Results 1 to 5 of 5
    camelback podium chill 25oZ
    Just bought this and I don't have any bottle cages that will hold it.
    Anybody know a cage that will hold it?
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Almost any cage will work, some of them are pretty tight though.
    Took some break in to fit nicely in my blackburn cages. After a few months, it softened up considerably, compared to a new one.
    Attachment 817145Attachment 817146Follow up post.
    I wanted to show how I solved my issue. The top loading cage was just not going to work. I found a left hand side load specialized bottle holder.
    The current bottle mounting screw holes are to high up for the longer bottle. Therefore I had to move cage holder down. I just moved the cage down, used the bottom hole for top cage, then used a couple zip ties to snug the bottom down. Went on my typical little over an hour ride and everything was good. Some small movement on bottom, nothing to worry about. The bottle I had filled with frozen water alittle over half way. Topped off before ride and at end of ride still had ice cold H2O, freaking awesome when it was smoking hot and I was dripping sweat, ahhh the little things...
    Reputation: Reverend_Maynard's Avatar
    Mar 2012
    You misled us with your question!
    It's not the cage, but your frame that didn't want to fit the bottle. Looks like you found a good solution., though.
  1. chill pod phin
    By delirian in forum Knolly
    Last Post: 07-01-2013, 09:18 AM
  2. Wind Chill
    By schnauzers in forum Passion
    Last Post: 04-27-2013, 06:54 AM
  3. How about a chill pill with all these ads please?
    By aedubber in forum Site Feedback/Issues
    Last Post: 08-05-2012, 04:29 PM
  4. Where to ride, scuba, chill?
    By Crockpot2001 in forum Asia + Philippines
    Last Post: 04-18-2012, 04:31 PM
  5. Chill out!!!
    By Aquaholic in forum Passion
    Last Post: 04-10-2011, 11:29 PM
