    Jul 2014
    Help front shock broke
    Hey guys when I got my bike I noticed the blue adjustment knob for the dampening on the front shock would spin around counter clockwise only when the shock compresses I brought it to the shop and they said the knob was loose and tightened it up I was on the trails today and this happened what do you guys think do I need to get it rebuild or is that only when fluid and air leaks Help front shock broke-image.jpg
    Reputation: onlycrimson's Avatar
    Nov 2008
    You need to use an Allen key to take the blue dial off. Then use a socket or wrench to tighten the cap back down. Then you can replace the blue cap. It may have just come loose, but I suppose could be stripped.
    Are you saying that the entire top cap assembly just popped out of upper leg while you are riding? Was it getting loose or did you notice before you start and kept riding? If it was totally threaded in before the ride and it happened, then your thread maybe totally stripped. If that's the case, then your forks maybe done unfortunately, not much you can do after top cap assembly strips. Not saying that's what happened, but the shop may have stripped it and didn't tell you.
    Either way, better close up picture of the thread may give us a better idea...
    This has nothing to do with Passion. Try your luck here...
    Shocks and Suspension
    *2018 Pivot Mach 5.5 Custom Build*
    *2018 Orange Alpine 6 Custom Build*
    *2017 Knolly Warden Custom Build*
  1. i broke my brain (rear shock specialized epic comp)
    By jkmacman in forum Shocks and Suspension
    Last Post: 12-08-2014, 09:01 AM
  2. Replies: 23
    Last Post: 07-24-2013, 08:54 PM
  3. Lower Shock Mount Bolt Broke on 2011 5.Spot
    By Falldog in forum Turner
    Last Post: 05-09-2013, 09:06 PM
  4. What the hell didi I do? (think I broke my rear shock)
    By Krellmachine in forum Shocks and Suspension
    Last Post: 10-04-2012, 12:33 PM
  5. Tooth broke off my front middle chainwheel after 6 rides!
    By Michaelmcgo in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-24-2012, 01:08 PM
