Results 1 to 27 of 27
    Rod
    Rod is offline
    Reputation: Rod's Avatar
    Oct 2007
    Question - I keep breaking spoking on the non drive side (disc brake side)
    What's the easiest way to deal with this? I've just been replacing them as they break. I've broken 4-5 now. Should I just keep replacing them as they break? I'm thinking about getting a bigger gauge spoke and just retruing the entire rim. What have you guys done? I've never broken a spoke, but the rear wheel on this wheelset can't handle my braking.
    There is not much choice between rotten apples.
    Rabid Lana fan
    Sounds like un-even spoke tension issues. A loose spoke will cause the opposite spoke to have extra force applied when it rolls to the bottom of the axis and has to support all the weight at that instant. (the loose spoke at the top isn't "carrying it's weight" so to speak)
    rOCktoberfest 2015 pt I here
    rOCktoberfest 2015 pt II here
    Rabid Lana fan
    This is assuming at least semi-quality wheels and spokes....cheapo wheelsets, all bets are off.
    I'm just messing with you
    Reputation: wv_bob's Avatar
    I had the same problem. Just go ahead and replace them all on that side and get it over with. Once I did that the problem stopped for me.
    Doubtful your braking caused it. Mine started when I caught a stick and broke one, then every time I'd go out another would break. Apparently breaking one overloads another then it just cascades from there.
    Chasing bears through the woods drunk with a dull hatchet is strongly not advised
    Rabid Lana fan
    If you have it trued, have the wheel builder be more concerned with even spoke tension, and less concerned with "true".
    Reputation: Fishbucket's Avatar
    Dec 2012
    Is this the
    " Because it's a new year, we can type bikes in the OC"
    thread??
    High Desert MTBer
    Reputation: rockerc's Avatar
    Huh? What are these 'spokes' of which you speak in the OC?!?
    It's all Here. Now.
    Rabid Lana fan
    OMG, you guys are right!
    I just had an 'out-of-forum' experience.
    Rod
    Rod is offline
    Oct 2007
    I used a tension meter and went through the entire wheel. I then trued the wheel. It worked for awhile, but I just broke a spoke on my new year's eve ride. The spokes that I break are always on the non drive side. It's a Stan's crest wheelset. It's about a year old. I'm just frustrated with it.
    Rod
    Rod is offline
    Oct 2007
    Quote Originally Posted by rockerc View Post
    Well played sir
    Rabid Lana fan
    Quote Originally Posted by Rod View Post
    So did you have to "compromise" the tension on some of the spokes to get it "true"?
    Rabid Lana fan
    I do my own wheels, and once I quit going for "real true", and started going for even spokes, and just accept alittle out of round, I quit breaking spokes.
    Rod
    Rod is offline
    Oct 2007
    To be honest, I probably did. I'll replace this spoke and then around the wheel again with the meter and check the spoke tension.
    I guess the question is, so after i tension everything up evenly and it's not straight, what do I do?
    Rabid Lana fan
    I just leave it. Rim brakes it would be a real issue, disk brakes, not so much.
    Rabid Lana fan
    I will admit, if you do a lot of high-speed fireroad downhill runs, a wobbly wheel is noticable. Anything up to around 30mph, hardly.
    Rod
    Rod is offline
    Oct 2007
    I do ride the road and fireroads quiet a bit, especially in the spring. I'll borrow the tension meter and go from there. If it happens again, I'll just replace the non drive side with larger spokes. These spokes are a little small for my taste.
    Seriously, go ahead and replace all the spokes on that side that haven't already been replaced. I went through the same crap you did, ride one day, fix it the next. Wash rinse repeat. I also posted a thread here to ask about it, but in the wheelbuilder's forum.
    Coincidentally, mine were breaking on a Stan's wheel too, Arch on ZTR hubs, factory build.
    I thought of pointing out the no bike talk in here rule, but I'm not inclined to tell anyone they're doing anything wrong.
    Here's a link to the thread where I asked about the problem
    spoke breakage - next move?
    Dec 2010
    Once one spoke breaks, it puts more stress on the others. Then another breaks and puts more stress on the others. And so on... It's truly a never-ending cycle. We always replace all spokes (drive and non drive side) once this begins to happen. It solves the issue completely, and as long as the rim and hub are in good shape it's like riding a brand new wheel. I'd suggest a complete rebuild, although replacing just the non-drive side is still better than replacing one at a time.
    live long and huck
    Reputation: Optimus's Avatar
    With much patience and a good understanding of how the groups of 4 spokes actually relate, you should be able to get the wheel pretty much perfectly true, zero rotational run out, and all spokes tensioned within 5% of each other. Of coarse a dished rear rim will have a higher tension on the drive side, but you should be able to get each side within 5% of itself. 1.8-2.0 double butted spokes are plenty strong enough.
    Rod
    Rod is offline
    Oct 2007
    Thanks guys. Bob, I would rather ask in here due to me only using this forum for the past two years. I "know" these guys, know who builds their own wheels, and in short, trust their advice.
    Yeah Rod I know what you mean. It's less likely you'll get a STFU N00B kind of answer in here.
    The few wheels I've built (or rebuilt) it seems like if you just go slow and get the tension equal early, it's not a big deal to build a good wheel. It takes me forever to finish one but it's not like I'm paying myself by the hour anyway.
    Rabid Lana fan
    I always seem to run out of patience, and have to settle for a little out of round or a bit of uneven spoke tension to get it perfect. I guess if I committed to the time, I could get a wheel there.
    Rod
    Rod is offline
    Oct 2007
    You're absolutely right Bob. It appears I just need to replace the spokes, take my time, and make sure everything is tensioned evenly again.
    Thread already spun
    Reputation: Zowie's Avatar
    Aug 2013
    Quote Originally Posted by wv_bob View Post
    Nope, you're paying yourself by the year... as they continue to roll.
    Yeah and now I'm over the hump so they're rolling faster and faster as I head downhill.
    live long and huck
    In about an hour I lace one up and run all of the nips in until the spoke pushes the screw driver out of the nip. Then for maybe 2-3 nights after work I take a cup of coffee out in the garage and true while I enjoy my coffee. Usually I get the wheel pretty much perfect in maybe another hour, maybe an hour and a half. Being a ToolMaker/Engineer type, I'm pretty anal about even the smallest run out, but I've had pretty good luck building my own.
  1. 2mm gap at Truvativ GXP drive side?
    By phoeneous in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-17-2017, 12:11 AM
  2. Replacing drive sold screw pivot on drive side?
    By Jaybo in forum Niner Bikes
    Last Post: 07-29-2012, 09:05 PM
  3. Replies: 4
    Last Post: 04-02-2012, 04:31 PM
  4. 2.5mm BB spacer on drive side
    By Bailey44 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-09-2012, 12:11 PM
  5. Drive side vs Disc side tension
    By edispilf in forum Wheels and Tires
    Last Post: 08-19-2011, 08:03 AM
