Results 1 to 7 of 7
    Tin Man
    Reputation: L8str's Avatar
    Dec 2012
    Any info on this place?...
    *At The Ridge FunTrails*****************"Pisgah's New Playground" - HOME
    Got an email from Meet-Up about the event on Jan 19th.
    The website does not say if the park is available all the time or just for scheduled events.
    Can someone tell this Noob what a "Pump Track" is?
    Fence guru
    Nov 2008
    TRBL is what that place looks like
    Reputation: jerry68's Avatar
    Quote Originally Posted by L8str View Post
    It's just like it sounds, a track that if ridden correctly only requires you to "pump" rather than pedal... think of it as a rhythm section in a loop (check out leelikesbikes.com) . They are a lot of fun and a great workout
    Simple pump track
    Pisgah Area SORBA
    Quote Originally Posted by kjlued View Post
    ... your idea of technical may be much different than other peoples idea of technical.
    Tin Man
    Dec 2012
    Thanks. Looks like they run smallish. That one is about 34 x 42'. According to the map ATR Map - *At The Ridge FunTrails*****************"Pisgah's New Playground" this one is around the same size.
    leelikesbikes dot com is awesome....it goes up to eleven!
    clk
    clk is offline
    Dec 2012
    Im curious about this place as well. There website is pretty vague, but i think ill go the 19th anyway.
    Tin Man
    Dec 2012
    I emailed the folks at ATR. Currently they are open for scheduled events only. They will be open for "practice" in the spring. I will be there on the 19th.
    I am out of town that weekend or I'd be going. A pump track is a workout.
    Pisgah Area SORBA
