Results 1 to 16 of 16
    Reputation: Pauldotcom's Avatar
    Aug 2010
    Adding an extra water bottle cage - adapter??
    Hey
    My new SS frame only has 1 bottle cage mount. Anyone have experience with an adapter that will hold on with abuse on rocky terrain? Thanks
    “People fear death even more than pain. It's strange that they fear death. Life hurts a lot more than death." JM
    Aug 2010
    Nah I don't like the way they fit. I'm very comfortable drilling and installing (I used to install roof racks and such on $50,000 Landcruisers) just figured I'd ask the frame builders on their thoughts; not looking for an alternative.
    Thanks anyhow for your input.
    Always Learning
    Reputation: BruceBrown's Avatar
    Aug 2010
    Guys I appreciate the advice but I'm not looking for an alternative. I do not like using camelbacks.
    Thanks for the all the links! I'm going to check them all out.
    I am simply looking to see if anyone else has added a cage by drilling and adding thread nut inserts. Thanks
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Pauldotcom View Post
    I would use the clamp on mounts, like those above.
    Drilling an existing frame is tough because of the tight clearances.
    mtbtires.com
    Reputation: sgtjim57's Avatar
    Drill frame, weaken frame, frame crack/break. I think I'd use clamp version for those reasons alone.
    2017 Cannondale Scalpel Si Carbon 3 (27.5)
    They make ones that fit in the top cap screw. Also 2 fish makes ones that has straps, no drilling.
    Aug 2010
    If drilling the frame weakens it, then why do manufactures do it all the time? I would love to hear from someone that has done it.
    Dec 1998
    A cleanly drilled hole with a rivnut or braze on is fine. It may technically weaken the tube, not usually an issue in practice.
    The problem with drilling an existing frame is getting the clean hole, especially on the inside of the main triangle. Can result in a ovalized hole and/or stress risers.
    Manufacturers drill the tubes before the frame is assembled.
    mtbtires.com
    > /dev/null 2&>1
    Reputation: Procter's Avatar
    Feb 2012
    Re: Adding an extra water bottle cage - adapter??
    Never done this myself but i agree with shiggy, i don't think it'll affect the strength of the frame. mount towards the middle of the tube far away from joints (which you probably would have done anyways but just saying). Stress is concentrated towards the joints, in the middle of the tube its surprisingly low - this is why butted tubes work.
    For drilling thin metal, a step-bit can't be beat. Clean hole, no catching:
    http://m.lowes.com/product?langId=-1...lue=4294707818
    Drill a pilot hole with a 1/16" first. This way you get no wandering when you start the step bit.
    Sent from (redacted by nsa)
    Laramie, Wyoming
    Reputation: alphazz's Avatar
    Oct 2012
    I have a kit for installing a threaded insert and have done so on MANY bikes with absolutely no issues.
    I had the same problem with my Civilian Luddite (I prefer no pack) This is what I did for under $10 which included the cage. After a year (1300+ miles) it is still good.
    no cage mount, no problem. | Mountain Bike Forums
    Feb 2012
    How about a seat post mount option?
    2012 Diamondback Podium 3
    2013 Specialized Stumpjumper EVO 29 - MIA
    2013 Giant Anthem X Advanced 2
    Aug 2010
    Those are the ones I am going to get.. Saw a guy with them the other day. Are they specialized?
    I like turtles
    Reputation: TiGeo's Avatar
    Quote Originally Posted by stop619 View Post
Name:	seat post cage mount.JPG
    Bingo...this is what my bike came with from Specy to solve this problem.
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro are #@$%
  1. Adding bottle cage bosses to a frame.
    By LyNx in forum Frame Building
    Last Post: 04-03-2016, 04:40 AM
  2. Jet 9 RDO Water Bottle Cage
    By tneker in forum Niner Bikes
    Last Post: 06-05-2013, 04:15 AM
  3. Adding bottle cage mount
    By mobile chernobyl in forum Frame Building
    Last Post: 11-02-2012, 12:30 AM
  4. 575 water bottle cage
    By jeffw-13 in forum Yeti
    Last Post: 04-30-2012, 04:06 AM
  5. Adding water bottle bosses to steel fork?
    By Johnny K in forum Frame Building
    Last Post: 02-09-2011, 04:19 AM
