Results 1 to 2 of 2
    inbred 100mm versus 456 at 100mm
    Hi all,
    I am looking for a 14" frame to built up as an offroad touring bike for my girlfriend. As the 14" inbreds are sold out, I thought maybe a 456evo ran with a 100mm fork would do too. Anyone with knowledge of angles can explain me how big of a difference there is between an inbred and a 456evo if both are run with a 100mm fork?
    Anyone rides a 456evo with a 100mm fork? Experiences? Pictures?
    Thanks.
    Reputation: CarolinaPanthers's Avatar
    Feb 2013
    I rode at 456 Evo2 at 120mm for a little while, thought the a-t-c was pretty close to the 150 Sektor I replaced it with. It was pretty comfortable on the rocky and steep, but the angles were obviously slacker with a taller fork. Probably not the same kind of riding she'll be doing where slightly steeper angles might be a little more favorable.
    The only con I foresee is a low bb at 100mm on the 456, but other that that it seems like a little more relaxed Inbred. I am ASSUMING the geo numbers from the Inbred are taken at 100mm but I could be totally wrong.
    Working with that assumption in mind:
    HA: 69* head angle on the 456 vs. 70* on the Inbred
    SA: The seat angle may a tiny bit steeper on the 456? It is 71.2* static at 150mm so a shorter fork should steepen that out a few degrees.
    ETT: 456 has a longer ETT, 571mm vs. 546mm. That could be remedied with a shorter stem on the 456 compared to what she would run on the Inbred, otherwise she might feel like she was leaning too far forward.
    Aside from that, I would venture to say they seem pretty similar. The bottom bracket might be lower on the 456. Not sure if pedal strikes are a concern, but that's a thought. Keep in mind I am not sure at what length fork the Inbred measurements were taken. Though if the posted Inbred measurements are at 80mm, the two should have pretty comparable geo at 100mm.
  1. Need Advice: Rockshox XC32 TK 100mm Vs Rockshox SL TORA 100mm
    By rajasekharbpai in forum Shocks and Suspension
    Last Post: 10-03-2013, 10:14 PM
  2. Got 100mm 29" HT what next 100mm 120mm or 140mm FS?
    By cloudbuster in forum General Discussion
    Last Post: 08-24-2013, 04:23 AM
  3. 100mm EBB Possible?
    By Dubeditions2 in forum Frame Building
    Last Post: 08-23-2013, 07:09 AM
  4. Reba RLT 100mm Or SID RCT3 100mm
    By kevinboyer in forum 29er Components
    Last Post: 03-18-2012, 01:53 PM
  5. jet 9 80 or 100mm
    By esach in forum Niner Bikes
    Last Post: 03-20-2011, 06:36 PM
