Results 1 to 31 of 31
    C456 Chainring Clearance
    So I'm building up my first bike, i'ts been pretty fun so far. However, I am a little worried by the chainring clearance. I put the SRAM x7 2x10 crankset on with 42T big ring and 28T little ring, it looks like there's about 1-2mm of clearance between the ring and the chainstay.
    Is that enough? Should I just buy the 39T and 26T ring? Do I have any other options?
    Oct 2007
    1-2mm sounds a little tight. Can you get pics? I would think that a 42/28 should work fine, is it possible you left out a spacer or something from the BB?
    2015 Niner Jet 9 Carbon
    2014 Focus Raven 27R
    2017 Lynskey GR250
    2016 Niner BSB
    1987 Haro RS1
    Yea, I'll get pics up in a second.
    As you probably know, the BB is 73mm so I didn't think spacers were required, there weren't any spacers in the box anyways.
    I've read quite a few people have had the same issue with 2x10 setups
    Quote Originally Posted by lee p View Post
    Is the issue just in general, or for the 456 specifically?
    I guess I can really only do two things, try and see what happens, if it rubs I'll have to get the smaller rings...
    Feb 2012
    Quote Originally Posted by kbrodie View Post
    You sure? The 3x9 SLX cranks need one 2.5mm spacer on the chainring side with the 73mm BB. With a 68mm BB, three of those are needed.
    You could try throwing a spacer in anyways.
    I've got an extra spacer in one of my single speed bikes to improve the chainline and it doesn't seem to cause any problems.
    Positive, no spacers required. They're only used on 68mm BB.
    Oct 2007
    That pic you posted looks okay. I think you have more than 1-2mm of space, I would not worry about it. If it rubs though you need to do something about it. Carbon is not like aluminum, you can do some serious damage if it is rubbing.
    2017 Lynskey GR250
    2016 Niner BSB
    1987 Haro RS1
    I've always fit one spacer on the drive side of 73mm anyway so I would do that, I've read on a few forums though of people finding it tight with the c456 and 2x10, go on one of the bigger British forums and do a search as lots of people seem to be running c456 over there
    GUIDANCE COUNSELOR
    Reputation: NoahColorado's Avatar
    SRAM cranks don't work like that - putting a spacer on the drive-side will have ZERO effect (it won't move anything....anywhere). The only way to get the chainring further out would be to remove material from the face of the non-drive side shell - and I probably wouldn't recommend that!
    NOAH SEARS
    MRP - Brand Manager
    Pivot Cycles - Team Rider
    Quote Originally Posted by NoahColorado View Post
    seems to be the consensus with the GXP cranksets, looks like my only option is to get some 39 and 26T chainrings for like $90.
    Any idea of the difference in radii b/w the 39 and 42T rings, I took a rough estimate by guessing the width of one T to be around 1cm (actually i measured), so the circumference would be about 39cm. So it would be smaller by about 3/pi cm. or about 0.9 cm. Which would probably give me about 5-7mm clearance instead of the 1-2 mm I have now.
    Oh well, thanks for the quick responses, I'll post picks when it's done. It's kind of a frankenbike b/c I just bought parts I could find good deals on. It's yellow and blue and has an embarrassingly long stem with a huge 150mm fork. It's kind of an oxymoron.
    Feb 2012
    Please post a picture of your bike when its complete. The yellow frame must be looking good. Btw. 150mm stem seems to be quite long for the 456C. I run mine with a 40mm stem (130mm fork / 650b wheels) and I love it. 60mm stem felt too long.
    Lol no, the fork is a sektor 150mm. I'm a little disappointed though, I just saw the $300 Revelation on competitive cyclist, oh well. I want to put the spacers in to drop it to 130mm, but the manual makes it seem pretty complicated, so I'll have to make do.
    The stem is 105mm, I didn't realize how long it was when I made the purchase. Eventually, when I scrounge up some dough I will buy a different stem. I was thinking of going with 70mm, but maybe that's too long? My limbs are pretty long, so I'll have to wait and see how stretched out I feel.
    Feb 2012
    My bad, I blame the 15 miles I just rode for my poor reading focus. I dare not recommend a specific stem length, my torso is short and my arms are even shorter so a short stem works for me, but when you look at the On one site, they recommend 40-60mm stems with most of the 456C frames. On-One Carbon 456 Un-Decaled Frame
    Yea, I've noticed. I don't have wheels on yet, but I have the saddle, fork and bars on. I tried kind of squatting down into the position and honestly didn't feel stretched at all, we'll see how it feels when I get it all together and make the necessary changes.
    Hope the ride went well. Any particular stem brands/models you recommend. What's the difference between a $30-50 stem and a $100 stem. I feel like as long as nothing comes loose or flexes and it's not a pig a cheaper stem would be fine.
    All That is Man
    Reputation: Zero Signal's Avatar
    The 2012 RaceFace Ride stems are cheap/light and come in short lengths. The big difference will be weight/strength and overall quality. The fancy ones say they're 'stiff'. I'm not sure how that translates to a stem. I've never experienced a flimsy stem. I wouldn't go any more expensive than an Easton Haven or RaceFace Turbine. I just ordered a 70mm RF Ride stem and a 750mm wide FUNN Fatboy bar for my 456c (20" frame), I'm 6'-0" with a short torso, but I like a long TT and bars level with the seat and I do mostly AM/XC riding, no real DH.
    John
    Feb 2012
    +1 on the Race Face stems. I ride with a 25.4 handlebar so my choices are very limited, but below is a 60mm Race Face Ride which works just fine. I found it on sale under $20.
    I switched since to a 40mm NC-17 S-Pro. It was one of a few options for 25.4 bars and it was deeply discounted, too.
    Darn, wish I'd seen this earlier. I just bought a Pro FRS stem this morning, in white.
    Went to get the brakes today from the LBS. Last time I was in there they had a set of 2011 Elixir CR's and he said $250 (maybe he meant each, I thought he meant for the set). I went in there today to pick them up and they said $400, then $300. I told them I'd rather go with some SLX and not worry about bleeding them every week.
    So now it's time for brakes, it seems that the SLX M666s are the way to go, reliable and good stopping power. I guess, I'd have to get some rotors and maybe adapters too. Anyone have other brake suggestions and or rotor suggestions?
    All That is Man
    Yeah, SLX is the way to go. For rotors, I'd go cheap (Alligators) or go Icetech. Youcan get the SLX brakes and Icetech RT-67 rotors for under $300 online.
    John
    Quote Originally Posted by Zero Signal View Post
    Any links? What about adapters for the SLX, the front is post mount and the rear is IS. I think I'd be fine with 160mm for the type of stuff I'll be doing, if not, I can make the necessary changes later.
    Here is the cheap but risky option...AVID ELIXER CR Pair Hydraulic Disc Brakeset Brake Set Red 160mm F + R NEW: 348493 Random Bike Parts
    $180 for the whole set.
    All That is Man
    I priced that from Universal Cycles
    John
    Feb 2012
    The SLX brakes should come with all the mounting hardware. Btw. the 456C will likely make you want to ride more aggressively than "the usual stuff you have been doing so far". I would strongly recommend considering a 180mm rotor in the front / 160mm in the rear, that is what I did after several dozens of miles with 160/160.
    OK, cool I was looking at universal, b/c that's where I can get the chainrings too. Unfortunately, the RT-67 don't come in 6 bolt, are there adapters or are there any cheap rotors I can get from universal as well?
    All That is Man
    The Alligator rotors from Pricepoint are pretty cheap, about $15. Yeah the RT-67s are centerlock and the non centerlock ones are about double the price. I don't know of any adapters for CL rotors to 6-bolt hubs.
    John
    I ended making my last purchases last night. I bought the wavy alligator rotors, 180 up front 160 in the rear and all the necessary adapters/brakes, as well as the new chainrings.
    How long does Universal usually take for a confirmation e-mail, because I haven't received one yet...
    My wheels came yesterday, a pair of DT Swiss m1800's. I was looking at ordering some hope pro 2's from wiggle, but found this set on ebay for a good price. I have heard that the hubs are pretty awesome and the wheels say they're hand made.
    I guess this has turned into a build thread. Would you like picture updates as I build, or a surprise finished build pic at the end?
    All That is Man
    Not sure how long they take. Give it a couple days. Just start a new thread for your build thread and keep us updated. I haven't seen a yellow 456c yet . . .
    John
    A waste of time it is is
    Reputation: emu26's Avatar
    stihacka, could you please tell me your bb height with the 650b wheels in your 456? Thanks
    Feb 2012
    Quote Originally Posted by emu26 View Post
    With a 130mm fork and NeoMotos 2.3 on a narrow rim, it is 13 5/8" to the center of the BB when unsagged.
    Thanks very much for that.
    I have just found your build thread as well and noted that you mentioned the bb height there as well. Very nice looking bike. Thanks again.
    Feb 2012
    Thank you Emu. I hope I gave you the same answer as I did the last time. I should update my thread as I replaced a few parts already and I like the bike even better.
    To the OP: I cannot wait to see the pictures of your Big Bird!
