Results 1 to 16 of 16
    Reputation: octanejake's Avatar
    Oct 2010
    Caution;  Merge;  Workers Ahead! Whippet chainguide help
    I am in the early stages of building up a whippet race bike for collegiate season and am having trouble figuring out which guide will work. The On-one sites say that high mounts work but also listed is the Sram S3. So my question is will I need to get a "D-mount" or an "S3/E-mount" or something else ? My plan is to use an MRP 1.X single ring up front. Thanks
    -Jake
    Reputation: Fix the Spade's Avatar
    You want the one that looks like this:
    I believe it is the D mount.
    Whippets have mounts for both SRAM and Shimano direct mount mechs, but the shimano one should easier to fit and adjust.
    Oct 2010
    aww, yes that is the d-mount version. thank you
    Oct 2010
    more help again please...this time with the headset. Both the US site and UK site are vague about the required headset. Yes they say 1-1/8 inch steer tube, integrated, and tell you an FSA Orbit CE Integrated Headset will do, but they don't specify the I.D. of the headtube. What is it? 42mm? 40/ 44/ 41.2/ 46 ?
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by octanejake View Post
    The bearing is 42mm (41.8)
    mtbtires.com
    Oct 2010
    thank you
    Oct 2010
    update for those interested. built
    weighs in around 22.6 lbs (using the notoriously inaccurate bathroom scale test [i need a digital scale])
    * And thanks for the help
    screamer
    Reputation: budgie's Avatar
    Nice! These whippets really build up quite light, don't they? I'm also digging the UD not-finish-finish. Mine sort of looks like burl wood, except carbon. Was expecting it'd be more uniform, but the whorls and such are really growing on me. Just had a crazy idea... couldn't one add pigment to the resin? Artsy-craftsy, a sort of back-woods-hobbit special edition.
    Back on topic: great bike, super fun to ride. Carry on.
    On heavy rotation: White Lung: Deep Fantasy
    http://sphotos-a.xx.fbcdn.net/hphoto...56590761_n.jpg
    Really nice build! Which size is the frame?
    Could you write some more info about the technical specifications? I'm especially interested to the cassette (11-36?), chainring size/type at front and which guide you installed to the DM plate.
    I'm thinking in something similar.
    Currently I'm using 3x10 with 42-32-24 x 11-36 but I'm not so satisfied with this setup and I don't use the smallest chainring at all... I don't really spend too much more money (buying 2x10 crankset with 40-28 for example, which would be too expensive for me), an 1x10 system would be a good alternative for me as well, I guess.
    ___
    2016 Canyon Grand Canyon CF SL 8.9 tuned (fully-rigid, 1x11)
    https://www.strava.com/athletes/2373507
    What chainring are u using? I know its off topic just thought of asking. Looks cool with slx crank
    Sent from my HTC Sensation 4G using Tapatalk 2
    Oct 2010
    Bike spec.
    FRAME On-One Whippet 2012 16" frame matte black carbon 1417g
    FORK Marzocchi 44TI-ATA / 2009 100-140mm 1700g
    HEADSET Ritchey PRO integrated 81g
    SPACERS FSA 13g
    Top cap and bolt Syntace (with bolt) 14g
    STEM Syntace Megaforce 2 122g
    HANDLEBAR Easton Haeven 177g
    GRIPS ESI Racers Edge (with bar ends) 49g
    FRONT WHEEL Easton XC-ONE 720g
    FRONT RIM STRIP (with wheel)
    FRONT AXLE Easton XC-ONE 58g
    FRONT TIRE Continental Race King 26"X2.0" 574g
    FRONT TUBE 166g
    REAR WHEEL Easton XC-ONE 876g
    REAR RIM STRIP (with wheel)
    REAR AXLE Easton XC-ONE 63g
    REAR TIRE 532g
    REAR TUBE 164g
    FRONT BRAKE Hayes Stroker Carbon caliper/ hose/ cylinder/ lever 280g
    FRONT ROTOR Hayes 160mm 115g
    FRONT ROTOR BOLTS Hayes 12g
    REAR BRAKE Hayes Stroker Carbon caliper/ hose/ cylinder/ lever 330g
    REAR ROTOR Hayes 160mm 113g
    REAR ROTOR BOLTS Hayes 12g
    SEATPOST Truvativ Hussefelt 303g
    SADDLE Selle Italia XR 267g
    SEAT CLAMP 24g
    CHAINRING BOLTS Sinz 15g
    BOTTOM BRACKET Shimano SM-BB92 73g
    CRANK ARM (SET) Shimano SLX 170mm 623g
    CHAIN RING FSA 36t 57g
    CHAIN GUIDE MRP 1.X FD style mount 59g
    PEDALS Time Attack 523g
    REAR MECH Sram X.9 mid-cage (included below)
    SHIFTER Sram X.9 384g
    CABLE/HOUSING (included above)
    CHAIN Sram PC-990 265g
    CASSETTE Sram PG-990 11-32tooth 272g
    BOTTLE MOUNTS 2g
    BOTTLE CAGE Blackburn Slick 23g
    BOTTLE MOUNTS 2g
    The cassette is a Sram PG991 11-32t 9-speed since I had it there wasn't any point of buying a new 10-spd at this time for me. And the Chain Ring is an FSA dh ring 36t. I also have a 32t chain ring in case I ever want a 1-to-1 climbing gear ratio. The guide is an MRP 1.X FD-mount guide which saves a lot of grams over the E.13 SRS with bash ring I had been using.
    Very nice build, thanks a lot for the very detailed information!
    Do you use 4mm version of Sinz chainring bolts? Did you use any washer to fine-tune the chainline?
    I also wanted to buy an MRP 1.X D-type but it's not available in my country. I tried to order from Germany but with less success... It seems I will finally end up with E.13 XCX-ST D-type or E-type (I would prefer the D-type), maybe with a "Blackspire Einfachx Direct Mount" which is slightly cheaper. However still very expensive.
    ___
    Oct 2010
    the sinz bolts are the 4mm ones, they are listed as track chainring bolts and came in a set of five. No washers, the chain line is good when run on the inside of the crank tabs. Only problem is the 1.X seems to be designed so the back "kicks out" away from the bike. Its in the right spot just angled wronged, Most likely I will need to grind it down so it can line up straight. Right now it grinds in the lowest gears.
    That is absolutely good news for me, if no further alignment is necessary to reach the ideal chain line, I will also choose the 4mm chainring bolts.
    MRP 1.X was supplied with washers/DM plate inserts like E.13 XCX? If yes (or if you can get an insert from the Internet like XCX has), you may only need to grind down the insert only to fine-tune the angle slightly.
    ___
    I am thinking about converting my on one whippet to single speed. However I am totally newbie when it comes to single speed building so I have few Whippet specific questions:
    - What kind of single chainset is compatible for whippet?
    - Currently I use SLX triple chainset whit BB92. Can I remove big and small ring and convert it single chainset? Do I need to use some spacers in that case between cranks and BB?
    How I see it, is that there might be some clearance issues with 32t ring without spacers?
    Thanks for your help!
    BR,
    Ari
    Dec 2012
    I ran an e thirteen guide on mine, it was the low mount one, bugger to shim up nicely, but never any trouble.
