Results 1 to 16 of 16
    Burning legs - a supplement solution?
    I have noticed that my reason for bailing on a climb is usually not heavy breathing, and not leg strength, but leg pain. Others I ride with seem to not have the burning problem as much. It might just be a simple muscle endurance problem, but I'm wondering if anyone uses a supplement that helps with this. I presume it is a lactic acid issue.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Quote Originally Posted by smilinsteve View Post
    Yes. No particular advice on a supplement but it could be a hydration problem (lack of) . You can elevate your lactate threshold through training though.
    http://search.yahoo.com/r/_ylt=A0oG7...-threshold-101
    Reputation: cman8's Avatar
    I like sportslegs. Some people might say it's useless but there are a lot that say it works me included
    There are some supplements that have helped my muscle endurance in weight training. Namely, creatine and Nitric Oxide Boosters, which are usually Arginine or AKG with a bunch of caffeine. I never really thought of trying them for riding. I know caffeinne is supposed to work for endurance athletes. Getting a few more reps in the weight room is so much different than pedaling, I don't know if the benefits would transfer.
    Reputation: jrastories's Avatar
    It does sound like you just can't clear the lactate fast enough, I don't think that any supplement will help with this, it is more training and a little HTFU to push though that lactate burn to the top of the hill where some light peddleing will be able to burn that excess lactate off.
    There is no real quick fixes to replace some good training and time in the sport.
    Rocky Element
    My Attempt at a Blog
    Reputation: AM Octopus's Avatar
    I have been using Sport Legs for the last few years and it really helps me with cramping in my legs on long climbs here in Colorado. I take four before every ride and I weight about 190lbs.
    They sell small sample packets that you could try instead of buying a whole bottle.
    Quote Originally Posted by AM Octopus View Post
    Wow did they name that stuff just for me?
    They have a pretty good web site:
    http://www.sportlegs.com
    It sounds great actually. I get the burn when I ski as well, and they mention that too. I think I'm going to try it.
    It should be easy to tell if it works. When I squat in the gym, I've always gotten sore afterwords, with the typical 2nd day being the worst phenomena, but in the last couple of years, the soreness continues into day 4! It makes it difficult to squat at all, because it prohibits any serious riding or hiking until I have recovered. It would be a good test.
    I'll try to get some for my next ride as well. Where do you buy yours?
    trail rat
    Reputation: slocaus's Avatar
    My friend is a nurse who lives in Davis. She runs medical support for the Davis Double Century every year. They keep mass quantities of generic Tums anti-acid tablets at the aid stations for cramps. Each tablet contains 400 mg of calcium. Apparently riders will come in with bad cramps, especially toward the end of the course. She told me she has given cramping riders half a dozen Tums, a full bottle of water, and 15 minutes later they are back on the bike.
    Apparently cyclists sweat out a lot of calcium along with other salts, and many serious riders are chronically low on calcium. This sometimes shows up with cyclists having low bone density, propensity for fractures, etc., the reason resistance training is recommended for bone strength at least in the off season.
    "The physician heals, Nature makes well" - real fortune cookie
    CCCMB trail work for trail access - SLO, CA
    Quote Originally Posted by slocaus View Post
    Interesting. The Sport Legs supplement also has a lot of calcium, but it is in calcium lactate form. Tums = Calcium carbonate?
    I never knew of the association between calcium and cramping and muscle burn. I don't know how cramping and burn are related, but I don't have a cramping problem, I have a burn problem, and the lactate in Sports Legs is what is supposed to help the burn.
    trail rat
    A pack of Tums is cheap, try it.
    Reputation: Team Fubar Rider's Avatar
    Sep 2003
    I've done some light research on this issue. Arginine can be beneficial in clearing waste from the cells, namely clearing uric acid (which is gout issue). Obviously with lactic acid being a waste by-product of cells, I have tried using arginine in a supplement form to see if it helps, but I haven't tried it for a long enough time to give a definitive answer. Thankfully, arginine is one of the cheaper amino acids, so if you try it, it won't cost you much.
    On a slightly related note (related in the fact it is another amino I'm referencing) That being said, I have had GREAT success using carnitine for riding. After 1 week on carnitine, my average heart rate for a ride over a same course (a training ride I did during the summer months) was lowered by almost 10 bpm and I was able to ride it faster than before. I don't think I gained that much fitness in a week, so I attribute it to the carnitine.
    Arginine is great, combine that with Cordygen, via Cordygen Ultra VO2 and you will be a machine.
    You forget all about leg pump and gasping for air.
    Reputation: Velosprocket's Avatar
    Have you tried bananas? Potassium seems to help me. I've tried Sport Legs because a friend of mine swears by them when snowboarding. I couldn't really tell a difference. I've also tried Hammer Endurolytes and Anti Fatigue Caps, both without noticing much difference.
    Just take a multi vitamin about 1 hour prior to your rides, and see if that helps. One of the Sports blemd of vitamins. More training will get your body used to getting rid of lactic acid better.
    You maybe over thinking this.
    Train. Heal, train some more.
    Eat well, take some multis and a protein shake for recovery. Add some fish oil for thicker hair
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    Quote Originally Posted by cman8 View Post
    +1 they work for me.
    I have a 6 Berth & 2 Berth Motorhomes that I rent out . They are based in Tauranga, New Zealand
  1. NAC supplement?
    By wiruth in forum XC Racing and Training
    Last Post: 07-26-2007, 06:32 AM
  2. Burning legs
    By pinkheadedbug in forum General Discussion
    Last Post: 09-06-2006, 10:42 AM
  3. legs burning, results falling...
    By -dude- in forum XC Racing and Training
    Last Post: 07-15-2006, 10:41 AM
  4. It takes legs to ride 44-16...long, beautiful legs....
    By El Beastro in forum Singlespeed
    Last Post: 02-16-2005, 11:06 PM
