Results 1 to 9 of 9
    whatever
    Technical Trails
    Can someone recommend a trail that invovles a long technical descent but with no stunts and climbing is no issue with me. Also I have heard of a trail called the Knob on 181 does that fit the description Preferably near Morganton
    Reputation: extrmtao's Avatar
    Mar 2006
    Quote Originally Posted by threeheadedduck
    Farlow Gap
    BS'ing less, riding more.
    Supporting PAS
    Upstate SORBA
    SORBA
    Farlow is probably the best answer I know of too,
    I would also say Bennett Gap, the upper portion stays pretty gnarly for a while. (the lower section is fun, but does not match your requirement)
    I hear and I forget. I see and I remember. I do and I understand. -- Confucius
    You could go to Kitsuma, in Black mountain. A little closer to Morganton.
    Reputation: AmosIv's Avatar
    May 2005
    Heartbreak Ridge
    Or if you want to stay closer to Morganton, the AT.
    Reputation: plume's Avatar
    Pilot Rock
    Some Assembly Required
    Reputation: man w/ one hand's Avatar
    Of all the trails up 181 & Wilsons, I don't know any that "require" you ride any stunts. They all have ride-a-rounds. Like AmosIv said, the AT run is good. Most any trail is good for fairly lengthy decents. Heart Break in Old Fort is awesome & Kitsuma.
    "Why are you willing to take so much & leave others in need...just because you can?"
    pronounced may-duh
    Reputation: Maida7's Avatar
    Apr 2005
    Avery creek the upper portion is just plain nasty
    Black mtn from presley gap to the ranger station
    Daniel Ridge short but lots of rocks and erosion
    Trace ridge not as techy but a ton of fun
    Big Creek
    Third Degree Hater-Fu
    Reputation: bizutch's Avatar
    Closer to Morganton would be Wilsons Creek for certain. Lots of trails in there that fit your exact description. Also, little known trail called Snooks Knob on hte parkway just past the Cedar Creek intersection around 5-6 miles before the turnoff to Mt Mitchell
    I am not a "Role Model"
