    Whippet front mech
    Hi . Can anyone recommend which direct mount front mech to buy? All the ones on chain reaction say specifically for 68-73mm bb shells and 48.8 mm chain lines 68 69 degree seat tube angles.
    I want to run a kcnc k2xc tripple chain set as a double.
    What do I need?
    Oct 2007
    I am using an XTR high direct mount. If you stick with On Ones recommendations you will be okay:
    High Direct Mount (HDM):
    Any SRAM HDM, 2x10, DUAL PULL
    Low Direct Mount (LDM):
    SRAM XX LDM 2x10 S3 42 TOP PULL- limited to 42T Chainsets
    The following Mechs need a 1mm washer between the HDM plate and the mech:
    Any SRAM HIGH DIRECT MOUNT, 3x10, DUAL PULL
    Shimano FD-M771-D (XT) 9 speed
    Shimano FD-M661-D (SLX) 9 speed
    Shimano FD-M771-10D (XT) 10 speed
    Shimano FD-M661-10D (SLX) 10 speed
    The following front mechs do not fit
    Low Direct Mount:
    All Shimano LDM
    Eg: Shimano FD-M771-E
    All SRAM LDM excluding XX S3
    2015 Niner Jet 9 Carbon
    2014 Focus Raven 27R
    2017 Lynskey GR250
    2016 Niner BSB
    1987 Haro RS1
    Thank you. Ordered an fd m771 .
    Guys, would it be possible to find a way to cover the part on the frame with a metal plate, in order to avoid damages that might be caused by a chain suck? To be honest, I'm a little bit disappointed why the Wippet does not have that metal plate...
    Any aftermarket piece of that metal? Maybe from On-One?
    As an alternative way (I'm just curious for that), would it be possible the lower direct mount mech to put a kind of 'plate', in order to avoid chain suck?
    Why I'm asking this, because, unfortunately, even if I covered my frame with pieces of thick plastic and a lot of zip ties, I got a chain suck (with a perfectly aligned front derailleur!) and my carbon frame has been scratched slightly...
    Today I saw a good example, let's take a look to the new 2013 Scott Genius 700/900's BB92 area:
    OK, it's mounted to ISCG tabs; but, if we are using a HDM derailleur, probably we would still have the possibility to use the LDM to mount a similar thing... Would be REALLY helpful!
    ___
    2016 Canyon Grand Canyon CF SL 8.9 tuned (fully-rigid, 1x11)
    https://www.strava.com/athletes/2373507
