Results 1 to 2 of 2
    solid gold plated
    Reputation: da_eddio's Avatar
    On One 456 Evo 2 Build Advice
    Ello all,
    I'm in the process of spec'ing up a build for my new 456 evo 2 frame and need some clarification as to what mechs I can fit.
    How much gear cable outer casing do i need to run full lengths to the front and rear mech? (frame is 20" btw)
    Lastly, does a 36th chainring fit up front ok with a 2x9 setup? I've read it might catch and cause chainsuck.
    Thanks in advance
    a message of inspiration from your friends at yoplait, fruit on the bottom, hope on top!
    Reputation: Ktse's Avatar
    Here's what you need:
    34.9 top pull front derailleur
    3 meters of gear cable housing (you may be able to get away with 2, but get 3 to be safe)
    36T chainring will be fine and have no problems clearing the frame unless the chainline of the driveside crank is offset
  1. Want to build SS, need some advice.
    By philroyjenkins in forum Singlespeed
    Last Post: 11-07-2013, 10:15 PM
  2. Advice on new build.....
    By N1kk0 in forum All Mountain
    Last Post: 02-04-2013, 04:11 PM
  3. First build need advice
    By Carrera66 in forum General Discussion
    Last Post: 04-01-2012, 02:29 PM
  4. Build Advice
    By ConorKwin in forum The ReCycle Bin
    Last Post: 11-08-2011, 01:05 PM
  5. Build Advice
    By DemonSpawn in forum 29er Bikes
    Last Post: 10-02-2011, 06:49 PM
