Results 1 to 6 of 6
Thread: Hitch for rack?
    Reputation: NorCAMBA Prez's Avatar
    New question here. Hitch for rack?
    I need to have a hitch put on my Pathfinder for a rack. Nissan charges a couple hundred $$ - I figure that's so I can tow a boat or something. Anyone know where I can get something lighter duty and cheaper for a bike rack?
    Reputation: glenzx's Avatar
    Quote Originally Posted by NorCAMBA Prez
    Lot's of aftermarket hitches out there.
    You'll want a class III / 2" receiver set up. Search for "Hidden Hitch" or "2" receiver hitch" and most sites / catalogs have a vehicle finder interface. Most all hitch set-ups can be a DIY project.... bolted mine to my 2000 cherokee and did the wiring in about 2 hours. Got the hitch and all the hdwe. I needed from etrailer.com, but there are lot's of dealers out there.
    DO NOT let U-Haul install a hitch for you, BTW, as they typically are BUTCHERS. I had an old grand wagoneer that they had installed a hitch on before I got it, and they had cut the FRAME and the exhaust pipe brcket to fit the dang hitch in place!
    Lastly, look into all the different aspects of hauling a trailer. Check the owners manual for rear differential fluid change, as it usually requires a heavier wt. oil, and usually recommends synthetic at that.
    If you've got an auto. trans, look into a HD trans. fluid cooler. With a Manual tranny, clutch wear is accelerated, so if you are in need of a clutch soon, get an aftermarket performance/HD unit....
    Lastly, with trailers, make sure everything else in your truck is in good shape, like brakes and suspension.
    As for bike rack add-ons, 2" receiver is more stable than the litle 1 1/4" style.
    "It's better to regret something you HAVE done, than something you haven't..." -
    rbtm member
    You can pick up an aftermarket 1 1/4" hitch for about $100 and install it yourself. That would probably be fine if you just want to carry a couple bikes. A 2" hitch is only about $50 more. I find my hitch incredibly useful for hauling all kinds of things since trailers are so inexpensive to rent.
    ali'i hua
    Reputation: SlowSSer's Avatar
    Quote Originally Posted by Mr.Bob
    the entry lever offerings from thule and yakima are about 150 bucks.
    Mtb Bum
    Reputation: Erik's Avatar
    JC Whitney had some for around $100. Go with the two inch hitch. If you want to haul more than one or two bikes at some point, the two inch hitch will allow more flexibility.
    contains quinine
    Reputation: Debaser's Avatar
    my reciever hitch was installed by a local welder. pretty darned cheap. i found him searching this old thing called "the yellow pages."
    Take the long cut, we'll get there eventually.
  1. Best car rack for DH bikes?
    By Freerider in forum Downhill - Freeride
    Last Post: 03-26-2004, 07:06 PM
  2. yakima racks
    By joshua_msu in forum General Discussion
    Last Post: 03-05-2004, 03:10 PM
  3. Saris B.A.T. hitch rack... anybody use one?
    By SLinBend in forum General Discussion
    Last Post: 03-05-2004, 12:27 PM
  4. Rear rack for 3 series Beemer?
    By happybiker in forum General Discussion
    Last Post: 02-02-2004, 02:28 PM
