Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 51 to 75 of 76
  1. #51
    gran jefe
    OP, great recipe. Works very well for me. Thanks for posting.
    Anyone recommending sea salt is missing the point.
  2. #52
    Quote Originally Posted by jennyv View Post
    Idinomac, sorry for the delay in getting back to you. I agree that you definitely need to test what you are going to use in training. Generally speaking, for Tailwind, we recommend starting off with 250 calories/24oz of water/hour and then adjusting up or down from there. This is dependent upon how efficiently your body processes calories (avg. human processes between 200-300 calories/hour). Also, although Tailwind is designed as a sole fuel source, you can take in other calories and dial back the calorie concentration accordingly. For example, let's say that you also plan on consuming 100 calories in food per hour, then dial back the concentration to 150 calories/24oz of water/hour.
    As for electrolytes, both CarboRocket and Tailwind contain way more electrolytes than other drinks out there which is why you typically don't need to supplement with salt tabs or salt pills. The average human sweats sodium (0.9 gram/liter), potassium (0.2 g/l), calcium (0.015 g/l), magnesium (0.0013 g/l) and other trace minerals (and this is the same profile we used for electrolytes in Tailwind).
    So, with both CarboRocket and Tailwind you can dial in the amount you need based on the number of scoops you use. Hope this helps.
    It's all good Jenny,I haven;t been on here much myself, I know about cutting back when I eat but I was just stacking the numbers with TW and CR 333 with the TW it has 25grams of sugar per scoop with CR333 it only 25ish grams per three scoops (so how is CR getting higher carbs with less sugar? unless I'm reading their label wrong) I know that I will get that sick felling with to much sugar at about the 18th hour in a 24 solo. Dean
  3. #53
    Tailwind Nutrition
    Nov 2012
    I looked up the ingredients for CarboRocket, and they use a 2:1 ratio of maltodextrin to fructose. My guess is they are listing the fructose as "sugar" and calling the maltodextrin "carbohydrate". They list 84g of "carbohydrate". So it's really maltodextrin sugar, just not called that on the label.
    There are three main types of carbohydrates:
    1. Simple carbohydrates: composed of 1 or 2 sugar units that are broken down and digested quickly.
    2. Complex carbohydrates (also referred to as starch) are made up of many sugar units. They are structurally more complex and take longer to be broken down and digested. Maltodextrin is a complex carbohydrate.
    3. Indigestible carbohydrates are also called fiber. The body is unable to breakdown fiber into small enough units for absorption. It is therefore not an energy source for the body but does promote health in many other ways.
    So, CR does have roughly the same amount of sugar as Tailwind and the same amount of carbohydrates (because they are the same thing).
    Hope this helps!
    Jenny
    Tailwind Nutrition
    www.tailwindnutrition.com
    www.facebook.com/tailwindnutrition
    Twitter: @gotailwind
  4. #54
    Hope this helps!
    Jenny
    It does help thank-you so much!
  5. #55
    Mar 2013
    Quote Originally Posted by Whambat View Post
    I have to caution against to much potassium, you can easily get into a state of hyperkalemia, potassium poisoning: it can be fatal. I'd recommend sticking to the ratio that salt stick uses posted above. Use regular salt to bring up the sodium while cutting back on the potassium. Hyperkalemia can cause heart dysrhythmias, a weak or slow pulse and paralysis.
    Seriously, look it up.
    Just wanted to comment on this since I did some looking up today. The recommended daily allowance of Potassium is 4700 mg. To give you an idea, one banana is about 500mg.. After looking into my diet, im probably only getting 2,000mg on the highest days.
    Here is a link I found that lists some foods with potassium: 10 High Potassium Foods / Nutrition / Vitamins and Minerals
    The OP's recipe of 1-1/2 tsp of light salt (1/4 tsp is 350mg of potassium) would yield 2100mg.
  6. #56
    gran jefe
    math is good.
  7. #57
    Jul 2013
    Quote Originally Posted by Hundun View Post
    No, I'm not really concerned about carb levels changing with differing fruit juices
    The reason I chose fruit juice over Kool-ade is because I detest chemical flavorings and dyes and juice is the more natural choice.
    Same with sugar; it's natural so I don't worry about it.
    We agree on these things. I'll take real sugar over any crap they are making to replace or mimic it. Thanks for the recipe I can't wait to try.
  8. #58
    Reputation: Taranis's Avatar
    Dec 2009
    Used this recipe last weekend for a 3+ hour ride w/ 4K climbing and it worked great, in combination with a mid ride Bannana
  9. #59
    emo member
    I made a 2 qt. batch the other day and thought it was great! I can't remember exactly what the original Gator Aid tasted like,but I thought mine reminded me of it.
    Made a few adjustments:
    1tsp Mediterranean sea salt
    1/2tsp light salt
    1 cup orange juice
    juice from 1/2 lemon
    a little less than 1/4 cup unfiltered honey
    fill the rest with water
    I think I might mess around with a mix (minus the salt) to drink anytime.
  10. #60
    Oct 2010
    I only use 1/4 tsp lite salt and 1/4 tsp regular salt per 2 quart mix. More than that and I thought it was rather salty. I did make a batch up without the salt like you said you may mess around with, but it just wasn't the same. I always liked Gatorade but prefer this much better as it is more natural, and tastes great!
  11. #61
    Reputation: GTscoob's Avatar
    Quote Originally Posted by Gundam168 View Post
    Yep. That's my recipe.
    3 tbsp wild honey
    1/2 tsp of salt
    750 ml water
    This seems like it would be great to cut some of the honey out and blend in a few dates instead.
    Here's another recipe I've been meaning to try:
    Quote Originally Posted by Thrive Homemade Sports Drink Recipe (raw)
    Juice of 1/2 lemon
    Juice of 1/4 lime
    3 dates
    2 cups water
    1 Tbsp agave nectar
    1 tsp coconut oil
    sea salt to taste
    Source: Thrive Sports Drink | No Meat Athlete
    It's pretty close to the recipe sslos posted just with more dates and less honey. Dates have more potassium by weight than bananas and are a great natural sweetener. I normally munch on them like shot blocks on a ride.
    Quote Originally Posted by sslos
    Here's a recipe that I use:
    1 1/2 Tablespoon of organic, local honey
    1 1/2-3 Tablespoons fresh-squeezed lime juice (to taste)
    1/4 Teaspoon of good quality, unprocessed sea salt (not table salt or kosher salt!)
    24 oz. filtered water
  12. #62
    Aug 2013
    I have a family history of pretty bad night cramps in the legs. I suffer from it, my mom and brother suffer from it, and my grandmother had them bad, as well as her father. I'm going to make some today and have the family start using it in hopes it changes our lives. Thanks for the post OP!
    I drive more when the streets need repairs!
  13. #63
    Jul 2013
    Quote Originally Posted by SandSpur View Post
    So if the entire 2 quarts of product is 2100mg, we would need a gallon of this elixir, a couple bananas, and more before we broke the daily potassium allowance. Is that right? That's before we account for how much potassium we lose. Can someone elaborate how drinking this will kill me? Personally, I only eat 2 of those high potassium foods regularly. I believe my potassium intake is below the daily allowance.
    For the record, too much anything can kill you.
  14. #64
    Thread resurrection!
    I ran into some gut cramping issues about 3 months into my training. Plain water, an occasional electrolyte tab, some hammer gel was no longer cutting it. The cramps wouldn't stop me in my tracks but they were uncomfortable and very distracting. I read around this site, researched the topic, found this post, gave your recipe a try and it works. I didn't have any cramps, not even the hint of one beginning. I have to tweak the taste a bit, but I'm very happy with the results.
    Thank you, SSLOS!
    SE Racing Stout 29er
  15. #65
    In my country I can't buy that "Morton Lite Salt", so, will adding just potassium chloride with other ingredients have same effect?
  16. #66
    gran jefe
    seems like that would work.
  17. #67
    Is anyone tried something like that?
  18. #68
    gran jefe
    i'm sure they have. google it.
  19. #69
    Thanks mate
  20. #70
    Aug 2014
    I set up an account so I could comment. I made this drink & it tastes EXACTLY like sports drink! Thank you so much for the recipe!!
  21. #71
    Reputation: Mr Pig's Avatar
    Good thread. I am the perfect guinea-pig as I suffer from terrible cramp, typically after maybe thirty-miles but last year it came on thirteen-miles into a fifty-mile ride and by the end I could hardly walk.
    Once the cramps in my calves start they just get worse no matter what I do. Stop and rest, push on, rub my legs, makes no difference. I've tried eating a lot, not eating much, different drinks, just now I'm on High5 4:1, but nothing stops them.
    I'll make up some of the drink listed here and see what happens. If it works I'll be a happy pig! ;0)
  22. #72
    So I'll try this one, but do you need the lime juice? Could you use another juice in stead?
  23. #73
    Trail Ninja
    Reputation: Varaxis's Avatar
    Making my own based off of the World Health Organization rehydration salts formula. Dextrose, Morton Salt Balance (instead of "lite" or "sea salt"), and Sodium Citrate. Also whatever comes with the flavoring I add later, if I choose to (ex. sucrose with the Countrytime Lemonade mix which I currently have).
    Got the hard to find ingredients from Amazon. Ex. Amazon.com : 4mular Sodium Citrate, 34 Ounce : Natural Flavoring Extracts : Grocery & Gourmet Food
    Looks like the Tailwind formula is similar but takes it a bit further, supplementing calcium and magnesium. What I don't understand is how fructose (part of honey and sucrose/sugar) being mixed in helps, especially when ideally you should be sipping periodically. I've read that it is digested into fat (apparently a triglyceride type) and glucose by the liver, while dextrose/glucose is straight up made available without digestion. Not sure if using more potassium with Morton Lite is helpful or not, considering too much is harmful. Nutrition facts labels don't include potassium content all the time (ex. peanut butter). Just going to follow a proven tested formula to start, aiming to replace what's lost, rather than supplementing for dietary deficiencies.
    I got a massive supply this way, pennies per serving. I figure later I can play around and gelatinize it too, into gummies. Maybe add supplements later, like B vitamins, since that's relatively safe and apparently it aids in burning calories from carbs, fat, and protein. Not sure if it burns alcohol based calories, but any excess is pissed out, due to it being water soluble.
  24. #74
    Trail Ninja
    Ended up just copying the Tailwind formula instead, since the WHO formula might as well be sea water.
    Thanks Tailwind! Your formula is far far better! Noticed that Morton's Salt Balance has Calcium Silicate and Magnesium Carbonate, which are for anti-caking and to be free flowing. So basically the only ingredients I'm using are Dextrose, Morton's Salt Balance, and Sodium Citrate. Just needed to find the right ratio to match the Tailwind formula, knowing 20g of Dextrose is 80 kcal, 1g of sodium citrate powder is 190mg Sodium, and 1/4 tsp of Morton's Salt Balance is 440mg Sodium and 200mg of Potassium.
    It works! Buy tailwind if ordering all the ingredients in measuring and mixing is too inconvenient and if you want flavor. At less than $1/serving, it's not a bad deal at all.
  25. #75
    Trail Ninja
    Ended up adding some regular sugar (sucrose) to my mix too, since it appears the "unflavored" version isn't really unflavored and isn't palatable to others. It doesn't taste like plain water nor like any other sports drink they've had... more like medicinal water after tossing a tablet in (like alka seltzer, which happens to have some similar ingredients). Well, it's not like I'm trying to sell batches to others, but I can see why Tailwind did it. The dextrose really isn't very sweet. Not sure if I have to be too wary about too much of it at one time, due to blood sugar spikes and the resulting insulin reaction, as it's only about 25g of sugar per water bottle at normal strength. The fructose in sucrose and honey isn't really that much anyways, even if it does get stored as a fat (triglyceride) rather than glycogen.
    Sugar is the 2nd main ingredient in Tailwind, while it turns out that it's the main ingredient in Skratch, when I went to reference it (Matcha tea + lemon flavor):
