Results 1 to 8 of 8
    Too Much Fun
    Reputation: benja55's Avatar
    Aug 2005
    New question here. Lurcher size question...
    Hi On-One peoples,
    I'm 5'8" with a shortish 30-31" inseam. I *think* I'm right in between the 16" and 18" Lurcher.
    Can anyone comment on sizing? Do they run larger or smaller? Is it a "true" size? Is it measured center to center?
    I did a search but it didn't seem to come up with anything.
    Many thanks in advance.
    - -benja- -
    Reputation: jimmay5469's Avatar
    Lurcher should have the same geo as the inbred. I just got a 16" inbred (5'9", 30-31" inseam). With the rigid fork on it I have plenty of standover. With an 80mm fork on there it's a little tighter, probably wouldn't want it any tighter. As far as my riding position, it is very comfortable for me, but I probably prefer to sit up a little straighter than most.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by benja55 View Post
    Hi On-One peoples,
    The ETT length is more important than the seat tube length.
    The geometry chart is here: On-One Lurcher Carbon Hardtail 29er Frame
    mtbtires.com
    Too Much Fun
    Aug 2005
    Hmmmm.... Can't tell which way to go.
    Quote Originally Posted by shiggy View Post
    ...Thanks Shiggy, I had been looking at that. I actually think I might do better on the 18. I'm right on the line. The FS bike I'm on now has an ETT of 22.8.
    - -benja- -
    Too Much Fun
    Aug 2005
    good info, thanks!
    Quote Originally Posted by jimmay5469 View Post
    Yeah, we're pretty close in size, but I like a bit more stretched out position. I'm also new to 29'ers as well, so lots to learn.
    - -benja- -
    Dec 1998
    22.8"? That is nearly an inch shorter than the 18" Lurcher. You would be very stretched out.
    mtbtires.com
    Too Much Fun
    Aug 2005
    Good job! good catch
    Yikes, measure twice; cut once. I mis-read the Lurcher # as 22.7. It's 23.7.
    - -benja- -
    Reputation: Click Click Boom's Avatar
    I'm 5'11 and the med. frame fits me perfect. (90mm stem, no set back on the post) We have 2 Lurchers and 2 Scandals at the shop and if I could do it again I would have ordered the Scandal.
    I love the geo of he Scandal\Lurcher but I'm just not a carbon fan. I run a 32:18 gear ratio and even with the chain "BMX" tight I still get chain slap on the chain stays. The carbon frame also transmits every little sound. It does look great!
    Maybe Shiggy will cut me a deal on one or two more frames. They would be #5 and #6 in the past 60 days.
