Page 2 of 2 FirstFirst 12
Results 51 to 84 of 84
  1. #51
    Reputation: newdee's Avatar
    Apr 2014
    Quote Originally Posted by shogun9 View Post
    Looks great, I might have to get one myself. How tall are you? Is that the 19.5" frame? What fork is that? I haven't followed On One in a while... looks like BB7's fit now?!
    Im just a hair over 5'10". This is an 18" frame. I spent a ton of time trying to figure out whether to go with 16" or 18" because i didn't want to be too stretched out. The fork is a Kona P2 off of a Kona Unit i picked up used with the BB7's for a bargain. Rotors are 180 front and rear. You could make a 160 rear work with a 20mm IS adapter but its really difficult to adjust the cable clamp and you dont get all of the travel of the sliders before the arm hits the seat stay. I played with it for a while and had it working by pre tightening the cable and taking up some of the travel in the arm prior to bolting the caliper to the frame. I wouldnt recommend it though because the second you want to adjust anything you'll instantly have 45 minutes of mucking around to do. So i swapped out the adapter to a 40mm IS and a 180 rotor and everything fits perfectly now.
  2. #52
    Apr 2014
    new shoes!
    Velocity blunt 35 rims laces to shimano xt hubs.
  3. #53
    Did I catch a niner+?
    This bike has gone through a lot of bike changes over the years.
    It has settled on a fixed commuter/tourer to which I think it handles well.
    Specs:
    18in Inbred frame
    Cane Creek S3
    Salsa Enabler Fork
    Fat Sheeba
    Endomorph 3.6
    LX Cranks
    36t chainring
    Stans ZTR Flow
    Paul WORD disc hub
    Velosolo 16t
    Big Apple 29x2.35 tubeless
    Titec J Bar
    BB7 160mm
    XTR Brake lever
    Sun Ringle flats
    Ibera RA5 rear rack
    Ibera pannier
    Sette cooler trunk bag (for lunch)
    M Revelate Tangle bag
    King Cages
    Salsa Everything Cage
    I love this frame and I do not think I will ever get rid of it.
    Attached Thumbnails Attached Thumbnails Inbred 29 build thread-inbred_commuter.jpg
  4. #54
    Oct 2013
  5. #55
    Reputation: MMcG's Avatar
    Jul 2003
    Quote Originally Posted by newdee View Post
    new shoes!
    Can you share clearance photos of the back? What is the rear tire size you are running there?
    Do you think you could run Blunt 35 650b rims with 2.8 Trailblazers in back?
  6. #56
    Oct 2013
    Quote Originally Posted by MMcG View Post
    Orange round - the approximate 650b wheel with 2,8 trailblazer in Inbred 29er frame.
    Attached Thumbnails Attached Thumbnails Inbred 29 build thread-dsc_0944-.jpg
  7. #57
    Apr 2014
    I sold these wheels. I'm now running a 2.25 Nobby Nic on a Blunt SS in the back. The inbred doesn't have a ton of clearance so i doubt a 2.8 would work due to the shape of the chain stays. Here are some photos of the Nic with the dropouts in the front 1/4 of the dropouts.
    Attached Thumbnails Attached Thumbnails Inbred 29 build thread-img_20151111_145931.jpg
  8. #58
    Apr 2014
    i should add that it looks closer the the sidewall than it is because the camera is centered over the tread/chainstay dimple. Nevertheless, i dont think B+ on an inbred is practical.
  9. #59
    Reputation: toothpuller's Avatar
    650B+ wtb trailblazer 2.8 and velocity blunt 35mm rims does not fit in the back. It fits, but with tire run out, there is rubbing. It's a no go.
  10. #60
    Jul 2003
    Quote Originally Posted by toothpuller View Post
    Good to know! Thank you for informing us.
  11. #61
    20 years in the woods
    ... and if we just ...
    Greetings from Portugal.
    Inbred 29er 18"
    Salsa Cromoto
    Superstar wheels,chainring
    Funn Flame handlebar
    X9 + XT
    10,5kg=23,2lbs
    Gajas what?
  12. #62
    Jun 2014
    I just ordered my On-One inbred 18" frame and looking forward to building it up! I am hoping that the size I went with inst too small and hoping other riders can chime in. I am 6'1" with an inseam of 34".
  13. #63
    I am your same size and have been riding the 18" frame for several years. I stretched the cockpit by using an 80mm stem and a 25mm layback seatpost. It will depend somewhat on your proportions and your preferences, but I think you will be OK on it. BTW, if you compare the 18" to the 20", the seat tube is 2" longer, but the front triangle is only 1 cm longer, so not much help. That's why I went with the 18".
  14. #64
    Jun 2014
    Quote Originally Posted by j0hn View Post
    Awesome! Thanks for the info man. I am coming from a XL Karate Monkey that was wayyy to big for me but I got a deal on it. Seems like the 18" runs a little bit bigger than most other frames. Do you have pics of yours?
  15. #65
    The title of this thread is specific to the 29er Inbred, but mine is 26er. I think the 29er isn't available on even number sizes, so I'm pretty sure yours is 26er as well, right?
    How's this? There are a lot of On-One parts on this bike.
  16. #66
    Jun 2014
Name:	inbred on tidal wave.jpg
    The Inbred 29er is offered in a 18"
    On-One Inbred 29er Single Speed Mountain Bike Frame LTD Edition | On - One
  17. #67
    OK, for some reason I was thinking the 29er version was built using odd sizes (15, 17, 19 etc). Thanks for the correction. I looked up the geometry chart and the 18" 29er has an effective top tube of 619mm while mine is only 602mm. This frame should fit you really well.
  18. #68
    Jun 2014
    Yeah I think so also. Have a straight 410mm seat post for now with a 70mm stem to test. Can always make adjustments if necessary! Thanks for the feedback.
  19. #69
    Apr 2014
    Im pretty sure this is a mistake on their site. I contacted on-one about this... like... two years ago, and they still haven't corrected it...
    I believe that the geometry page shown for the regular vertical dropout model is correct, while the geometry for the ltd version is bogus. you'll notice the geometry chart on the ltd page has sizes that you cant order, that is, the sizes simply dont match up. As far as im aware, the 18" 29er LTD i bought has a 602mm ETT
  20. #70
    Jun 2014
    This is the frame I bought:
    One One Inbred 29 Single Speed Frame | eBay
    His measurement says:
    18 inch C-C, 21 Center to Top. 24" long top tube so this is for a taller rider. Probably 6 foot or more.
  21. #71
    Apr 2014
    Quote Originally Posted by kendalja View Post
    so that would be the largest frame size, based on the center of the bottom bracket to the top of the seat tube dimension.
    i just measured my Center to top Dimension (for what is supposed to be an 18"), and its 457mm, which would be consistent with the vertical dropout chart,
    On-One Inbred 29er Mountain Bike Frame Vertical Dropout | On - One
    not the ltd chart, even though it is the ltd model
    i can only imagine how much confusion this has caused for them, so im surprised it hasn't been fixed yet
  22. #72
    Jun 2014
    So this frame should still be ok for me though?
  23. #73
    Jun 2014
    So you are saying this is the 20"?
  24. #74
    Apr 2014
    i don't have any experience in terms of bike fitting. i only commented because i had the same confusion with regards to sizing.
    the frame measurements on ebay are sloppy, so the C to Top of seat tube is the only thing you have to go by. One one doesn't state their actual top tube lengths, and the ebay ad doesn't say if that effective, center to center, or just the top tube between the welds.. etc. If its the 21" on the vertical dropout geometry page, or the 20" on the LTD page(if there are really two different sets of frame geometry for the same bike), its probably going to be longer than your karate monkey.
  25. #75
    Jun 2014
    Yeah I agree the measurements are very sloppy. I am hoping that this bike is not too big for me
  26. #76
    Jun 2014
    The seller said "I'm 5'10" and it's too big for me by a little bit"
  27. #77
    Jun 2014
    Can anyone here chime in who owns a 21" On-one inbred?
  28. #78
    Not sure why you wouldn't start your own thread for this question.
    You will need to run a real short stem.
    I'm 6' 1" with a 34" inseam when measured for bike fit, not pant's inseam.
    I ride the 19.5 frame and it fits me with around 90mm stems and about a foot or so of seatpost showing.
    I have one 18" frame and need a 410mm seatpost to get enough insertion.
    A couple of the 19.5 frames:
    The 18" frame:
  29. #79
    Jun 2014
    Monday I received my 21" used frame from winning an eBay auction and was super excited. Only to find this:
    I filed a claim and seller refunded my money but lesson learned. I decided rather to buy used I purchased a new one direct from on-one. Just thought I would share my experience on here and will continue to post pictures of my build. I did however get to keep the frame and am looking into repairing it. I was also able to determine that the 21" frame is a bit too big for me and ordered the 19.5". Cheers!
  30. #80
    Apr 2014
    Yikes!
    Where is the crack?
  31. #81
    Jun 2014
    Yikes!
    Where is the crack?
    Non-drive side chain stay where the divot is for tire clearance.
  32. #82
    Feb 2016
    Salsa Cromoto fork
    Hope 50mm stem
    Archex on Hope Evo Pro II; ardent 2.4 front, 2.25 rear.
    Xt cranks, changing between 1x9 and 3218,19, 20) depending on what's happening, same for the saddle and bars - but currently SDG bel-air and Thomson xc carbon ~720mm(?) ish.
    SLX brakes 180mm front, 160mm rear.
    Hope headset cups, Hope chain ring.
    ~5 years old(?), has the love marks to prove it as well.
    People have ragged on it since I bought it; albeit colour choice, rigid set up, frame weight etc etc - but its rad, and highly recommended.
  33. #83
    Jun 2014
    Just completed mine and weighs in just a tad over 21lbs.
  34. #84
    Apr 2014
    awesome.
  1. On One Inbred Build
    By konak in forum On One
    Last Post: 01-08-2017, 12:50 PM
  2. On-one Inbred Build
    By Mudsimus in forum On One
    Last Post: 06-13-2011, 02:25 AM
  3. On no, another Inbred thread
    By marty_hd in forum Singlespeed
    Last Post: 12-15-2008, 06:45 AM
  4. Replies: 8
    Last Post: 04-05-2007, 02:18 PM
  5. Inbred 29er complete OR Inbred 29er frame + build kit
    By jahona in forum Bike and Frame discussion
    Last Post: 04-03-2007, 09:35 AM
