Page 10 of 17 FirstFirst ... 6 7 8 9 10 11 12 13 14 ... LastLast
Results 226 to 250 of 405
Thread: 45650b
  1. #226
    Reputation: TwoNin9r's Avatar
    Jan 2011
    Re: 45650b
    Quote Originally Posted by sambosuda View Post
    So I'm running a 50mm Renthal Duo, love the look of the stem. My issue is I feel very cramped and too upright while riding.
    Thinking of going w/ a 70mm stem to stretch out a bit more. Anyone else riding this combo?
    I'm on a 60mm stem but super wide bars and I dont feel cramped at 6'3" (on a 20" frame)
  2. #227
    Mar 2014
    Current bars are 740mm and The 50mm stem.
    Maybe I'm just use to my XC setup 29er.
  3. #228
    Jan 2011
    I will say I'm going down to a 760mm bar from a 780 (mostly because they're yellow!)
  4. #229
    Those of you who are 5'9 and went with 18", do you wish you had the 16"? I will be using mine for all mtn with a 140mm xfusion on the front. I ride an 18" giant trance x with 26" wheels but looking at the geo chart of the on one, the top tube on my 18" trance is the same as the top tube on the 16" on one.
    I'm just scared i may be too stretched out but i have no idea.
    There's something about those long grueling climbs that gets my front end all stiff... And I'm not talking about lockout...
  5. #230
    Jan 2014
    Quote Originally Posted by kikoraa View Post
    I'm 5'10 and riding an 18" with 40mm stem and 720 bars and my saddle quite far forward in the seat rails. It is a fun bike but I could definitely ride a 16" comfortably and run wider bars because I'm used to riding a medium SC Solo with 50mm/730mm bars.
    You could swing either way and be happy. I bought mine bigger so other mates could ride it and it's more XC friendly as I have the solo for bigger jump tracks .etc
  6. #231
    45650b
    Wishing I went with a 18.
    Running a 80mm stem on my 16' w/740mm bars.
    How tall are you?
  7. #232
    Mar 2014
  8. #233
    Reputation: Ramjm_2000's Avatar
    Jan 2005
    Another persons fit isn't going to help you at all, especially if your in between sizes. I'm 5'9" and ride the 18" with a 60mm. Fits like a glove with saddles rails dead center. In my case a 16" would have been a mistake.
  9. #234
    Quote Originally Posted by Ramjm_2000 View Post
    Same here. 5'9" on an 18 with a 50mm stem. I was wishing for a 17" when I ordered but I went big and its perfect.
  10. #235
    Mar 2014
    How tall are you?
    I'm 5'10"
    I have short legs and a longer uper body. 29.5" inseam.
    will probably end up selling my 16"
  11. #236
    45650b
    Hmm. I'm 5'9 with long legs and short torse/reach. Maybe the 18" with a short stem would suffice.
  12. #237
    Mar 2014
    Since I removed my On One decals, the probibility of them exchanging my frame is very slim.
    Guess I'm just going to ride it. It doesnt feel terrible at all.
  13. #238
    45650b
    Should be done this weekend. Unbelievably excited about this build. 140mm x fusion velvet, 1x10 with a race face narrow wide.
    Debating weather I should just use a clutch derailleur or use my non clutch with a bionicon c guide.
    My clutch is currently on my 2x10 full suspension.
    Any ideas?
  14. #239
    Jan 2011
    Run the 1x10 with the clutch and the 2x10 with the non clutch, seems logical? I run a race face nw on mine with a non clutch slx rd ans even that refuses to drop chain.
  15. #240
    Jan 2011
    Re: 45650b
    Specs sheet and better photos will follow
  16. #241
    Reputation: HarMi's Avatar
    Aug 2014
    Could somebody measure inner width of chain stays? For example 1, 2, 3 and 4 inch behind the bottom bracket. The question is how wide 26" tire can be mounted to 45650B frame?
  17. #242
    Big Paws on a Puppy!!
    Reputation: Ratman's Avatar
    May 2005
    My apologies if this question has been asked/answered already but is it possible to install a fork with a straight 1.5" steerer tube on the 45650B?
    ‎"My bicycle masters boardwalk and quagmire with aplomb." - Tom Nuttall
  18. #243
    Quote Originally Posted by Ratman View Post
    That's a good question. I know you can run tapered using an external bottom cup (EC44). I wonder if you could use the same for the top? I really don;t see why it wouldn't work considering the headtube ID is the same through.
  19. #244
    Jan 2011
    Re: 45650b
    Yes. Straight or tapered. I have a straight steerer.
  20. #245
    Jan 2011
    Any head tube that will accommodate a tapered fork will accommodate a straight steerer by changing the bottom cup of the headset (I'm sure there are exceptions, but that's the general rule). On the 45650b, you can run a tapered fork on an external cup lower headset and a straight steerer in either an external cup or inset. Though I don't see any reason top run an inset unless you had maybe a 160mm straight steerer fork as the frame it's designed for up to 150
    So for straight steerer
    zs44/28.6 ec44/30
    Though you could use zs44/28.6 zs44/30 as mentioned above, but it would just lower you're geo a bit
    And for tapered
    zs44/28.6 ec44/40
  21. #246
    He was asking about a 1.5" straight steerer. vs the more common 1-1/8th.
  22. #247
    Jan 2005
    TwoNin29r was correct. Its all about the headset.
  23. #248
    Jan 2011
    Re: 45650b
    Bahaha
    My bad. Then yes, as long as they make an ec44/38.1 top cup
    Like this, I think.
    http://www.universalcycles.com/shopp...s.php?id=61209
  24. #249
    Jan 2011
    Re: 45650b
    Quick shot of my 45650b and my old (now my friend's) inbred 29
  25. #250
    Jan 2011
    Re: 45650b
    Got this text from the wheel builder.
  1. On-One 45650b
    By etal in forum 27.5
    Last Post: 08-01-2015, 01:27 PM
  2. 45650b C "Red Fox"
    By StiHacka in forum On One
    Last Post: 11-04-2014, 04:58 AM
