and my favorite is special permission only. Their pretty lax about it though. If your a club member and call to ask the have no issues, or in my case I just have permanent permission (Ranger has my vehicle info and plate numbers). Biggest threat there is Deer, only because they stand in the way in the worst possible places. Had a couple close calls with stopping a few feet short of a face full of deer a**.
    Night riding is a BLAST even solo if you don't ride in a city where you have drugs and gangs to worry about.
    Life on a bike doesn't begin till the sun goes down.
    US partner for Ravemen:
    www.rakclighting.com
  93. #93
    Feb 2006
    Quote Originally Posted by RAKC Ind View Post
    I'm much the same. There are a few coyotes around the trail system where I do most of my solo night rides but they don't worry me. No skunks or mountain lions or bears to worry about. There is the occasional moose but I encounter a lot more of them in the day. The odd time I see a few teenagers near one of the trailheads but I don't fear them at all. I just say hello and continue on my way. It's not like a few drunk kids on foot could catch me if I put the hammer down anyway.
  94. #94
    Dec 2016
    I'm always mountain biking alone even @ night. I thinks it's safe as I'm quite familiar with my route and terrain... sure it'd be nice to have company but I'm a loner and enjoy solitude when I ride. Night time feels actually safer because I can bike on the roads n streets and see cars coming further which directions than daytime because of their headlights. Also less people in general out n about so I can bike on pathways with out worrying about pedestrians. Win/win
  95. #95
    Co Springs
    Reputation: bachman1961's Avatar
    Oct 2013
    Never even thought about night riding until a few years ago, getting out with some guys that ride weekly starting in the evenings. When riding with them, I'd usually cut out a bit early since I'd had enough of a workout and I didn't have a 'proper' light anyways. I kept up enough to enjoy the rides but they were all a bit more extreme in skills and levels of trails , high end bikes etc.... Good group, just a bit beyond me at the time.
    It got me back to riding though and now I get out with some others. Been a number of weeknight evenings starting about one hour before dark and riding back at about 45 min of total dark. Def fun and challenging and I have a worthy light.
    I do miss the big picture of the horizon so the focal point at night can tend to put me a bit more off balance a times in the tech stuff. Not really a complaint, just a bit of the fun and challenge. I'm sure that changes with a second lamp as I know some run the handlebar and the helmet light, one more of flood lamp coverage.
    Seems like night riding may be popular also just from the standpoint of those that can only ride after work on weekdays and not want to fuss up the weekend family time or other commitments.
    As for safety other than the animal kingdom, I think even in areas where you feel safe riding alone, it's good to remember that crimes of opportunity happen often and spur of the moment.
    When you are out there with your light on, your profile is readily identified by anyone within sightline distance meaning they know where you are and you are very likely alone unless riding with another who isn't operating a light.
    In the Middle Ages, the biggest mistake was not putting on your armor because you were 'just going down to the corner.'
  96. #96
    Nov 2006
    I was in India a few years ago. We had to return to another city 200km away and my hosts told me it was unsafe to drive at night.
    We left the next morning at sunrise and it was complete carnage on the road.
    Trucks turned over on their sides and one had hit an elephant.
    The roads aren't very good and they drive insane, honking the whole time.
    You'd have to be crazy to ride a bike on any busy road.
  97. #97
    RAKC Industries
    Jan 2017
    Quote Originally Posted by bachman1961 View Post
    My night riding is usually done on trails in very rural areas so nothing to worry about there.
    One trail though is on one end of a park that the other wide borders not a great neighborhood of the city it's in. I carry a knife or 2 on me when I ride out there. Usually never any issues but a couple weeks ago there were several riders/runners/hikers there and some trash went through smashing windows to steal stuff. And that parking lot is on the good end of the park (side where there are small farms and nice houses). Happened in broad daylight.
  1. Night riding?
    By Mattntp in forum Hawaii
    Last Post: 07-25-2015, 12:29 AM
  2. Went riding last night.
    By buckfiddious in forum Fat bikes
    Last Post: 10-02-2013, 07:13 AM
  3. Night riding with a dog?
    By homey in forum Arizona
    Last Post: 09-09-2012, 05:58 PM
  4. Night Riding
    By bedell99 in forum Colorado - Front Range
    Last Post: 02-02-2012, 11:11 PM
  5. Night Riding?
    By vinnyl26 in forum California - Norcal
    Last Post: 09-29-2011, 02:38 PM
