Results 1 to 14 of 14
    Reputation: Fishbucket's Avatar
    Dec 2012
    I think my laptop is gonna catch fire !
    Man , this thing is too hot to touch on the bottom near the heat sink.
    and the hinge on the left is really hot too. It's a work computer, gonna take weeks and a trip to San Jose to get it looked at. Then if I get a new one, transferring all the files and crap takes all day !
    Hey Miraculous... Go Raiders ! .
    -Dad
    El Gato Malo
    Drop it like it's hot.....
    <iframe width="560" height="315" src="//www.youtube.com/embed/RaCodgL9cvk" frameborder="0" allowfullscreen></iframe>
    9 lives
    Fire down below
    F*ck Cancer
    Eat your veggies
    Binned
    Nov 2008
    Too many hot porn scenes.... your laptop is close to having a "big O". Rub it sensuously to send it over the edge.
    Dec 2012
    I shut it off to cool and within 3 mins. it's hot again.. Like you cant touch it hot.
    Crazy !
    I'm going to try and clean it tomorrow... I better find the fire extinguisher first..
    Gonna turn it off again... Be back later.
    -Dad
    Ride More, Work Less
    Reputation: heyyall's Avatar
    Check to see if the fan is clogged. One more thing, watch less porn.
    Craigslist & MTBR --free ads for all
    Quote Originally Posted by heyyall View Post
    The problem is worse if one uses cornstarch or body powder instead of a liquid type for "lube". The cornstarch leaves a cloud during the big O that gets sucked into the fan. Oh, I read this on the internet..
    lean forward
    Self Appointed Judge&Jury
    Oct 2000
    ~ B A D A S S ~
    Reputation: car bone's Avatar
    Quote Originally Posted by Fishbucket View Post
    Is it a highend computer such as a Thinkpad T or W, or possibly an Elitebook? Or perhaps a Panasonic Toughbook? If not, there is your problem.
    And I'm serious too.
    Rule #9 // If you are out riding in bad weather, it means you are a badass. Period.
    Quote Originally Posted by iheartbicycles View Post
    Specialized sucks ass.
    Dec 2012
    It's a Thinkpad T420 ... The Computer company I work for dolls them out.
    I for got to get my temp probe out and see just how hot it is. I might run down to the truck and get it.
    It's been running for a few hours and I can smell the hot plastic. I also put in a req. for IT to tell me what to do.
    They will respond by email, just after it goes in flames and evacuates the building..
    brb.
    Edit:
    At the left speaker grill I got 124 deg.F on the bottom at the same location it's 130 deg.F at the left hinge it's 97 deg. F
    ****** to the dirt
    just use it in a walk in freezer and you'll be fine.
    Dec 2012
    Quote Originally Posted by deke505 View Post
    that's Thinking inside the box !
    -Dad
    ~ B A D A S S ~
    You need to get all the dust out from the computer, lenovo has guides on their site that shows you how to totally disasseble everything. And you are not voiding the warranty afaik with thinkpads by doing this. after a few years the coolers get clogged with dust and it needs to be removed. Also when you have it in pieces you should replace the cooling pasted between the coolers and the cpu/gpu. the best chemical to remove this with is diethyl ether, its found in "car starting gas", then remove the remaining thin film with acetone or booze. Also sometimes you need to shim the distance between the cpu/gpu and cooler with copper pieces that you have to make yourself.
    If you are unlucky you have a coputer that always was running hot due to it being a thin version and/or someone chose to put in a "highend" (=really hot) gpu, then there is nothing you can do to eliminate the problem, but you can get as good as new or like a bit better by doing what I wrote up there. ^
    ~ B A D A S S ~
    I have a t400, but i chose the slowest cpu and intel onboard gpu and therefor the most quiet and coolest model in the range. Mine gets like warm but never hot no matter what.
  1. N gear chain catch vs high $$$ chain catch
    By crclawn in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-10-2012, 08:24 AM
  2. OT - What I did with an old Laptop
    By SilkMoneyLove in forum General Discussion
    Last Post: 02-21-2012, 02:48 PM
