I am thinking to build Scandal 26"-frame with rigid 29er fork (Salsa CroMoto Grande). The fork's A-C is 468mm, and since I am also planning to use On-One Smoothie Regular Headset with extra 5mm on lower cup, total "fork height" will then be identical to A-C of 100mm suspension forks.
According to On-One site, geometry of Scandal is based on fully extended 80 mm fork, but I need standover with fully extended 100 mm fork. If anyone has Scandal or Inbred (which has same geometry) in size 20" with fork of similar A-C, I would be very thankful if you could measure standover height of your bike.
