    Mar 2011
    Quick fork question/Inbred 26"
    I have a 16" Inbred swapout 26er and I finally picked up a new (to me) X Fusion Enix for it to replace the clapped out Manitou that was on it. The old fork had 100mm of travel and felt pretty good except a bit light in the front end when climbing.
    The new fork came set at 80mm instead of the 100mm that the seller said. Am I crazy to run it at 80? I don't ride anything that technical, some roots and stuff but no rock gardens around here. Lots of up and down though.
    thanks!
    I had the fork on my 26" Inbred set to 80mm originally, before changing to a 100mm spring. I can't say I noticed a huge difference, except that the 100mm is stiffer (which is why I changed it). Handling felt fine with either and losing 20mm (less if you factor in sag) wasn't a big deal. I'd recommend giving your fork a go at 80mm, and if you hate it, it shouldn't be too hard to adjust to 100.
    Surly Cross Check: fat tire roadie
    Surly LHT: Kid hauler
    On One Inbred: SS 26er
    Mar 2011
    The update goes like this:
    I'm a dumbass, there was no air in the fork. I pumped it up and voila my bike is awesome.
    Excellent! Enjoy!
  1. Quick Vaya fork question
    By 43st in forum Salsa
    Last Post: 02-14-2013, 05:15 PM
  2. Inbred 29 + rigid 26" fork for city use?
    By Bulldog in forum 29er Bikes
    Last Post: 01-31-2012, 08:06 PM
  3. Quick question! New fork.....vs old
    By ProjectDan35 in forum Shocks and Suspension
    Last Post: 11-17-2011, 03:24 PM
  4. question on On One Inbred 29 size 16"
    By Jingleman in forum 29er Bikes
    Last Post: 06-20-2011, 08:35 AM
