Results 1 to 34 of 34
Thread: whippet 650b
    whippet 650b
    Anyone confirm that a 650b 2.3 neomoto will fit the back end of a whippet? I like running the big and meaty here on the east coast
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Dan0930 View Post
    Yes, it fits.
    Think the dish on my wheel is off a bit.
    No issues with FD clearance
    mtbtires.com
    Reputation: MMcG's Avatar
    Jul 2003
    Sweet!
    Are these cool with using a 100mm fork? How about going up to even say a 120mm Talas?
    Dec 2008
    So, what's the down low on running 650b on a whippet? As you may know, I have both a rigid and suspension fork for mine. This will raise the axles and BB 0.75" which isn't too drastic. I really like the geometry and handling of my whippet. I'm guessing that won't change with slightly larger wheels? I have no clue but does the 456 have a lower BB due to being aimed at a more aggressive riding style? Lower CG and all that.
    Jul 2003
    I suspect that your bb height may only change by .5"
    Dec 1998
    Quote Originally Posted by bennymack View Post
    Given tires with the same cross section the BB ht changes by 12mm (~0.5"). 650B rims (584mm) are exactly 25mm larger diameter than 26" rims (559mm)
    The 456 BB is about the same with a 100mm fork and higher with a longer fork because it is used in more roughed terrain where increased pedal and chainring clearance is needed.
    mtbtires.com
    Uncle
    Reputation: Entrenador's Avatar
    Bump: BB height with 26" wheels?
    Hey bennymack, care to exchange rep points for a static BB measurement, from floor to center - including the fork this measurement comes with? Inquiring minds (& future owners ) would like to know.
    650b option might be in my future, but I'll certainly build it up with the little wheels firs.
    Thanks much.
    -E
    Every rose has it's thorn.
    enjoy the ear worm
    Reputation: Kristinka's Avatar
    Aug 2010
    Quote Originally Posted by shiggy View Post
    What is the BB drop of Whippet frame?
    Uncle
    Quote Originally Posted by Kristinka View Post
    I didn't measure BB drop, but I built the bike up with a 100mm fox fork & 2.2" 26" tires. Static BB height with this set up was 12.5". With a 650B Nevegal 2.35, same fork, and 26" Mutano 2.4 in the back, the BB height sat right at 13". Worth noting that the 650B Nev2.35 is a much taller tire than the undersized 26" 2.25 Nobby Nic that it replaced.
    enjoy the ear worm
    Reputation: dhbomber's Avatar
    Nov 2006
    Hey sorry to wake this thread up, but I'm about to buy the last set of Schwalbe Racing Ralphs in 650b for my whippet...I see there 2.2" wide, and read that schwalbes are rather wide...Will 650b Racing Ralphs fit the rear end of the whippet?
    My Bike: http://forums.mtbr.com/showpost.php?...3&postcount=49
    On-One Whippet 650b XC machine
    Aug 2010
    The 2,25" Raplhs are only 55mm wide.
    A little off track, but since the whippet will take a smaller 650B, would a 700C wheel with 35 'cross tires fit? Width-wise I have no doubt, but what about diameter?
    Dec 1998
    Quote Originally Posted by dhbomber View Post
    Fits fine
    mtbtires.com
    Dec 1998
    Quote Originally Posted by deuxdiesel View Post
    650B x 2.35 fits easily.
    700x35--Not a problem
    mtbtires.com
    Shiggy. Any chance of on one producing replacement drop outs to correct the bb height for 650b on the whippet?
    Reputation: brant's Avatar
    Quote Originally Posted by Nsynk View Post
    No.
    Quote Originally Posted by brant View Post
    No.
    brant
    Thank you for the reply. As economical with words as a Yorkshire man with money !
    Obvious question is why?
    Do you not think the whippet should be 650b? Is it because you never intended it to be 650b when you designed it? Are the stresses or geometry wrong for 650b ? Is it because you are designing a specific 650b and don't want to dilute the sales or do you just not agree with 650b?
    Kenton, over t' hill in Keighley.
    Dec 1998
    brant
    1. There is no way to make new Swapouts that would lower the BB. The axle/QR skewer would hit the frame.
    2. Even if the Swapouts could be modified, you would also need to change the front end height to maintain the frame angles.
    3. +1/2" of BB height is still "correct". Some of us prefer high BBs. I hate dragging pedals.
    mtbtires.com
    Hi shiggy . Intense have used modified dropouts to create their 650b carbide and tracer models but of course their BB' s are higher in the first place. I wonder how they get round the higher front end issue?
    Dropping the bb down will give the bike that " riding in" feeling and stability that 29ers have from the bb being lower than the axles.
    Of course nothing can beat designing the bike from the ground up to suit the wheel size .
    Dec 1998
    Intense uses totally different frame/dropout designs, and some riders seem not to care about frame angle changes.
    BB ht is highly debated by riders. My personal custom bikes (rigid, 26 and 29) have 13" high BBs. When it gets below ~12.2" I feel like the bike gets hung up on things (in addition to banging pedals). The claimed effect on cornering is a non-issue for me.
    I agree a bike is best designed for the wheel size to be used (though I have improved the handling of a low BB 26er with "B" wheels), which is why I brought up the front end height issue.
    mtbtires.com
    Feb 2012
    brant
    Shiggy gave us a good explanation and this completes the big picture: https://twitter.com/shedfire/status/205627825833771008
    I am happy that the 456C works with 650b wheels so well regardless of what its company says on twitter. Hopefully there will be more good alternatives on the market soon.
    On-One has any plan to release X-12 compatible rear dropouts for Whippet in the future?
    ___
    2016 Canyon Grand Canyon CF SL 8.9 tuned (fully-rigid, 1x11)
    https://www.strava.com/athletes/2373507
    Dec 1998
    Quote Originally Posted by semmiho View Post
    Not at this time. 142/12 has limited benefits in a rigid frame and raises the cost a (un)fair amount.
    mtbtires.com
    Jul 2003
    so with a frame like the Whippet - can I run old Shimano Hollowtech XT cranks? the Pre outboard bearing XT cranks?
    or
    Do I need an outboard bearing style crankset?
    Dec 1998
    Quote Originally Posted by MMcG View Post
    or
    I have not seen a BB92 to threaded adaptor. Likely because the shell is too wide.
    Need to use an external bearing type crankset.
    (Though I may have found a way to use my Profile Racing cranks )
    mtbtires.com
    Jul 2003
    Thanks shiggy
    Oct 2007
    I've been riding my Whippet since April as a 26er with a 2.4 Racing Ralph in the front and a 2.4 Furious Fred in the back. I just put on some 650b Racing Ralphs front and rear. The first thing I noticed while riding around the parking lot was that it felt higher due to the higher bottom bracket. I was a little concerned about this at first, but once out on the trail, as opposed to pavement, the higher BB actually worked quite well and handled great. I also noted that there is less sidewall flex in my tires going from 2.4s to 2.25s. This greatly improved cornering. Overall the Whippet makes a great conversion. The larger wheels let the bike handle a lot more, it was a little jittery even with the high volume 26" tires.
    And now for the pics:
    2015 Niner Jet 9 Carbon
    2014 Focus Raven 27R
    2017 Lynskey GR250
    2016 Niner BSB
    1987 Haro RS1
    Reputation: Click Click Boom's Avatar
    How does the whippet handle as a 650b? If I wanted to build one up as a rigid singlespeed would a 425 a/c fork make the bike to twitchy? What would the head angle, bb height and seat angle be set up like this?
    Oct 2007
    Quote Originally Posted by Click Click Boom View Post
    It rides great as 650b. The change in trail from the larger wheels does slow down the steering a little bit. But I think 425 would still make the bike too twitchy. But I guess it depends on your preferences for steering feel. I am not a math genius, so I am not going to able to figure out what those geometry numbers would be.
    2017 Lynskey GR250
    2016 Niner BSB
    1987 Haro RS1
    Mar 2013
    Brand new to the MTBR forums. My On One Whippet arrived in the mail today and I'm looking forward to building it up as a 650b. Stans rims with X9 hubs should be here in a few days.
    Question though, I just put my 26'er back wheel on and it looks like there is plenty of clearance round the seatstay but the chainstay looks a little tight. I'm currently running a Specialized Captain (Sport) 2.2 so it is a beefy tire. Just getting a little freaked that the 650b with either Neo Moto 2.3 or something from Schwalbe will fit. Reassure me guys!
    Dec 1998
    whippet 650b
    Quote Originally Posted by korymu View Post
    The Neo 2.3 fit just fine.
    mtbtires.com
    Nov 2013
    I'm thinking of buying a pair of 650b's for my whippet. Anyone (after a season use) have pros and cons compared 26 <-> 650B on the whippet?
    Edit1: which FOX forks is recommended using 650B (also 26"),, seems like most FOX forks are tapered and will not fit the Whippet..
    Big Test Icycles
    Reputation: Hangtime's Avatar
    whippet 650b
    Very interested in this frame as an upcoming race bike build. How is the handling with 650b and 100mm fork. Any feedback on the frame Vs a Dirty Harry would be appreciated.
    Reputation: Ltdan12a's Avatar
    Jun 2012
    BUMP!!!
    So it's been a couple years now, anybody else make the "jump" to 650b?
