Scandal Seatpost length
Anyone out there in the 5'-11" range (inseam is 32.5" in sox, floor - crotch) on an 18" Scandal? What length post are you running? I've got a frame on the way and need to pick up a post. If possible I'd like to get one before the frame arrives. Will 350mm be enough? My current frame is a 17" with a 400mm post. I don't think I'm at the minimum insertion line, but I know I've got a lot sthcking out. Thanks.
I'm gonna have to kill ya
I am 5'9" with that inseam and ride an 18 29er v2 and also have a 16" 26er scandal but prefer the fit of the 18" (and 29" wheel is sooo much better).
Anyway funnily enough the 16" hasa 350mm post 2cm from the max mark and the 18" has a longer 400mm one (all they had) that I have yet to cut down, You could get away with a 300mm on the 18" based on that but a 350mm would be the best
Hope that helps
Re: Scandal Seatpost length
Thanks! I took some rough measurements on my current frame and am fairly certain 350mm will be plenty.
Sent from my Motorola Electrify using Tapatalk 2
By Triple8Sol in forum Intense
Last Post: 08-02-2012, 04:39 PM
By ejreyes6 in forum Niner Bikes
Last Post: 07-12-2012, 05:15 PM
Last Post: 07-06-2012, 12:26 PM
Last Post: 06-10-2011, 10:21 PM
By shiggy in forum General Discussion
Last Post: 06-08-2011, 08:49 AM
- You may not post replies
- You may not edit your posts
Forum Rules
