Results 1 to 8 of 8
    Reputation: Mitch1171's Avatar
    Jan 2009
    Front tire recommendation for FATS!
    Im running Maxis IKONS on my bike and will be making a trip to FATS late October. Will the IKONS be ok with that terrain? Thanks
    Reputation: Mike Brown's Avatar
    That's a near ideal tire for FATS IMO- fast roller but high volume.
    Jan 2009
    Quote Originally Posted by Mike Brown View Post
    So maybe if I throw on an ardent that will have enough bite?
    Fence guru
    Nov 2008
    Road tires
    Rogue Exterminator
    Reputation: kjlued's Avatar
    Skinny road tires.
    Just stick it in granny and start grinding.
    Ignore them. FATS and the rest of the trails in that area are awesome. Ain't the mountains, but still totally awesome.
    An Ikon is all the tire you will need. Roll it!
    \m/{-_-}\m/
    Reputation: Sun Burn's Avatar
    Feb 2007
    I run Ikons front and rear all over the southeast including the gnarly stuff in Pisgah. They are the perfect tire for FATS. I'm running 29s tubeless and I run 24psi front and 25 rear pretty much everywhere. I weigh 170.
    Hope that helps!
    The ardent is overkill and heavy for the constant accelerations. I've been using a Rocket Ron up front with an Ikon in the back for several years now with great luck. I'm going to replace the RR with a 2.4 IKON up front to see how it goes. Going tubeless may by the biggest benefit 'round here as it improved traction on the sometimes slick/hard packed surfaces.
    All that said, watch the weather. It's been the worst weather year ever here and, normally expected good fall weather, is not guaranteed. Some of trails are pretty rutted and a little extra bite could be good. Also check Sorba-CSRA for hunting closures etc.
  1. Tire recommendation
    By ditchmedic in forum Commuting
    Last Post: 11-01-2012, 06:58 PM
  2. Replies: 22
    Last Post: 10-25-2012, 09:38 AM
  3. Need Tire Recommendation
    By matty1551 in forum Wheels and Tires
    Last Post: 05-14-2012, 06:50 PM
  4. Need recommendation for big squishy front tire
    By loginhater in forum 29er Bikes
    Last Post: 03-09-2011, 07:05 AM
  5. Tire recommendation please.
    By Breitness24 in forum 29er Bikes
    Last Post: 03-06-2011, 09:40 AM
