    Oct 2011
    inbred deraileur hanger, should i worry ?
    I'm assembling parts to build my first On-One, a geared inbred. I just realized the deraileur hanger is non-replaceable. Coming from an all aluminum frame background, i'm used to the replaceable hangers, I've bent a few and had to replace them. Does a steel frame shake off impacts that much better, do you just bend the frame back into alignment, is this even a concern to most other riders ?
    Reputation: Nater's Avatar
    Re: inbred deraileur hanger, should i worry ?
    Steel frames are more resilient. They can generally be bent back.
    Oct 2011
    thanks for the info, makes me feel a bit more secure
    I'll also add that the steel that makes up the dropout/hanger area is quite thick and burly....at least is is on my version with track ends (i.e. not the geared-only version). I've found that derailleurs snap before the hanger gets too bent.
  1. non-replaceable deraileur hanger-is it a big deal ?
    By lolaralph in forum Bike and Frame discussion
    Last Post: 09-27-2013, 05:08 PM
  2. Deraileur Hanger
    By net wurker in forum Transition Bikes
    Last Post: 05-23-2013, 09:00 PM
  3. Hifi deraileur hanger
    By likeaboss in forum Trek
    Last Post: 01-02-2013, 02:08 PM
  4. ABP deraileur hanger
    By bmxican114 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-18-2012, 12:07 AM
  5. do I need a deraileur hanger?
    By Thunderboltgreaseslapper in forum Singlespeed
    Last Post: 06-13-2011, 10:24 PM
