Results 1 to 84 of 84
    mtbr lurker
    Reputation: Drew69's Avatar
    Aug 2010
    Inbred 29 build thread
    After months of planning I've finally got the parts to build my inbred... I can't wait till I'm off work so I can go into work and finish it on my own time.
    There is a frame like yours on the auction site here in NZ and I'm tempted to go after it but never having built a bike from parts I'm a bit nervous ;] so I'll be watching this thread for hints and tips.
    An object in possession seldom retains the same charm that it had in pursuit. Pliny the Younger (62 AD - 114 AD)
    Brian
    mtbr lurker
    Aug 2010
    Building a frame like this is pretty easy. The only thing to note is that I sprayed the inside with T-9 (rust inhibitor) for some peace of mind. Building a bike is all about having the correct tools, if you don't have them go to a local bike shop.
    Short-Change-Hero
    Reputation: gregnash's Avatar
    Very nice... Cant tell you how much i love my 2nd Gen Inbred 29er (with Flows). Seriously an awesome riding bike. It is responsive, takes a good amount of the bump off most stuff and setup with a good fork it is near a superhero!!! With 100mm up front I feel like it is completely responsive without being twitchy (running a 19.5" with a 70mm stem). I have had multiple people stop me and talk to me about it, riding or not, and have completely blown the doors off guys in much more expensive bikes.
    What all are you setting her up with? Put up your spec list and waiting to see what she looks like and your ride impressions!!! NOTE: be careful with rear tire clearance and some front derailleurs, I have an M770 XT fd and with anything larger than 2.2" I have to just about slide the wheel all the way back to get clearance. I started out running a set of 2.35" tires and the rear wheel was as far back as I could go to clear them.
    mtbr lurker
    Aug 2010
    full spec..
    Hubs - hope pro 2 evo
    Spokes - DT 2.0 -1.8
    Rims -Stans Flow
    Skewers - hope
    Brakes - hope tech evo x2
    Rotors - hope floats
    BB- SKF 600
    Cranks- Middleburn
    Chain guide - MRP
    Chainstay protector - lizard skinz
    Seat Post - Kent Eriksen
    Saddle - Selle Italia Turbomatic GF
    Collar - Thomson
    Headset - Chris King
    Fork - On-One carbon
    Stem/Handlebar - FSA
    Shifter/Derailleur - Shimano XT
    Grips - ESI
    After I figure out my position I'll get a stem to match the collar and an enve or syntace bar
    mtbr lurker
    Aug 2010
    Nearly finished... I need a longer bolt and some spacers for my chain guide and I need to get some long rides in to finalize my position and cut the housing and hoses. First thing that hit me was how much more comfortable the total package is than the motobecane outcast.
    Reputation: Tubbsy's Avatar
    Looks great.
    Like you, I've almost finished mine but just ran out of time before returning to work.
    Jan 2011
    Nice build, i am also in the process of building mine. Waiting for other parts to come so i can start putting parts together.
    Mar 2012
    my first inbred build
    Anxiously awaiting my inbred 29er swap-out frame and was curious as to others' thoughts on forks.
    The question, for me, is not whether to run rigid, but what rigid fork to try. Any good/bad thoughts on any of these:
    white bros rock solid
    on one cro-mo
    salsa grande
    surly KM
    origina 8 black ops
    Feb 2010
    Drew, you must live in Florida...
    I've heard many good things about the new Surly KM. Thinner tubing, lighter weight, sleeker looks, etc. The older models weren't the greatest (from what I've heard). I haven't seen any steel On-One forks around, but if you can find one, I'd go with that strictly because of aesthetics. The salsa is more expensive, but they're in high demand and you'll be able to resell it if rigid isn't your thing. From this store its actually cheaper than the KM, so I'd pull the trigger on it now to save $30 or so.
    I'll be running my inbred with a Kona P2 I've had for some years, but like some of those forks you listed, don't seem to be in stock.
    Suspension and gears are the bastion of the proletariat.
    Feb 2010
    Quote Originally Posted by Tulsan View Post
    on one cro-mo
    salsa grande
    surly KM
    origina 8 black ops
    Outside outfitters has the grande for $72
    mtbr lurker
    Aug 2010
    Update
    Work has been slow so I took the time to go tubeless, the conversion was a breeze. The tires easily inflated without lubrication while using a floor pump. I'm still awaiting different bars/stem.
    25lbs 10oz with infamous ladybug bell
    Let's see some other inbred 29ers and weights.
    Short-Change-Hero
    Most recent picture of mine after pulling her down and dusting her off for the season. Just changed the front tire to a GEAX Gato to match the GEAX Saguaro in the rear. After a short gravel path ride with some pop offs the Gato seems like a great tire. Should have a better idea this weekend. Seat of the pants weight is about 28lbs.
    Untitled by renofizz, on Flickr
    Combat Wombat
    Reputation: BrianU's Avatar
    Quote Originally Posted by Drew69 View Post
    Looks Great! I got the same frame in orange and have everything, except for the fork waiting in the garage to be built up. Have a Salsa cromoto grande on the way that KodiakBear mentioned from Outsideoutfitters. What size frame are you running there? The 16" Inbred's effective top tube length is about 1/2" longer than my 16" Vassago, add in the different seat tube angle and I am not sure about stem length and if I will want any offset in the seatpost. I am just going to use an old Titec seatpost for now and experiment with several different stem/bar combinations I have in my garage and figure out exactly what I want. I plan to run mine with gears, since I already have a Vassago Jabberwocky SS. I need to mount the BB and crank to see if the GEAX Gato will allow me enough room to run a front derailleur. If I can, plan to run a 2X9 setup.
    If this thing rides anything like it looks, it is going to be kick a$$. Welds on my frame are the best I have ever seen on any production steel frame. After purchasing the frame from Planet X, was planning on just slowly picking up parts here and there when good deals popped up. I did start out that way, but as soon as I got a set of wheels, it was a done deal. Freak'in obsession I tell you. Been 4 years since I built up a bike and forgot how much fun this part of the process is.
    Oct 2010
    New Inbred 29 Build
    This is a bunch of 1sts for me. 1st 29 anything, 1st On One, 1st steel frame since my first MTB in 1990, 1st HT since my first MTB in 1990.
    Just finished the build. Dont have a weight yet.
    Small Inbred 29
    Marz Cors SL set to 120, 15 MM TA
    Crossmax wheels
    Hope M4 Pro brakes
    XTR rear shifter, mech and cass. (1x10)
    Widget 28T front CR
    Chris King BB
    Easton Havoc Bars
    Random other bits
    Going for first ride today. Heres hoping I like a 29 HT....
    Attached Thumbnails Attached Thumbnails Inbred 29 build thread-inbred-29er-001.jpg
    Reputation: meezo's Avatar
    Mar 2012
    i ordered the following :
    On One Inbred 29er Single Speed LTD Edition / 16 inch / Pearl White
    OnOne Oversize Flat Bar Handlebar / Black / MTB / 318mm Clamp
    OnOne 6061T6 Forged Alloy Seatclamp Bolt Up / 298 mm
    OnOne Smoothie Regular Headset / 11/8 / Black / External
    OnOne 3D Forged Stem / 100 mm / Matt Black / 6 degrees / 318mm Clamp
    OnOne chaintug / Quick Release Version
    OnOne Pivotal Seatpost / 272mm / Black
    OnOne Singlespeed Converter Kit with 16t Sprocket / 16t
    OnOne Carbon Fork / 11/8 / Black / 29er
    Got DT Swiss 450sl wheels and sella italia slr xp and esi grips.
    Can you guys please advise what crankset/chainset to get, i was looking at truvativ stylo 1.1 or the racefac respond, money bracket around $180
    I've just put two SLX crank sets on my Inbreds. Nice looking cranks without spending a fortune.
    I like the Shimano cranks, cheap and work fine for me (Deore LX, Hone).
    Don't forget to have the frame bb faced when using external bb bearings.
    Feb 2010
    Quote Originally Posted by Slash5 View Post
    I second that, you just might want a new (steel) middle ring. 32x16 is beast for a 29er IMO. Jenson has them for 130 I believe.
    I went with LX's on mine. People have said they're about a good as SLX's and XT's, which I doubt, but they have nonetheless gotten good reviews and are cheap.
    Mar 2012
    thanks guys, looking to go that route, currently running slx on my 26er ht... love them!
    Can't find much reviews on my previous listed cranksets
    Reputation: htnswches's Avatar
    I like XT cranks, can't find one thing bad about them. I have SLX on my 456 and those can be had a little cheaper.
    Here's my 29er Inbred
    small Inbred, sliding drop outs
    Rockshox Reba Team SL
    Shimano 2X10 Drivetrain XT and SLX
    Sun Ringle Charger Expert UST
    Conti Race Kings 2.2
    SLX disc brakes
    Thomson post and collar
    WTB Deva saddle
    Easton cockpit
    mtbr lurker
    Aug 2010
    Quote Originally Posted by meezo View Post
    I am very partial to shimano stuff as far as value and durability are concerned. Can't wait to see your build!
    Did I catch a niner+?
    <a href="http://photobucket.com" target="_blank"><img src="http://img.photobucket.com/albums/v319/mrpink57/d37428f1.jpg" border="0" alt="Photobucket"></a>
    18" Inbred
    Salsa Cromoto Grande Maxle fork
    Hope Pro 2 20mm/Paul WORD Disc
    Thomson X4 90mm -6deg
    Ergon Grips
    Shimano XT brakes 160mm f/r (ice tech)
    LX Crankset 175mm
    XT BB
    XT 32t chainring/WI Trials 18t FW
    HBC Nut Tuggers
    Time ATAC XS
    8 speed Ultrega chain
    Thomson Elite Setback 330mm
    WTB Pure V ti rails
    Stan's Flow
    Maxxis Ikon 3C EXC EXO 29x2.2 tubeless stan's juice
    King SS cage
    This is my "race mode"
    <iframe width="560" height="315" src="http://www.youtube.com/embed/kTQdNZyKRtU" frameborder="0" allowfullscreen></iframe>
    Just cleaned. Sound at end is my phone vibrating lol.
    Mar 2012
    i really hope my build looks as good as the above
    Mar 2012
    hi guys
    question, i've ordered the On One Inbred 29er Single Speed LTD Edition. question is i bought a set of dt swiss sl450 that come off a geared specialized, will i be able to run the ss conversion kit on the rear hub with no issue, does the distance between the rear stays(axle length) accomodate for this or would i have to get a short freehub?
    ps. I'm new to single speeders
    Assuming they are the usual mountain bike 135mm width and 9mm axle, they will work fine.
    I've just built up a Inbred 29er LTD and I'm using the normal wheels off my Trek Sawyer with a shim stack and a single speed cog. Works great and lets you get a perfect chain line.
    Mar 2012
    Thanks, got my wheels on sunday, waiting for my frame patiently!
    Mar 2012
    Frame arrived yesterday, will upload pics once i complete build.... I'm so excited!
    Mar 2013
    I have taken the plunge and I'm getting a On One Inbred 29er Single Speed (not so) LTD Edition in 21 inch in the Pearl White paint with the On One Carbon fork.
    thank you for being generous with all your build details. This will be a project bike for me so im taking the time to build it with the best parts i can.
    so far my kit swag looks like
    the frame kit,
    OnOne Inbred 29er Single Speed LTD Edition / 21 inch / Pearl White
    OnOne Fleegle Pro Handlebar / White /
    OnOne 3D Forged Stem / 80 mm / Polished Black / 17 degrees /
    HOnOne Spacer Set / Black
    OnOne Twelfty MTB Seatpost
    Parts bought
    Avid elixer 5 (black)
    Oury grips in Hot Pink or Orange
    parts to gets
    wheels [single speed only, not fixed]
    chain, cogs,
    disk rotors (prob 180/160)
    Crank Bros Candy pedals
    I'm looking for advice on what cranks and BB to source. I want the axel lengths to be as close to spot on as possible to get good chain alignment. can anyone help me out?
    I will upgrade the bike with a suspension fork and a hub gear in the not too distant future so this will be my project bike.
    cheers
    If you haven't already placed the OnOne order, get a seatpost clamp, the 29.8 size is a bit hard to find.
    The OnOne cogs and single speed chain ring are usually good deals - haven't checked the price lately.
    The best deals on rotors is usually on Ebay although you just missed some great rotor deals on Chain Reaction.
    As far as a crank, I'd just watch for the best deal you can find - everyone seems to like the Shimano SLX cranks. Jenson has them for $90 right now but looks like you are in Australia. You can sell the chain rings to offset some of the cost. The Shimano cranks are good because you can play with shims for the chainline.
    If you already have a 29er, you can pickup a rear wheel only and use your other front. I do that for several of my bikes.
    Does anyone know when Swap out Inbred 29 frames will be in stock? And do the new ones have the ISCG mounts? How about 2 water bottle mounts?
    I'll likely be looking to order a frame in the next couple of months. Keep the photos and build specs coming.
    Mar 2013
    Quote Originally Posted by cmscheip View Post
    Im not sure about the frames. might be best to contact On One. only they will know their stock levels and what might be on order.
    if your keen for mounts then remember that having a steel frame means you can find a frame builder to "tweak" the frame if you need it.
    Mar 2013
    I've finally now got my frame and I've finished building it up.
    its got a good mix to the components and after I finish playing with the setup I will be able to report about how it rides and start on planning stage 2 and 3 of my project bike.
    It's going to be my "get out and ride" bike. I still have my road bikes gathering dust and my other 29" mountain bike is still there for when I go to riding but this will be used to get milk or de stress. It's a BMX bike with 29" wheels instead of 20"
    No gears, no ultra fancy ultra light bits, no suspension forks to worry about.
    Bike Setup
    STAGE 1 (complete)
    Frame: On-One Inbred 29er Slot Dropout Pearl White
    Fork: On-One Carbon Fork
    headset: On-One Smoothie Regular Headset
    Seatpost: On-One Twelfty MTB Seatpost
    Stem: On-One 3D Forged Stem
    Seat Clamp: On-One TECH Series CNC Quick Release Seat clamp
    Handlebar: On-One Fleegle Pro Handlebar
    Tyres: package
    Cranks: Shimano SLX 175mm (green bolts)
    Front Ring: 34t
    Rear Cog: 18t
    Chain: no idea but it works
    Wheels: Mavic Crossride 29
    Disc Brakes: Avid Elixir 5
    Discs: Avid HS 1 (160mm)
    Grips: ESI (blue)
    Pedals: Crank Brothers Candy 2 (orange)
    Saddle: plank of wood?
    Stage 2: (projected mid 2014)
    100mm Suspension forks TBA (Reba/SID quality)
    Stage 3: (projected 2015)
    Hub Gear TBA
    Reputation: theNomad's Avatar
    Dec 2010
    so how do they climb? Lots of rear grip? How about the descent, is the HT angle slack enough to make it match the new offerings?
    I also wonder about the security of the slot drop outs on a geared setup. Anyone slipping wheels on drops or anything?
    Oct 2012
    I have two inbreds....darn those on-one frame sales! I would recommend a 100mm fork on these. The on-one site shows two sets of specs on their page and mentions both a 80mm and 100mm (max) fork size. I've emailed them and they said the frame was designed 'for' a 100mm fork, so there you go. Although, the on-one carbon fork you can tell is much closer to an 80mm riding height and lowers the BB.
    The first time I rode a 29er it was a vassago steel frame and fork. One of the first things I remember thinking was that there was a surprising amount of suspension feel on the front wheel. No so with the on-one carbon fork. This thing beats me up going downhill. I'm still waiting to get another tower pro for the second bike.
    I haven't had slippage issues with the track dropouts with my bolt-on hub, but I did get longer bolts just so I could get them extra tight without messing up threads. The few times I've ran a quick release with the surly chain tugg, I didn't have a problem either. The on-one chain tuggs also come in a quick release specific version.
    nice looking bikes
    Mar 2013
    Quote Originally Posted by theNomad View Post
    As far as how they climb, I'm on a single speed and I'm limited by my f34t-r18t combo with regard to everything speed related on that bike. Hands down it's the best MTB I own. It rides like a giant BMX, it's fun, tracks well and I'm happy with how it descends. I'm yet to go off road with it but the single speed was built to be my "get out and ride" bike. I still have my road bikes gathering dust and my other 29" mountain bike is still there for when I go to riding but this will be used to get milk or de stress. It's a BMX bike with 29" wheels instead of 20"
    The slot drop outs are a simple fix. Get a good chain tug. or if your wanting to use the frame you mentioned then i dont see there being any issues. if your wanting to use gears i'd probably recommend using the frame with the vertical dropouts instead.
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    Some updates to mine:
    Answer Protaper 780mm bars
    Manitou Tower fork
    Superstar/Pacenti TL28 wheels
    Dec 2010
    Well, I'm about to pull the trigger on an inbred 29 frame with swap dropouts unless a deal comes up used real fast or i get a comparable price on a Kona Unit etc. But at the Inbred pricepoint it seems it can't be beat.
    I have a New fork and a complete SLX drivetrain waiting for it. Just need to find a wheelset that is light on a budget.
    Short-Change-Hero
    Can you lace your own wheels? If you can look at BikeHubStore.com and use their hubs and some Kinlin Rims and then buy your spokes from Dan's Comp (you get free nipples with each spoke) and they you can have a pretty killer set of wheels for cheap.
    Mar 2013
    the Mavic wheelset i have on my inbred are good solid wheels. I'm really happy i got them and if you ever get a fork that has a Maxel axel then its a simple change and your in business.
    if you can get the swap out drop outs then id go for it and put the vertical drop outs on it.
    im really happy with the bike. its my project frame and when i can afford it I will do the stuff ive previously detailed.
    good luck
    Dec 2010
    I ccan lace my own wheels and I actually have a set of hubs (nothing too special) that have 160R and 180F rotors. I'll look into the prices to see if it can come out cheaper to lace up a set with tubeless rims as I hope to go that route soon.
    May 2012
    5 rides on it.... and our love is growing stronger
    Fender question.
    Inbred 29er frame has rack mounts. Would it be possible to add rear fender and fix it to the rack mounts somehow? Anyone who tried?
    It looks possible, however I don't really know which fender (or mudguard) would be applicable. (For example: Sledgehammer | Inbred 29er | Readers Rides - As Seen On TV )
    Anyway, this is my Inbred 29er:
    ___
    2016 Canyon Grand Canyon CF SL 8.9 tuned (fully-rigid, 1x11)
    https://www.strava.com/athletes/2373507
    Oct 2011
    My kid with his older Inbred before the last 20 mile descent on an October four day Kokopelli ride.
    Wheels are RH rims with 2.4 Conti X-King rear, 3.0 Knard front. KM fork.
    There's two chainrings (32-24) on the crank but no front derailleur. Shifting is done by hand or foot! Regular 11-36 10 speed cassette.
    Just Ride!
    Reputation: kustomz's Avatar
    Kokopelli ride, wow, I want to go back there so bad! That looks like a great set-up for riding that area too.
    Reputation: roeb's Avatar
    Mar 2014
    Hi guys,
    yesterday I have completed my Inbred 29er SSP. Soon I will change the black stem with a green stem and the current tires with RaceKing 2.2 tires.
    How do you like it?
    DSC_0521
    von roeb2k6 auf Flickr
    DSC_0510
    DSC_0515
    DSC_0517
    Reputation: newdee's Avatar
    Apr 2014
    Just Finished
    Looks great, I might have to get one myself. How tall are you? Is that the 19.5" frame? What fork is that? I haven't followed On One in a while... looks like BB7's fit now?!
    Apr 2014
    Quote Originally Posted by shogun9 View Post
    Im just a hair over 5'10". This is an 18" frame. I spent a ton of time trying to figure out whether to go with 16" or 18" because i didn't want to be too stretched out. The fork is a Kona P2 off of a Kona Unit i picked up used with the BB7's for a bargain. Rotors are 180 front and rear. You could make a 160 rear work with a 20mm IS adapter but its really difficult to adjust the cable clamp and you dont get all of the travel of the sliders before the arm hits the seat stay. I played with it for a while and had it working by pre tightening the cable and taking up some of the travel in the arm prior to bolting the caliper to the frame. I wouldnt recommend it though because the second you want to adjust anything you'll instantly have 45 minutes of mucking around to do. So i swapped out the adapter to a 40mm IS and a 180 rotor and everything fits perfectly now.
    Apr 2014
    new shoes!
    Velocity blunt 35 rims laces to shimano xt hubs.
    This bike has gone through a lot of bike changes over the years.
    It has settled on a fixed commuter/tourer to which I think it handles well.
    Specs:
    18in Inbred frame
    Cane Creek S3
    Salsa Enabler Fork
    Fat Sheeba
    Endomorph 3.6
    LX Cranks
    36t chainring
    Stans ZTR Flow
    Paul WORD disc hub
    Velosolo 16t
    Big Apple 29x2.35 tubeless
    Titec J Bar
    BB7 160mm
    XTR Brake lever
    Sun Ringle flats
    Ibera RA5 rear rack
    Ibera pannier
    Sette cooler trunk bag (for lunch)
    M Revelate Tangle bag
    King Cages
    Salsa Everything Cage
    I love this frame and I do not think I will ever get rid of it.
    Attached Thumbnails Attached Thumbnails Inbred 29 build thread-inbred_commuter.jpg
    Oct 2013
    Reputation: MMcG's Avatar
    Jul 2003
    Quote Originally Posted by newdee View Post
    new shoes!
    Can you share clearance photos of the back? What is the rear tire size you are running there?
    Do you think you could run Blunt 35 650b rims with 2.8 Trailblazers in back?
    Oct 2013
    Quote Originally Posted by MMcG View Post
    Orange round - the approximate 650b wheel with 2,8 trailblazer in Inbred 29er frame.
    Attached Thumbnails Attached Thumbnails Inbred 29 build thread-dsc_0944-.jpg
    Apr 2014
    I sold these wheels. I'm now running a 2.25 Nobby Nic on a Blunt SS in the back. The inbred doesn't have a ton of clearance so i doubt a 2.8 would work due to the shape of the chain stays. Here are some photos of the Nic with the dropouts in the front 1/4 of the dropouts.
    Attached Thumbnails Attached Thumbnails Inbred 29 build thread-img_20151111_145931.jpg
    Apr 2014
    i should add that it looks closer the the sidewall than it is because the camera is centered over the tread/chainstay dimple. Nevertheless, i dont think B+ on an inbred is practical.
    Reputation: toothpuller's Avatar
    650B+ wtb trailblazer 2.8 and velocity blunt 35mm rims does not fit in the back. It fits, but with tire run out, there is rubbing. It's a no go.
    Jul 2003
    Quote Originally Posted by toothpuller View Post
    Good to know! Thank you for informing us.
    20 years in the woods
    ... and if we just ...
    Greetings from Portugal.
    Inbred 29er 18"
    Salsa Cromoto
    Superstar wheels,chainring
    Funn Flame handlebar
    X9 + XT
    10,5kg=23,2lbs
    Gajas what?
    Jun 2014
    I just ordered my On-One inbred 18" frame and looking forward to building it up! I am hoping that the size I went with inst too small and hoping other riders can chime in. I am 6'1" with an inseam of 34".
    I am your same size and have been riding the 18" frame for several years. I stretched the cockpit by using an 80mm stem and a 25mm layback seatpost. It will depend somewhat on your proportions and your preferences, but I think you will be OK on it. BTW, if you compare the 18" to the 20", the seat tube is 2" longer, but the front triangle is only 1 cm longer, so not much help. That's why I went with the 18".
    Jun 2014
    Quote Originally Posted by j0hn View Post
    Awesome! Thanks for the info man. I am coming from a XL Karate Monkey that was wayyy to big for me but I got a deal on it. Seems like the 18" runs a little bit bigger than most other frames. Do you have pics of yours?
    The title of this thread is specific to the 29er Inbred, but mine is 26er. I think the 29er isn't available on even number sizes, so I'm pretty sure yours is 26er as well, right?
    How's this? There are a lot of On-One parts on this bike.
    Jun 2014
Name:	inbred on tidal wave.jpg
    The Inbred 29er is offered in a 18"
    On-One Inbred 29er Single Speed Mountain Bike Frame LTD Edition | On - One
  67. #67
    OK, for some reason I was thinking the 29er version was built using odd sizes (15, 17, 19 etc). Thanks for the correction. I looked up the geometry chart and the 18" 29er has an effective top tube of 619mm while mine is only 602mm. This frame should fit you really well.
  68. #68
    Jun 2014
    Yeah I think so also. Have a straight 410mm seat post for now with a 70mm stem to test. Can always make adjustments if necessary! Thanks for the feedback.
  69. #69
    Apr 2014
    Im pretty sure this is a mistake on their site. I contacted on-one about this... like... two years ago, and they still haven't corrected it...
    I believe that the geometry page shown for the regular vertical dropout model is correct, while the geometry for the ltd version is bogus. you'll notice the geometry chart on the ltd page has sizes that you cant order, that is, the sizes simply dont match up. As far as im aware, the 18" 29er LTD i bought has a 602mm ETT
  70. #70
    Jun 2014
    This is the frame I bought:
    One One Inbred 29 Single Speed Frame | eBay
    His measurement says:
    18 inch C-C, 21 Center to Top. 24" long top tube so this is for a taller rider. Probably 6 foot or more.
  71. #71
    Apr 2014
    Quote Originally Posted by kendalja View Post
    so that would be the largest frame size, based on the center of the bottom bracket to the top of the seat tube dimension.
    i just measured my Center to top Dimension (for what is supposed to be an 18"), and its 457mm, which would be consistent with the vertical dropout chart,
    On-One Inbred 29er Mountain Bike Frame Vertical Dropout | On - One
    not the ltd chart, even though it is the ltd model
    i can only imagine how much confusion this has caused for them, so im surprised it hasn't been fixed yet
  72. #72
    Jun 2014
    So this frame should still be ok for me though?
  73. #73
    Jun 2014
    So you are saying this is the 20"?
  74. #74
    Apr 2014
    i don't have any experience in terms of bike fitting. i only commented because i had the same confusion with regards to sizing.
    the frame measurements on ebay are sloppy, so the C to Top of seat tube is the only thing you have to go by. One one doesn't state their actual top tube lengths, and the ebay ad doesn't say if that effective, center to center, or just the top tube between the welds.. etc. If its the 21" on the vertical dropout geometry page, or the 20" on the LTD page(if there are really two different sets of frame geometry for the same bike), its probably going to be longer than your karate monkey.
  75. #75
    Jun 2014
    Yeah I agree the measurements are very sloppy. I am hoping that this bike is not too big for me
  76. #76
    Jun 2014
    The seller said "I'm 5'10" and it's too big for me by a little bit"
  77. #77
    Jun 2014
    Can anyone here chime in who owns a 21" On-one inbred?
  78. #78
    Not sure why you wouldn't start your own thread for this question.
    You will need to run a real short stem.
    I'm 6' 1" with a 34" inseam when measured for bike fit, not pant's inseam.
    I ride the 19.5 frame and it fits me with around 90mm stems and about a foot or so of seatpost showing.
    I have one 18" frame and need a 410mm seatpost to get enough insertion.
    A couple of the 19.5 frames:
    The 18" frame:
  79. #79
    Jun 2014
    Monday I received my 21" used frame from winning an eBay auction and was super excited. Only to find this:
    I filed a claim and seller refunded my money but lesson learned. I decided rather to buy used I purchased a new one direct from on-one. Just thought I would share my experience on here and will continue to post pictures of my build. I did however get to keep the frame and am looking into repairing it. I was also able to determine that the 21" frame is a bit too big for me and ordered the 19.5". Cheers!
  80. #80
    Apr 2014
    Yikes!
    Where is the crack?
  81. #81
    Jun 2014
    Yikes!
    Where is the crack?
    Non-drive side chain stay where the divot is for tire clearance.
  82. #82
    Feb 2016
    Salsa Cromoto fork
    Hope 50mm stem
    Archex on Hope Evo Pro II; ardent 2.4 front, 2.25 rear.
    Xt cranks, changing between 1x9 and 3218,19, 20) depending on what's happening, same for the saddle and bars - but currently SDG bel-air and Thomson xc carbon ~720mm(?) ish.
    SLX brakes 180mm front, 160mm rear.
    Hope headset cups, Hope chain ring.
    ~5 years old(?), has the love marks to prove it as well.
    People have ragged on it since I bought it; albeit colour choice, rigid set up, frame weight etc etc - but its rad, and highly recommended.
  83. #83
    Jun 2014
    Just completed mine and weighs in just a tad over 21lbs.
  84. #84
    Apr 2014
    awesome.
  1. On One Inbred Build
    By konak in forum On One
    Last Post: 01-08-2017, 01:50 PM
  2. On-one Inbred Build
    By Mudsimus in forum On One
    Last Post: 06-13-2011, 02:25 AM
  3. On no, another Inbred thread
    By marty_hd in forum Singlespeed
    Last Post: 12-15-2008, 07:45 AM
  4. Replies: 8
    Last Post: 04-05-2007, 02:18 PM
  5. Inbred 29er complete OR Inbred 29er frame + build kit
    By jahona in forum Bike and Frame discussion
    Last Post: 04-03-2007, 09:35 AM
Members who have read this thread: 8
