There is not enough clearance for the arm to move completely. Am I the only one having this problem? This picture is with the 160 mount. I tried a 140 mount and it still won't fit. Any advice would be greatly appreciated.
I have the same problem on my non-swapout horizontal dropout Inbred 29er with the Avid BB7 caliper. I think the only solution would be to up the rear rotor size to a 180/185mm and move the caliper forward a bit… or not be so frugal and get hydraulics… although I SUCK at bleeding hydraulic systems.
QUOTE from MTBR.COM: You have given out too much Reputation in the last 24 hours, try again later.
I would add that my XT hydros are worth every penny. No issues, very good smooth braking. Have then on 2 On One's, although the BB7s on my kids' Inbreds work well and are a good value. I also used a 185 rotor and adapter on one of them in the rear, on a 16" 26er frame.
I have the same issue on my med C456. Except going up to 180mm rotor didn't exactly fix the problem. I got it working, but my brake is grabby as all hell. I imagine a 203mm might work.
I know that the SLX brake will work for sure, but I wanted to keep the hydros on bikes I actually enjoy and not just on the girlfriend machine.
160 should fit, 'cause you don't need the whole stroke of the BB7.
You can see the cable is slack, just tighten it a bit, just enough so the bolt doesn't touch the seatstay.
[img]http://forums.mtbr.com/attachments/one/729529d1349836990-bb7-rear-wont-fit-my-inbred-29er-swapout-cimg2449.jpg[/img
The solution to this problem is simple - ask On one / Titus to replace your current swapout with a different one that mounts the caliper behind the seatstay. I am not talking about the SS one - they have a different design that mounts the caliper outside of the rear triangle.
Yes it's still a problem. Worse on 26ers and small frames. I had to frig around with my large 29er Inbreds to get them to work.
Shiggy isn't with OnOne anymore.
I have a slot dropout Inbred 29er, size 18".
I use the road BB7 (160mm discs) and I encountered the same problem -actually on both a 16" and a 18" frame- , solved with a low-profile hex head bolt.
I took a standard hex head bolt out of my junk box and cut the head down to about half height on my lathe.
You could do the same by chucking it in a drill and running it against a grinder or Dremel.
I got a moderately low profile torx bolt from McMaster Carr. Not as low as a button head, but lower than the stock. Only issue is that you can't get in at the bolt without removing the caliber, which is easiest if you remove the wheel. Not a huge deal, but it is definitely something that should have been seen up-front, as BB7's are pretty standard fare on mountain bikes, and especially budget builds, which On-One Frames lend themselves to.
