Results 1 to 43 of 43
Thread: healthy carbs?
    healthy carbs?
    Been tring to burn some belly fat latley. Stopped eating fatty lunches and replaced with protien powder. Seemed ok untill i realized i was having a hard time riding up the big hills to and from work.
    So i had some pasta and the next 2-3 days i was all good. Didnt feel tired during the day. I dont want to go nuts on pasta so what would you guys recomend for healy cards to supplement the protien? And what to eat after a big ride(had some protien powder but read I should do a 3:1 carb to protien)
    Also would like to know more about carb loading before a race
    Log off and go ride!
    Jul 2003
    Post exercise fuel should be carb heavy. Your glycogen is depleted. Your muscle cells will not recover unless the glycogen is recovered. Hence the 3:1 ratio. Some researchers claim 4: or 5:1, others 2:1. I don't get into quibbling over the exact number, just be carb heavy at first. After an hour or so eat a protein heavy meal.
    Carbo loading is controversial. Some swear by it, others point out current research suggests it is a myth that gains no benefit. If it works for you then stick with it.
    Sports nutrition research is getting real interesting. Some very good research from abroad is showing ordinary off the shelf food eaten at the right time, and the right combinations and ratios, will outperform supplement pills and powders. Also research from abroad is showing much more genetic (read: ethnic origin) plays a much greater role than previously believed. Conventional thinking was ethnic differences in nutritional needs were so minor they could be ignored. Now we know different. Age and gender differences are also significant.
    Save Jesus
    Reputation: beanbag's Avatar
    This is a pretty complicated and controversial question. There are many schools of thought on which forms of carbs are good and which are bad. I think most everybody agrees that simple sugars alone like coke and gatorade are bad. Many think that white bread and other nutritionally devoid flours are bad too. Some think that wheat products are bad because the gluten and other chemicals will rip up your insides, even if you aren't a celiac. Some think potatoes and yams are bad, others think they are good. Almost nobody will say that fruit is bad, even though it has mostly a simple sugar, fructose.
    IMHO, if you are trying to lose weight, first you should figure out what kind of fat you have. There is fat evenly distributed around the body, and then there is a type of fat called "visceral fat", which basically means beer belly and man boobs. If you have the latter, that is the "bad kind", which has all the implications for metabolic and cardiovascular malaise. I think that it is also a hint that your fatness is carb-related, so maybe a reduced bad-carb diet would work for you.
    To answer your original question, I think banana is ok. Fruit and veggie is ok. (Fruit juice not OK.) Potato and yam might be ok. They tend to be satiating, so you won't overeat. Sugary stuff is no go. Low satiety stuff like white rice and non-whole wheat pasta is probably not that great. The reason is that it is too easy to overeat them, like how you have chinese food, and then you are hungry again later. Depending on whether you are worried about gluten ripping up your insides, whole grains and other non-wheat grainy things might be ok. Healthy fats like avocado, olives, and salmon are ok.
    Should have cleared up that im not over weight. Im 6ft and vary between 174 to 178lbs. But i have a bit of fat in the middle region. Just a bit of belly and some love handles. Non of it is hanging but its there and i figured doing 20km rides in and hour regularly should burn some of it. So it must be my diet. I am know as a lover of food and do over eat alot. Need to learn to eat a decent amout and then wait 10 min. Instead i eat till im "full". When i cut back on the amount of food my gut shrinks pretty quickly but the bit of fat remains.
    Reputation: Nubster's Avatar
    Try to get your carbs from whole grain sources and avoid the white stuff if possibe...white bread, white rice, white potatoes, white pasta, ect.
    Kona Big Unit SS
    Kona Private Jake SSCX
    DiamondBack Release 3
    ...but I'm a Silly Hunter
    Reputation: Haint's Avatar
    Ideally, once you have a Diet you are in the zone with, you'll want Carbohydrates to be ingested prior to your Race/Marathon Ride. They are very complex building-blocks so digestion is slowed. Almost like Sugar in how your body processes them, and to how unique the composition of them is -- so your body has it's own exercise too.
    Cool-down is always, always, always going to be protein-source. Strip Steak w/ Blue Cheese (exta-protein for a reward) for example.
    Chocolate Milk is the best recovery-item. Chocolate and also Olive Oil are good for the Heart, so drink the good stuff.
    Pasta, Bread, Potato. All 'Eggs that Bind' in your Diet. As they have the most organic and the most involved make-up into what they are as whole foods, your body will have a treat with turning them into fuel, and if you are at that point of having machine-like-metabolism, you will just further those strides as you go along.
    Jul 2003
    From true nutritional viewpoint there is no such thing as good carb or bad carb. All carbs have a place in a healthy diet. Immediately post work a high glycemic carb may be better than low glycemic. You want the sugar in your bloodstream as fast as possible to replenish glycogen. The rest of the day lower glycemic is preferred.
    FYI high and low glycemic is not synonymous with refined and unrefined. Look at a glycemic index list to choose your carbs, not some arbitrary "white bread versus whole grain" classication.
    A healthy diet does not mean you must live the life of an ascetic monk. If you otherwise eat healthy you can still have a twinkie or double bacon cheeseburger ocassionally.
    Reputation: nojoke's Avatar
    The below link is speaking on the benefits/downsides of your carb consumption when it comes to your overall health. Worth a look, as is the whole site.
    How many carbs should I eat each day? | Mark's Daily Apple
    Piggbacking on one of the posts above I tend to stay away from processed foods as much as possible. In the 18 months that I have changed my eating/lifestyle I have achieved things I never thought possible at 34, and all the good vitals to go along with it, Blood Pressure, cholesterol level (good LDL vs HDL splot) resting heart rate, strength, sleep function, overall wellness etc.....
    Introducing the New Primal Blueprint Food Pyramid | Mark's Daily Apple
    Reputation: joeinchi's Avatar
    Jun 2010
    Lots of good advice, above.
    I recently lost about 20 lbs of body fat (3 inches off my waistline) over four months and the one suggestion I'd add is to figure out the right number of calories you need to consume daily to maintain your weight ... and then cut back 500 cal/day. That should let you lose about a 1/2" - 3/4" per month off your belly.
    The problem with crash dieting--aside from decreased metabolic rate and energy levels--is that you'll lose muscle mass along with fat. While it sounds counterintuitive, you need to make sure you eat enough to maintain muscle mass while losing fat.
    The Effects Of Low Caloric Intake | LIVESTRONG.COM
    Mar 2012
    Quote Originally Posted by machine4321 View Post
    plain quaker oats oatmeal w/ water is very healthy for carbs
    Aug 2005
    Quote Originally Posted by brf4n View Post
    ..for a horse it might be.
    Save Jesus
    Here are some reasons it might not be:
    Are Oats Healthy? | Mark's Daily Apple
    As mentioned in the comments of that article, it really spikes your blood sugar. I stopped eating oatmeal after I noticed that I tended to get an elevated heartrate afterwards.
    Been tring to burn some belly fat latley.Really trying to improve muscle to fat ratio Stopped eating fatty lunches and replaced with protien powder.You can overdo the protein Seemed ok untill i realized i was having a hard time riding up the big hills to and from work.Makes sense
    Well you have to eat enough fats and protein to be healthy....
    Then you have to eat enough carbs....That depends on how much energy you expend...if you are trying to loss some weight and gain some muscles....then you probably want ot run about 250 to 400 calories light per day...X 7 days/3500cal/lb = .65 lbs/week.
    Really that simple....and yes as your body begins to burn fat to replace the glycogen instead of easily available carbs in your guts then you will feel tired and hungry.
    If you stay away from simple carbs fructose, sucrose, glucose...you won't get as much of a sugar high and low...
    Mar 2012
    Quote Originally Posted by beanbag View Post
    Uhh, Oatmeal with sugar added in it (flavored Oatmeal) of course will spike blood sugar. Regular Oatmeal, with no sugar, will not. All the articles talking about Oatmeal spiking blood sugar are talking about flavored Oatmeals, especially the Oatmeal meals where people put in strawberries, bananas, etc.
    Oatmeal is just about the healthiest carb out there, next to eating/drinking plain maltodextrin.
    This is what I am talking about: http://www.theonlinecandyshop.com/im...lbvaluebox.jpg
    Super healthy, very pure, and very cheap at Costco. (something like under $10)
    Dec 2009
    +1 on the oatmeal. It's not realistic to demonize all carbs, despite what the latest fads might suggest.
    This is all really good info. I have been watching my portions but not calories. I have a very high metabolisim ( i should be 300lbs) but I cant bank on that forever.
    Again i dont want to lose any weight just burn the belly fat. But there is no time for weight tranning.
    Seems like I need to push beyond being out of energy to get that result. But it seems counter productive as I would rather be properly nurished to build the legs as I have started racing.
    I found some of this trash Oatmeal in my cupboard, not the fruit kind and added sugar, I dont eat it, but my wife does. PLAIN, Quaker Oats...
    1/2 up serving size
    27g carbs
    1g sugar
    5 gram protein
    3g fat
    The difference between sugar added vs plain....? Not much maybe 2-3g carbs.
    Bottom line, its a carb, its 27g worth, and will spike your blood sugar/insulin levels. Recipe for diabetes? I will probably further add that you think a bagel, some fruit, and possibly a large cip of juice is good for you also in 1 sitting at breakfast. . Well over 100g of carbs, just for breakfast.
    My usual 3 eggs for breakfast, 1 TBSP of almond butter, stomps a 1/2 cup of lousy oatmeal out for nutritional value all around, and doesnt have nearly the effect as the oatmeal does on my health, in the negative way. The facts are this....Less carbs (aprox 10g in the whole breakfast) , more protein (25g) , more fat (where your energy should come from), less calories, and its 100% natural, no processed BS. You cant support lean muscle mass with oatmeal, doesnt supply the value.
    I agree you need carbs, but they should be moderated and you should iknow what good carbs and bad carbs are generally 100-150g per day. Although the typical american takes in excess of 300g per day, and they wonder why obesity and diabetes are at an all time high?? Generally speaking, anything processed is a bad carb.....including Oats which is another form of bread/grains.
    Before anyone gets on the cholesterol bad train people generally dont know what bad cholesterol means, and what good cholesterol is. You know what the leading cause of bad cholesterol is (LDL)? Elevated carb intakes and high sugar intakes......hmmmmmm. You can have high cholesterol with a good ldl/hdl split.
    Save Jesus
    No, you have it wrong if you think the way to lose fat is to starve yourself or work to exhaustion. These are good ways to lose muscle mass. Read post #3, second paragraph again. Also set aside some time to read the links from nojoke.
    Dec 2009
    Quote Originally Posted by nojoke View Post
    1/2 up serving size
    27g carbs
    1g sugar
    5 gram protein
    3g fat
    I respectfully disagree with your post.
    You should read up on glycemic index, glycemic load, and the difference between complex carbs and simple sugars. Oats are a good food that will not cause an insulin spike. It is ilinformed to suggest otherwise.
    People overdo the simple carbs and that's a problem. 150 grams of carbs a day is simply inadequate for a competitive endurance athlete.
    Quote Originally Posted by jathanas View Post
    (excuse me, spelling is off, just had eye surgery)
    Thats what these places are for
    I have read up on the gyclemic index, and I am educated on it. Good carbs, and bad carbs. I think my views stem from grains and the health issues they create, and oats are a form of those. That is why I shy away from oatmeal and oatmeal has peaked my interest.
    For my personal use Oatmeal holds no nutritional value to me. Its low in protein, high in carbs (low GI) as you suggested, although the claim it doesnt spike is false. Levels will still raise but slowly Hince a carb is carb, they just have different overlall outcomes on insulin and glucose levels on the realm of time. I took the link from below wiki, cause I dont have my good literature at reference.
    Glycemic index - Wikipedia, the free encyclopedia
    A low-GI food will release glucose more slowly and steadily, which leads to more suitable postprandial (after meal) blood glucose readings. A high-GI food causes a more rapid rise in blood glucose levels and is suitable for energy recovery after exercise or for a person experiencing hypoglycemia.
    I agree, different levels of atheltics will require different level of intakes, and I was simply addressing the OP's post on good/bad. However if you stick to the triangle I listed above several posts ago its a cut and dry case, and will generally lead to a lower overall level of carb intake and a healthy/healthier lifestyle.
    I have ZERO issues sustaining my daily lifestyle on my current intake. I Crossfit alot, Im a Crossfit Trainer, Active duty military (15 years) and do local XC trails/DH and race both. If my daily intake was inadequate I would of killed myself off by now. For example..yesterdays meal.
    Breakfast
    3-4 Fish oil tablets, multivitamin
    3 eggs
    1 TBSP almond butter
    Coffee, black.
    Snack between breakfast/lunch as I feel......
    almonds/apple
    Lunch
    8oz Chicken breast
    Can of spinnach
    3 asparagus spears
    More snacks...
    almonds/nuts and a fruit just before I workout in the afternoon (4pm) whether its Crossfit or riding.......sometimes both.
    Post workout
    60g of Gold Standard Optimum Whey protein, typically the only dairy I ever drink/eat......
    Dinner
    Salmon , grilled
    Grilled peppers
    maybe some Tea.....
    I try to avoid eating carb heavy foods before bed as well as the body needs to be as dormant as possible during sleep.
    Save Jesus
    Oats do cause a blood sugar spike for many. You can find several cases if you search on the internet about it. One example:
    Oatmeal: Good or bad? | Track Your Plaque Blog
    This is even despite the fact that the GL is not that high. I don't know what it is about oatmeal that affects some people. Maybe because the "standard serving" is much smaller than what people normally eat. Maybe because as the first meal of the day you have a big steaming face full of carbohydrate and almost nothing else. In any case, it made me feel funny afterwards (and lots of others as well), and no I did not add sugar to it, and no, I am not diabetic.
    Blood sugar aside, the main point is that oatmeal is a relatively nutritionally devoid food. It has some token nutrients and anti-nutrients as well. Why not get your carbs from foods that have more nutrients in them instead?
    If you are a serious endurance athlete whose energy requirements far exceed what fat metabolism (+ glycogen) can supply, then you would need to eat a face full of carbs on purpose and oatmeal would be a efficient way to get them. I don't think the OP is at that point.
    Dec 2009
    Thanks both beanbag and nojoke for your posts. I found them both to be "food for thought".
    I've cut most gluten and wheat based foods from my diet with good results. I still eat oats though, especially as a meal before a very long ride or extra hard training session. They work really well for me.
    I agree that there is no need to go heavy on the carbs on easy days. Like you i choose protein first at those times.
    Cheers, J
    edit: Speedy recovery nojoke!
    I have been eating whole grain steel cut oats(one pack) with a bit of pure maple syrup and 2 cut up straw berrys on the morning and I have felt alot better on my ride to work in the mornings.
    I thought whole grains were ok as a carb. Im going to read the links posted.
    Flow like water
    Reputation: DavyRay's Avatar
    Fat is good. Your body can reject excess fat quite easily, and it makes you feel full. It is also really good for you. Don't avoid fat.
    Do avoid sugar and starches. Potatoes are very bad. Rice is better. Carb amounts should be small unless you are really burning lots of calories. Digging ditches is a good justification for major carb calories. Endurance athletics training all day is another good reason to eat lots of carbs. Weight training, not so much.
    Do eat reasonable portions at the right times. Once you cut sugars and excess carbs, the rest is just common sense. I know this is not the story that the magazines were pushing a few years ago.
    EDIT: I re-read your earlier posts. Nevermind.
    You are trying to lose fat in one spot! It does not work that way.
    I understand the fat wont come one area.
    Ive come to the conclusion I eat a LOT of sugars and bad carbs.
    When I had mentioned 'machine-like-metabolism' it referes to both being able to burn fat, but also keeping and maintaining metabolism up at this point.
    You are right about realizing you can have sugar be taken to excess, and it's good to be at that point. Once that hill is crested, the immediate cravings your body sends out -- due to the empty-sugar-rush being found -- will be able to be crushed.
    Jun 2010
    Quote Originally Posted by DavyRay View Post
    I agree with everything you wrote ... except the knock on potatoes. Could you elaborate? I know french fries, baked with all the fixings, au gratin, mashed, etc, when you add in all the other ingredients, represent a ton of calories without a lot of nutritional value.
    A large baked potato (10.5 oz), however, offers the following:
    Cal: 278
    Fat: 0.4g
    Cholesterol: 0 mg
    Carbs: 63.2g
    Dietery fiber: 6.6g
    Sugars: 3.5g
    Protein: 7.5g
    Also high in potassium, vitamin B6 and vitamin C
    Add a tablespoon of sour cream (30 cal) for taste and is it really that bad for you?
    I think most people think they are bad due to high GI........
    Jun 2010
    Thanks for the reply.
    Regarding baked potatoes, it appears to have fallen in the middle of that GI range you referenced, along with rice:
    Medium GI 56–69 whole wheat products, basmati rice, sweet potato, sucrose, baked potatoes
    It's no big deal. Just curious as to why some believe Potatoes are very bad.
    Dec 2009
    Checked the article. The guy ate oatmeal with fruit and skim milk, then had an insulin spike. He now doesn't recommend oatmeal to diabetics. OK.
    Sample size of the scientific study = 1.
    I accept that people should ensure adequate protein and veges in their diet. Having said that I'm not convinced that grains like oatmeal have no place in a healthy balanced diet.
    As for the high pretein low carb diet, that can lead to ketosis, which is not good:
    "Ketosis is a condition in which levels of ketones (ketone bodies) in the blood are elevated. Ketones are formed when glycogen stores in the liver have run out. The ketones are used for energy. Ketones are small carbon fragments that are the fuel created by the breakdown of fat stores. Ketosis is potentially a serious condition if keytone levels go too high....
    Our brain can use glucose or ketones for energy; it cannot generally burn fat for energy.
    When there are plenty of carbohydrates in the body, it breaks them down into glucose, which is then converted into energy and transported into the cells of our body.
    If glucose cannot be broken down, as may be the case if the insulin levels are too low, or if there is a lack of glucose, then the body has to break down stored fat and convert it into energy. Metabolizing fat raises blood ketone levels, leading to ketosis. Ketosis can occur with Type 1 diabetes (not enough insulin), alcoholism, starvation, and with a low-carb, high fat/protein diet.
    Ketones consist of acetone, acetoacetate or beta-hydroxybutyrate. Very high ketone levels can be toxic, making the blood more acid, and may damage such organs as the kidneys and liver."
    What Is Ketosis? What Causes Ketosis?
    Each to theirs.
    Cheers, J
    Save Jesus
    Potato is a somewhat controversial food.
    Some reasons why it might be bad:
    A facefull of carbs, (similar to oatmeal - mainly bad if you can't handle it or don't need the extra energy)
    Contains saponins and lectins (use internet search)
    Some reasons why it might be good:
    Stephan at whole health blog, one of the most intellectually honest health sites I have read, really likes potatoes and writes a lot about them
    Whole Health Source: Potatoes and Human Health, Part III
    I think sweet potatoes and yams have a bit more nutrients in them, though
    The Difference Between Yams and Sweet Potatoes | Mark's Daily Apple
    May 2010
    The supposition that humans need carbs is completely false. That said, if you cut out carbs and don't increase fat consumption you're not going to have energy.
    Save Jesus
    Ketosis is a medical condition, and is not the same as the low carb style "ketogenic". Going into ketosis requires eating less than about 50g carb per day, which even the paleo websites wouldn't recommend. See nojoke's first link on page 8.
    Dec 2009
    Riding in a ketogenic state is not really the best way to extract high performance from the human body in endurance endeavors. It is well documented that whilst the body can use fat for fuel ( never exclusively ) it works much more efficiently with glycogen as a primary source; even then you still burn some fat. This mostly applies to endurance sports that highly tax the cardiovascular system.
    Save Jesus
    And this is why the Paleo Diet for Athletes book recommends you start to load up on carbs before, during, and after exercise.
    Dec 2009
    It's a sound recommendation by Friels.
    Best of both worlds and it's what I've been doing... Mostly.
    Portion wise, what amout of carbs are good before a ride? I ask because I tend to over due portions. Im sure i might double or triple what I should be eating for carbs.
    Flow like water
    Quote Originally Posted by joeinchi View Post
    Cal: 278
    Fat: 0.4g
    Cholesterol: 0 mg
    Carbs: 63.2g
    Dietery fiber: 6.6g
    Sugars: 3.5g
    Protein: 7.5g
    Good observation.
    I do not have good evidence for potatoes being very bad. I have heard lots of advice to diabetics that potatoes convert to sugar almost immediately. I do know that the amount of potato consumed by us has increased a huge amount in the last few decades. They are available everywhere in large quantities, mostly in french fries and chips of various types.
    I have not looked on glycemic index tables to see where they lie.
    I do subscribe to the belief that it is better to eat starches with fats and protein. I do eat baked potatoes. I just don't think they should be the majority of my diet.
    Eating prior to a Race or Big Day or Night Ride should meet satisfaction-levels, mainly. Digestion is a constant-process, what is happening during Bicycling is very heavily cardio-vascular -- replenishing Oxygen reserves. Oxygen and Water are the two major 'vehicles' which get taken to full advantage in the transformation of food-to-energy.
    As a standing-directive, one Sugar g is always going to create one Carbohydrate g. There are exceptions, rare and found in overly-processed beverages.
    Potato and Pasta are high-carb simple foods. But even with keeping consistent activities, the body is going to be programed to anticipate both Carbs and Sugars -- they are very deliberate and such complex molecules. Bulking-up prior to a ride is always the best start, only your body has to be weened-off the stuff! So until you have a low-threshold for sugary-intake, Carbs are going to present a pitfall in having immediate-results be met from the whole Day of Riding.
    Fatigue and odd-cravings are typical, but that's why it is so good to adhere to drinking Water, and to strictly limit Soda-intake. It's a beverage! Not a source of Hydration!!
    Very good read on the topic of eating Primal/Paleo and maintaining athletic performance in regards to carb intake.
    Primal Compromises for Athletes | Mark's Daily Apple
    Depending on the length and intensity of your workouts (and races) you’ll need anywhere between 60-100 extra grams of carbs (beyond what we discuss above on a low carb plan) each day per hour of intense endurance work.
    Read more: Primal Compromises for Athletes | Mark's Daily Apple
    Jun 2010
    Good observation.
    ... I do subscribe to the belief that it is better to eat starches with fats and protein. I do eat baked potatoes. I just don't think they should be the majority of my diet.
    Dec 2009
    It really depends on the ride duration and intensity. With liver and muscle glycogen levels at normal most fit riders have a about 90 minutes of riding in them before they bonk. That feels horrible BTW...
    If I'm heaidng off in the morning I wolf down a banana, and then eat something on the bike every 30-45 minutes depending on the pace.
    Vegan on the S-Works
    Reputation: durianrider's Avatar
    Excess carbs are burnt via dietary thermogenesis.
    The fat you eat is the fat you wear.
    If anyone wants to disagree please take off your shirt and post the photo.
    Still don't believe me? Go visit the carb fuelled societys like Kenya, Thailand, China, Japan etc and look at how trim people are as a society and how little animal products the slim people eat.
    If you want to get lean, replace grease and animal protein with whole food plant carbs like fruits, veg, rice, corn, barley, oats, quinoa etc.
    Dr McDougall just put out another great book called the 'Starch Solution'.
