Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 76 to 100 of 117
Thread: Dirty Disco
  1. #76
    Hey Tyliquila,
    Those black decals look great, who made them for you? I'd like some for the DD I'm building.
    This is mine, built it myself and I'm lovin it!
    54 sized frame with Shimano 105 shifters and rearmech, cx70 crank and frontmech, Thomson post, clamp and stem, salsa cowbell.
    The wheels are XT hubs with some old mavic cxp33 rims, I had layin around. I'm thinking abouting replacing them with some of those Chinese plastic hoops.
    Had some flat black decals made for the bike because the original white ones were a little bit "loud" for me. Really like how they turned out
  2. #77
    I see that they are out of stock in everything but Smalls. Any idea when big boy sizes will be back in stock?
    2009 Fuji Tahoe Pro 29er
    1982 Fuji Supreme
    200? Cannondale Prophet
    2011 Focus Mares AX3
  3. #78
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Trooper46 View Post
    We should have more in a few weeks
    mtbtires.com
  4. #79
    Jan 2009
    Any of you current Dirty Disco owners have a satisfactory fender set-up? I know it's possible to fudge together a fender setup on nearly any bike, but the DD seems not to have a drilled fork crown or seat stay bridge, which makes it difficult. Workarounds?
    I'm so close to ordering this frameset, but will need good fenders. It will be a 'cross race bike for 1.5 months and a rain/commuter for the next 9...
  5. #80
    Off the back...
    Reputation: pinkrobe's Avatar
    Anyone rolling the TRP Hywires yet, or are they still vaporware/unobtanium?
    dgsmills.com
    #pinkrobeyyc
    CMBA
  6. #81
    Nice bike, just wondering if you have toe overlap with this frame.
  7. #82
    Dirty Disco
    I just finished building my Dirty Disco. I think it is an awesome disc cyclocross for the money. I wanted to find a frame that closely matched to my 54 sized Madone geometry. The 54 Dirty Disco fit the bill. The only big difference is 10 mm longer top tube and slight slacker steering angle. The Dirty Disco also has a longer wheelbase which is a big welcome.
    I'm impressed with the ride quality it has. It feels silky smooth over rough roads and gravel roads. It must be the combination of the carbon frame and the 34mm tires that I am running on the bike. I have no toe overlap on the Dirty Disco with 34 tires. I always did have toe overlap on other similar sized bikes.
    I have a few minor issues with the frame. I ride with my heels in. My right heel sometimes rubs the rear chain stay tube. I thought it must be the way the chain stay tube is shaped to clear the wider 135mm hub. What I found out that my crankset is not centered on the frame. The bottom bracket shell does not have any offset. I have checked all my other road and cyclocross bikes and all of them have a offset of approx 2.5 mm to the drive side. The crankset is 1/4 inch off center to the left. I am using two washer on the right pedal spindle to remedy the heel/chainstay rubbing. I am thinking of using bottom bracket spacer or crankset spindle washer to shift the crankset a bit to the drive side.
    My other issue is where the brake cable mount is placed on the chain stays. It takes up some clearance if I want to run fatter tires. It takes up about 1/8 inch. It is placed on the top. I think it should have been placed on the sides unless this would weaken chain stay structurally.
    With those minor issues, I am still having a blast on this bike. I am sure those are a non-issue to most.
  8. #83
    Sep 2012
    Quote Originally Posted by shiggy View Post
    Hey shiggy, 2 questions.
    Is the frame sale officially over? If so, how long is the wait until the next one?
    Any changes on the new frames coming in or just a new run of the current setup?
    Thanks.
  9. #84
    Manchester, England
    Reputation: Chocolatebike's Avatar
    Here's mine just after I got it:-
    Disco ! Yeah baby ! by Chocolatebike1, on Flickr
    On One Dirty Disco by Chocolatebike1, on Flickr
    And here it is during and after an overnight ride along Hadrian's Wall:-
    12-09-29 Carlisle-Newcastle Disco Baby by Chocolatebike1, on Flickr
    12-09-29 Carlisle-Newcastle Tyne bridges by Chocolatebike1, on Flickr
    It's my first carbon bike and I think it's fantastic. I bought the frame and fork as a stop-gap to use the running gear from my broken Ti bike. I'm getting a new Ti frame under warranty but I'm not sure that it will do anything better than the Disco.
    The guards are old style Race Blade XLs with the addition of extension pieces from my old Crud-Catcher Road Racers. The CC RR piece behind the down tube is fantastic.
    I'm doing a 200k Audax on the Disco on Saturday.
    Bring it on !
    My only gripe:_
    Frame, fork and headset from Planet X UK- 699.99GBP
    Frame and fork from Planet X USA- 549USD (~340GBP). That's an expensive headset.
    ETA a further picture. You can see the clearance with 24mm tyres:-
    12-09-29 Carlisle-Newcastle Disco Tyne by Chocolatebike1, on Flickr
  10. #85
    jdg
    jdg is offline
    Max tire size?
    Sorry if I missed it but what is the max tire size?
  11. #86
    Bro Mountainbiker
    Reputation: Sheepo5669's Avatar
    May 2010
    Quote Originally Posted by jdg View Post
    I believe they say 38mm. But I dont know if that is with mud clearance or without. I can measure with my vernier calipers when im back at the shop.
    Raised in a Chicken-Coop by Chickens
  12. #87
    Dec 2009
    I measure 50mm gap in the fork. I have 38mm tires on mine now, and plenty of space up front, but that's about all will fit between the chainstays.
  13. #88
    jdg
    jdg is offline
    Thanks for the info all.
  14. #89
    Nov 2006
    Dirty Disco headset
    I am looking to buy Dirty Disco frameset from Titus USA but they are out of Dirty Disco headset, so questions please:
    Will this be compatible? Wiggle | FSA Orbit C-40 ACB Black 1 1/8 Aheadset | Headsets
    or this Wiggle | FSA Orbit C-40 ACB (48mm) Black 1 1/8 Aheadset | Headsets
    or this Wiggle | FSA Orbit CF-40 Industrial Headset | Headsets
    I can buy one from On-One UK but will cost twice as much as any of the above 3 (will be last option)
    Many thanks.
  15. #90
    Hi Chocolatebike.Just purchased a XL DD myself. I was very interested in your recent pictures especially of the Hadrian's Wall Cycle route - Newcastle end. Can I ask what seat bag were you using? Is it something from USA or is it a Carradice? It would fit well on my XL version. Adrian
  16. #91
    Manchester, England
    It is a Carradice, an SQR Tour. This one:- SQR Tour saddle bag
    I'm very pleased with it, it holds enough for a few days B&B touring.
    I also bought an extra mount so I can move the bag between bikes.
  17. #92
    Dirty Disco
    Thanks for that info. I know of the bag but never seen one before, now that I have seen it in action will definetly get one. Intrigued also to know what tyres size do you use for road. Did you mention a 24 mm size are they Contis? I am using the tyres I have acquired over the years ie an old set of Marathon Racer 32mm but looking at poss Schwalbe Ultremo ZX or Durano plus to purchase. Adrian
  18. #93
    Manchester, England
    The tyres are Vittoria Pave SGs, the green tread is just visible on the last photo.
    All of the running gear came off my Ti bike when the frame cracked; the Disco is really just a stand-in until I get a warranty replacement for the Ti frame.
    When that arrives, I might get a little more creative with the Disco's tyres; I'm a big fan of Marathon Supremes so I might put some 28mm versions of those on it. 28mm Ultremo ZXs are another alternative.
    That's unless I decide to put some actual cross type tyres on it !
  19. #94
    Dec 2009
    Quote Originally Posted by mttklmhifi1 View Post
    I used to ride with my heels in, which makes your knees stick out at the top of the stroke. Then I, after a fitting, realized I was compensating for having my feet locked into my pedals without varus shims, or "flatfooted." Now that my feet are shimmed with wedges under my cleats, my feet point straight ahead, and my legs are in line with pedals throughout the stroke.
    Varus wedges - Road Bike, Cycling Forums
    To compensate for the lack of wedges, I was pointing toes out to avoid stress on my knees.
    Re. the brake cable clip, they must be riveted by hand: mine doesn't do that.
  20. #95
    Quote Originally Posted by mudrock View Post
    Iím the opposite. My knees used to bang the top tube and my right heel rubs the crankarm before being fitted with soles/shims. I have slightly higher than Medium arch. I use superfeet soles to support my arch and prevent arch collapse at the bottom stroke. I have been called a duck because my toes point out. I have tried two varus shims on right shoes and one varus shim on the left. They make my feet point out straight but place my knees too outward. I have been using one varus shim on the right shoe and flat shim on the left. My heels are slightly in but no rubbing or pain. Knees pedal in straight lines. This setup works perfect for all my other bikes until the Dirty Disco bike. I have moved the FSA bottom bracket crush washer from non-drive side to the drive side. This eliminated any heel/chainstay rubbing.
  21. #96
    I wonder if it is okay to drill out a drain hole in the bottom bracket. My Dirty Disco is getting filled with water after riding in the rain.
    I use my Dirty Disco for rain and gravel rides. I noticed the bike was getting heavier but didnít think anything of it until I hanged my bike by its front wheel. Water was pouring out of the seatpost. Should I somehow caulk the rail clamp mount where the water enters or just drill a drain hole in the bottom bracket?
  22. #97
    PRETENDURO
    Good thing itís not a steel frameÖ as for cutting/drilling cabron fibre, Iím not the guy to ask.
    QUOTE from MTBR.COM: You have given Brewtality too much Reputation in the last 24 hours, try again later.
  23. #98
    Planet Bike Speedez Hybrid fenders + Dirty Disco = happy rider
    Quote Originally Posted by TwoWheelMan View Post
    I use the Planet Bike Speedez Hybrid on my DD...I love the coverage and adjustability. I've used these fenders on my last three commuter bikes (two with disc brakes, one with mini-v.)
  24. #99
    Manchester, England
  25. #100
    Hey Shiggy,
    Can you get these frames? I don't know what size I need, I'm 5'9" with average proportions. It's going to be a road bike with bullhorn bars.
    Thanks,
    Shawn
  1. Cleaning my dirty dirty shoes
    By SuccaMC in forum Apparel and Protection
    Last Post: 03-11-2009, 10:51 AM
  2. Replies: 41
    Last Post: 12-13-2006, 03:58 AM
  3. Dirty, Dirty, ExoGrid!!!
    By N8! in forum Titus
    Last Post: 09-04-2006, 07:20 PM
  4. You dirty, dirty girl! (Wily content)
    By motoman711 in forum 29er Bikes
    Last Post: 05-13-2005, 01:56 PM
  5. Sloppy Dakota Ridge + Dirty Dirty White Ranch
    By ibmkidIII in forum Passion
    Last Post: 01-27-2004, 06:17 AM
