On One Bike pictures......
252K views 657 replies 274 participants last post by  Ol Bromy
#1 ·
thought of starting this thread with sharing of different type of OnOne bikes..
here are the pictures and specs below
456 Ti - Large Frame
DT Swiss XMM140 15QR (twin shot control)
On One ultralight CNC Stem 70mm
Easton EC70 MonkeyLite Low Riser (685mm) with ESI Foam grips
KS-i950R Seatpost
Fizik Tundra 2
SRAM X0 Shifters
SRAM X0 RD Medium Cage
SRAM X9 FD
Shimano XTR Brakes
Shimano XT crank (175mm) with VP-59 Pedals
Blackspire Chain ring (26T, 34T) with Raceface Bash guard
Blackspire Stinger ISCG 05
Shimano XT Cassette with modified 36T
KMC X9 SL Chain
Mavic CrossMax ST Wheelset
Panaracer AM/4x Front tyre (2.35) ghetto tubeless
Panaracer Rampage Rear tyre (2.1) ghetto tubeless
Weight - approx. 11.9kg @ 26.24 lbs
really loving the ride so far.....
there's another thread here on the 456 ti...https://forums.mtbr.com/showthread.php?t=700285
#455 ·
My c456
Some really nice bikes on here, makes me proud to be an on one owner!
Here's my carbon 456
Spec includes
Rock shock revs 150mm
Stans flow tubeless rims
Sram x9 2x9 gearing
Easton haven carbon bars
Shimano saint flat pedals
Rocket Ron tubeless rear
Hans Dampf tubeless front
Nanotech brakes
Weighs in at around 26lb
#471 ·
This bike has gone through some changes since I built it up at the end of last winter.
Current Build:
16in Fatty Rolling Chassis Build
40mm Hussefelt Stem
760mm Nukeproof Riser Alum
Ergon Grips
FSA Alpha 175mm cranks w/ XTR chainrings
FSA DH Platinum ISIS bb
Time ATAC Z pedals
Shimano XTR M960 RD
Paul thumbie with Shiimano shifter
Truvativ Seatpost (being replaced with 410mm Thomson)
Sette saddle (mimics WTB Pure V)
KMC Rustbuster chain 9 speed
Shimano 12-36 "29er" cassette 9 speed
For the middle ring I had to use small spacers to mate it up with the cranks. With a spacer on the drive side of the bb everything clears fine.
#474 ·
Recently built this up and only had her out on a few rides, but after being struck down with the man flu and being unable to ride I fully detailed and lubed her up and took some snaps.
Budget build from donor bike and CRC etc... sale parts.
-On-One 456 Evo II 16" frame in matt raw.
-2013 Manitou Minute Pro 120mm fork (would like to upgrade to something travel adjustable up to 150mm in the future)
- SunRingle Charger Expert wheelset. (factory bearings needed replacement within 2 months)
-Maxxis High Roller II 2.3" mounted tubeless.
-Shimano BR-M395 Hydraulic disc brakes with Avid Cleansweep G3 rotors 160mm (work well, will replace when dead)
-SLX 9spd rear mech.
-XT 9spd shifter
-Front mech and shifter Acera (soon to go 2x9 and may or may not keep this gear depending on how well it works)
-Cheap Shimano crankset, I think also Acera. (Will replace when) dead.
-Crank Bros Cobalt 3 bars 680mm (but have some Funn 810mm bars in the post)
-On-One 50mm stem.
-On-One Twelfty Seatpost.
-WTB Shadow V saddle.
-DMR V8 Pedals.
Absolutely love this bike.
It will never be this clean again.
Bicycle Wheel Tire Bicycles--Equipment and supplies Crankset
