Page 9 of 9 FirstFirst ... 56789
Results 401 to 417 of 417
Thread: 45650b
  1. #401
    Tor
    Tor is offline
    Jan 2013
    Thanks again! I took a new measure today, and the widest point is at 33cm, wich means even more space, so I guess it will work
  2. #402
    Jun 2015
    Any new info about it?
    Quote Originally Posted by Tor View Post
  3. #403
    San Miguel Beer Drinker
    Fun bike!!!
    Saving up for a better fork and wheelset.
  4. #404
    Changed the wheelset to hope+wtb
    Fork is pike
    Zee brakes
    Loads of fun
  5. #405
    Sep 2004
    45650b
    AWESOME BIKE! Fast! Nimble!
    Small frame
    RS Revelation @130mm travel
    KS dropper post
    Renthal 50mm stem
    Shimano XT 1x11 speed drivetrain
    Stans EX Arch
    WTB Vigilante(2.3 F) Trailboss (2.25R)
  6. #406
    Dec 2012
    is the rear hanger / dropout part of the frame? in case of braking it can it be repaired?
  7. #407
    Quote Originally Posted by brandaopj View Post
    Yes it's part of the frame, not a separate hanger. It's a steel frame so the mech is likely to break before it does. If it was damaged you could look into welding it, but the frames are so cheap to replace anyway
  8. #408
    Steel is far less brittle than say aluminum, so when you snag the dérailleur, the hanger bends. You can usually bend it back, but the alignment has to be perfect. If you can't swing it then find a local frame builder to help you.
  9. #409
    Dec 2012
    thanks for the replies.
    how well does the raw goes trough the years?
    Does it need some special attention?
  10. #410
    Dec 2012
    does the stickers come off easily of the raw?
  11. #411
    Sep 2015
    I think the stickers are under the clear. That don't look easy to remove on mine.
  12. #412
    ILIKEBIKES
    They are under the clear... you have to first remove the clear to get at the stickers. I was doing mine- lots of sanding.
  13. #413
    Mar 2011
    Anybody running 1x11 have issues backpedaling in the largest cog? I want to know if the chainstays are too short.
  14. #414
    Sep 2015
    Quote Originally Posted by Honda Guy View Post
    I am running 1x10 with a 42 tooth cog, and once I got my chainline right, I can backpedal all day. I would think 1x11 would be the same.
  15. #415
    There is no reason to think a "short" chainstay would cause that, the differences in lengths of CS among bikes is fairly minimal, even between wheelsizes. The issue of the chain skipping down the cog is fairly common, and has a lot more to do with chainline. Bring your cranks inboard if possible. Otherwise, just don't backpedal while in the lowest gear...
  16. #416
    MTB Addict
    Quote Originally Posted by max_lombardy View Post
    A short chainstay length will make the angles slightly more significant. But unless there's a several inch difference in chainstay length, it won't be enough of a difference to matter between any 2 bikes.
  17. #417
    Mar 2005
    genius
    all of ya'll
    GENIUS-SSSS
    it's like reading a family circle cartoon...and twice as mind-bending
  1. On-One 45650b
    By etal in forum 27.5
    Last Post: 08-01-2015, 01:27 PM
  2. 45650b C "Red Fox"
    By StiHacka in forum On One
    Last Post: 11-04-2014, 04:58 AM
