Results 1 to 35 of 35
Thread: Oramm 2014
    May 2012
    Oramm 2014
    General question about the type of equipment people are using. Looking at the many videos available, and seeing many of the posts on ORAMM, I haven't seen people talk about what type of bike is better. Videos show people on full suspension, hard tails and I see the posts about people on SS. For someone riding this the first time, what would be the best advice? I have a 29er hardtail, and a CF full suspension at my disposal.
    I have ridden all of these trails at some time or another on the full suspension bike, but am curious if the weight penalty would make the hard tail a better option for 60+ miles.
    One other thing, what tires are people running? I usually use the WTB Weirwolfs, but they are heavy and are going to suck big time on the climbs. Would something like the Conti x-king be a better pick?
    Rogue Exterminator
    Reputation: kjlued's Avatar
    Yes
    Just stick it in granny and start grinding.
    Reputation: jerry68's Avatar
    Full rigid steel Fargo with drop bars? Oh, and ride to the race, do the race, and ride back home.
    True story, kjlued knows who I am talking about.
    Pisgah Area SORBA
    Quote Originally Posted by kjlued View Post
    ... your idea of technical may be much different than other peoples idea of technical.
    Rogue Exterminator
    Yes, I know that mofo.
    It takes a special kind of crazy to add 50 miles to 60 mile race.
    I have a passion for cycling but Joe takes it to a whole new level.
    Almost sounds like something Tom would do to.
    Ok OP, to answer your question in a serious way.
    There are reasons you see all sorts of bikes and that is because there is all sorts of riding. At some points you are going to wish you had a full suspension long travel bike and others a drop bar road bike and at times everything in between. So basically you pick your poison and go with it.
    thecentralscrutinizer
    Reputation: mopartodd's Avatar
    Run whatcha brung!
    2015 Kona JTS
    2014 Scott Scale 710
    2014 Giant Anthem 27.5
    Reputation: Mike Brown's Avatar
    OP: What's your goal? To compete for a top 10% finish or rock out the fun factor?
    This race is absolutely won/lost on the climbs. So, if those are your goals, which bike is best for you for gravel road hammering?
    ORAMM also features three incredibly fast descents with some of the best technical XC riding anywhere. So, if your goal is to finish and have fun, which bike would best suit that goal?
    May 2012
    Quote Originally Posted by Mike Brown View Post
    My goal is not to race, I do enough of that on the road. I would like to finish in 8 hours or less, and have fun at the same time (though the time will all be relative depending on the conditions). I will be with a group of four others from Florida, who would have ultimately the same questions and same level of fitness and ability. I climb better on the hard tail, but descending is definitely more fun on the full suspension. Grinding out gravel roads on either will hurt, but is entirely doable with the lock out on the full suspension. Having done both Heartbreak and Kitsuma on the full suspension, it's definitely a plus for the full suspension.
    There is only a two lb difference between the two bikes, so other than efficiency between two bikes I'm leaning more towards the full suspension now. Tires are going to be my conundrum now.
    Rogue Exterminator
    Why does everyone get hung up on the weight of the bike?
    Unless you plan on carrying the bike the whole time, 2 lbs isn't going to matter enough to worry about it (unless that 2 lbs is in the wheels or driveline of course).
    May 2012
    Two lbs matters a lot, because it is dead weight you are carrying up. It is weight that over the course of 65 miles means a lot. Having completed 6 Gap and The Assault on Mt. Mitchell, 2 lbs means a lot of wasted energy carrying weight that has no benefit to the rider. Carried a camelbak on my first and second 6 Gap, and finished respectably. On my third with no camelbak and everything else being identical I finished 45 minutes earlier. That's what 2 lbs means.
    The efficiency of the hard tail on the long climbs will probably be a wash when compared to the efficiency and comfort of the full suspension on the downhills.
    Rogue Exterminator
    Or you could have just been having a better day or maybe you became a stronger rider.
    But if you want to believe that 2 lbs is going to save you 45 minutes in ORAM, then go right ahead. However there are a lot more things that will come in to play than 2 lbs .
    Assuming the bike fits you well for the long distance and you have good skills down steep, tight, twisty, rocky, rooty terrain at the end of a very long ride , I'd say either go with a nice carbon or titanium hard tail with very light wheels and somewhat beefy tires. If your skills and body are not up to the beating, then go full suspension (perhaps 100mm max), carbon/al with light wheels and somewhat light tubeless compatible tires (low rolling resistance). I doubt anything needs to be mentioned about wheel size for this event. Oh yeah... dropper seat posts are the bomb on Kitzuma and Heartbreak.
    IoC
    IoC is offline
    Quote Originally Posted by fuel98rider View Post
    That'll probably answer your question right there. If you're either good enough on the DH with the hardtail or timid enough on either where the full suspension isn't much of a time saver, use the hardtail if it's lighter enough to make a difference.
    I've usually used a light/fast rear (like WTB Nano) and something that's not going to be terrifying on the DH up front (Ardent, Specialized Captain, etc.).
    I might just use Specialized Fast Traks front -and- back. I've been testing them in damper stuff this Spring and they're surprisingly grippy and roll like mad on gravel/road....of which there's a lot on ORAMM.
    Quote Originally Posted by jerry68 View Post
    That was a long day.
    I'm not doing ORAMM this year, but I'm thinking of riding up the parkway or some of the trails to take pictures. If you see a guy beside the trail with a ti rigid Salsa Fargo and drop bars, say "Hi." (I'm selling the steel...)
    Rogue Exterminator
    Quote Originally Posted by IoC View Post
    What was it, a little over 100 miles of mixed riding with a race a in the middle? lol
    100 miles on the road bike on pavement only would be a long day for me. You're just nuts. haha
    IoC
    IoC is offline
    104 or something like that. Full story at Unweight: Joe Rinehart on Bikes and Code: 2013 ORAMM - 106mi on a rigid drop-bar Salsa Fargo
    Reputation: Ride-beer-rinse-repeat's Avatar
    FWIW
    I'm an average (by ORAMM standards - I'll aim to finish below 8 hours) rider and I am familiar with the course. I'll be on my Niner AIR 9 with an 80 mm front fork 1x9 with a 32 front/11-34 rear. I also have a Santa Cruz Butcher and a Surly KM single speed that I ride, depending on my mood and conditions, and I have ridden all parts of the course on my FS as well.
    I prefer to use the Niner for this distance, and it suits me better for the long climbs and relatively short and not super tough tech stuff. Plus I'm 46 and flying downhill is not my thing anymore since stuff hurts more for much longer. Needless to say, I am not at all concerned about my Enduro time - I just don't want to fly off the ridge. Also, I would prefer not to be hauling a Camelback in July, and this frame holds 2 water bottles while my FS does not.
    For tires - Geaux Saguaro rear and Gato front tubeless at 25-28 psi or maybe up to 30 due again to the relativly small amounts of tech. I like rolling a less aggressive rear tire, and it doesn't drag as much on the climbs. I'm not light though - by mid summer I'll be at around 175.
    So the best answer (from my perspective) is: If you want to bust the climbs and enjoy a fun ride down, go hardtail. If you don't mind a bit more suffering on the climbs and want to bust the downhills and maybe compete for time on the Enduro, grab the FS. If you want to suffer for all 60+ miles, grab a single speed.
    Your results may vary.
    "Get busy living, or get busy dying"
    Reputation: mikeridesabike's Avatar
    Start off with dual suspension. Have someone meet you at rest stop 2 with a road bike that has heavy duty tires. Ride that until you turn off of the BRP. Then switch back for HBR and Kitsuma. Piece of cake.
    I am just hoping that Kitsuma is not a slop fest this year like it was the 2nd time down last year.
    Friends don let friends ride road bikes.
    http://www.facebook.com/mikebmiller
    eschewing obfuscation
    Reputation: 44gnats's Avatar
    If you're riding ORAMM for "fun" and anticipate an 8 hour time, I suggest riding the most comfortable, fun and safe bike you've got (full bounce). The ht is likely faster, overall, but what difference does 10-15 minutes make if you're finishing mid pack? Heartbreak is a punishing descent and while Kitsuma isn't as rough, it can hurt that many hours in. I have a 23lbs full bounce and a 20lbs ht; I have done ORAMM 5 times (4/5 on the fs) and still obsess over the decision. I am shooting for 5:40 or less, so I may go ht and pray my body holds up at the end. As for tires, if it's dry, go fast rolling front and rear with a strong casing in the back. If it's wet and/or you have mediocre technical skills, run a trail tire up front and something fast in the rear. Tubeless, low pressure of course. Good luck!
    "Bikes have wheels." -Noam Chomsky
    Question: How far is it via trail from the railroad bed to the left turn onto Curtis Creek pavement? That's the only part I have not pre ridden, and it kills me not knowing that part.
    Or is that what I rode in Jerdon Mountain last year and the year before?
    Quote Originally Posted by GRobIII View Post
    That it part of the JMC course. I think it is about 10 miles.
    IoC
    IoC is offline
    Quote Originally Posted by mikeridesabike View Post
    Yeah, it's something like 11 overall miles from the turn off of the road (before the tracks) to Curtis Creek.
    The first 1.5 are a nearly 800-foot climb up Star Gap. After the tracks and a creek crossing, get ready for hike-a-bike then to have to walk up something like 16-17 switchbacks. When you get to the exposed one where it's sunny and the trail turns into a rocky drainage chute, it's time to start pedaling again.
    After you get to the top, it's a switchbacky descent to the road. Stay sharp, a few sneak up on you: I wound up in the woods a few years ago because of a sudden u-turn.
    Once you hit the gravel road, it's rolling up and down before a looooong gravel descent to CC road. Again, watch where you're going, last year's rains caused some damage to the road that'd be nasty to hit at 30mph.
    Don't Stop Spinnin'!
    Reputation: ReD_tomato's Avatar
    Hello all... I'll be in the area from 6/9 to 6/14. I was wondering if any locals would be willing to join me and a buddy for a ride in the area. We are registered for ORAMM but have never ridden the area. We'd be arriving Monday from South Florida. Getting a taste of whats to come in July would be great. It doesnt have to be the entire course, but just to get an idea of conditions and terrain.
    any group rides or info would be much appreciated.
    ~every end is a new beginning...
    I'm 1.5 hours from Old Fort, and have ridden there a lot. While I'm not local, I'm closer than FL, and I'd like to join you and know the course very well.
    Where in S FL? I'm from Naples way back....
    That would be awesome. I'm free all week. Staying in Black Mtn area. I'm from Miami, so I'm looking forward to riding up there again. I go up at least once a year but never in the Old Fort area. I'll pm you my number and look forward to the ride!
    Post ride beer on me!
    Any others plan on riding anywhere in WNC please let me know.
    Re: Oramm 2014
    There was a dude from Miami battling it out with me for 343rd place last year. I was riding up CCR and he was pushing lots of it, but we were going about the same speed. This guy was huge - not fat huge but linebacker huge. The last I saw of him, he was pulled over on the BRP calling his wife to come get him. Big props to anybody who drives that far with minimal mountain training and even attempts something like ORAMM. And he had to drive all the way back home and be at work on Monday.
    Sent from my Venue 8 3830 using Tapatalk
    Heading up this weekend from GSO if anyone is interested in pre-riding. Looking for 35-40mi...most of the course but not the roads i nand out of town and Kitsuma only once.
    'GSO'? 'Splain.......
    The 'Boro...the Gee to the Ess to the Oh. G-Vegas. The motherland. The Green Burro. Geeksboro. Home.
    May 2012
    Quote Originally Posted by mattedhead View Post
    Must be "the" weekend to pre-ride it. A couple of my friends and I from Florida are heading up this Friday; plan on riding Bent Creek on Friday and 30-40 of the ORAMM route on Saturday. There is another couple of guys that will be up there on Sunday to ride the same thing. Looking forward to it, hopefully the weather will cooperate.
    2014 Trek Superfly
    2013 Trek Madone 6.2
    2012 Trek Fuel EX 9.8
    2003 Trek Fuel 98
    2002 Trek 5500 OCLV
    Kind of tough to do a 30-40 miler without hitting the roads. I need to do a pre-ride my self but I signed up for the Looking Glass Tour road ride this Sat. 100 miles of pure fun.
    Fuel98rider,
    Where in FL you from? Rode up there early last week with two of your FL boys from Miami. Hardest part of those trails is getting in the 40 without supplemental water. We ran out on Heartbreak, and only made it based on full water bottles we found on the trail. Maybe less than sanitary, but we were dying. Funny to watch the three of us fight over the bottles we came across.
    Mattedhead,
    Your are probably on your own this weekend. I burned a ton of passes riding for 8 hours up there on Saturday!
    Have fun, all. Be safe.
    May 2012
    From Orlando, but a large group of us rode 40 miles in Belleview/Ocala on Sunday. Water is always gong to be an issue. I believe I've read that there is a fresh water spring somewhere along the long gravel road climb, so that might be the incentive to include the road in our travels this weekend. If we end up meeting with the other group, it might be worthwhile to station a car with extra water somewhere along the way, which would give us more time on the trail. We're going to have to play it by ear on Friday. I keep looking for a definitive location of that freshwater spring, bit haven't seen anything specific.
    2014 Trek Superfly
    2003 Trek Fuel 98
    2002 Trek 5500 OCLV
    Fuel,
    The 'spring' is appx 4 miles from where you turn off Star Gap onto Curtis Creek on your right side past the campground. It's a white pvc pipe coming out of the group and splashing onto a rock. Penalty for failure here with gastro issues is too high. I say park the car with water in it. Or just stop at every overlook on the Parkway like I did and beg water from people, or pick up bottles on Heartbreak.
    Fuel,
    If I'm not mistaken there is drinking water at CUrtis Creek campground or use the spring and carry a few iodine tabs.
    For Curtis Creek Campground.
    GPS: 35.71014, -82.191811
    Drinking water from spigots there.
    [QUOTE=GRobIII;
    Mattedhead,
    .[/QUOTE]
    I'll be burning a few hall passes myself. I'm gonna try to to get up there ride 40ish mi and be home by late lunch. With a four hour r/t drive I am going to begin scripting my apology to SWMBO now!!! I hope to be on my bike and headed up Kitsuma by 0700 running the course and finishing up at the truck without repeating Kitsuma.
  1. ORAMM entry
    By 44gnats in forum Endurance XC Racing
    Last Post: 07-08-2013, 03:45 AM
  2. ORAMM Pre-ride
    By scuuder3 in forum North & South Carolina
    Last Post: 05-31-2012, 08:45 AM
  3. Oramm
    By gcadelina in forum Endurance XC Racing
    Last Post: 01-21-2012, 12:39 PM
  4. ORAMM Volunteers
    By bd279 in forum North & South Carolina
    Last Post: 07-25-2011, 06:30 PM
  5. ORAMM course
    By eischman in forum Tandem Mountain Bikes
    Last Post: 06-30-2011, 08:37 AM
