Results 1 to 5 of 5
    DIY: Thule bike tray 2 to 4 extension for $30
    Extend your Thule 2 bike tray to a 4 bike tray for only $30
    So basically what you are doing is joining 2 Thule bike racks together
    So the key ingredient here is to have a friend who also has a Thule (2) bike tray and join them together, instead of paying the 350.00$ for Thule's extension you can make your own for 30$.
    everything you need, also a drill will be necessary
    2- Thule (2bike) bike trays
    1- 32" 12gauge 1.5 square tubing
    2- 32" 3/16 x 1-1/2 flatbar(shims)
    1- 6 1/2" x 2 square tubing (trailer hitch tubing)
    4- Bolts 3"long 11mm Zinc plated, washers and nylon threaded nuts.
    raw materials...look for a steel shop in your area
    STEP 1
    start by removing one bike tray from its hitch
    STEP 2
    There is a small screw on the bike rack that needs to be removed with a screwdriver. insert 32" long square tubing with shims all the way into bike rack square tube.
    One thing I noticed is if you push this square tubing all the way in until it stops you wont be able to fold your bike tray up, so back the square tubing out just a bit so you can pull the lever to fold your bike tray up.
    connector tube inserted
    showing here both the racks on 32" connector tube with the extra stout square tubing that will eventually slide between the two racks to add extra support and prevent any kind of freak bending.
    STEP 3
    Drill holes Tighten Bolts
    Put all pieces together make sure the internal connector tube is where you want it within the square tubing of the joined Thule bike racks. As you drill your holes insert and tighten the bolts to keep parts from shifting...Drill 2 holes into each bike tray and make sure these holes go through the internal connector tubing as well...Insert bolts and tighten firmly, I also added some locktite but may not be necessary with the nylon threaded nuts.
    showing where I drilled my holes and the additional square support tubing between the 2 racks, The stout square tubing support just floats between the 2 racks...depending on how you have your trays mounted you may have to shift them slightly to allow for enough room between racks...I had just enough room between my 2 racks for the 6 1/2" long square support tubing and a bolt.
    once the bolts are tightened it will be very solid
    VERY satisfied with the results for such an easy DIY project...The rack was put to the test this weekend on a 6 hour road trip 80mph+ highway speeds, driving though cities, curbs, bumps etc. But the real test came driving out to the trail heads on bumpy rocky fireroads, the bike rack did not even flinch. Super solid design would highly reccomend for the DIYers out there.
    for any of you who have driven up to the Gaucomole trail in Hurricane UT. you know how bumpy that road can be...the rack handled it all like a champ!!
    This works great for times when you have a group of 4 wanting to do a road trip or run odd man out shuttles...once you are done everything can be unbolted and the trays put back on their own vehicles. the only thing you are left with 2 small holes drilled in your rack.
    Nice job. I plan on fitting a cheap hanging rack tonthe end of my thule. Almost like ising the thile as another reciver. The good bikes will get the thule and the rest will get the $30 used haning rack lol
    beer thief
    Reputation: radair's Avatar
    Dec 2002
    You should change the title of this thread to "DIY ...[snip]...$30 plus another $350 rack (that you need to dismantle)".
    Seriously
    Quote Originally Posted by radair View Post
    Seriously
    Well the idea is that "you" and your friends already bought your racks some time ago and do not have to pay that extra $350 dollars for an extension.
    If by dismantle you mean removing 2 bolts, thats about 2 minutes of hard labor. And once the initial setup is made the whole thing takes about 5 minutes to bolt up.
    Dont worry, I learned by now the mountain bike community is a hard crowd to please
    Hey dmar123
    Very cool. I had the same sort of thought. Glad to come across your post.
    I was going to try some 1 3/4 steel box tube for the insert and matching 2" box tube for the extension. Then just bolt the bike trays to the 2" box steel extension. By my measurements, it should be a nice tight fit. Might need to grind the inside radii a little. Might mig weld the 1 3/4" insert to the extension or just through bolt it all.
    What do you think ?
    Thanks,
    Peter
  1. Thule just released the new wheel tray's
    By gcappy in forum Fat bikes
    Last Post: 01-15-2014, 06:20 PM
  2. Need 2 bike Thule Extension
    By nicksstorm in forum Idaho, Montana, Wyoming
    Last Post: 09-21-2013, 11:29 PM
  3. Anyone with a Thule fork mount tray for sale?
    By goalieman24 in forum Virginia, WV, Maryland, DC, Delaware
    Last Post: 09-06-2012, 02:05 PM
  4. Cutting Thule tray to fit brake calipers
    By cave12man in forum Cars and Bike Racks
    Last Post: 06-09-2012, 05:34 AM
  5. Thule T2 extension
    By istvisinet in forum Arizona
    Last Post: 07-26-2011, 10:37 AM
