Results 1 to 11 of 11
    Smorgasbord & Chunky Monkey tubeless?
    Just posted this in the wheels/tires forum, but thought I would ask the question here, as you On One guys might have more direct knowledge:
    Just saw a couple On One tires for the first time -- a Smorgasbord and Chunky Monkey a friend has purchased from On One/Titus in Portland.
    I am impressed with the tread patterns, feel of the sidewalls, and the aggressive look of the beads.
    I would like to run these tires in 29er but am committed to tubeless.
    Does anyone have experience or thoughts on running these with Stan's and no tube?
    I would be running them on WTB i23 rims with Stan's tape. Would love to run a 2.4 Chunky Monkey on the front.
    Shiggy and Brant, what do you think?
    Thanks for any input!
    http://shop.titusti.com/product-p/tyoocm29x24.htm
    http://shop.titusti.com/product-p/tyoosm29x225.htm
    My friend's 26er tires. Chunky Monkey 2.4 (mounted on rim) on the right and Smorgasbord 2.25 (unmounted) on the left.
    Smorgasbord & Chunky Monkey tubeless?-imageuploadedbytapatalk1366593917.803207.jpg
    Smorgasbord & Chunky Monkey tubeless?-imageuploadedbytapatalk1366593933.967504.jpg
    Reputation: fer83's Avatar
    they "pop" in the rim just right and are very air tight. tested in sun-ringle charger expert rims
    Got some good feedback in the wheels/tires forum:
    Run Smorgasbord or Chunky Monkey tubeless?
    Some good info in this Singletrack thread:
    http://singletrackworld.com/forum/to...-chunky-monkey
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by eugenemtbing View Post
    These are standard bead tires and I do not recommend using any standard tire and/or rim without inner tubes.
    mtbtires.com
    nothing to see here
    Reputation: Stevob's Avatar
    FYI, I set my smorgasbord and chunky monkey up tubeless, no dramas, on crest rims. Seated and sealed well. Loving this combo.
    I see hills.
    I want to climb them.
    I also set up CM and SMB on Stans Flows recently with no drama's. Ran them with a tube for a week, pulled the tube out, poured in some goop and they pumped straight up with a basic floor pump. Been riding them for a month that way with no issue.
    Reputation: CarolinaPanthers's Avatar
    Feb 2013
    Chunky Monkeys, Flow Ex's, overlapping Gorilla Tape at the valve stem, and soapy water. To peak Joe Blow blew them up quite easily. Though a second pair of hands/a stand to hold them in the air made things much smoother
    I work in .001 tolerances
    Reputation: HomegrownMN's Avatar
    Re: Smorgasbord & Chunky Monkey tubeless?
    One CM in 26" flavor and one in a 29", both tubeless from the get go using Stans. 6+ months now.
    Same carcass as the Ardent, made by Maxxis, some of the best tires I've ever converted.
    Anyone running these tubeless on UST rims?
  1. Chunky Monkey
    By bikeny in forum 29er Bikes
    Last Post: 12-25-2015, 09:41 PM
  2. Smorgasbord owners out there?!?
    By Eastcoaster in forum Vintage, Retro, Classic
    Last Post: 10-09-2015, 02:58 PM
  3. Run Smorgasbord or Chunky Monkey tubeless?
    By eugenemtbing in forum Wheels and Tires
    Last Post: 03-28-2014, 08:11 AM
  4. SPAM: On One Chunky Monkey 29x2.4" tires
    By bikeny in forum 29er Components
    Last Post: 02-22-2013, 12:26 PM
  5. Smorgasbord Cycles: Complete History
    Last Post: 11-28-2009, 06:49 PM
