Results 1 to 2 of 2
    what tune rockshox monarch plus for Killer B
    Hello. Im planning to upgrade the shock of my killer b3 and considering rockshox monarch plus that comes with 3 tunes low, mid and high. If any help Im 125 lbs (56kg) thanks.
    Bernardo
    Shinobi-Wan Kenobi Moderator
    Reputation: kristian's Avatar
    My Shinobi takes a high volume, high damping Monarch. If I read the description of the new 2014 Monarch Plus correctly, the damping range has been improved so the only variable is the high vs. low volume air chamber.
    If you were to use the low volume, the shock would have a more progressive curve. The Shinobi (and I'm assuming all ART Norcos) have a progressive rate already so they need to have the high volume flavor--otherwise there would be too much ramp-up at the end of the stroke.
    For what it's worth, I'm totally digging the regular Monarch--I'm sure the Plus is even better!
  1. Replies: 34
    Last Post: 08-05-2016, 07:10 AM
  2. Replies: 1
    Last Post: 08-25-2013, 11:52 PM
  3. RS Monarch, Monarch Plus, Vivid tune diagram
    By Breal604 in forum Shocks and Suspension
    Last Post: 11-05-2011, 05:15 PM
  4. Which tune Monarch Plus?
    By MinskyBA in forum Ibis
    Last Post: 07-28-2011, 09:33 AM
  5. Monarch RT3 - High Tune vs H3 Tune?
    By madtrix in forum Shocks and Suspension
    Last Post: 07-26-2011, 06:42 PM
