Results 1 to 30 of 30
    trainer
    Hydration Bladder in a frame bag?
    I have seen a few comments from riders using a hydration bladder in a frame bag. Does anyone have any experience with this? It sounds like a great combination to me. I have a Revelate Tangle frame bag and would like to give it a try. Are there any issues with "draw from a bag mounted horizontally? etc? I appreciate any feedback you might have. Thanks
    gran jefe
    seems like it would work well. you would want a bite valve that keeps air from getting back in to the pack, OR just make sure the hose outlet is at the lowest point on the bag. i have not done this myself though.
    I did a test run with a 6L bag filled up about half way in a frame bag that sits all the way in the bottom of the frames main triangle. I didn't like the feel for a couple of reasons. The pack bulged out and frequently my ginormous (LOL) calves would rub. The sloshing seemed to be detectable, but I am willing to chalk that up to an overactive imagination. It also seemed like it would be stressful on the pack.
    I wound up carry a full 6L MSR dromedry and a 3L HydroPak on my back and did not have any issues at 46 years old and 155lb.
    I might consider having something custom made, but if you set up bike up correctly for carrying the weight on your back then you should be ok.
    trainer
    Thanks Bill and GHam, good advice on the bite valve. I am only looking to carry about 100 oz in the fram bag to eliminate carrying the back pack. I am a big guy 6'1" and 220 and want to avoid the back pack especially in hot weather when I need the fluid the most!
    I can relate to the no hydration pack on back thing ..I went through that a few years back. You might consider getting the MSR dromesdry bag as it holds it's shape better than most and can with stand oiling and freezing. The tubes for drinking directly out of the bladder are sold separately. tho.
    nocturnal oblivion
    Reputation: stumblemumble's Avatar
    Mar 2006
    here's mine
    I use a platypus 2L reservoir with the soda cap type opening. The big, camelback style openings just take up too much space in the bag.
    I route the hose up to the bar and keep it clipped to a cable by a name badge alligator clip thing.
    Works great, the weight is very centered and low so it really is not very noticeable. Manuals, jumps, other foolhardiness is not significantly affected. The benefits are obvious (no backpack).
    Attached Thumbnails Attached Thumbnails Hydration Bladder in a frame bag?-p8270065.jpg
    "...like sex with the trail." - Boe
    nocturnal oblivion
    Mar 2006
    And that setup ^^^ holds about 1.75L max water with cell phone, couple cliff bars, couple gels, tube, and patch kit.
    The above is maximum capacity for that Jandd bag, note the pump attached to the frame. If I want to carry a bit more I put on the seat bag.
    trainer
    Stumble, Thanks for the info and pic your setup looks like what I am looking for!
    Reputation: mikeridesabike's Avatar
    Quote Originally Posted by stumblemumble View Post
    Is that this pack:?
    Frame Pack
    Friends don let friends ride road bikes.
    http://www.facebook.com/mikebmiller
    Reputation: Burt4x4's Avatar
    Feb 2013
    Maybe a hydro bladder with some airpressure to squirt the drink up to you =
    Hydration Packs with In-line water Filters and Pack Bladders by Geigerrig
    WHen my pack needs a new bladder considering this one....
    Ride MORE = Live Longer
    Love Dirt / Hate Pavement
    Reputation: bamwa's Avatar
    Nice. I want to try this.
    Keep trying to do the awesomest thing you've ever done.
    I went this route two years ago and have never looked back. I bought my frame pack from Joe Tonsager, J.Paks LLC he makes custom frame bags after you send him a template of your frame. My reservoir is on the non drive side and can hold a 100oz bladder, non drive side also has two pockets for other stuff. The drive side is one big pocket that holds my pump, pump straps hold it in place, and two small ockets for my multi tool, snacks, etc. The possibilities are practically endless. Joe is a pleasure to deal with, very customer focused, he is a mountain biker, and knows what our needs are and designs accordingly.
    Attached Thumbnails Attached Thumbnails Hydration Bladder in a frame bag?-dscn0011.jpg
    Reputation: Rcksqrl's Avatar
    Aug 2013
    Have my jpak on order! Looking forward to losing the backpack!
    Sent from magic wish granting phone
    Aug 2013
    Had my paks for awhile now, love not carrying a backpack anymore. Due to my frame I had to go to a smaller hydration bladder but if concerned I can always haul more water on the front forks. HIGHLY recommend jpaks and getting a frame bag for 90% of the population!
    Aug 2013
    Working awesome.
    Robertson
    Reputation: rpearce1475's Avatar
    Jan 2015
    Not exactly what you're talking about, but: Under-The-Seat Bike Hydration System
    One of my buddies uses this for XC racing. He likes it.
    Aug 2013
    With longer and cooler rides I've found that it can freeze in the tubing even if I blow the water into the bag. So I've taken to carrying a regular water bottle on the fork in the insulated bag. 98% of the time no issues but sometimes you just have to expect the unexpected!
    Apr 2015
    Hyration bag on full susspension bike
    Just made a bag to hold my waterName:  IMG_0205.JPG
Size:  43.4 KBName:  IMG_0206.JPG
    It holds 70 oz and the hose stays in place with a little help from velcro.
    Sorry about the upside down pics.
    saddlemeat
    Reputation: bsieb's Avatar
    Aug 2003
    Keeping it simple... easy to grab, never falls out.
    Attached Thumbnails Attached Thumbnails Hydration Bladder in a frame bag?-dsc01375-copy.jpg
    I ride with the best dogs.
    Apr 2015
    I ended us using a Topeak Mondopack XL on the seat post in addition hydration backpack for long, hot rides with no water source.
    Topeak® Cycling Accessories ? Products - MondoPack XL
    In the Mondopack XL, can put in a completely full 2l Camelbak bladder, food, tools, cycle first aide kit, arm warmers with just a bit of room to spare. This pack easily clears my back tire and keeps weight over seat post. I just swap the bladder and supply line when using. I considered the other options on MTBR forums, but they were either too large or expensive.
    Put this inside of that. Fill with water. Suck all of the air out.
    Mount on bike. Wrap tube over bars. Hope your knees don't rub.
    Ride all day.
    Oct 2010
    This pack has a low profile and won't bulge as much. Your repair kit, etc. could fit in the center.
    https://www.amazon.com/Source-Outdoo...rds=source+wlp
    Reputation: EugeneTheJeep's Avatar
    Jan 2015
    I just started doing this as well, works great! I use a 100 oz bladder in my Rouge Panda bag, also some food, sandwiches whatever. I feel it helps during high speed cornering keeping a lower center of gravity. It's VERY hot here so it's nice to not have to wear the back pack!
    Still working on a system so the tube is long enough to drink while riding, but still able to stow so it's not in the way and flopping all over lol.
    2017 Giant Trance 2
    2015 Ghost Kato 5 (bikepacker)
    2016 GT Traffic 3.0 (commuter)
    1988ish GT Mach One
    Aug 2013
    Not the best picts since the binge is in the cluttered garage......
    Tube comes from pack, up stem and around left side. Attached with I'd badge holder that is retractable keeping it from falling down. Does it flop around a little? Yes but never been in my way or distracted me.
    Jan 2014
    for those of you with longer hoses that need a management system
    Hydrapak Elite Quantum Clip > Accessories > Hydration > Hydration Pack Accessories | Jenson USA
    edit:
    I also run my Geigerrig 100oz (3L) pack in my Salsa framebag. I can't even ride anymore with water on my back. It's either a pack in the framebag or a few bottles of water for a ride.
    Jan 2015
    Quote Originally Posted by Rcksqrl View Post
    Good idea, Ill have to find one of those ID badge things, thanks!
    2017 Giant Trance 2
    1988ish GT Mach One
    Jan 2015
    Quote Originally Posted by JW.dvdt View Post
    edit:
    Camelbak has something similar I was looking at the other day too, will give that a shot thanks! CamelBak | MAGNETIC TUBE TRAP for biking and hiking hydration packs
    2017 Giant Trance 2
    1988ish GT Mach One
    Aug 2017
    Thanks for all the ideas here. I wrapped up the details for one solution here:
    Mountain Bike Frame Hydration Hack · The Witty Ginger
    Reputation: mtnbkrmike's Avatar
    Mar 2015
    Good Christ this looks whacked out to me. For a bunch of different reasons. Do people really despise CamelBaks that much? Do they not have bottle bosses on their frames? Does this not affect the ride quality of the bike?
    saddlemeat
    Aug 2003
    I run the bladder hose out the top compartment main zipper opening, that way it is easy to remove to fill or have handy at night. I just lay the hose over the loop bar and tuck the end between cables or straps. I like being able to tuck the hose completely back inside the framepack at times, where it is protected from weather or other conditions. This keeps things simple and clean.
Members who have read this thread: 55
