Results 1 to 31 of 31
    how heavy are you ??
    Reputation: Scottay5150's Avatar
    this is cutting into my passion!
    any constructive thoughts?
    thanks much
    Attached Thumbnails Attached Thumbnails this is cutting into my passion!-mri-results0001.jpg
    What does Marsellus Wallace look like, A BIT*H?
    Jan 2013
    My back always feels better when I get to ride. so maybe ride more!
    2012 Salsa Horsethief
    2015 Salsa Mukluk3
    Re: this is cutting into my passion!
    Quote Originally Posted by JHFWIC View Post
    My I have big numbness in my calf/shin. No pain in the back. This isn't something I can just shake off. I wish I could.
    Sent from my SCH-I605 using Tapatalk 2
    Jan 2013
    Are you riding a FS?
    If you are not, thats your #1 way to still ride but beat your back up less. If you already are? Man.... that sucks bro. When you rehab do core work, stronger abs = stronger back.
    Reputation: telemike's Avatar
    I've had three surgeries on my lower back; the first two were older "cut em open" type surgeries and created problems that were (more or less) resolved by a more recent arthroscopic surgery. I still have some pain and there have been three other serious exacerbations that didn't lead to surgery.
    I'm having the most pain free period of my adult life recently. I credit mountain biking for the improvement.
    Physical therapy for herniated disks aims to strengthen the band of muscles across your stomach. I found that pushing the mtb up long hills tenses this muscle band and has greatly strengthened it. No, I'm not kidding!
    Beyond this, I have no strong advice other than to avoid chiropractors, gravity boots, and other duck noises (in my opinion) and get opinions from several surgeons. The more modern laminectomies are done by arthroscope and leave a lot less collateral damage (scar tissue). Also, I know many more people that had unsatisfactory experiences with spinal fusion operations that ones that came out great. Fusion is one to avoid unless you have to have it.
    Don't lift stuff, especially heavy or clumsy stuff - ever! Get help lifting. Don't run, keep your stride short walking and skiing to avoid rotating your hips a lot. Take the bottom with your special friends; the top requires a backwards curve of the spine that greatly aggravates disk problems.
    Also, certain medicinal herbs that block the CB1 and CB2 pain receptors are more effective at blocking referred pain for me with less side effects that the standard medicines like norytriptlene, neurontin, etc.
    Good luck and keep riding!
    mtbr member extraordinair
    Reputation: Stupendous Man's Avatar
    I would love to see the results of an MRI done on my back!
    But, I'll second telemikes comments above. I've never had surgery, but mtbing has definitely increased my back strength over time - and definitely pay attention when lifting things. Do it right, never twist, never rush it. One setback will put you down for a looooong time. One thing I'll add - pay more attention to your core strength - crunches and leg lifts etc. And listen to your body. I tend to know when my back is just not feeling up to doing much, and I wont push it, even if it means missing a ride.
    Good luck buddy, and know you are not alone!
    Grit, spit, and a whole lot of duct tape!
    Apr 2013
    Buy one of those big rubber exercise balls and google core workouts for them. I can't recommend them enough. While I've never had the leg numbness, I did have severe recurring lower back pain that has all but completely gone away since using one of these. These exercises get your large muscle groups balanced and working together again. Good luck.
    Reputation: dbhammercycle's Avatar
    I've had back pain for several years, starting in late high school after a round of squats, on the warm down no less. Anyway, the advice here is pretty sound. Work on your core, stretch, don't lift anything incorrectly, and relax when the back tells you to. I've found that yoga has helped me quite a bit. I like the movement in some of the poses and it helps with small muscle control. I've also heard the Tai-Chi can help for the same reasons. Warm-up a little before trail rides with a lap or two in the parking lot. Ibuprophen can help a little as it is a muscle relaxant, just don't assume that it fixes the issue. If you take some time to strengthen and stretch, your back should still give you years of good trail riding.
    I don't know why,... it's just MUSS easier to pedal than the other ones.
    Reputation: MSU Alum's Avatar
    Don't you think that a question about multilevel degenerative disc disease and biking would be better directed to your doctor rather than a bunch of guys you don't know on a mountain bike forum?
    I think he's just looking for others with similar issues to chime in on their experiences. He should certainly listen to a doctor or physical therapist rather than us. However, having others thoughts could improve the quality of the conversation he has with his doc.
    I don't know what he's looking for other than advice. If he uses it to enhance his dialog with his doctor, great. If he does anything physically that is recommended on the forum without discussing it with his doc, he's asking for trouble. Unless there's someone on the forum qualified to read the results of his MRI, which is pretty unlikely.
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    What do you think? Is there pain? Is it manageable/sustainable? is it something youve been able to work through or has the condition got worse from riding? Ive had to ask these same questions due to a shoulder that continues to get worse and right arm that goes numb b/c of a MTB neck/serious concussion yard sale some 8 years a go.
    Reputation: dirtyjack's Avatar
    I have a persistent lower back pain that I keep at bay by core exercises and using an inversion table that helps ease spinal compression. Hip flexors also pull at the base of the spin. Many cyclists have tight flexors. Stretch them babies.
    SantaCruz Tallboy C
    SantaCruz Solo C
    Specialized Fatboy
    Trek Madone 8
    Kestrel RT 700
    Lemond Zurich
    Jan 2013
    You should try going to a chiropractor for a few months. You might be able to still ride and not make the problem any worse, depending on the cause of the herniation and the degree/longevity.
    Avoid riding while taking medication for the pain/numbness. Those symptoms are there for a reason and if you push it you will make it worse.
    Dec 2010
    Quote Originally Posted by dbhammercycle View Post
    Amen. This is absolutely the best advice. Avoid, as if your life depended on it, getting trapped in the circle of doctors, pain medications, and surgery.
    Not to say that surgery isn't sometimes necessary but if you have a hammer, everything is a nail. Likewise if you go to a surgeon they are predisposed to do surgery whether it's the best option or not. Many routine back surgeries are unnecessary and lead to even more surgeries and complications. A good surgeon knows when not to operate.
    We are a terrifically overmedicated society and the majority of medical care dispensed is either unnecessary of of only marginal benefit.
    In regard to the MRI report, even people with no back pain have disk bulges and abnormalities in their spines and the findings of imaging don't always correlate to the location and severity of symptoms. Take with a grain of salt.
    This!
    Quote Originally Posted by jrm View Post
    No pain, just numbness. Doctor visit is today.. Physical therapist said more than likely surgery would be suggested by Dr.
    Dec 2010
    Quote Originally Posted by santiagomo87 View Post
    No no no. Real medical doctors are bad enough without resorting to quacks. Chiropractors are absolutely not qualified to diagnose or treat disorders of the spine. Their medical training is slipshod and, reiterating that if you have a hammer you will nail, cracking your back is not always the best thing to do.
    If your back problems are not severe enough to warrant seeing a real doctor (a Neurosurgeon or an Orthopedic Surgeon), I'd recommend a good massage therapist or common sense things like stretching or back exercises.
    Quote Originally Posted by Ailuropoda View Post
    That is a bit over dramatic. Chiros can provide a good deal of pain relief. However, they tend to treat only the symptoms. There was a time when back pain and discomfort prevented me from sleeping at night. After 2 months visiting a chiro, I was sleeping again without issue. Would I have gotten better on my own? perhaps, but Im pretty sure it wouldn't have happened as quickly.
    Dec 2010
    Quote Originally Posted by Stupendous Man View Post
    Confirmation bias.
    I have a cold. Idiot doctor gives me antibiotics. I get better. Antibiotics cured the cold.
    Seriously dude?
    Confimation bias - Ive never been to a chiro, all chiros are idiot quacks.
    When its your back or body, treat it the way you feel is necessary.
    Jan 2013
    I am a Chiropractor and believe me, during my 5 years of training I am more qualified to diagnose the spine than an MD. I don't want to go off topic but please don't go bashing other's professions when you clearly don't know what you are talking about.
    However, you do speak true words Ailuropoda in regards to avoiding medication/surgery.
    Perhaps you had a bad experience with a chiropractor. As with any profession, there are people who are good at it and people who are bad at it and since the spine is such a delicate thing you definetely don't want to go with a bad one. Cracking your back can be as good as it can be bad depending on the cause.
    Dec 2010
    Seriously dude?
    I don't think you understand confirmation bias.
    I had back pain. I went to a chiropractor for two months and, mirabile dictu, my back got better. Would your back had gotten better on its own?
    Jun 2012
    I used to hit up the chiro all the time, didnt do much long term, started doing massage therapy, WOW way better results, back pain is not always your spine doing funky shit. your muscles can cause way more pain then you think. I have been dealing with a back injury sine I was 13, a fractured vertebrate that will never heal. I was told never to roller skate, skate board do any sports or i could break it and be in a wheel chair the rest of my life. After 2 years I said **** it I am taking the chance, done everything plus. Been hit by a car head on on my motorcycle, crashed more times then I care to remember on the MTB over 20 years. Sometimes what they say is a some what educated guess, I guess I beat the odds or not but I wasn't sitting on my ass any longer. Do I still have pain hell yeah, hurts everyday, its amazing what you can get used to. If it does ever let go at least I enjoyed my life till that point, no regrets.
    Giant XTC 2 29er
    KHS Flagstaff 29er FS
    Neon Bow Trials Bike
    Norco Fluid 9.2 29er FS
    Norco BIGFOOT FATTY
    Here's the update. Blown out disc pushing on nerve. Not gonna help to shoot it up, disc repair. The disc needs to be pulled and the vertebra need to be fused. The repair would work temporarily and blow up again.. Not what I wanted to hear.
    Reputation: nightops's Avatar
    Dec 2004
    Can you walk? does it kill you when you ride? i'd avoid that procedure unless i was absolutely hobbled...anything non invasive to help that situation would be be my response until i could go no further. I got a sciatica two years ago and had an mri done. My doctor at Cedar sinai suggested i go with therapy first and i'm glad he did because the pain went away with physical therapy and stretching. Now i know how to stretch the problem area and what i must do to keep it from happening again. good luck with whatever path you end up taking.
    Reputation: kope007's Avatar
    Mar 2013
    I feel for you brother. I had surgery in 2007. Post basketball game had pain for several days which turned into my leg being 75% numb. Usually when you have numbness that doesn't subside in a few days surgery is going to be recommended unless you just want to live with it. I couldn't walk up a flight of stairs. I waited for 3 months, but no improvement. They only had to remove a portion of my disc to relieve the pressure. No more numbness but I still have no reflex in the leg. But I've been doing everything I always did, albeit a little more cautiously.
    Good luck to you.
    Quote Originally Posted by nightops View Post
    Issues walking, loss of strength is not good for biking... I have no pain. The numbness and power loss is what I need back...
    Quote Originally Posted by kope007 View Post
    Good luck to you.
    Did you get the strength back?
    Bollocks
    Reputation: Surly Gentleman's Avatar
    Aug 2010
    ... a lifetime of competitive rugby, coupled with getting hit by a car going 50+ mph and finally poor posture whilst lifting, gave me bulging and herniated discs, bone fragments and a crumbling vertebrae. i got to the point i couldn't walk, stand, sit or lie down without being in agonizing pain. a steroidal epidural relieved the pain for a week. sometimes surgery is the only option. if thats the route you take, research your neurosurgeon and anesthesiologist well and get it done before your quality of life deteriorates. i had the fronts of two discs "trimmed" so they would stop pressing on my sciatic nerve, the bone fragments and debris removed and the crumbling vertebrae and herniated disc left alone. its only a matter of time before these two things deteriorate to the point i need a fusion. in the mean time, i've strengthened my core, i stretch every time i go from sitting to standing and if my back is feeling stiff or sore, i take it easy for a day or two and it loosens on its own. apart from the occasional stiffness/soreness, the only lasting issue is nerve damage in my leg which is a minor problem. the only major drawback is i can't use clipless pedals because i can't turn my leg fast enough to unlock my foot!
    good luck.
    You only live once but if you do it right, once is enough.
    Mar 2013
    Quote Originally Posted by Scottay5150 View Post
    For the most part. I never rehabed like I could have. I would say its @90% of my other leg. I'm able to do everything I did before; basketball, softball, flag football. But my game has changed a bit. Have to be more of a crafty veteran than just a pure athlete. But that probably has just as much to do with age and family life catching up to me.
  1. Cutting a seatpost?
    By fongster in forum General Discussion
    Last Post: 12-31-2011, 12:52 PM
  2. Replies: 78
    Last Post: 11-09-2011, 06:02 AM
  3. Tires not cutting it
    By gemini9 in forum Beginner's Corner
    Last Post: 05-11-2011, 06:01 AM
  4. cutting trails
    By sm4k in forum Trail Building and Advocacy
    Last Post: 02-28-2011, 06:43 AM
  5. Cutting stem?
    By Eville140 in forum Frame Building
    Last Post: 01-05-2011, 05:08 PM
