Results 1 to 5 of 5
    Apr 2014
    Inbred SS 26er Limited Edition - Budget / Parts bin Build (and hello)
    Hi everyone, this is my current ride: Inbred SS 26er Limited Edition - Budget / Parts bin Build (and hello)-sbubpeo.jpg
    As you can probably guess by looking at the bike, I used to be into dirt-jumping as a lad. Now, after 4 years of living abroad and being away from mountain biking (although I kept my skills and legs strong as a commuter), I've lost my taste for big air and broken bones.
    I've been hitting the local XC trails several times a week and have been having a blast, even on this 13-inch, 32lb bruiser. More importantly, after just a few months of singlespeed riding, I noticed I'm smoother, faster, and stronger than I ever have been. Probably a similar story for most of you.
    Anyway, my back has started hurting before my legs and I'm taking that as a sign that you shouldn't ride XC on a oversized BMX bike. I'm 5'10'' with a 32'' inseam.
    Size: Initially I thought I wanted a 16", but now I'm pretty sure I need 18". I like a small-feeling bike, but I also want room for climbing even with a short stem.
    Carry-over parts: I will reuse my wheels/tires, brakes, drivetrain, and handlebar/stem/grips.
    New parts:
    Inbred frame
    Fork - used 100mm Rockshox or Fox from eBay. ideally a Reba.
    Avid Speed dial 7 levers
    Charge Spoon saddle
    FSA Orbit MX headset
    Halo Hex skewers
    On-one seatpost and clamp
    To deal with the rear BB7 problem, I'll just put my 185 front rotor on the rear, and order a 180mm post adapter and 180mm rotor for the front. A little funny, but it avoids having a wrong-size (180 or 183) rotor in the rear, while putting the front on the more common 180mm standard.
    Any ideas, suggestions? Thanks for reading! I'm planning to order everything but the fork this weekend. I'll wait for a great deal on a used high-end fork instead of grabbing something cheaper and newer.
    Reputation: akaBrowntown's Avatar
    Nov 2012
    Definitely go with the 18" and get a short stem for it - it will be a lot more comfortable and still be playful. As long as you plan on being in the saddle, the bigger option is the best bet.
    Sounds good. You will need a brake adapter for the 185 rear. I always tell people to get the seat clamp from OnOne cause the size is a bit hard to find but you have that covered. If you are ordering from the UK they will install the headset for you cheaper than a bike shop.
    Apr 2014
    thanks fellas. i am reconsidering the used Reba idea and i'm very tempted to put a suntour Axon or Epicon on there...
    pics as things progress!
    Apr 2014
    It's still right at 28lbs though, no doubt because of those burly azonic outlaws. For those interested, the frame was 2534 grams. 18"
    The fork is an ebay find - new old stock (2010?) Axon Werx ELD. ELD means electronic lockout, which is the ugly wire wrapped around my brake cable. The whole system adds about 250g by my estimation and I don't really use lockout, so I may try to remove it as a future project.
    Otherwise the fork seems stiff and supple, but I have yet to really test its durability. For now, I'm pretty excited about getting a 1650g, 100mm travel, 15mm axle fork for $200.
    Other parts:
    Avid Speed Dial + BB7
    FSA Orbit MX
    Gusset saddle
    Gusset lightweight front rotor
    KMC Rustbuster chain (we'll see)
    Race Face single ring
    Kore 45mm stem
    Funn riser bars (31.8mm)
    Heavy old stuff:
    26" Azonic Outlaw wheelset
    Truvativ V-Drive cranks (170mm)
    Truvativ Giga Pipe BB
    Weyless BMX pedals
    32x18 gearing
    Not the lightest, but cheap and should be tough as nails.
    Don't forget to keep an eye out for these guys:
  1. Superlight - budget/parts bin build
    By blilrat in forum 27.5
    Last Post: 07-09-2014, 04:03 PM
  2. My On-One Inbred 25lb Parts Bin SS Build
    By TwoNin9r in forum 29er Bikes
    Last Post: 12-01-2013, 07:26 PM
  3. Replies: 4
    Last Post: 11-21-2012, 06:44 PM
  4. Limited Edition Juicy 7's?
    By HoboBob5 in forum Brake Time
    Last Post: 07-30-2012, 05:50 AM
  5. Inbred SS Limited Edition
    By kvojr in forum On One
    Last Post: 06-13-2012, 04:00 PM
