Results 1 to 14 of 14
Thread: 60/20/20
    60/20/20
    Good day
    I am looking at taking my diet a little more serious this season, and was hoping to get some insight from endurance athletes who pay attention to their Macros. Based on some research I have learned that a 60/20/20 (60% Carbs, 20% Fat, 20% Protein) protocol with various caloric intake ranges is not uncommon.
    Based on the fact I put in close to 15 hours a week, sometimes multiple sessions per day My caloric intake is 3000 at 185 lbs.
    Anyone else have luck with this protocol?
    Cheers
    Isn't this SAD ? Standard American Diet? I'm having great luck with targeted ketosis and intermittent fasting with the goal being endocrine system optimization. You are not necessarily what you eat, but what your body does with with what you eat.
    Log off and go ride!
    Jul 2003
    That is around what is sometimes suggested for in season endurance type activities on a periodization plan. Power/strength activities are lighter on carbs and heavier to protein.
    Out of season endurance diet is closer to a so-called keto diet.
    So many trails... so little time...
    RAKC Industries
    Jan 2017
    The percentages dont matter near as much as quality.
    Carbs from raw sources (vegetables mainly, some unprocessed grains but limited)
    Fats from specific sources. Like fat from pork and processed oils is horrible. Where as fats from salmon and fruits/veggies are good
    Protien. Again depends on sources.
    Without professional help you will have to experiment with percentages. Genetics has a big part in what percentages you work best with. Even plays a bigger part in what sources of the macros work best.
    It takes time and changes can take as much as 2 weeks to notice if results are good or bad.
    But most important is getting what your personal body needs, not just macros but every little vitamin and mineral intake level can have an effect. Sometimes big, sometimes nothing more than increasing your recovery time by a few minutes.
    The best athletes arent ones that train the hardest or the best, they are the ones that have mastered taking care of their bodies down to the fine details of there vitamin amd mineral intakes. It can get crazy but when you train hard how your body processes everything changes.
    Sent from my SM-G950U using Tapatalk
    Life on a bike doesn't begin till the sun goes down.
    Bicycles aren't motorized
    Reputation: life behind bars's Avatar
    May 2014
    Quote Originally Posted by nowlan View Post
    Good day
    Cheers
    What are your specific goals? Maintenance? Weight loss? Weight gain? We know you are 185 pds., how tall are you? 15 hours a week at what intensity? It's all in the details.
    You meet the craziest people riding e-bikes!
    Make
    America
    Gravel
    Again
    Quote Originally Posted by RAKC Ind View Post
    I am trying to get to that point. I have always been a healthy eater, just never tried to perfect a tailored diet to my athletic needs.
    Quote Originally Posted by dave54 View Post
    I agree that tailoring your diet around phases/cycles is key.
    Quote Originally Posted by life behind bars View Post
    My goals are to be able to consistently perform and recover.
    Right now I am Base Building so itís not very intense, just long efforts.
    RAKC Industries
    Jan 2017
    Its not just your athletic needs, your body on a normal basis has requirements that will vary a bit from the standard. When yout a serious athlete it becomes much more important because every bit is more rapidly consumed and deficiencies can result without even knowing it. That is part of what can cause "bad days" if your resting and eating what should be properly already. Your body has ran low on something.
    Its a time consuming project to set sorted out but youll know as it improves. Both in how you generally feel as well as a bit of gains performance wise across the board
    tire to rim ratio tester
    Reputation: richj8990's Avatar
    Apr 2017
    100% correct. Some people metabolize carbs so fast they actually get low blood sugar in the next 1-3 hours after a simple carb meal or snack. They need a heavier protein/fat meal, and one before the workout. Others find protein and fat very heavy and hard/slow to digest; those are the ones that can't have a meal before the workout or they will feel nauseated and sluggish. It's ALL genetics, 100%. You have to figure it out for yourself. It took me years to figure out a good daily diet, and that was after reading dozens of books and hundreds of research articles. But it's worth the time and effort not just for your workout but for your quality of life. 60/20/20 is OK to start with, but if you are gaining non-muscle weight and don't feel better, then you can go closer to the Zone diet of 40/30/30 and see how that goes (although I don't really like going too much over 25% protein). And from there customize it with how you feel. Even stuff like niacinamide vs. niacin can feel different depending on your genetics (I'm not supplementing with either of those at this time, minor side effects with both).
    Pierced from below, souls of my treacherous past
    RAKC Industries
    Jan 2017
    You mentioned another thing, try to avoid supplements. Food based is much more effective.
    Quote Originally Posted by richj8990 View Post
    Solid points
    Any recommendations on what indicators to look for when tweaking?
    What about changing the ratio durimg certain phases of training?
    Apr 2017
    Solid points
    Well I don't train. I would not call walking a treadmill and having fun on 33-38 lb bikes really training
    I didn't change my diet for biking in other words. There are a couple of books I'd recommend on the subject: The Metabolic Typing Diet by William Wolcott, and The Nutrition Solution by Harold Kristal. I briefly corresponded with Wolcott several years ago and he kindly reminded me that Metabolic Typing was his copyright and I cannot use it for any future publications. So I'll use some generic phrase like biochemical typing in my next book, which is going really, really slow to write.
    Below is all speculation since I don't train: supposedly you want to carb load before training; you can take 100-200 micrograms of chromium picolinate daily for this, along with a B-complex supplement. For longer rides you will start burning more fat after depleting glycogen reserves; omega 3s and conjugated linoleic acid (CLA) are good. They also recommend carnitine powder but don't take that if you have any seizure or family history of that in the past. Protein is good but it does have a strong thermic (warming) effect, and I have developed some mild heat intolerance in the warm sun lately, possibly due to eating about 30-40 grams of protein before biking. Again this all depends on genetics too.
    Would you agree with changing your Macros during a Taper Week? Or reducing total Caloric intake.
Members who have read this thread: 57
