Results 1 to 12 of 12
    dead weight
    What's the best tire pressure for WNC
    Now that we all know the Pisgah is the best tire for WNC, what's the best air pressure for that tire?
    A bunch of my ride pics: http://uberfarm.com/mnf
    Big Mac
    Reputation: mbmb65's Avatar
    50 hundred. Metric, of course.
    Fence guru
    Nov 2008
    I run anywhere from 10-12 psi depending on the terrain on dhs 40-45 on uphills tubeless of course
    Mar 2011
    If you're not married to the Pisgah tire...0 PSI is perfect. Dude is riding pretty gingerly on the rocks though.
    dead weight
    I hadn't seen that before, so it's nice to know zero is an option.
    I run six hundred and fifty bees in my tire.
    Jun 2012
    I'll offer a serious answer: go as low as you can without pinch flatting a tube / burping your tubless tire. I'm running Hans Dampfs tubless at around 22psi front and 25psi back.
    Rogue Exterminator
    Reputation: kjlued's Avatar
    Ok even more serious answer.
    Depends on tire, where you riding in Pisgah, trail conditions, type of riding you are doing, rider preference, etc.
    Not hard to figure out.
    If you lack traction reduce the air pressure.
    If you feel you have too much rolling resistance then raise the air pressure.
    Also raise the pressure if you are getting pinch flats or burping.
    Just stick it in granny and start grinding.
    Reputation: carverboy's Avatar
    personally I run 28 front 32 rear tubeless. Any lower= burp flats and rim dings. Im 165 pounds without gear(my hydration pack weighs 10 pounds even)
    UGG boots will germinate Paris Hilton like intellect in your soles!
    Jun 2012
    Quote Originally Posted by carverboy View Post
    Dang, what rim & tire combo are you running? I'm on sun ringle chargers with hans dampfs and I don't lose any pressure from burping or dings at 22 front, 25 rear and I weigh about 160 geared up.
    Rogue Exterminator
    I run 25 to 30 with tubes and don't pinch flat.
    Quote Originally Posted by guitarb View Post
    Riding Stan 355's with Nevagal tires 2.3 front 2.1 rear. I'm close to 180 with gear factor in the narrower rim as well. Lower pressure results in tire squirm in cornering that I don't care for as well.
  1. Tire pressure for DH
    By jmang in forum Downhill - Freeride
    Last Post: 06-20-2013, 09:48 AM
  2. Tire pressure
    By gsheffer in forum Downhill - Freeride
    Last Post: 04-01-2012, 09:50 AM
  3. Tire Pressure ?
    By rickcin in forum General Discussion
    Last Post: 07-11-2011, 12:18 AM
  4. Tire Pressure
    By AllisonWunderland in forum Beginner's Corner
    Last Post: 06-20-2011, 05:49 AM
  5. tire pressure
    By Posty in forum Beginner's Corner
    Last Post: 05-13-2011, 04:35 AM
