Page 2 of 2 FirstFirst 12
Results 101 to 184 of 184
  1. #101
    Reputation: bgfthntr's Avatar
    I had a Grade 4 in 1998 and had two surgery's to fix it. I popped out the screw from the first time around because of my own impatience and started using my arm. Second time around the Dr. put a band to hold the clavical is place. It's still there and the shoulder works great. Considering my degree of separation I was able to get 99% motion out the shoulder. I can even throw a baseball still. It took some time to feel comfortable on the trails again.... I was a bit spooked from getting hurt again.
  2. #102
    Reputation: Blurr's Avatar
    Dec 2009
    lol well **** long as it is revived I may as well pipe in now, I dislocated my left shoulder nearly 20 years ago now, I decided not to have surgery, and lived with quit a bit of pain and a shoulder that popped out constantly, so much so that when I was fighting (did some kickboxing) I could not jab with my left or it would pop out, finally now, it still pops out somewhat, but I have always had full use and still do some pretty heavy lifting with weights.
    Just ate **** two weeks ago and probably strained my clavicle on my right shoulder, first day really sucked, things were moving around and you could feel it, second day it was not so much pain so I merely limited my mobility and dealt with it, two weeks later it is only sore when I am laying on my side, seems to be working alright so no doctors yet. Im old school, if possible I think a person is better off working through things. lol now I know after reading this thread what that bump on my shoulder is, oh well, its going down.
  3. #103
    Ugh week 3 and I'm still using a sling...
    Went to physio this morning.. they're really seeming like the most pointless people ever.. they do a little lazer and tell me the EASIEST exercises which span from rotating my elbow to applying a little pressure on my shoulder.. Tells me I should finish them in a week.. I literally have gotten it half hour ago and I can do them all without any pain...
    2 things I've been wondering...
    1. Is it that easy to re separate it? Alota people here have said this hasn't been their first time doing it.
    2. When has everyone else stopped using their sling for a grade 3? Like its been 3 weeks and a day and I'm pretty sure I can cope without the sling but apparently my physio wants it on for ANOTHER 3 weeks cuz he rathers it be stiff then work on stretching it rather than letting it get loose and having no way of stiffening it... It really seems pointless though... this sling feels like something I'm wearing but to no point. Like a silly hat but on 24/7.
  4. #104
    Dec 2009
    Quote Originally Posted by killing_it
    I have no Idea what mine was at all, but and I never used a sling, I just minimized movement with it, but yea, I still used it.
    Doctors and the like will always go a bit extra on the careful side do to insurance reasons as well as just to be careful.
    these are some very good exercises to strengthen your shoulder, Im not going to be so arrogant however as to say it should be something you should do right away.
    anyhow, hold your arms out straight, palms up, do slow rotations forward and backwards. Also just doing shoulder shrugs helps as well.
    edit
    IM also going to step out here and while the separation of my left shoulder I never did anything with it, I was still able to build it back up and bench my max 350, at that point you could feel it moving out again.
    Lateral press was close to 300 as well since then. Not saying that is something you want to go for, just saying its possible to build yourself back up.
  5. #105
    Disgruntled Peccary
    Reputation: dysfunction's Avatar
    I've re-separated mine (both left and right have done it). I'm gonna hazard a thesis that since they're pretty easy to damage the fist time, once you've done damage it'll be easier to separate.. depending on how bad your damage was in the first place..
    I've always gotten mine out of the sling as soon as I could stand it comfortably, course that will also be situationally dependent.
    mike
  6. #106
    I dream on two wheels
    Reputation: Simonns's Avatar
    Quote Originally Posted by dysfunction
    I didn't think you could re-separate an AC separation since once you tear your ligaments they don't grow back. Hence the bump on the shoulder. I would think that you might be more at risk of breaking your collar bone after already separating your AC.
    Unless you guys are talking about actually dislocating your shoulders.
    Whiskey
  7. #107
    Gnarley!!!!!
    Reputation: Burtonrider250's Avatar
    Separated my shoulder back when I was 16. Required surgery.
    It's never been the same
    I can no longer weight lift how I used too. Real drag, but I guess it could be much much worse.
    "I saw a guy crapping on the side of a very busy trail"
    -Unkownrash
    -08 Yeti 575
  8. #108
    Disgruntled Peccary
    Quote Originally Posted by Simonns
    It'll depend on the severity of the injury. You haven't completely torn a grade 1, 2 you've only torn the AC, not CC ligaments etc.
    I've dislocated the shoulder as well.. I'll take an AC separation any day
    mike
  9. #109
    Keep the sling on! You want to immobilize the shoulder for at least 6 weeks. This is how I popped the crew out out mine and had to have a 2nd surgery. Take your time and do it right. It will be stiff for awhile unitl you go to PT and they work it free.
  10. #110
    Feb 2010
    Snowboarding Grade III
    I just separated my right shoulder this past Saturday, Grade 3. Snowboarding. Glad I found this post, it really helped reading about other people's experiences.
    My two cents:
    1) You can't re-separate if you've had a grade 3. Once you rip the tendons they're done for. they do not grow back.
    2) I just got back from my ortho appointment, I went to a very top notch doctor in Manhattan. He is supposedly one of the best in the country, and all the signed photographs from professional football/baseball people on his wall made me believe it. He told me to ditch the sling already (this is day three), you are only hurting recovery by keeping it immobilized. He also said he doubts I will need surgery, and that he only recommends it for people who really need full use (like baseball players). I pressed him about this and said I didn't like the idea of living the next 50 years having detached parts. He said after 4 weeks of PT I will barely notice a difference. Surgery is always an option, but I don't hurt anything by waiting. I have a follow up in a month, he assured me that at that time I will be fine. Reading other posts here I am beginning to believe it.
    I guess I'll have a hump for the rest of my life. Oh well
  11. #111
    Feb 2010
    Although I'm not a MTB, I am an avid snowboarder and I needed to find a forum about AC grade 3 separations. On Christmas just a month ago I had a nasty fall off a 15ft cliff, which resulted in an ac grade 3 separation. I remember feeling dazed and nauseous after the accident. Luckily, I had enough energy and coordination to get down to the first building at the base of the mountain. I was taken by the ski patrol to the clinic where I was driven to the ortho 40 minutes away by my father and brother. I was warned about the controversy surrounding surgery, but still opted for it. I was told by many that I had the best shoulder ortho surgeon in the valley and was in good hands. Its been a month since the surgery and I've been out of the sling for a week now. It is starting to feel great besides the bitter cold of winter that cools the metal in my shoulder. Otherwise, recovery is going well! I will take the metal out in May will be eager to work out again! Here is a pic of the shoulder before and after surgery.
  12. #112
    Feb 2010
    3rd Degree AC separation
    I tripped and fell at Christmas time in Puerto Vallarta ( ya, so I had had a few two many margaritas ) not exactly the way I would plan this, but I had it x rayed when I got back home. Family practitioner said x rays showed 3rd degree and put me in a sling. Two days later I saw the orthopedic surgeon. He said "get of out the sling and start using it". I asked how much and he said, "your body will let you know when you have gone too far". As for surgery, I opted to have it, the bump seemed enormous, and I feared being limited in workouts and actually, at anything I did. But I didn't like this surgeon, so got a second opinion from a surgeon who specializes in sports medicine and shoulders. He also said I could live with it, but I said no, cut me open. Surgery was two weeks ago, I am in a sling for 6 weeks, and the screw that is connecting things will be removed in a second surgery in 3 months. Cadaver hamstring was used saving me getting cut on twice. After the screw is removed, I cannot workout for 5 months. I can hardly tell where the incision is, the suture job ( all underneath the skin) was done so well. I know I have a long way to go, but I have never doubted my decision to have surgery.
  13. #113
    Reputation: jkad's Avatar
    Dec 2005
    I separated my right shoulder oner the bars a few years ago, still have a cool bump, then this happen Kayaking this Oct. The Dislocation was way more painful.
    Attached Thumbnails Attached Thumbnails AC Separation Grade III Recovery-arm11.jpg
    "foot to pedal, wheel to dirt, there is no substitute for the act of riding "
  14. #114
    Lol holy s***, I never knew your arm could drop that low with a dislocation.
    Just keeping people up to date. Its now officially been 6 weeks, my physio said I could slowly start taking it off today in intervals.. however... I took it out of the sling 3 days earlier thinking there wouldn't be much harm, there was no pain whatsoever for me but now theres a giiiiiiannnnt bump, like defiantly bigger than it was before, on my shoulder now. I suppose if thats it its not too bad, it just feels really awkward more than anything. Still range of motion is limited, and certain exercises like rotator cuff exercises are REALLY painful. Its like the joint freezes up all together.
    Who knows if it would have made a difference if I kept it in a sling for the full 3 days but I guess its something ill live with.
    I ended up buying a "rugby ac joint' brace near where I live which specializes in sports injuries. Its just a neoprine material that wraps around the one shoulder applying some pressure on the ac. I dunno how much it actually pushes down, I suppose its more for padding and confidence than anything else, but when I have it on it practically feels like my shoulders pretty normal. I guess I'm gonna wear that under my shirt till I feel like its unnecessary, then only when I'm playing sports.
  15. #115
    Grade 3 Shoulder Separation
    Quote Originally Posted by JJ_n_Houston
    I also suffered a grade 3 shoulder separation going over the bars trying to get around a n00b on the trail during a race and high sided my pedal on a root. pitched over and separated the right shoulder. That was 3 yrs ago. Like you I was in a sling to see how it would heal. Wasn't getting the range of motion and strenght back after 3 months and opted for surgery. Had one of the best docs in ATL. do a modified weaver dunn procedure on it. He specializes in shoulder injuries and works on a lot of the pro athletes in ATL. He had the autographed photos on his wall also. Besides mtn biking I am also a competitive 2-man sand v'ball player. (Used to play semi-pro back in the day) Still play open and A level. It took a full year of rehab, working out and rebuilding the strength but I'm a 100% with what I have left in my right shoulder. Pushing the same weight I was in the gym prior to the separation. Playing v'ball again. Back on the bike and raced last yr. in the 12 hr series on a 4-man team. (we won the point series) Shoulder aches on occassion from playing v'ball but that could be overuse to.
  16. #116
    well
    this is becoming a theme. don't mean to overrun this biking board with snowboarders, but it appears we suffer common injuries. i actually registered for this board today because i was interested in reading about mountain biking and i stumbled across this thread. i actually just suffered a Grade III AC joint separation 9 days ago at Windham in the Catskills trying to do a rail grind. not a smart idea. my x-ray looks nasty as well, just take my word for it.
    the replies on this post really say it all, some do well with surgery, some don't. this is the first injury of this type that i've ever suffered and to be honest...i expected worse. i'm now 9 days removed from a Grade III and i don't need my sling at all. the doctor at the mountain gave me some medieval-looking harness to wear, but when i had my shoulder re-examined by a doctor in Manhattan, he told me i didn't need it (thank god).
    i can move my shoulder through most of my pre-injury range of motion with some stiffness and pain. sleeping is annoying. i snore like a freight train when i sleep on my back, yet that seems to be the only comfortable position. my poor wife - she has been trying to shove those pain meds down my throat all week so i can sleep well (and, in turn, she'll be able to sleep well), but i have no interest in narcotics.
    i'm due back to my orthopedist in about 10 days. i hope to be ready to start PT at that time. i don't really care about the bump (after all, i'm not a runway model), but i DO care about loss of function. if i'm not able to gain full range of motion and strength back, i'll have to consider some other options. but after reading this thread, i'm even more optimistic that full recovery can be achieved without the knife.
  17. #117
    Quote Originally Posted by mjake4479
    I did both of my shoulders snowboarding. Both grade III. I'm about 8 weeks in on my second one. Its still sore when I lift things and reach across my body. However, in the last couple days if feels like things are moving a lot more inside. When I move my shoulder you can see the collar bone moving and popping. It hurts a little and feels really strange. I'm wondering if there is some scar tissue building up or something. I don't remember if my left shoulder did this when I tore that one. Thanks.
    -Simon
    Whiskey
  18. #118
    Because I am !
    Reputation: outdoornut's Avatar
    Aug 2005
    6 to 8 weeks is about right, however you won't be 100% for several months. I would notice some pain 3 to 4 months later when doing a bunny hop or after several hours of riding. But it's back to normal now. The bump will be there unless you get surgery. My specialist advised they have more trouble with arthritis down the road after surgery and recommended I just leave it alone.
    I feel for ya, just follow the docs orders.
    ODN
    Caffeine ! "Do stupid things faster and with more energy" ! !
  19. #119
    Dec 2005
    graphic pic.
    Here is my arm 24hrs after surgery. Very sore, on the road to recovery!
    Attached Thumbnails Attached Thumbnails AC Separation Grade III Recovery-arm2.jpg
  20. #120
    I haven't posted on MTBR in ages, but I caught this thread and wanted to chime in. I suffered a Grade 5 AC separation last year, right about this time. March. I was in a moto accident, swerving to avoid a truck that turned in front of me. I was lucky. The accident happened a few blocks from home. I pushed my bike back home, and my roommate took me to the hospital, down the street. I was totally fine, save for my messed up shoulder.
    Went to see an ortho soon after, who gave me the option to have surgery or not. I was informed that in my case, I could wait and see before deciding on surgery. Taking into account all of my activities: Climbing/bouldering, MTB, Snowboarding.
    That was a year ago, almost to the day actually. I have not had the surgery. During the first few weeks I was in a sling, but able to go to work and do normal things, just one handed. After about three weeks or so, I started doing physical therapy to get my range of motion back etc. Pain was manageable, nothing too bad. I pushed it though, within a safe range. I figured, more effort and pain endured during physical therapy would mean better results for me later.
    So, here I am, one year later. I'm mountain biking, and bouldering. Carrying on with my normal activities. I do experience soreness at times, but for the most part my activity now is pretty much the same as it was before the injury. I have the bump, but it's not horrific, at least to me.
    I am able to do pushups, pullups etc. Haven't really lifted weights or anything like that, but I didn't really do any of that before the injury anyway so that's fine.
  21. #121
    I jointed this forum just to post on this thread! I don't have a shoulder injury but rather a shoulder deformity that I have had all of my life (but just discovered when my shoulder hurt so bad I thought I would puke) - there is a hook on the AC bone/joint, and that hook will press into my rotator cuff at times, causing pain. The more I use it, the worse it gets. The doctor said to just be careful, that it will not cause harm to the rotator cuff, but I need my shoulder! Anybody dealt with this issue? Thoughts on what to do aside from not using it too much?? I do swim and am very careful with the shoulder and form.
  22. #122
    Well, it has been some time since my last post. I had a grade V separation in June '09. I was 57 at the time. After consulting an ortho-surgeon I opted to have surgery. The separation was about 1-1/4" and all 3 ligaments were shredded, the end of the clavicle was poking through the muscle tissue.
    A hook plate was installed to hold the joint in place. Due to the trauma involved in maneuvering the joint back together, there was a considerable amount of pain after the surgery. I was up and about in two weeks for easy rides. After about a month, the swelling in the shoulder went away, but the joint became more susceptible to pain in use. As time went on, the presence of the plate became more and more noticeable.
    After the allotted 6 months, I had the plate removed and the recovery from that surgery was just a matter of a few days. The joint is now held together with scar tissue. The shoulder dropped a little with the removal of the plate, but I have no noticeable bump.
    Today, 4 months, after having the plate removed the shoulder feels OK. I have full range of motion and the shoulder feels stronger everyday. The only ache I get is when I sleep directly on the shoulder, but even that is becoming less as time goes on. I have not done any physical therapy other than to just use it as much as I can tolerate, per the doctor.
    It was an easy choice for me to have the surgery. A bump is one thing, the sharp end of the clavicle messing with poking through the skin is another. Also, the joint is now separated with scar tissue and so that should prevent any future arthritic conditions of bones of the joint coming in direct contact with another.
  23. #123
    Hey so its me again, haven't posted in awilllllllee, but just to say how my shoulders been after a grade 3 separation. So however long its been from my last post (at least over 5 months-ish) my shoulder literally feels totally normal again. Minus the bump on it, I don't notice it at all. (If you wanna be pickly theres a small 'clicking' sound when I rotate my right shoulder fully but thats about it.) There was some pain when I got my sling off whenever I worked out for the first couple weeks but that went away, now that I'm out of school for the spring/summer I work out practically everyday minus the days when I have rugby practices. (yeah I play rugby too and it doesn't bother me at all taking a hit, or giving one, on it or anything). So basically its back to normal again! This was just to sum up my experience with the injury, I never got any surgery just weekly physio and I'm glad that I did!
  24. #124
    Aug 2010
    Ok, first time poster. What's up?
    Got surgery tomorrow morning to put my shoulder back together.
    Yes I mountain bike AND snowboard, but my grade III sep happened on my 22mph electric skateboard, I'm 45 and have been ripping around on this thing for 9 years with zero falls. I broke two of just three rules on Wednesday. Rule #1 Helmet(always), rule
    #2 No flip flops(broke that one), and rule #3 keep your eye on the next 30 feet of road(Oops). False confidence in a smooth familiar stretch of road that grew a new pot-hole.
    Thanks to everyone who has taken the time to toot thier experiences. I have opted for the surgery and I'm gonna be somewhat of a guinnypig with some new technology. I guess they drill holes through the clavical and the acromi, thread this synthetic material through both, attach to a button underneath, draw them together like rethreading a broken baseball mit, and put a button on top. This method requires no second surgery to remove hardware and is done out-patient. I will keep all you crazies posted on the result.
    Wish me luck, never been under the knife.
  25. #125
    Reputation: sooner518's Avatar
    Quote Originally Posted by Rickhopper
    That sounds really familiar to the surgery my friend had for an AC seperation about 2 years ago. Not to freak you out, but it was unsucessful (I think the material tore or something) and he ended up having to have a 2nd surgery with a plate and screws about 2 months later. After the first surgery, his doc seemed kind of ambivalent about him riding and told him he could ride a road bike like 2-3 weeks after surgery and if he coul stand the pain, mountain a few weeks after that, which he only did once, although he did ride his road bike alot around town.
    long story short, he had to have the 2nd surgery and went through alot more extensive rehab and this time, the doc said absolutely no bikes for like 3 months. im not really sure what exactly went wrong the first time.... anyhow, good luck and dont push it too soon!
  26. #126
    Reputation: Noclutch's Avatar
    Jun 2010
    25 years ago I went OTB big time on a dirt bike, grade 3 A-C I think. Had a sx where they tighened everything up with suture materials, cut the end of the clavicle off, ran basically a big ole lag screw through a hole drilled in the acromion and into the cut end of the clavicle. THE POST OP PAIN WAS AWFUL for the first couple of weeks It was much better for the following couple of months and even the GF had to be on top for this period, and even that was sorta uncomfortable, but I was OK with that LOL
    So after 2 or 3 months? the screw was removed, a short period of light home unstructured rehab, and was back to racing HS within a couple of months. Everything is hunkey dory at this juncture, racing all this time and take my share of get-offs and no further pain. Got a lump- who cares- no pain and only very minor decreased range of motion( can't reach my left shoulder blade with my right hand like the other side)
    Part of my decision to have sx when I maybe could have avoided it- and this is the take home message- as my doctor explained, is that you can not have arthritis if there is no "arth", no joint= no arthritis, which I have none of. Something to consider for those on the fence about sx.... YMMV
  27. #127
    Life is Go0d!
    Reputation: mo0se's Avatar
    Those suck... had my share.. twice!!
    The only regrets in life, are the risks you didn't take.
  28. #128
    Aug 2010
    I just wanted to say thank you so much for sharing your experiences guys! Joined for this thread only. Had a grade 3 on my left shoulder about a month ago at Hafjell Bikepark here in Norway. I thought "Oh well, they´ll fix me up" but my to my surprise the doctors took a bunch of x-rays and sent me home. With less than no information I´m sitting here contemplating having to sell my Intense M6 and dropping out of twin-tip skiing because of this injury.
    I don´t have much pain, but I do get some lightening bolts through my shoulder from time to time when I stretch or when I try to open/close the car door. Had some really bad cramps in my shoulder muscles that hurt like Hell, but thankfully they´re gone now.
    I am amazed that this is it.... That the doctors go "Well, that´s life, we don´t advice you to operate but to make the best out of it..." After all the garish accidents I´ve seen my friends go through, with broken bones and crap like that ... I wasn´t expecting to be told that I was going to have a bone pushing against the skin on my shoulder for the rest of my life. It´s not the cosmetic part that is my issue, but the fact that I have a "rogue" bone in my body and that anything I wear rubs against it and keep it sore. I´m a skinny guy so the bump is pretty visual. Showed it to a female co-worker and she had to sit down
    But what do you guys recon. Is a AC degree 3 damage a career ender or what? Did you just recover and jump back on the horse?
    Thanks again for all the good info!
  29. #129
    Dec 2009
    almost 9 mos since I had My accident, have no Idea the grade as after reading this thread i never bothered to go to the doctor until a month later, I had the classic bump and it felt loose, but it just stayed sore, I nursed it and used it a bit more and more, month later when I went in the doc said it looked good and to let pain be my guide, No bump any longer and Seems fine so far *knocking on wood*
  30. #130
    Aug 2010
    Hey Roller Coaster,
    My grade III separation happened on 8/4/10, my surgeon went in and cabled me back together on 8/9/10. The pain prior to the surgery was manageable with some ibuprofin, but the post operation pain was indescribable for 4-5 days, today all I do is ice it a couple times a day.
    My shoulder is right back where it was before my accident. Doctor says everything will re-attach if I follow through with his orders.
    Doctors orders after reconstruction: Keep shoulder strapped to side of body, let gravity make it fall away from your body only to dry after shower and to apply deoderant, no lifting, reaching or swinging that arm for 6 weeks. After which I can start therapy. Don't know what that entails yet, my six weeks aren't up till the begining of Oct.
    The repair itself included a four inch/15 staple opening on top of my shoulder, a couple holes in bones, a cable with a hook on bottom and a button on top. Pretty cool.
    Any body that says they had anything worse than a grade III, have your doctor call my surgeon who has been doing this for decades.
    I will let you know how things are progressing, I can't wait to get back in my kayak and on my surfboard. Yippy Kayay!!
  31. #131
    injured reserve list
    Reputation: Scrub's Avatar
    Well I had my surgery in March but it didn't end up as well as the Dr. said it would. The wires came loose and the rods ended up coming loose and didn't hold anything in place. Total waste of 6 months, now doing PT. My county hospital sucks, thats what happens when you don't have insurance.
    I only had the x-rays done at Sierra the closest ER near downieville, surgery back in the bay area
    Attached Thumbnails Attached Thumbnails AC Separation Grade III Recovery-xray9.jpg
    You're not entitled to anything until you work hard and earn it. CMQ
  32. #132
    i had a stage II separation in 05 and my shoulder aches a lot. Probably because I was playing college lacrosse at the time and did not let it heal right. I am pretty sure there is some arthritis going on in there now. I still don't sleep on the injured shoulder as it will ache in the am. The shoulder also tires very slowly when throwing objects for a period of time.
  33. #133
    Nov 2008
    picture of my step pre op
    This was 5 years ago. General practitioner called it a grade 2 and the surgeon called it a definite 5. Looks normal now, but will always be kinda "crusty", especially when a low pressure system moves into town. This is road rash and I got thrown head on into a car while going downhill. Hence, it is pretty ugly. Paid for my masters degree, tax free, and I got a couple bottles of vicodin. Fun times! Biggest bummer is I'll never surf like I used to. Way to crusty and awkward paddling, kinda burns. Doesn't affect riding a bike at all though.
  34. #134
    Aug 2010
    Looks like that damn tape tearing your skin from the bandage was the worst part, just kidding. I will keep you all posted. I have a feeling that if my surgery works out, my doctor is going to get a lot of business. Keeping my fingers crossed and my arm strapped down.
    By the way, that could be my x-ray, my incision, and I will be praying for all of us.
  35. #135
    Jun 2010
    How can you live without any surgery after this accident ? I had this too, AC 3, and i´m very happy that i had a operation. My shoulder looks better,i feel better and i think that i´m in balance with my shoulder.The doc told me that i can live with this accident without surgery, but i have to workout my shoulder until the rest of my life to get no osteoarthritis ?
    I had my ACIII back in 1988, surgically speaking they were still dancing around fires and painting on cave walls. Faced with a huge scar on my shoulder from a Navy doc or taking my chances with just physical therapy I took the PT and never regretted it. I do have arthritis and I don't bench press much (push ups and dips instead) and I still don't sleep on my left side but everything else is good. If I hurt it again today I would probably opt for surgery. A co worker had it, tiny little scar, good drugs and much better surgical techiques sort of made it a no brainer.
  36. #136
    Reputation: Minimalist's Avatar
    About 4 years ago I had a type III separation. The doctor told me, surgery may or may not be successful. He also told me that there is no conclusive evidence that arthritis (if developed) is coming from the bone rubbing against skin or the actual accident. Finally the doc said, if I develop any problems that there are ways to resolve any issues even after years. I opted against surgery and am fine. I can do everything without any issues today.
  37. #137
    Reputation: waterdogs's Avatar
    Jun 2010
    Man, there is a lot of this going around. Here's my wife's Grade 4 from Aug 19, fixed on Aug 26. I don't have pics of the staples as it's under the bandage. I'll take a pic of it on Fri when she gets them pulled.
    Attached Thumbnails Attached Thumbnails AC Separation Grade III Recovery-img_9239-copy.jpg
    Media Manager - Coming Soon
    Press Relations - Team Billy Goat Bikes - Mountain Khakis
  38. #138
    Shaman
    Quote Originally Posted by RollerCoasterVictim
    I
    No! Both my shoulders have 3rd Degree AC separations and I still race downhill at 44! They do take a while to feel good though.
    Skills coaching loved by passionate riders of all levels and trusted by the pros.
    www.betterride.net
  39. #139
    Jun 2010
    Quote Originally Posted by BetterRide
    @ BetterRide.... How long is that? So my wife knows what to expect.
  40. #140
    Jun 2010
    Quote Originally Posted by NoWake
    I did a grade 3 a little over a year ago. It's still not 100% and I'm sure it never will be. I followed the PT religiously and didn't ride for probably 6-8 weeks. It still feels like it's going to pop out whenever I get knocked forward on the bike or over 300 lbs on the bench etc. All of my workout symmetry is out of whack.
    At this point I'm really thinking I should have went against the ortho's recommendation and did the surgery...I'd take a scar and 95% over a big bump and 80%. I don't see how a Dr can say you'll be 100% when your whole shoulder geometry is out of line...
    Of course, drilling a couple of holes in my shoulder and tying it together with a peice of my hamstring didn't sound that great either
    I saw one negative reply about the surgery as well...anyone else go through with the surgery? What were your results?
    I smashed my shoulder on July 20th of this year. Here is the xray:
    I had surgery on August 10th. My doc feels that with this type of repair, I will have a better chance at a full recovery. I start therapy in two weeks. Here is a xray of the repair:
    I have to return in approximately 6 months to have the plate/hook removed.
    I haven't been on my bike since and it's killing me. He talked like the recovery time is considerable, but wouldn't give an estimate. I'm surprised that it's taking so long for the pain to subside.
  41. #141
    Shaman
    Quote Originally Posted by waterdogs
    I think it depends on your age, how healthy you are and your pain threshold. I was 21 when I separated my left shoulder and I was snowboarding 5 days later (but in pain) I was 32 when I separated my right (dominate arm) shoulder and it took 2 months before I could ride mellow trails comfortably. Hopefully yours starts to feel better in less time.
    www.betterride.net
  42. #142
    Two grade III here as well, no surgery on either of them.. I'm riding more than ever, no pain, a little popping here and there.
    Whiskey
  43. #143
    Jun 2010
    Just from my wife's personal experience, be a little careful on the Grade 3 decision not to do anything. The Doc said that the Xray told him that it was a 3 and gave us the option of doing nothing or fixing it properly. She decided to let him work his magic. When she came out of surgery, I told me it was actually a 4 in his opinion as the clavical (sp?) was pushed back in to the muscle and would have caused more problems long term. Just food for thought based on our experience.
  44. #144
    I had a grade 3 about 4 years ago from a skiing accident. They said it was a "classic" example of a grade 3 that didn't require surgery. I ended up doing some PT and I was back rock climbing in 50-60 days. It was before I rode. I don't have any long term pain or anything else besides the bump of pride/shame. My wife and daughter both call it the alien that lives on my shoulder.
  45. #145
    Ok I guess I will play this game. I am just under 2 weeks into my injury time out, suffered a Grade III AC Separation on my left shoulder practicing for a DH race. Pain at the time was incredible but I somehow managed to drive myself 60 miles home and then to the ER. Xray didnt look good at all, first they thought my collarbone was broken then someone said my AC was separated. Orthopoedist confirmed a Grade III about 3 days later.
    The doc I saw is the team ortho doc for the 76ers. We went through the option of tightrope surgery or no surgery. I had already done a significant amount of reading prior to my appointment so I knew that if surgery wasnt necessary I wasnt going down that road. He said I could do either but that he has only had one tightrope where the clavical didnt move at all afterward and that studies have shown that Grade III's have just as much a chance of full recovery with or without the surgery. Since its my left arm and I am right handed, he agreed with me that he wouldnt do it unless I wanted to for cosmetic reasons. I can live with a bump on my shoulder, I named it Kuatto. I am seeing him in about 2 weeks, at that time he'll assign me to PT. He told me to get out of the sling as soon as I could handle it.
    About a week into the injury, I was able to take my arm out of the sling. Today I have the sling with me but I am not wearing it at work. The pain is gone, certain movements do feel uncomfortable but not painful. My shoulder feels weak but I can tell the strength is coming back every day, ROM will take a while since I can tell there is some decent scar tissue buildup already that will have to get broken down. I am hopeful that I'll make a full recovery and be back on the DH bike in about 5-6 weeks, just in time to race the last race of the season and try to hold my top spot in the series overall.
  46. #146
    Reputation: charging_rhinos's Avatar
    just did mine two weeks ago. Grade 3 and my collarbone was sticking up a full 2 inches above the rest of my shoulder. It's a bit gross to have to push your won bones back into place, but it felt a lot better after I did.
    Anyway, it's healing surprisingly fast, although I'm sure it feels better than it actually is internally. Going to get in the pool next week for some very light stretching and a bit of muscle work, but overall, things are going rather well.
    just ordered an EVS SB04 shoulder brace to help things along a bit too. Should be here soon
    tangaroo: What electrolytes do chicken and turkey have again?
    rck18: All of them, because they're meat.
  47. #147
    Quote Originally Posted by charging_rhinos
    Let me know what you think of the SB04. I have been researching tons of different products and need to pick something that I will run for DH. The SB04 looks good but I am concerned that it'll need a supplemental pad for the AC area.
  48. #148
    Reputation: chas_martel's Avatar
    Quote Originally Posted by zon
    So I will never be 100%. That sucks.
    Yes it does suck. I had an Grade III AC Separation 2.5 years ago and my shoulder has never been the same. 4 months after the injury it felt fine, fast forward a couple of years and
    the pain is back as well as this funny disconnected feeling in my shoulder.
    Crap, I sure don't want surgery. Hope you get better soon.
    Nobody cares...........
  49. #149
    Aug 2010
    Same here! The SB04 looks very interesting. But the thing is that I have no idea how this brace+shoulder bump will work with my Dainese armor. Just the thought of the armour rubbing against the bump gives me the chills.
    Still it looks way more promising than the other "Robocop" versions.
    Please do give us your thoughts on the SB04 if you can
    Regards
  50. #150
    Jan 2009
    Thought I'd share my grade 3 AC separation story, which occured on May 9th this year. I'm a roadie, not an MTB'er (found your forum while searching for lights for night riding) and was involved in a head on collision with another cyclist at a local park. I was pulling off the front of a paceline when a guy on an cruiser type bike came around a curve wide left towards me, leaning on his handlebars, not paying attention. Several of us yelled and I hit the brakes, he never seemed to see us until he nearly hit the guy in front of me, then slammed into me handlebar to handlebar. I had slowed from 23 to maybe 15 or so, he was probably going the same speed. The impact was hard enough to completely break the top tube of my aluminum bike and severely bend my downtube and I fell over on my right shoulder. The other guy kind of laid there for a few minutes muttering something about not riding without a helmet again, then while everyone was tending to me and the huge lump in my shoulder, he got on his bike and road off.
    Anyway, my son meets me at the park and loads my broken bike and me into his car and takes me to the emergency room. The doctor comes in after the x-rays to tell me I have a grade 3 shoulder separation and gives me a sling. Prescribes hydrocodone for the pain and ibuprofen and ice packs for the swelling. First few days (especially the day after) were pretty uncomfortable. I was able to drive my car (6 speed manual) after two days but had to use my left hand to put it in reverse. Decided to wait longer to do that again. I kept my arm in the sling (and developed a nasty under arm rash...) and the ibuprofen/ice pack regiment up. At the ER doctor's recommendation, I made an appointment with an orthopedic sports specialist in Irving (TX) at a center that treats many of the Dallas area pro athletes.
    I went this past Tuesday (May 17) and met with the specialist. He took some x-rays and noted my range of motion (I was able to raise my arm level with my shoulder) and my grip to access muscle strength. I'm not the typical 130 pound zero upper body mass roadie, I did a lot of lifting when I was younger and he said that helped limit the severity of the bone movement. His x-rays showed the collar bone had dropped significantly in relation to the x-rays on the evening of the accident. He then said it would be best for me to simply to ditch the sling and go back to my normal routine as the pain allows. While he would love to do the surgery on my shoulder (says it is his favorite operation), he didn't feel I would gain any additional strength or mobility with surgery and my recovery would take longer. 3 days now since that appointment and my range of motion has definitely improved and the pain has noticeably lessened. My son said the bump is barely noticeable now and both shoulders are at the same height.
    I hope to be back working on Monday (I have a detailing business, hence my user name) and I think the motions of washing, buffing and waxing cars will provide some pretty good PT for my shoulder. I already have a new frame for my bike and plan on swapping everything off my old bike to the new frame sometime late next week-don't want to put it together too quick because then I know I will be riding it then
    I go back for a follow up in the middle of June, I'll post how that appointment goes and what my progress is. FWIW, I'll be 50 in a few weeks.
  51. #151
    Jan 2009
    Just an update. I haven't been back to the specialist yet (next week, I guess) but my range of motion almost 5 weeks after the injury is pretty good. No problems raising my arm over my head or supporting my weight as I lean across cars (like I said, I'm a car detailer) or using my buffers. Still have some pain that mostly occurs when sitting down, typing, using the mouse or eating right handed. It is lessened if I maintain good posture and slumping over a bit makes it worse. Has anyone else experienced this? Otherwise I am about 95% pain free at this point.
  52. #152
    Aug 2010
    Thanks for the update Scottwax! I smashed my shoulder in august 2010 and suffered a grade three. Now I have no pain, but it feels like my shoulder/arm is slightly tired like after the first day of skiing. I haven´t touched my downhill bike since my accident. It is all in my head, I know that, but I have to trust my own body before I drop in again. I get some pain now and then. It feels like when you have used your ok arm and carried a heavy bag of groceries. The bump on my shoulder is highly visible, but it looks worse after heavy carrying. But the summary is: Mor or less no pain, 90% power, visible bump, phsycological issues regarding the accident. Else everything is ok.
    I have been told NOT to do surgery, BUT I was told that if I started to experience pain there was a spanking new procedure they could do. It was all about harvesting ligaments from the back of the knees and using them to tie the shoulder back down... Not sure about that one... happy for now!
    Oh! And also, my insurance payed out 8060 usd Told my girlfriend I was going to buy a new downhill bike. She told me to go to Hell and stay there...
    The best of luck with your shoulder! I guess the best thing is that we are not suffering from too much pain as this is for life or untill they start harvesting ligaments from stem cells or something
    Happy trails!
  53. #153
    Jan 2009
    Good to hear you are doing better. I still have some occasional soreness, usually if I buff more than 1 car in a day but it is more of a temporary dull ache than anything really bothersome. No problems on my road bike. Got back on my bike on June 14th, put 2500 miles on my bike since.
  54. #154
    I have a grade 3 separated right and grade 2 separated left. I've had no surgeries and I feel fine. I can say that its important to stay in good shape so your muscles compensate where the ligaments left off.
  55. #155
    Oct 2011
    ScottWax, I have the soreness/knots in neck to back of shoulder when sitting at computer. Did this diminsh over time with you?
  56. #156
    Oct 2011
    Waterdogs, How long did your wife wait before deciding to do surgery? Did she do PT at first?
  57. #157
    Dec 2011
    Scottwax,
    Did you have numbness and tingling in your hand? Did it ever go away? I have a grade two i think.
  58. #158
    Dec 2011
    I had a grade 2 in Oct. 2010 I was feeling fine after the initial healing process and then last week without doing anything I started having pain and way less mobility. The pain feels like a nerve. I'm a bit worried. I don't want surgery! Anyone try massage?
    What the hell? Anyone?
  59. #159
    Jan 2009
    No numbness or tingling that I remember.
    Still have some minor soreness if I sleep in my right side or lift something heavy with my right arm. However, bench pressing, rows, lat pulldowns, flys and triceps extensions don't cause me any pain.
  60. #160
    If your injury is anything like mine was, you're going to be hurting from it for a long time. I was back on my bike after 7 weeks but wasn't able to do hard riding for 12. 9 months later, if I push too hard, I hurt for days- that includes non-biking activities. I didn't have the $$$ to do what was recommended to me by the surgeon which was massage therapy on the area after the initial healing phase. Good luck to you and your healing!
  61. #161
    Jan 2009
    I don't hurt for days when I overwork my shoulder, more like a few minutes. What is weird is about the 15-20 mile mark on my road bike I feel some soreness in the shoulder, but after 20 miles or so, it goes away. Just that 5 mile window. Go figure. The specialist didn't mention any need for massage therapy, he just said to get my arm out of the sling and use it as much as the level of pain would allow. Hard part was sleeping upright for about a month and on my back for another few months. Now as long as I keep a pillow under my right arm, I can sleep on my stomach. Sucks that it seems I will have to make at least some allowances for my shoulder for quite some time.
    I'm just glad I was able to get more or less back to work after a couple weeks. I have a mobile detailing business and when I don't work, I don't make money. That was part of the reason I didn't opt for surgery, probably would have missed 4-6 weeks of work instead of about 15 days. Cosmetically, the lump isn't too noticeable, I did a lot of weightlifting when I was younger so I have enough muscle mass to mostly hide it.
  62. #162
    Jan 2009
    Yes, haven't noticed it in a long time.
  63. #163
    Quote Originally Posted by trouble0613 View Post
    wow, that's terrible and totally different from my experience. I won a pull-up contest(~20) while drunk at my buddy's wedding reception no more than a month after my own grade 3. Full bunny hops were possible within 6 weeks of the injury. Pretty much the same recovery time was required for my grade 2 a year later.
    The only thing that persisted is minor weakness doing dips (i.e. the triceps exercise).
  64. #164
    Jan 2009
    Its been a year and 7 months now. Seems to be close to 100% recovered. No problems throwing a baseball or football, can swing a bat at full speed without any issues. Slight decrease in range of motion when reaching across my body (compared to my other arm), but nothing that remotely inhibits me. I can now sleep in any position, no longer have to keep a pillow under my right arm. Still some occasional tightness but no pain. Really glad so far I didn't have surgery.
  65. #165
    Reputation: Joe-it-all's Avatar
    ^this
    I did mine early Aug '12, was back on the mt bike mid sept. Extending the front end for drops or rollers was dicey the first week or two. It's all good now and generally wouldn't even know I did anything except for the nub sticking up.
  66. #166
    Jan 2013
    Quote Originally Posted by Scottwax View Post
    Hello Scottwax/all,
    I write to you from Spain and the thing is that a couple of weeks ago I made and AC dislocation grade 3. Out of 6 traumatologist 4 recommended conservative treatment so thats what I am doing. I am quite scared because the gym is my world. I cant stand the idea of not being able of lifting as before. From what I see Scottwax, now you are 100% recovered and can lift with the same intensity and strenght as before. What was your recovery process? Would you recommend me surgery? Do you think I will be able to lift as before? How long were you out of the gym?
    Thank you everyone
  67. #167
    Jan 2013
    Sorry I wanted to send a PM
  68. #168
    Jan 2009
    Quote Originally Posted by Coleman87 View Post
    Hello Scottwax/all,
    Thank you everyone
    Really late reply, I road bike so I don't check this forum too often...although that will be changing as I plan on getting an MTB to ride in the winter, need to mix things up. All my roadie friends switch to MTBs in the winter and riding solo when its in the 40s and 50s sucks when you're alone.
    I didn't really do anything, just went back to my normal activities as the pain would allow. It was 6 months or so before I did any lifting, biggest issue was when I was holding something heavy in my right hand, I could feel a pulling sensation in my shoulder, so I made it a point to carry heavy groceries (go through a ton of Powerade Zero this time of year) in my right hand, after a few more months, no problems carrying really heavy stuff now. I don't do that much lifting, got a lot of size left over from when I did and on the bike, bulk is the enemy so most of my upper body workout is detailing cars in my business.
    At the point, I am glad I didn't have surgery. I have the same range of motion on both shoulders now, strength seems equal in both. Even after several months, I felt something like bar dips would be out of the question but I've tried a few, no pain at all, no unusual movement in the shoulder. Even without a shirt on, its very hard to tell I had the separation the lump is so small. The size of my traps help too.
  69. #169
    Gonna add to this...
    I injured myself just last week. Today I had my follow up with an orthopedist. He said that I have a higher end grade 3 separation. He said that I am in a grey area and that I need to decide whether or not to get the surgery. As soon as I mentioned that I race bikes, he recommended the surgery.
    Its weird because I'm not in all that much pain. I can rotate my arm but certain movements or lifting anything will aggravate it. I hope I'm making the right choice. He also said that if I decide to do surgery, we need to do it asap. I'm going in tomorrow! I just want to be back on the bike without any issues after recovery.
  70. #170
    Quote Originally Posted by generate View Post
    higher end means it's about to cost you more. It sounds like a crock to me. Is he the one who will benefit financially from the surgery or is he sending you to someone with whom he's unlikely to have a substantial affiliation?
    Higher grades of AC separation typically include severe deformations such as your clavicle being displaced. If you just have the usual notch in your shoulder (both of mine are separated) though it may be too swollen still to really tell, then the majority of current medical advice is that you don't get surgery. I would ice it and do ample physical therapy and you'll be back riding soon.
  71. #171
    Jan 2009
    Agree completely. 2 years out and I'm fully back to normal without surgery. And I was in a lot of pain the first few weeks, couldn't even reach down to tie my shoes for about 3 weeks. I was also told by the specialist I saw that incidents of arthritis are lower without the surgery than with.
    I'm not a doctor and have no idea what a more severe grade 3 would be, but I was told most insurance companies consider it an aggressive form of treatment.
  72. #172
    Jun 2010
    I suffered a high grade II separation in June on my road bike (that will teach me to stay on the dirt). Doc stated that it usually takes 3 months to heel and about three months to get back to full strength. I seemed to complete the healing process a bit more quickly, as I had full movement and rotation by the end of two months. Strengthening the shoulder is taking longer than I would like, but work has kept me from exercising it as consistently as I would like. I have a pronounced bump on my shoulder from the protruding end of my clavicle.
    As far as addressing the OP's original question, I was back on my mtb at the end of the second month, sticking to the easiest trails to keep fall potential to a minimum. I still haven't started to ride the most difficult trails yet, still fearing a fall on the shoulder, as I know its not strong enough yet to take another hit. Still have yet to get back on the road bike.
  73. #173
    In regards to my original post, by saying "high grade 3", he basically meant that it was almost a grade 4. He said that if it were a grade 4 then surgery would be necessary but it my case I could still make a decision.
    I did go through with the surgery a week ago. Doc also found that I had tore my labrum as well and he fixed that. First couple days were hell, but I am currently off pain meds and starting to get a full nights sleep. Overall I feel really good. When I take the sling off just to stretch my arm out and do pendulum exercises, it feels solid. I can move around without pain. I'm taking it really easy on it until my follow up appointment next week.
    Typically I heal up quicker than normal, even at 37. I've been riding my trainer (no handed and gingerly) since the day I got out of surgery. I'm glad this happened now instead if the middle of spring or summer, but it sucks either way. I race all year (road, track, mtb and CX) so I'm hoping to be able to recover enough to start winter training in a couple months.
    Another thing is supplementation. Not sure what you guys are into but I've always believed in the supplements I use. I've gone through a lot of trial and error over the years. Some of the things I have been taking to aid recovery are Vit d, fish oil, Protein powder, Collagen protein, and L-glutamine. Also eating higher fat/protein and cutting back my carbs a lot since I'm not training. I'm trying not to be 20lbs heavier when I get back on the bike!
    I'll try to update here as things progress.
  74. #174
    Feb 2015
    First of all, Very thankful to everyone who contributed to this thread. It has been really helpful to me. I am a Chiropractor working in Veitnam, and an avid mountain Biker. LatelyI have started training for an ironman. Bought my first road bike, carbon Cannonade, on Saturday, 4 days ago. at 51 years old, have never ridden a road bike, but figured since i was an expert mountain biker, Road bike would be a peace of cake. Wow was i wrong. Long story short, I also now have a grade 3 AC dislocation on my left shoulder, and some poor Vientiane fellow has a large dent in the rear Panel of his
    white Mercedes.
    have talked to three orthopedic surgeons, who i trust, and after reading this post, I am going to try to manage the injury conservatively. My other Chiropractor has been K taping it several times a day, and have been getting Class 4 laser treatment and gentle physiotherapy an chiropractic care in my clinic hourly. after 3 days, i don’t seem to need the sling, and full passive range of motion, but can only lift a little in any direction using my own Strength. Laser seems to really help remarkably with the pain. I have spent 10 hours reading case studies and journals on the net, and even being a doctor myself, it has taken a few days to get my head around what would be the best course of action.
    Two of the surgeons offered various procedures, but also gave the opinion that It was probably just as good of an idea to avoid the surgery. all three recommended against the tight rope procedure in an active athlete. I will post my outcome in a few weeks, in case it is useful to anyone.
    thanks again.
  75. #175
    May 2013
    I had a grade 3. Rested for 12 weeks and am fine. Fell last week and landed on same shoulder again, but luckily to repeat injury. Rest. Always avoid surgery if that's an option.
  76. #176
    Reputation: Mr.Wizard's Avatar
    Feb 2015
    Hooked a root last night and went down hard.
    After a long night in ER, found out I have a grade 3 separation.
    Dang, it was really an epic ride.
    I'm in my 60's, appointment with Doctors Monday.....
    "Be what you is and not what you is not. Folks that is what they is, is the happiest lot."
  77. #177
    Reputation: Burt4x4's Avatar
    Feb 2013
    ^^Whiskey & Time is all you need! Welcome to the "bump" club!
    RIDE!!!!!!!!!!!!!!!!
    Ride MORE = Live Longer
    Love Dirt / Hate Pavement
  78. #178
    Feb 2015
    Quote Originally Posted by Burt4x4 View Post
    Amen...
  79. #179
    Reputation: BeanMan's Avatar
    Grade 3 here. Use it to your advantage. I told my Wife I couldn't scrub my back in the shower because of it and got her in the shower with me 6 to 8 weeks for recovery.
  80. #180
    Feb 2013
    ^^ Brilliant LOL
  81. #181
    Ugly
    Great thread and good read for those subsequently injured (like me ). Post crash 4 months, the worst thing is how it looks. My separation is a full bone width from its original position. If my arm is held back, it looks like a bump. If held forward, the whole freaking bone sticks up and looks gnarly. It catches on the seat belt all of the time (left shoulder). I'm holding off on any surgery until next spring which will be a year from the crash. I've heard both negative and positive surgery experiences, so I'm a bit leery. You can't undo surgery I don't know why the pic is sideways or how to fix it. Sorry...AC Separation Grade III Recovery-img_2699.jpg
  82. #182
    P.S. Those that say it takes 3 months to heal are wrong. I'm at 5+ months now. Sleeping on that side is still a problem. Even moderate activity with my left arm can result in significant pain the day and 2nd day after. I'm still wanting to wait a year before deciding on surgery, although it seems my shoulder is dropping making the bone stick up further looking worse than a couple of months ago. I sure wish this had never happened
  83. #183
    Reputation: roadracerX's Avatar
    Hang in there, it gets better. I got my grade 3 back in 2002. It was rough for a while but I was racing my motorcycle again months later without surgery. As soon as the doc told me it was ok to resume normal activities I started to work on building up the muscle around it. The first pushup almost made me cry but I kept at it.
    I had the same problem years later that I couldnt sleep on that shoulder but it barely sticks up now and never bothers me anymore.
  84. #184
    I appreciate your words on encouragement roadracerX. I'm in my 60s and 14 years from now I'll likely be dead I didn't take real good care of myself in my younger years. Ha! My slogan has become, 'it could always be worse' and that is so true.
    On a non-related note, I've not been able to ride much at all for the last 3 years. I went from 600 miles a month average to 20 due to neck pain. After chasing that problem for the last 3 years and having all kinds of treatments that did nothing, I went to an infectious disease doctor last week to be tested for Lyme. I'm really, really, really hoping I have it so it can be fixed and I can get back in the saddle. I miss how I felt riding 4-5k a year. If I can get over that hump, the shoulder will be minor. Like I mentioned earlier, the worst thing is how it looks. Here's hoping!
