Results 1 to 27 of 27
    Larger Hydration Pack Bladder - More than 3L?
    I have a camelbak mule wich is 100oz/3L...Problem is that I can drain all 3L within 5 to 10 miles. Is there anything out there that is larger?
    I've always drinken a lot while riding...probably because of how much I sweat, but if I don't drink this much I'll get severely dehydrated out on the traile with a massive headache, etc...not fun.
    Looking for any thoughts!!
    You could get a second bladder and put it in the large main pocket of your Mule, then just switch bladders when the first one is empty.
    Cumbria, England.
    Reputation: D45yth's Avatar
    Jan 2009
    Some packs actually have room for two bladders and you end up having a drink tube over each shoulder. Maybe you could do what the above post says, but make a small hole in the top of your pack for the tube to exit?
    - The seasons blow away, but the love is just the same -
    I like the two bladder idea...I don't like the idea of starting my rides with 6L worth of water weight!!
    why not not put a couple bottles in your pack in the massive pocket? Heck I can carry 3 additional liters EASY and have room for food...
    Reputation: CrzyTuning's Avatar
    Mar 2012
    3l in 5-10 miles? Do you hydrate yourself well enough a few hours prior to riding? That's a lot of freaking water. I drink 2l in about 10 miles, depending on how much climbing I do.
    The torture ends now.
    Oct 2010
    I would be looking at putting that extra water weight somewhere on the bike in bottles and cages. I don't like riding with 3L plus tools/food in my backpack, can't imagine enjoying 5-6L of water weight on your back. Or try to route your ride past water sources and carry a filter. There are lots of great light-weight water filters out there for backpackers.
    Quote Originally Posted by CrzyTuning View Post
    Yep I'm well hydrated before I go. I've always sweat more than my buddies...I think this is just how I work.
    It may also have to do with riding in 90+ degree weather with humidity up around 60-70%
    Reputation: pleepleus's Avatar
    MSR DromLite - 6 Liter at REI.com
    They also make a 10L bladder
    You need the MSR Hydration Kit at REI.com so you have the tube to drink out of
    I used to hike with a guy that always carried the 10L one. It took up his whole pack. Near the end of the trail he would end up draining most of the water because it was so heavy.
    I've never felt the need for more than a 3L bladder and a 1L Nalgene in my pack. For multi-day outings I carry a Katadyn filter
    Log off and go ride!
    Jul 2003
    I have a one gallon bladder. Had it for years. So old the brand name is worn off the pack, I can not tell or remember the manufacturer.
    Reputation: VBrakesAndBarEnds's Avatar
    Jun 2012
    bring a frozen bottle of water with you and dump that into your bladder when you start getting low... or freeze the bottle 1/2 way and fill with water before ride if a full frozen bottle is too much ice... Here in arizona I freeze 2 water bottles overnight and put them in my bladder before the ride... Or just freeze one larger water bottle and dump that in before the ride..
    Quote Originally Posted by js1221 View Post
    I think I'm going to go the route of two bladders in one bag...I just wont fill up the second one completely because I think 6L is overkill.
    That said does anyone know which packs will hold 2 bladders with room for gear,etc?
    I've been thinking of the following:
    Osprey Raptor 14
    Camelbak Hawg
    Camelbak Mule
    Thoughts?
    EDR
    Reputation: eatdrinkride's Avatar
    Jun 2005
    The Hawg has a large enough main section for a second bladder, it even has holes for two hoses. You could carry an extra liter or two and still have room for some trail essentials/tools. I have a Mule and a Hawg, the Mule is too small for two bladders imo.
    Quote Originally Posted by eatdrinkride View Post
    Humm...guess I need to find a deal on a hawg. Not sure if I want to spend $130-150 on a pack.
    Would the mule take two bladders? Just two tight with two and gear is what I assume your getting at.
    You can put a second bladder in the Mule. Just put it in the large main pocket and run the hose out between the zipper pulls.
    If you do buy a new pack. You might want something with an internal frame to handle the extra weight of all that water. I have an Osprey Stratus 24 that handles a lot of weight really well.
    Quote Originally Posted by pleepleus View Post
    Good advice...I was contemplating the ergon packs which has an exoskeleton.
    EDR
    Jun 2005
    Quote Originally Posted by jbsmith View Post
    Too small for two bladders and any gear. Do-able I suppose if you carry nothing else but water. I'd have to go look at mine to be sure but I find the main compartment very tight with one completely full bladder as it is. Can't imagine any way to squeeze another 3L in there, maybe 1+L
    You really can put two 3L bladders a a MULE. With some tools, first aid kid, pump, food, two spare tubes, phone, keys and a knife. There's not much room for any thing else . Its kinda heavy (16 or 17 lbs on the bathroom scale).
    It's not supper comfortable but it didn't feel like a barrel on my back like I thought it would. I only put about 2.5L in each bladder though. I could see doing this in a dry climate on a long ride with nowhere to refill.
    Attached Thumbnails Attached Thumbnails Larger Hydration Pack Bladder - More than 3L?-img_0170-640x480-.jpg
    Thanks for the pics!
    [QUOTE=jbsmith;9542388]Thanks for the pics![/QUOTE
    No problem, I'm board. Just sitting around the house waiting for the temp to cool down so I can go on a ride. It's still 98 deg. outside so I'm having trouble getting motivated to leave the house.
    Sounds like here...98 and 75% humidity
    EDR
    Jun 2005
    I bought mine for $79 but I was very patient and scoured the net for a while.
    But based on the pics below the Mule is do-able, although if you really need that much water all the time it's not ideal. Try your Mule and shop for a large pack over time.
    I use both. Mule in winter and the Hawg in summer. I'm in Phoenix so I don't need to pack clothes or anything, I use the larger pack to carry a 32oz bottle of Gatorade plus my 3L.....and all my trail gear.
    Yeah I don't think I need 6L of water...I think I'd probably be fine with 4ish. That said I think the mule will suffice, since outside of water I only take a pump, tube, multitool, phone, wallet, keys, energybar/food. Food being optional depending on the length.
    You can also try clipping an unbottle onto your pack. Another option to consider, if you will, that doesn't cost as much as a different pack.
    Went with an osprey syncro 10. Can't put 6L in there (never really my intention) but does handle 4+ without issue.
    The back support seems to keep it square on my back.
    May 2005
    Fluid consumption info
    You drink allot but maybe it just works for you.
    Some good reading The Top 10 - The biggest mistakes endurance athletes make | Hammer Nutrition
    2013 Banshee Spitfire V2 650b
