Results 1 to 5 of 5
    Jun 2005
    Inbred with slot horizontal dropouts questions?
    I'm thinking of buying a 29er Inbred with slot dropouts.
    When running it geared, do you slide the wheel all the way forward? If so would I not need the chain tensioner?. Also, do you need to remove the disc brake caliper in order to take the rear wheel on and off? i thought I read somewhere that when the disc brake mounts are positioned inide the chainstays, like on the Inbred, the back caliper needs to be removed for wheel removal
    thanks
    Rhymes with fartmaster
    Quote Originally Posted by dragbike View Post
    When running it geared, do you slide the wheel all the way forward? If so would I not need the chain tensioners. Also, do you need to remove the disc brake caliper in order to take the rear wheel on and off? i thought I read somewhere that when the disc brake mounts are positioned inide the chainstays, like on the Inbred, the back caliper needs to be removed for wheel removal
    thanks
    If it’s a 1x9 or 1x10 setup then no problem. However, with a derailleur up front you need to slide the rear wheel back just a bit, as otherwise the tire will be flush up against the front derailleur! I ended up using two Surly Tuggnuts to keep things tensioned—I am running a bolt-through rear axle setup, so the Tuggnuts fit the bill nicely in order to keep the tire from jamming into the front derailleur.
    Jun 2005
    Quote Originally Posted by Leopold Porkstacker View Post
    I was actually planning to try it as a 1 x 9. Other option would be a 2 x 9 with a Shimano SLX front derailleur that is 2 ring specific. Its not as long as a 3 ring front derailleur. Maybe that would work too.
    thanks for the info!!
    Not true. I had mine set up as a 3x9 with the wheel all the way forward in the slot drops - no need for the Tugnuts. I was using a modified Sram FD.
    Quote Originally Posted by pulsepro View Post
    I have a crappy Shimano something-something el-cheapo (I think it’s a Deore LX) derailleur up front, and it has a lot of “backhang” (I made up a new terminology!) wherein the cable attach point mechanism is on the ass-end (toward the rear tire) of the unit, so I wasn’t so lucky with clearance. Good to know it can be done on the 29er.
