    I'm just messing with you
    Reputation: wv_bob's Avatar
    Any EE's, techs, or hobbyists? Looking for advice
    I've got a Harbor Freight wireless motion detector alarm that signals a base station to ring a chime.
    Wireless Driveway Alert & Driveway Alarm System
    It's got plenty of range to reach all corners of my house, so I wondered if there was any way to interface it to a PC, so instead of ringing a sometimes useless chime, it could be configured to do multiple things - for example, text me. The things are close to dirt cheap, so it could be an effective way to home-brew a security system on a budget.
    I took it apart and it's got two wires from the circuit board to the chime, so it seems do-able if I could get some advice on how to interface that to something (like a basic stamp or ??) that could in turn signal the controlling PC.
    The attachment shows the circuit board, and the two green wires go to the chime and are about 4 inches long. The base station is powered by 3 C-cells. I can take it apart further, if it would help.
    Any suggestions are appreciated.
    Attached Thumbnails Attached Thumbnails Any EE's, techs, or hobbyists?  Looking for advice-clipboard06.jpg
    Chasing bears through the woods drunk with a dull hatchet is strongly not advised
    Flappity flappity flap
    Reputation: Zowie's Avatar
    Aug 2013
    I don't know if it would be all that much cheaper than AVR/Arduino stuff.
    Maybe if you have a serial port still, and can find a DC signal on that board? (Probably AC audio going to the chime?)
    I was hoping to just use what I've got, since I've already got the sensor & base gadgets, and PCs out the wazoo. Undoubtedly I've got one with a serial port, I know I've got them back through Windows95, but I think I got rid of all the DOS and C/PM stuff.
    As for a DC signal ... we both missed the three red LCDs left center on the board that light up with the chime. That's the ticket, ain't it? I suspect there's going to be something close to 4.5v there, since it's got 3 C cells @ 1.5v each.
    I'll look at AVR/Arduino also. I've got a link saved to the Arduino playground, but never really checked it out much.
    Aug 2013
    The rough thing with a serial port might be the voltage--LED is 3-3.5V, I believe 3V is the minimum in the 232 standard, (+DC, at least,) so you may need a bit more voltage to get it to trigger. I know I've seen projects floating around the net for some time that use the DTR line for switching type applications, but it's been a while.
    I didn't think about it before, but a joystick port could be a better option as far as wiring goes--they seemed to end up on a lot of sound cards well into the 2000's. There's a 5V line on the joystick port so you can get rid of those batteries, and use it to trigger if the 3V level isn't enough with a fet or some such.
    Game port - Wikipedia, the free encyclopedia
    IIRC, some joystick drivers/utilities could attach hot keys to buttons, might be the ticket if you can find one that runs on the OS you can find.
  1. RT86 Ice-Techs vs XT RT76 Rotors
    By mevnet in forum Brake Time
    Last Post: 02-09-2015, 08:30 PM
  2. Shimano XT ice techs, amateur review
    By madsedan in forum Brake Time
    Last Post: 06-07-2013, 06:30 AM
  3. Do we have any ski techs in here?
    By Bro in forum Off Camber (off topic)
    Last Post: 01-06-2013, 05:25 AM
  4. OT: Any ski techs here?
    By Damitletsride! in forum General Discussion
    Last Post: 06-04-2011, 02:12 PM
  5. Tipping for Techs?
    By longfinkillie in forum Tooltime
    Last Post: 03-10-2011, 07:44 AM
