Page 14 of 14 FirstFirst ... 41011121314
Results 651 to 674 of 674
  1. #651
    Quote Originally Posted by thasingletrackmastah View Post
    Is this the "internal swapout" ?
    180 fits om my size L and my wifes size S.
    What happened to the frame price?
    Should have bought a couple more, would have been a great investment
    I thoght the same when I checked the price recently.
    I have the same vertical swapout you linked, it works well with 160mm rotors, tried with Magura Louise BAT and Shimano XTR trail brakes, I haven't noticed any 'clearance' issues so far.
    I have horizontal swapouts as well, used it for 2-3 months, didn't have issues with 160mm rotors and XTR trail brakes.
    According to my service excel sheet, there is ~10000 kms / 6200 miles in my Lurcher frame. Used mostly with On-One rigid fork, no issues so far.
    Nevertheless, I'm pretty convinced about that the On-One tapered rigid fork is simply too stiff, there is no flex at all. I have just changed it to a Ritchey WCS carbon rigid fork...
    ___
    2016 Canyon Grand Canyon CF SL 8.9 tuned (fully-rigid, 1x11)
    https://www.strava.com/athletes/2373507
  2. #652
    Yes - That is the internal swapout.
    Frame prices go up and down depending on the stock level.
  3. #653
    Apr 2014
    Quote Originally Posted by Titus/On One USA View Post
    You can definitely fit a 180mm rotor on the Monocoque Tapered fork.
    160mm rotor on the rear with an internal swapout/180mm on the rear with an external swapout.
    Thank you. I was hoping for a 200-203mm answer, but 180 isn't bad.
    180 fits om my size L and my wifes size.
  4. #654
    Apr 2014
    I just thought of something. What to do about mounting the 180mm rotor to the fork? What adapter, if I need one, do I use? What about the rear rotor mounting situation?
  5. #655
    Reputation: Awshucks's Avatar
    Apr 2013
    I again just wanted to say how much i love this frame after more use. I've gone now SS to 1x10 and the versatility is awesome, and the frame always fits like a glove. I hope they don't stop making these!
  6. #656
    Apr 2014
    The front rigid fork really appears to have no clearance issues with fitting a 203mm rotor. This is an image with a 180mm rotor in place.
  7. #657
    Apr 2014
    This is what I used with the XT 785 calipers.
  8. #658
    Apr 2014
    Quote Originally Posted by themonkeyking View Post
    F*ck it. I ordered new rotors & brackets. Went 203 front & 180 rear. Will give definitive answer when they get here, & I either succeed or fail with the mounting.
  9. #659
    Just Ride!
    Reputation: kustomz's Avatar
    I always thought max rotor dimensions were based on the amount of force the frame and fork could handle and not just clearance?
  10. #660
    Apr 2014
    Quote Originally Posted by kustomz View Post
    How does post #649 read to you?
  11. #661
    Reputation: vikb's Avatar
    Quote Originally Posted by pwu_1 View Post
    Any one else running the lurcher with the single speed drop,out having issues with chain tension? My rear wheel has a 135x12mm hub and I tried using 2 different types of reducer axles and no matter how tight I try to tighten the nuts, seems like chain looses tension after a couple rides. I finally gave up and bought some chain tugs and installed on both drop outs and seems like the wheel,is still slipping., how is that even possible? The tugs should prevent the wheel from sliding forward right? Anyways, just curious if anyone has the same issue. Wondering if getting new drop outs might help
    Not on a Lurcher, but with another horizontal dropout bike I found that if my chain tension was too high the wheel would get tweaked to the NDS of the bike by moving the NDS axle back a touch. This reduced chain tension and is not controlled by a chain tug.
    All I had to do to resolve the problem was to run the chain with a little more slack in it. That is better for the drivetrain and your bearings anyways.
    Safe riding,
    Vik
    www.vikapproved.com
  12. #662
    Apr 2014
    Here's the Shimano 203mm caliper adapter & the 203mm rotor mounted to the On-One rigid carbon fork.
    The 203mm rotor to fork clearance.
  13. #663
    Reputation: BudMelman's Avatar
    Sep 2012
    I have the Lurcher frame and fork set up as single speed and love it.
    Has anyone tried fitting a 29+ tire up front with the carbon fork?
  14. #664
    Reputation: JokerSC's Avatar
    Did they stop producing the Lurcher? Don't see it for sale on the ON ONE sites anywhere
    RideMFRide
  15. #665
    Nov 2015
    Quote Originally Posted by jjmtb1 View Post
    I am 6' with a 32 inseam. I bought a large. I always felt it was a little big. Since I was getting tired of swapping it back and forth between single and geared I bought another one. This time I bought a medium. I think the medium fits a little better but with stem lengths I hardly notice a difference. I set up the medium as the single and the large as the geared. Now I just ride which ever one I am mood for and I don't really think about the size.
    I came in here to read up to see if I need a L or XL so I can buy your L!!! Good to see this cause I'm 6'2 and have the 19 scandal and was thinking a 21 lurcher. I'll be in touch on your L soon if it's still around. I'm the guy who asked if you would SS the large on PB.
    Did you ever try a 29+ in rear?
    Has anybody tried that? I was told it fits 3.0. Any truth? I tried searching.
  16. #666
    Reputation: jjmtb1's Avatar
    Quote Originally Posted by LaneDetroitCity View Post
    I haven't tried a 29+ in the rear. I would doubt it would fit. Maybe there are others that have tried and can chime in but I put a 2.4 ralph on the back and that was close.
    Of course with the carbon front allows more options but I think the rear would be sketchy.
    Each bike is still available.
    Paid
    I will PM you some details if you are interested.
  17. #667
    Reputation: scottay's Avatar
    Looking for some SS dropouts for my Lurcher. Anyone got some laying in the parts bin?
    Reputation: AmericanTemplar's Avatar
    If anyone is interested, I have a 19.5" Lurcher going for $200 shipped in the classifieds. It's in great shape!
  19. #669
    Nov 2015
    Quote Originally Posted by AmericanTemplar View Post
    I'm buying it! I hit you on PB
    Sent from my 831C using Tapatalk
  20. #670
    Awesome, yeah hope you enjoy it!
  21. #671
    Reputation: thasingletrackmastah's Avatar
    Belgian beer and Scotch whisky.
  22. #672
    Nov 2015
    Hey I bought the one from Grant.
    It's a large. What are these building up to rigid SS
    Xo crank
    King arch wheels
    Rdo fork
    Xt brakes
    Carbon cockpit
    Rough estimate? SS.
  23. #673
    Pirate!!!
    Reputation: Captain Cobb's Avatar
    I just put the final touches on this little rocket ship. I'm really pleased with how it turned out.
    Sorry, most of the pictures are sideways
  24. #674
    Here's a picture of my Lurcher, build up rigid as 1x10.
    weight 10.06kg
